Hello everyone
I want to set up a Brother DCP-T310 printer with Manjaro Linux.
For troubleshooting, I got the drivers from both official Brother support page and another download source:
https://support.brother.com/g/b/downloadtop.aspx?c=in&lang=en&prod=dcpt310_all
https://printerdrivers.com/brother-dcp-t310-driver/
As far as I can tell both sources offer the same Brother Linux driver packages but I am still not clear on the best way to install them on Manjaro.
Brother supplies the driver packages for Linux as well as installation tools for the DCP-T310. These come in both DEB and RPM package formats.
Here are my questions:
Has anybody here installed a Brother DCP-T310 on a very recent Manjaro release?
Would it be preferable to use the Brother installer script or to build/install an Arch package?
Could you please tell me if there are any dependencies related to printing and scanning that I should install?
Is it possible to print with the generic CUPS driver or is the Brother-specific driver a must-have?
I also came across some older threads indicating that Brother printers usually are compatible with Manjaro and other Arch-based distributions even though extra driver installation might be needed.
Any pointers or step-by-step guide to the installation will be highly valued.
Thanks in advance!
