Hello,
Im new on Manjaro. I switched from Windows 10
I have a Combo Printer/Scanner Brother DCP 7055W. The problem is that the scanner don’t work.
I want an USB connection
I installed the package “DCP 7055” from AUR, printing is working well
For the Scan part I installed brscan4 and brscan-skey also from AUR but the scanner isn’t working. When i wan’t to scan something it shows an error message “Invalid Argument”. The scanner don’t scan It is reconized though. :
$ scanimage -L
device `brother4:bus1;dev1’ is a Brother DCP-7055W USB scanner
I tried :
$ scanimage -T
Output format is not set, using pnm as a default.
scanimage: rounded value of br-x from 211.9 to 211.881
scanimage: rounded value of br-y from 355.6 to 355.567
scanimage: sane_start: Invalid argument
The printer seems to be seen on the wrong bus and device compare to sane
$ lsusb
Bus 004 Device 012: ID 04f9:02ce Brother Industries, Ltd DCP-7055W
$ scanimage --help
Here is the last part of the output :
List of available devices:
brother4:bus1;dev1
Sane try to find my scanner in the wrong place Bus1 Device 1 instead of true lsusb position which is Bus 004 Device 012
I don’t know how to solve it.
I even tried on another computer on Debian with propriatary drivers. The problem is the same…
I tried to add this rule in a file in /etc/udev/rules.d/ :
brother scanners rules
ATTRS{idVendor}==“04f9”, MODE=“0666”, GROUP=“scanner”, ENV{libsane_matched}=“yes”
But it didn’t fix anything.
EDIT : The scanner/Printer is working fine on Windows 10
Thanks in advance for your help
