Broadcom wireless network broken after Manjaro update, no Wifi
I update every Saturday. This Saturday have noticed two problems.
Firstly, no Wifi (linux61-broadcom-wl updated from 6.30.223.271-114 to 6.30.223.271-115).
Secondly, sudo (updated from 1.9.16.p5-2 to 1.9.15p5-1), launched from zsh, unusually fails to find a command which is normally found according to user path. Maybe a deliberate change in sudo?
I have restored previous Manjoro version (2024-07-13), OK, updated again, same problems.
(my_base) alba@mac2011-manjaro% inxi
CPU: dual core Intel Core i5-2415M (-MT MCP-) speed/min/max: 2315/800/2900 MHz
Kernel: 6.1.98-1-MANJARO x86_64 Up: 25m Mem: 5.04/15.54 GiB (32.4%)
Storage: 1.82 TiB (29.9% used) Procs: 320 Shell: Zsh inxi: 3.3.35
Did you notice the same?
What do you advise to investigate further?
I am thinking about updating everything except broadcom and sudo and see.
I am thinking, that some more basic information might be helpful, to encourage others to offer informed suggestions:
System information:
inxi --admin --verbosity=8 --filter --no-host --width
Recent logs:
journalctl --boot=-1 --priority=3 --catalog --no-pager
…and possibly more, but this will be a good start.
Cheers.
In the meantime, I have updated again, excepting broadcom and sudo.
The sudo problem does not show, hence sudo has changed, I can easily adapt.
The broadcom problem persists and is truly annoying.
% uname -a
Linux mac2011-manjaro 6.1.100-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Jul 19 14:51:57 UTC 2024 x86_64 GNU/Linux
Check the boot messages for errors
% sudo dmesg --level=err,warn
[    0.228834] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.228834]  #3
[    0.781454] ata1.00: supports DRM functions and may not be fully accessible
[    0.783307] ata1.00: supports DRM functions and may not be fully accessible
[    5.247309] kauditd_printk_skb: 7 callbacks suppressed
[    6.718597] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
[    6.718836] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.718847] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.718856] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.718863] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    7.234962] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    7.259499] at24 9-0050: supply vcc not found, using dummy regulator
[    8.558721] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[   27.300517] hfsplus: write access to a journaled filesystem is not supported, use the force option at your own risk, mounting read-only.
% journalctl -b -1|grep --ignore-case broadcom
No Broadcom!
Coming back to 24.0.3 from last week:
[sudo] password for alba:
[    0.228634] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.228634]  #3
[    0.931068] ata1.00: supports DRM functions and may not be fully accessible
[    0.932924] ata1.00: supports DRM functions and may not be fully accessible
[    6.554181] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[   25.095429] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
[   25.095441] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[   25.095445] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[   25.095449] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[   25.095453] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   26.091981] at24 9-0050: supply vcc not found, using dummy regulator
[   26.424149] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[   27.270612] wl: loading out-of-tree module taints kernel.
[   27.270623] wl: module license 'MIXED/Proprietary' taints kernel.
[   27.270625] Disabling lock debugging due to kernel taint
[   27.423679] wlan0: Broadcom BCM4331 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[  101.248574] hfsplus: write access to a journaled filesystem is not supported, use the force option at your own risk, mounting read-only.
Above are warnings about Broadcom Wireless.
I now update linux61-broadcom-wl and sudo so that a restart is required and then my system is up to date, version 24.0.4.
[    0.228258] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.228258]  #3
[    0.790664] ata1.00: supports DRM functions and may not be fully accessible
[    0.792606] ata1.00: supports DRM functions and may not be fully accessible
[    5.290148] kauditd_printk_skb: 3 callbacks suppressed
[    6.996071] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
[    6.996099] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.996108] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.996115] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[    6.996121] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    7.921814] at24 9-0050: supply vcc not found, using dummy regulator
[    8.104697] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    8.969419] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[   32.012080] hfsplus: write access to a journaled filesystem is not supported, use the force option at your own risk, mounting read-only.
Still no Broadcom:
As requested:
% journalctl --boot=-1 --priority=3 --catalog --no-pager
Jul 21 01:01:53 mac2011-manjaro dbus-broker-launch[807]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
░░ Subject: Invalid service file
░░ Defined-By: dbus-broker
░░ Support: https://groups.google.com/forum/#!forum/bus1-devel
░░ A service file is a ini-type configuration file.
░░ It has one required section
░░ named [D-BUS Service]. The section contains the required key 'Name', which
░░ must be a valid D-Bus name that is unique across all service files. It also
░░ contains at least one of the two optional keys 'SystemdService' and 'Exec',
░░ as well as optionally the key 'User'. Exec must be a valid shell command and
░░ User must be a valid user on the system.
