Has anyone gotten the Broadcom Crystal HD decoder bcm70012 to install completely?
It’s the only reason this HP Mini 210 with 2GB still has Win 7 and Win 10 on it. If I ever get it working, Windows will be wiped from existence.
Did you try to install libcrystalhd from AUR?
https://aur.archlinux.org/packages/libcrystalhd/
Install:
pamac build libcrystalhd
Load the module:
sudo modprobe crystalhd
Check if the module is loaded:
lsmod
It is unmaintained. There’s a new URL in AUR. The OP will have to build it himself. There’s a readme file in the driver package from broadcom with generic instructions. But of course a proper PKGBUILD should be written.
If someone could post the complete procedure.
I am receiving this error …
Error: Failed to prepare transaction: could not find database
Edit build files ? [y/N]
