Hi,
Can someone help me understand the reasons for my wifi not connecting automatically on system bootup, please?
I have listed my system info below:
System: Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=a92be740-7301-4153-9809-6d1c08b5b793 rw quiet apparmor=1
security=apparmor resume=UUID=a61c2182-74f1-4835-91bf-c2e31cb2f052 udev.log_priority=3
Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-H GAMING v: Rev X.0x serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1404 date: 09/10/2018
Memory: RAM: total: 15.55 GiB used: 2.26 GiB (14.5%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM1 size: No Module Installed
Device-2: ChannelA-DIMM2 size: 8 GiB speed: 2666 MT/s type: DDR4 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: Corsair part-no: CM4X8GF2666C16K8 serial: N/A
Device-3: ChannelB-DIMM1 size: No Module Installed
Device-4: ChannelB-DIMM2 size: 8 GiB speed: 2666 MT/s type: DDR4 detail: synchronous bus-width: 64 bits
CPU: Info: 6-Core model: Intel Core i7-8086K socket: LGA1151 bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE cache: L1: 384 KiB L2: 12 MiB L3: 12 MiB bogomips: 96039
Speed: 800 MHz min/max: 800/5000 MHz base/boost: 4000/8300 volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz):
1: 800 2: 800 3: 800 4: 800 5: 800 6: 799 7: 800 8: 800 9: 800 10: 801 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma
fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: eVga.com. driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1f02 class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5") s-diag: 692mm (27.3")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
chip-ID: 8086:15bc class-ID: 0200
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl v: kernel modules: bcma port: 3000
bus-ID: 05:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 3.41 TiB used: 202.16 GiB (5.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7
temp: 33 Celsius C scheme: GPT
SMART: yes health: PASSED on: 25 hrs cycles: 875 read-units: 1,297,569 [664 GB] written-units: 3,175,764 [1.62 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB family: based SSDs size: 465.76 GiB
block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2B6Q
temp: 27 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 66d 15h cycles: 1042 written: 10.69 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102 family: BarraCuda 3.5 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 0001
temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 66d 13h cycles: 1039 read: 18.04 TiB written: 5.43 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Fast SSD size: 931.51 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 0002 scheme: MBR
SMART Message: A mandatory SMART command failed. Various possible causes.
Partition: ID-1: / raw-size: 448.65 GiB size: 440.54 GiB (98.19%) used: 202.16 GiB (45.9%) fs: ext4 block-size: 4096 B
dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: a92be740-7301-4153-9809-6d1c08b5b793
Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a61c2182-74f1-4835-91bf-c2e31cb2f052
Unmounted: ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 232.88 GiB fs: ntfs label: Sam250 uuid: 7AD01758D0171A49
ID-2: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: Sea2TB uuid: C80C23040C22ED5E
ID-3: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ext4 label: USB-DATA uuid: 53409113-94f8-4552-a322-66cec61e8c3f
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-4:2 info: Microsoft XBOX ACC type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-2: 1-7:3 info: Hoksi DGK68C type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 2f68:4001 class-ID: 0300
Device-3: 1-8:4 info: Razer USA DeathAdder Elite type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:005c class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 2-2:2 info: Seagate RSS LLC Fast SSD type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 10 Gb/s
power: 896mA chip-ID: 0bc2:ab09 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 46 C
Info: Processes: 282 Uptime: 17m wakeups: 1 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1358
pacman: 1337 lib: 394 flatpak: 12 snap: 9 Shell: Bash (sudo) v: 5.1.8 running-in: konsole inxi: 3.3.04
Please let me know if any extra output is needed which can help me with this issue. Many thanks in advance!
Mark
Updated 29-Jun-2021 to encapsulate text as I have just learned how to do this…