░░ A service file should be named after the D-Bus name it configures. That is
░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
░░ For backwards compatibility, we only warn when files do not follow this
░░ convention when run as a user bus. The system bus considers this an error
░░ and ignores the service file.
Jul 21 01:02:05 mac2011-manjaro gdm-password][1237]: gkr-pam: unable to locate daemon control file
Jul 21 01:02:05 mac2011-manjaro dbus-broker-launch[1280]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Jul 21 01:02:06 mac2011-manjaro gdm[738]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Jul 21 01:02:07 mac2011-manjaro systemd[1250]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 193 and the job result is failed.
░░ The job identifier is 189 and the job result is failed.
Jul 21 01:02:16 mac2011-manjaro gdm[738]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Jul 21 01:08:53 mac2011-manjaro dbus-broker-launch[646]: Activation request for 'org.bluez' failed.
Jul 21 01:08:53 mac2011-manjaro pulseaudio[1608]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NameHasNoOwner:Could not activate remote peer 'org.bluez': activation request failed: unit is invalid
Jul 21 01:08:53 mac2011-manjaro pulseaudio[1608]: Assertion 'pa_atomic_load(&(y)->_ref) > 0' failed at ../pulseaudio/src/modules/bluetooth/bluez5-util.c:2207, function pa_bluetooth_discovery_hook(). Aborting.
Jul 21 01:08:53 mac2011-manjaro dbus-broker-launch[646]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Jul 21 01:08:54 mac2011-manjaro dbus-broker-launch[646]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
% sudo inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.1.100-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-
    root=UUID=56df36bb-acc9-4ce7-b8bd-b76c52c14aff rw apparmor=1
  Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0 serial: <filter>
    Chassis: type: 10 v: Mac-94245B3640C91C81 serial: <filter>
  Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1 serial: <filter>
    uuid: a22d8cc8-f65b-d75a-ba80-972073102d8f UEFI: Apple
    v: MBP81.88Z.0050.B00.1804101331 date: 04/10/18
  ID-1: BAT0 charge: 60.2 Wh (100.0%) condition: 60.2/62.9 Wh (95.7%)
    volts: 12.4 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
    status: full cycles: 57
  Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.54 GiB used: 5.35 GiB (34.5%)
    igpu: 64 MiB
  Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: 1333 MT/s
    volts: N/A width: N/A manufacturer: N/A
    part-no: 0x202020202020202020202020202020202020 serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: 1333 MT/s
    volts: N/A width: N/A manufacturer: 0x859B
    part-no: 0x435438473353313333394D2E4D3136465000 serial: <filter>
  Slot: 0 type: PCIe status: available length: short volts: 3.3 bus-ID: N/A
  Slot: 1 type: PCIe status: available info: ExpressCard length: short
  Slot: 2 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
  Slot: 3 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
  Slot: 4 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
  Slot: 5 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
  Info: model: Intel Core i5-2415M socket: U2E1 bits: 64 type: MT MCP SMP
    arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12 process: Intel 32nm
    family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L1: 4x 128 KiB (512 KiB) desc: d-2x32 KiB; i-2x32 KiB L2: 4x 512 KiB (2 MiB)
    desc: 2x256 KiB L3: 4x 3 MiB (12 MiB) desc: 1x3 MiB
  Speed (MHz): avg: 860 high: 1026 min/max: 800/2900 base/boost: 2335/2300
    scaling: driver: intel_cpufreq governor: schedutil volts: 0.0 V cores: 1: 802
    2: 798 3: 815 4: 1026 bogomips: 18366
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Apple driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: DP-1,LVDS-1 empty: DP-2,
    DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0126 class-ID: 0300
  Device-2: Apple FaceTime HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 05ac:8509
  Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1880 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 pos: top-left model: Dell S3221QS serial: <filter>
    built: 2021 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2 chroma: red: x: 0.678
    y: 0.310 green: x: 0.275 y: 0.659 blue: x: 0.153 y: 0.067 white: x: 0.314
    y: 0.329 size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1920x1080i, 1600x1200,
    1680x1050, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
    unhandled CEA mode 95 5: parse_edid: unhandled CEA mode 96
  Monitor-2: LVDS-1 pos: primary,bottom-r model: Apple Color LCD built: 2009
    res: 1280x800 hz: 60 dpi: 114 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
    green: x: 0.310 y: 0.612 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 286x179mm (11.26x7.05") diag: 337mm (13.3") ratio: 16:10
    modes: 1280x800
  EDID-Warnings: 1: parse_edid: unknown flag 1
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.1.4-manjaro1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    device-ID: 8086:0126 memory: 1.46 GiB unified: yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
    class-ID: 0403
  API: ALSA v: k6.1.100-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
    driver: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
  Info: services: mld, NetworkManager, nfsd, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1.3:9
    chip-ID: 05ac:821a class-ID: fe01
  Local Storage: total: 1.82 TiB used: 557.98 GiB (30.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 033 temp: 29 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 111d 18h cycles: 9933
    written: 14.23 TiB Old-Age: UDMA CRC errors: 12784
    alert: Bad cable/connection?
