- there are 7 kwin tiling modes only 2 that work properly
- When I tile any application to the top it becomes like this:
Mod edit: uploaded image(s) removed- our input does not appear in the terminal until I stop this tiling mode
- the same problem in the other tiling modes except for the right and the left side
examples:
UPDATE:
- This happens only with Xorg, there is no problem with Wayland
As I recall there is no default tiling - you have to add it manually using the KWin Scripts section.
Every part of the System Settings allowing you to customize your system displays the following information
And with your own keyboard commands to activate them.
