Hi there, I’ve got a little confusing problem with my printer, I some don’t understand the problem and didn’t find a solution so far.
When I want to print something an press the print-Button, I can see the printer’s LED blinking as it is supposed to to. But then, nothing happens, not even a noise. After a few seconds I get the message “printing completed” - but as I said, nothing happened.
Using my macbook with the same printer, it works just fine. So the printer is not the problem.
Does anybody know, what I could do about that?
Greetings from Lingen, Germany
Timo
Some system information:
ystem:
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
Desktop: Cinnamon v: 6.0.4 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop N7401ZE_N7401ZE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: N7401ZE v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: N7401ZE.301 date: 06/02/2022
ID-1: BAT0 charge: 65.9 Wh (100.0%) condition: 65.9/70.0 Wh (94.1%)
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP cache: L2: 11.5 MiB
Speed (MHz): avg: 574 min/max: 400/4600:4700:3500 cores: 1: 521 2: 400
3: 511 4: 400 5: 400 6: 400 7: 476 8: 400 9: 400 10: 400 11: 484 12: 400
13: 400 14: 400 15: 3500 16: 400 17: 400 18: 400 19: 400 20: 400
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] driver: nvidia
v: 550.90.07
Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
type: USB
Device-4: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 1: 3840x2160~60Hz
2: 2880x1800~120Hz
API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
renderer: Mesa Intel Graphics (ADL GT2)
Device-1: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA driver: snd_hda_intel
type: USB
Device-4: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp0s13f0u1u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb type: USB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Local Storage: total: 953.87 GiB used: 163.77 GiB (17.2%)
ID-1: /dev/nvme0n1 vendor: Micron model: 3400 MTFDKBA1T0TFH
ID-1: / size: 953.57 GiB used: 163.77 GiB (17.2%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 576 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 953.57 GiB used: 163.77 GiB (17.2%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 953.57 GiB used: 163.77 GiB (17.2%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%)
file: /swap/swapfile
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (rpm): cpu: 2000
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 4.38 GiB (28.6%)
Processes: 422 Uptime: 19m Shell: Bash inxi: 3.3.35
The printer is brother HL 2030
