Brother HL1110 printer - no driver can be installed
Brother HL1110 printer no driver can be installed
If trying to install driver with Manjaro
Manjaro recommend 7 different HL1070-drivers that do not work.
From the Brother support site, I downloaded driver hl1110lpr-3.0.1-1.i386.deb and hl1110cupswrapper-3.0.1-1.i386.deb
I have converted the packages with debtap to …tar.gz files
and tried with
sudo pacman  -U    packname.tar.gz
to install these but received:
...architecture not valid
...package has no valid architecture
in Debian/Ubuntu it just works.
Is there any similar method in Manjaro or any other solution ?
Take a look at the link below. The .deb method is most straight forward:
https://wiki.archlinux.org/title/Packaging_Brother_printer_drivers
HL-1110 - that is a printer which have I worn out several drum kits with. :slight_smile:
Manjaro does not recommend any drivers - you have probably found them on AUR.
Remove any packages you have experimented with and build the above package.
pamac build brother-hl1118
I am using a old brother as well - HL-2240D and it requires special attention too.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Please read this:
Especially the section How to install software? as installing .deb files opens your system up to something called dependency hell…
:scream:
