Broken dependencies on full system upgrade (after long hiatus...)
I have a Manjaro VM which I use unfrequently. I’ve let 8 months go by without updating the system and today, not unsurprisingly, I’m having broken dependencies.
Here’s what I’m seeing -
[abc@V-Manjaro-Doralicia ~]$ sudo pacman-mirrors --geoip
[sudo] password for abc:
::INFO Downloading mirrors from repo.manjaro.org
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.319 Brazil         : https://manjaro.c3sl.ufpr.br/
::INFO Writing mirror list
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[abc@V-Manjaro-Doralicia ~]$ sudo pacman -Syyuw
 core        172.1 KiB   989 KiB/s 00:00 [##########################################################################################################] 100%
 extra        1900.0 KiB   455 KiB/s 00:04 [##########################################################################################################] 100%
 community        6.7 MiB   485 KiB/s 00:14 [##########################################################################################################] 100%
 multilib        177.2 KiB  1024 KiB/s 00:00 [##########################################################################################################] 100%
:: Replace jack with extra/jack2? [Y/n] y
:: Replace lib32-jack with multilib/lib32-jack2? [Y/n] y
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] y
:: Replace pamac-common with extra/libpamac? [Y/n] y
:: Replace python-dbus with extra/dbus-python? [Y/n] y
:: Replace python-dbus-common with extra/dbus-python? [Y/n] y
resolving dependencies...
:: installing lib32-libcanberra (0.30+2+gc0620e4-5) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing libcanberra (0.30+2+gc0620e4-5) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
I have tried to alternatively DENY the 2 libcanberra replacement requests, but the result is WORSE as even more dependency breakages are shown.
Also checked what would happen if I just removed the 2 libcanberra packages - they would basically drag down half the system with them.
I did some basic searches on similar issues, but I’ve only found suggestions on rechecking mirrors which I had already done from the start.
Any suggestions on how to upgrade this system ? Thx in advance !!
Try
pamac upgrade
or
remove those packages:
sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer . `
sudo pacman -Syyu
It was in the known issues, in previous Stable announcement threads
  • You might be blocked updating when using pacman due to some libcanberra packages. Simply remove those packages: sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer. We recommend to use pamac anyway, which does this automatically: pamac update
Thx @omano & @admdb.
I did run pacman -Rdd successfully as suggested. Then I followed it with pacman -Syyuw , which had been running while I was doing other stuff. However in the meantime my VM froze for whatever reason (I suspect some disk space constraint after 1.4Gb of updates), therefore I can’t report (for now at least) any results.
I had previously tried the pamac upgrade command, but since it led to some ‘broken dependency’ message very similar to the ones originally issued by pacman, I had dismissed it without noticing it was a WARNING, not an error like the pacman one. It might probably have run to a good conclusion as well.
About the ‘known issues’ from the announcement threads: Yes I had routinely paid due attention to them in the past. In this particular case however, there were 19 threads for all the updates I had skipped, so I just checked the most recent one. And Google failed to provide any further hints, that’s why I ended up asking here.
For the record, here’s one of the announcement threads where this issue was spelled out:
Back to my original issue: I’ll probably have to hunt down a backup for my VM and restart from scratch, as the current running one has seemingly been drawn into a black hole. Oh well, s*** happens…
Thank you guys again. Cheers and take care !
Hello,
I just wanted to add my final report here for completeness sake.
The ‘freezing’ I was experimenting in my Manjaro VM was actually a ‘hiding’ of console output, due to my borked usage of 'tee' in order to save a text log for the update operations. This happened first with pacman and later with pamac.
Once this hurdle was cleared, my system become fully updated again with pamac update . No issues.
Cheers
