Brother FAX 4100 printer
Hello, I have manjaro gnome version and I have a Brother fax4100 printer on installing manjaro it does see the printer but the driver isnt correct. I have never installed a printer on an arch linux before I do have the PPD file needed and just need to know the steps and commands needed to properly install it Im sure there are things i need to do first, please explain it to me what to do first as in putting the pdd where it goes and so on…Thanks in advance
I assume you are up to date and on the latest stable update already, is that correct?
More details why you think your driver isn’t correct would be probably helpfull,
i never heared about a PPD file, i have a cannon printer and was never in need for something like that.
Many people reported printing problems also and rolled back their libcupsfilter package.
But this was 2 month ago.
If this problem is solved now with the newest libcups version? I don’t know, i also worried about printing at the moment, because i have to do many printing this month :frowning:
If you think you already had setup your printer correctly and if nobody has another solution, maybe rollback could work for you?
Keep in mind to always create a system snapshot, just in case something is wrong.
yes system is fully updated. is showing Brother fax 4100 but the driver isnt the fax 4100 shows model Alps MD-1000
I have tryed installing the tool for linux at brother site and commands fail
The current libcupsfilters should be fine again.
It’s not a driver, but rather a plain-text file containing directives regarding the pertinent printer’s margins, supported paper sizes and built-in fonts. :wink:
ah ok well the printer the system installed i unlocked it then hit print test page and its just processing now for 3 minutes at the brother site there is a installer tool and 2 rpm files just dont know how to use the rpm files to attempt installing it should i maybe just update the printer since this is a 2006 printer to one made this year?
Arch-based distributions do not user .rpm packages. There is a way to try installing those using a tool from the AUR, but this is not recommended.
If it’s that old, then it’s bound to be supported. Open a tab in your browser to your local CUPS configuration page and try changing some settings there.
P.S.: Please use punctuation and proper capitalization. Your posts are extremely hard to read, even for native English speakers, not to mention for people whose main language is not English.
I am inspecting what brother has on their site. The good news is, there is some lpd and cups wrapper and ppd…the bad news is it is all entangled in scripts and the are old (not systemd aware for example).
So we will have to gut them out to reach the essence and still no guarantee with drivers that can legally consume alcohol in the US :stuck_out_tongue_winking_eye:
Whatever you do do not run the scripts from the site. There is damage potential.
Edit: i just read you have the ppd. Have you tried this:
Using the CUPS Web Interface (i asked a friendly ai since the last years i only install network printers)
  1. Connect and Power On: Plug the printer into a USB port on your system and turn it on.
  2. Open CUPS Administration: Open your web browser and go to http://localhost:631. Click on the Administration tab, then click Add Printer.
  3. Select Local Printer: Under Local Printers, CUPS should automatically detect your printer (e.g., HP LaserJet or USB Printer #1). Select it and click Continue.
  4. Name and Share: Fill in the printer name and check Share This Printer only if you want other machines on your local network to be able to print to it. Click Continue.
  5. Driver Selection: Select your printer’s Make and Model from the list, or click Browse/Choose File to upload its specific PPD driver file, then click Add Printer.
The password required is your sudo password.
Sorry about the usage. I gave up on that unit, and I went and got a Brother HL-L2465DW printer. It does have wifi, have to figure out how to get it to work is all. Thanks for all the help all.
Im gonna pass on Manjaro, The 2 other linux OS i use installed it right away using dpgk. Maybe I’m not ready to come up to Arch at this time
That would have been relatively easy, and I’m sure we could have helped you with that, but… :backhand_index_pointing_down:
In that case, we wish you well, but then it no longer serves any purpose to leave this thread open. :man_shrugging:
