Hi, I’ve just installed Manjaro today on an old Toshiba Satellite that was gathering dust. It has a Broadcom BCM43142 network controller which seems to require extra work to get working. After some googling, the fix seems relatively simple, if I had an ethernet port or a way of tethering my phone - but I don’t I’m afraid. How can I download the drivers on a different machine, to a USB stick to then be installed on my Manjaro machine?
Below is my inxi output:
[manjaro@manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: SATELLITE C40-C v: PSCRLE-001018EN
serial: <filter> Chassis: type: 10 v: * serial: <filter>
Mobo: TOSHIBA model: ARWAA v: 1.00 serial: <filter> UEFI: TOSHIBA v: 5.00
date: 08/06/2015
ID-1: BAT1 charge: 30.9 Wh condition: 30.9/31.7 Wh (97%) volts: 16.4/14.4
model: TOSHIBA PABAS0241231 type: Li-ion serial: <filter> status: Full
RAM: total: 1.79 GiB used: 912.4 MiB (49.7%)
Info: Dual Core model: Intel Celeron N3050 bits: 64 type: MCP arch: Airmont
family: 6 model-id: 4C (76) stepping: 3 microcode: 368 L2 cache: 1024 KiB
bogomips: 6402
Speed: 480 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 480 2: 480
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b1
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04f2:b446
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.3.1
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:2284
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Lite-On driver: N/A
port: f040 bus ID: 02:00.0 chip ID: 14e4:4365
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 32.87 GiB used: 71.8 MiB (0.2%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: 032GE4 size: 29.12 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 0x7
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer
size: 3.75 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 7.01
ID-1: / raw size: N/A size: 1.34 GiB used: 71.8 MiB (5.2%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 512 MiB fs: vfat label: N/A
uuid: C06C-CA13
ID-2: /dev/mmcblk0p2 maj-min: 179:2 size: 28.62 GiB fs: ext4 label: N/A
uuid: f8b6da97-9140-4421-b37d-530e8af47d5d
ID-3: /dev/sda1 maj-min: 8:1 size: 2.73 GiB fs: iso9660
label: MANJARO_XFCE_2021 uuid: 2021-01-03-08-16-14-00
ID-4: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C274-6DF3
Hub: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-3:2 info: SanDisk Cruzer Micro U3 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0781:5406 serial: <filter>
Device-2: 1-4:5 info: Toshiba BCM43142A0 type: <vendor specific>
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip ID: 0930:0225
serial: <filter>
Device-3: 1-5:3 info: Chicony TOSHIBA Web Camera - HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b446
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 174 Uptime: 1h 01m wakeups: 2 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1203 lib: 370 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.01