  ID-2: /dev/sdb maj-min: 8:16 model: Disk size: 931.51 GiB block-size:
    physical: 512 B logical: 512 B type: FireWire tech: N/A serial: N/A
    scheme: GPT
  SMART: no
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GS31N rev: TA17
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 465.61 GiB size: 457.23 GiB (98.20%)
    used: 248.65 GiB (54.4%) fs: ext4 block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: Manjaro uuid: 56df36bb-acc9-4ce7-b8bd-b76c52c14aff
    used: 15.3 MiB (5.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: B7C7-0640
  ID-3: /run/media/alba/EFI raw-size: 351 MiB size: 350.3 MiB (99.79%)
    used: 15.3 MiB (4.4%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    label: EFI uuid: 9C09-3B8F
  ID-4: /run/media/alba/Mac OS X El Capitan raw-size: 464.48 GiB
    size: 464.48 GiB (100.00%) used: 309.3 GiB (66.6%) fs: hfsplus
    block-size: 4096 B dev: /dev/sdb4 maj-min: 8:20 label: Mac OS X El Capitan
    uuid: 3771b656-357f-3ac4-a993-704353fc89b7
  ID-1: /dev/sda3 maj-min: 8:3 size: 464.88 GiB fs: hfsplus
    label: Mac OS El Capitan uuid: 82d1c656-ef8c-3486-a93a-fe4abee157eb
  ID-2: /dev/sda4 maj-min: 8:4 size: 619.9 MiB fs: hfsplus label: Recovery HD
    uuid: 40d48383-7f08-3968-aa16-7a12ffdfd7e3
  ID-3: /dev/sdb2 maj-min: 8:18 size: 465.96 GiB fs: ext4
    label: Manjaro backup uuid: a0135863-9375-4aea-b942-fe7c7dc7bc7d
  ID-4: /dev/sdb5 maj-min: 8:21 size: 619.9 MiB fs: hfsplus
    label: Recovery HD uuid: 1925d052-aca6-307a-8025-ad6321a399f4
  Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-2: 1-1:2 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA chip-ID: 0424:2513
  Hub-3: 1-1.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
    Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 1-1.1.3:9 info: Apple Bluetooth Host Controller type: bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 05ac:821a class-ID: fe01
  Device-2: 1-1.2:5 info: Apple Internal Keyboard/Trackpad (ANSI)
    type: keyboard,HID,mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 40mA
    chip-ID: 05ac:0252 class-ID: 0301
  Device-3: 1-1.3:6 info: Logitech Nano Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-4: 1-2:3 info: Apple FaceTime HD Camera type: video driver: uvcvideo
    interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
  Hub-4: 2-0:1 info: full speed or root hub ports: 8 rev: 2.0
  Hub-5: 2-1:2 info: Microchip (formerly SMSC) 2.0 Hub ports: 2 rev: 2.0
  Device-1: 2-1.1:3 info: Apple Built-in IR Receiver type: HID
    driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
  Hub-6: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Hub-7: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
  System Temperatures: cpu: 77.0 C mobo: 0.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1802 libs: 399 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://mirror.easyname.at/manjaro/unstable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/unstable/$repo/$arch
    3: https://nnenix.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://manjaro.ipacct.com/manjaro/unstable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    6: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    7: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 312
  1: cpu: 40.5% command: chrome pid: 1489 mem: 597.4 MiB (3.7%)
  2: cpu: 13.0% command: chrome pid: 2632 mem: 228.8 MiB (1.4%)
  3: cpu: 11.4% command: skypeforlinux pid: 2122 mem: 256.1 MiB (1.6%)
  4: cpu: 8.3% command: pamac-manager pid: 2774 mem: 784.0 MiB (4.9%)
  5: cpu: 6.3% command: gnome-shell pid: 1354 mem: 203.0 MiB (1.2%)
  Memory top: 5 of 312
  1: mem: 784.0 MiB (4.9%) command: pamac-manager pid: 2774 cpu: 8.3%
  2: mem: 597.4 MiB (3.7%) command: chrome pid: 1489 cpu: 40.5%
  3: mem: 258.6 MiB (1.6%) command: chrome pid: 2282 cpu: 4.4%
  4: mem: 256.1 MiB (1.6%) command: skypeforlinux pid: 2122 cpu: 11.4%
  5: mem: 228.8 MiB (1.4%) command: chrome pid: 2632 cpu: 13.0%
  Processes: 312 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: gnome-terminal inxi: 3.3.35
In summary, Manjaro 24.0.4 as opposed to 24.0.3 fails to load linux61-broadcom-wl Broadcom wireless network.
The problem has disappeared in Manjaro 24.0.5.
