So a while back I dropped my laptop and it landed right on an occupied USB port. This port now no longer works, and from what I can tell is causing my machine to fail to suspend. How do I go about fixing this?
Journalctl link: http://0x0.st/HF2T.txt
INXI:
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=b9be9256-4c8e-43ae-ab5d-ede8311a152f rw quiet splash
resume=UUID=bbc9a091-ec83-432b-9d73-7b0d00189f33 udev.log_priority=3
amd_pstate=passive
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 82KT v: IdeaPad 3 14ALC6
serial: <filter> Chassis: type: 10 v: IdeaPad 3 14ALC6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465WIN serial: <filter>
part-nu: LENOVO_MT_82KT_BU_idea_FM_IdeaPad 3 14ALC6
uuid: 04b3cb81-9017-4323-8e8e-84a93805cc7c UEFI: LENOVO v: GLCN51WW
date: 09/28/2022
ID-1: BAT0 charge: 34.6 Wh (81.2%) condition: 42.6/45.0 Wh (94.6%)
power: 16.7 W volts: 11.4 min: 11.1 model: SMP L20M3PF0 type: Li-poly
serial: <filter> status: discharging cycles: 213
Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1788 high: 4043 min/max: 400/4056 boost: enabled
base/boost: 2100/4050 scaling: driver: amd-pstate governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 4043 2: 4042 3: 1796 4: 1113
5: 1113 6: 1950 7: 1035 8: 1113 9: 1040 10: 1035 11: 2071 12: 1113
bogomips: 50322
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 48.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:2137
class-ID: 0e02
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0x408d built: 2019 res: 1920x1080
hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.57 6.7.7-1-MANJARO) device-ID: 1002:164c memory: 1.95 GiB
unified: no
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:164c surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 294.05 GiB (63.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-500GM-2 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 41061C20 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 74d 5h cycles: 3,299
read-units: 9,811,252 [5.02 TB] written-units: 11,721,386 [6.00 TB]
ID-1: / raw-size: 429.03 GiB size: 421.23 GiB (98.18%)
used: 294.04 GiB (69.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: partition size: 36.43 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 57.5 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): N/A
Memory: total: 36 GiB note: est. available: 33.12 GiB used: 5.87 GiB (17.7%)
Processes: 345 Power: uptime: 15m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 fails: 4 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 13.24 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: 1753 pm: pacman pkgs: 1731 libs: 471 tools: pamac,yay pm: flatpak
pkgs: 22 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.33```
