So i am writing this in a live iso of manjaro on the same computer the ssd got corrupted.
I was trying to destroy my own data using the tool “wipe” for then securely replace it with a fresh install of Manjaro. However i was very stupid that night, and decided to run wipe in the same hard drive it was running from. After 20% completion, the pc crashed and i cannot boot from the ssd.
With the live iso, i tried to diagnose and repair the partitions but it was no much help.
WHAT I CAN DO
Identify partitions (gparted can see the filetype and size of the partitions)
Recover files with gpart, but only in read mode
WHAT DOESN’T WORK
I cannot in any shape or form do any writing operations to the drive, if i try to reformat, resize or delete a partition in gparted, it returns this error:
Input/Output error during write on /dev/sda
I cannot use dd or similar tools to shred the data of the hard drive either, they seem get stuck on the operation and i have to kill their tasks.
Sadly fsck doesn’t seem to work either, it will return this if i run it with /dev/sda (running e2fsck with the superblock will return same error):
fsck from util-linux 2.37
fsck.ext2: Bad magic number in super-block while trying to open /dev/sda
/dev/sda:
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
/dev/sda contains `DOS/MBR boot sector; partition 1 : ID=0xee, start-CHS (0x0,0,2), end-CHS (0x3ff,255,63), startsector 1, 500118191 sectors, extended partition table (last)' data
If i try /dev/sda2 (main partition):
/dev/sda2: clean, 11/15032320 files, 1221151/60128751 blocks
as for dmesg i get constantly the following errors:
exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 199.868962] ata2.00: irq_stat 0x40000001
[ 199.868964] ata2.00: failed command: WRITE DMA
[ 199.868969] ata2.00: cmd ca/00:28:00:00:00/00:00:00:00:00/e0 tag 4 dma 20480
[ 199.901025] ata2.00: irq_stat 0x40000001
[ 199.901032] ata2.00: failed command: WRITE DMA EXT
[ 199.901048] ata2.00: cmd 35/00:28:88:32:cf/00:00:1d:00:00/e0 tag 14 dma 20480
I/O error, dev sda, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 5 prio class 0
[ 199.918664] Buffer I/O error on dev sda, logical block 0, lost async page write
[ 199.918687] Buffer I/O error on dev sda, logical block 1, lost async page write
[ 199.918692] Buffer I/O error on dev sda, logical block 2, lost async page write
[ 199.918714] Buffer I/O error on dev sda, logical block 3, lost async page write
[ 199.918718] Buffer I/O error on dev sda, logical block 4, lost async page write
[ 199.918736] ata2: EH complete
