Hello everyone, after an update, the icons on add/remove software seem to be broken for some reason (they are broken seemingly at random, most alarmingly, the checkbox emblem as well):
How can I fix this?
KDE Specs:
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.5.0
Qt Version: 6.7.2
Kernel Version: 6.9.12-3-MANJARO (64-bit)
Graphics Platform: X11
Processors: 32 × AMD Ryzen 9 5950X 16-Core Processor
Memory: 62.7 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3070/PCIe/SSE2
System Specs:
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.9-x86_64
root=UUID=f93c1401-5d8f-4e69-851a-80f1d0f0f5f7 rw rootflags=subvol=@
radeon.modeset=1 nvdia-drm.modeset=1 quiet
cryptdevice=UUID=33225521-2b39-4ce3-99df-9c599f1ba390:luks-disk
root=/dev/mapper/luks-disk apparmor=1 security=apparmor
resume=/dev/mapper/luks-swap udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
UEFI: American Megatrends v: 5013 date: 03/22/2024
System RAM: total: 64 GiB available: 62.7 GiB used: 21.78 GiB (34.7%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: G Skill Intl
part-no: F4-3200C16-16GVK serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3599 min/max: 2200/5223 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 3599 3: 3599
4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
13: 3599 14: 3599 15: 3599 16: 3599 17: 3599 18: 3599 19: 3599 20: 3599
21: 3599 22: 3599 23: 3599 24: 3599 25: 3599 26: 3599 27: 3599 28: 3599
29: 3599 30: 3599 31: 3599 32: 3599 bogomips: 217679
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cape Verde PRO [Radeon HD
7750/8740 / R7 250E] vendor: VISIONTEK driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: DP-3,DP-4 empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0
chip-ID: 1002:683f class-ID: 0300 temp: 49.0 C
Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 0c45:6367
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting failed: nvidia
dri: radeonsi gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
s-diag: 1953mm (76.91")
Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-2-3 pos: 2-1 res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: DP-2-4 pos: 1-1 res: 1920x1080 dpi: 93
Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 550.107.02
device-ID: 10de:2484 surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Oland/Hainan/Cape
Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] vendor: VISIONTEK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:aab0 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
Device-5: Schiit Audio Unison Universal Dac driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 30be:1019
class-ID: 0102
Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: ztw4lh7jsv state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Info: services: NetworkManager, systemd-timesyncd, xinetd
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5.3:7
chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-cr maj-min: 254:2 type: LUKS dm: dm-2 size: 7.28 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 7.28 TiB
Device-2: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 3.72 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:5 size: 3.72 TiB
Device-3: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:6 size: 8.8 GiB
Local Storage: total: 15.59 TiB used: 5.72 TiB (36.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: TeamGroup model: TM8FP4004T
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: VB421D65 temp: 44.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000VN0022-2EL112
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC61 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Gaming Xbox 360
size: 7.48 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 8.02
scheme: GPT
ID-1: / raw-size: 3.72 TiB size: 3.72 TiB (100.00%) used: 800.15 GiB (21.0%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-disk label: N/A
uuid: N/A
used: 1.1 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4 label: N/A
uuid: 28CD-9A1B
ID-3: /home raw-size: 3.72 TiB size: 3.72 TiB (100.00%)
used: 800.15 GiB (21.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-disk label: N/A uuid: N/A
ID-4: /run/media/sarah/ConvergentRefuge raw-size: 7.28 TiB
size: 7.28 TiB (100.00%) used: 4.71 TiB (64.7%) fs: btrfs dev: /dev/dm-2
maj-min: 254:2 mapped: luks-cr label: N/A uuid: N/A
ID-5: /run/media/sarah/MSS_EXtended raw-size: 475.51 GiB
size: 475.51 GiB (100.00%) used: 231.54 GiB (48.7%) fs: btrfs
dev: /dev/nvme1n1p1 maj-min: 259:1 label: MSS EXtended
uuid: f98b3a12-e0e4-48c7-91c2-6e3aa6dcd32c
ID-1: swap-1 type: partition size: 8.8 GiB used: 16.8 MiB (0.2%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: swap
uuid: c3b0a27c-c251-4bf8-b6c4-e86db51f58d5
ID-1: /dev/nvme1n1p2 maj-min: 259:2 size: 456 GiB fs: ntfs label: N/A
uuid: 5ECA358FCA356485
ID-2: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
label: JerichoVariance uuid: 1AB22D5664889CBD
ID-3: /dev/sdc1 maj-min: 8:33 size: 3.64 GiB fs: iso9660
ID-4: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 10F6-934F
ID-5: /dev/sdd1 maj-min: 8:49 size: 7.48 GiB fs: vfat label: BIOS
uuid: 8D81-7EC9
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-3:3 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0
chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Device-2: 1-4:4 info: Microdia USB 2.0 Camera type: video,audio
chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
chip-ID: 2109:3431 class-ID: 0900
Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-1:2 info: Microdia Backlit Gaming Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:652f class-ID: 0301
Device-2: 5-2:3 info: Schiit Audio Unison Universal Dac type: audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30be:1019 class-ID: 0102
Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 0b05:194e class-ID: 0300 serial: <filter>
Hub-11: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-12: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-14: 7-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 7-6:3 info: SanDisk Cruzer Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5151 class-ID: 0806
serial: <filter>
Hub-15: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 8-2:2 info: SanDisk Ultra type: mass storage driver: usb-storage
interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 896mA chip-ID: 0781:5581 class-ID: 0806 serial: <filter>
Hub-16: 9-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 9-2:2 info: Razer USA Naga Chroma type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0053 class-ID: 0300
Device-2: 9-3:5 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO R
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 231d:0200 class-ID: 0300
Device-3: 9-4:6 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO L
chip-ID: 231d:0201 class-ID: 0300
Hub-17: 10-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 52.0 C mobo: 39.0 C gpu: radeon temp: 49.0 C
Fan Speeds (rpm): fan-1: 1534 fan-2: 994 fan-3: 1253 fan-4: 1234
fan-5: 3103 fan-6: 0 fan-7: 0
Processes: 787 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2502 pm: pacman pkgs: 2429 libs: 550 tools: pamac,yay pm: flatpak
pkgs: 53 pm: snap pkgs: 20 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13
Shell: Bash v: 5.2.32 running-in: yakuake inxi: 3.3.36
