Brightness randomly goes down
Im having issues where my screen brightness will randomly go down, sometimes it will go down to 30% sometimes it will go down to 5%.
Ive checked some similar questions here and I couldnt find an awnser, so hopefully somone can help me out.
Im not 100% sure whats going to be helpful here, so ive posted some logs and other stuff below, if anyone has any other suggestions of logs to post ill be happy to
  Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=7979a6d6-d005-47e1-ad73-56e8f5bef7ab rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
    serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
    UEFI: American Megatrends v: 0904 date: 09/14/2018
  Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF4
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 32013
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 550.78
    alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
    2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
    s-diag: 868mm (34.19")
  Monitor-1: Unknown-1 mapped: HDMI-0 res: 3440x1440 hz: 50 dpi: 110
    size: 797x333mm (31.38x13.11") modes: 3440x1440
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1070 driver: nvidia v: 550.78 device-ID: 10de:1b81
    surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-3: Razer USA Barracuda Pro 2.4
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-14.1:4 chip-ID: 1532:053a class-ID: 0301
    serial: <filter>
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF-ID-1: br-3215fcb136c8 state: down mac: <filter>
  IF-ID-2: br-617af164e82b state: down mac: <filter>
  IF-ID-3: br-ecd3e317c94b state: down mac: <filter>
  IF-ID-4: docker0 state: down mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:2 chip-ID: 2357:0604
  Local Storage: total: 2.73 TiB used: 685.52 GiB (24.5%)
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 211070WD temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EURX-63T0FY0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
  ID-1: / raw-size: 833.56 GiB size: 819.4 GiB (98.30%)
    used: 280.29 GiB (34.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 51 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Memory: total: 32 GiB available: 31.26 GiB used: 5.43 GiB (17.4%)
  Processes: 214 Power: uptime: 6h 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1529 libs: 475 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.34
[chris@chris ~]$ journalctl --catalog --priority=3 --boot=-1
May 24 09:27:18 chris kernel: x86/cpu: SGX disabled by BIOS.
May 24 09:27:19 chris kernel: hid-generic 0003:1532:028D.000B: No inputs registered, leaving
May 24 09:27:21 chris bluetoothd[467]: Failed to set mode: Failed (0x03)
May 24 09:27:38 chris bluetoothd[467]: Failed to set mode: Failed (0x03)
May 24 10:29:16 chris kernel: hid-generic 0003:1532:028D.0016: No inputs registered, leaving
May 24 10:37:15 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 10:37:20 chris kernel: usb 1-14.1: 1:0: usb_set_interface failed (-71)
May 24 10:51:46 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 10:51:51 chris kernel: usb 1-14.1: 1:0: usb_set_interface failed (-71)
May 24 12:45:40 chris kernel: hid-generic 0003:1532:028D.0022: No inputs registered, leaving
May 24 12:45:41 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 12:45:41 chris kernel: usb 1-14.1: 2:1: usb_set_interface failed (-71)
May 24 12:53:05 chris kernel: hid-generic 0003:1532:028D.002E: No inputs registered, leaving
May 24 13:29:24 chris kernel: hid-generic 0003:1532:028D.003A: No inputs registered, leaving
May 24 13:30:31 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:30:31 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:33 chris kernel: hid-generic 0003:1532:028D.0047: No inputs registered, leaving
May 24 13:50:35 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:35 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:37 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:37 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:38 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:38 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:40 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:40 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:41 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:41 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:42 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:42 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:44 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:44 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:51 chris pulseaudio[1210]: Error opening PCM device front:2: No such file or directory
May 24 13:50:51 chris pulseaudio[1210]: Error opening PCM device hw:2: No such file or directory
May 24 13:50:51 chris kernel: usb 1-14.1: device descriptor read/64, error -32
May 24 13:50:52 chris kernel: usb 1-14.1: device not accepting address 33, error -71
May 24 13:50:53 chris kernel: usb 1-14.1: device descriptor read/64, error -32
May 24 13:50:54 chris kernel: usb 1-14.1: device not accepting address 36, error -71
May 24 13:50:55 chris kernel: usb 1-14.1: device not accepting address 37, error -71
May 24 13:50:55 chris kernel: usb 1-14-port1: unable to enumerate USB device
May 24 16:24:45 chris kernel: hid-generic 0003:1532:028D.0054: No inputs registered, leaving
May 24 16:36:30 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 16:36:42 chris kernel: usb 1-14.1: 1:0: usb_set_interface failed (-71)
May 24 17:10:34 chris kernel: hid-generic 0003:1532:028D.0060: No inputs registered, leaving
May 24 17:10:35 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 17:10:35 chris kernel: usb 1-14.1: 1:0: usb_set_interface failed (-71)
May 24 17:12:10 chris kernel: usb 1-14.1: 1:1: cannot get freq at ep 0x7
May 24 17:12:16 chris kernel: usb 1-14.1: 1:0: usb_set_interface failed (-71)
May 24 17:19:39 chris pulseaudio[1210]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
May 24 17:19:39 chris pulseaudio[1210]: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
May 24 17:19:39 chris pulseaudio[1210]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Have you checked the following settings? :point_down:
check your Energysettings - Display and Brightness
I have Dim automatically set to after 5 minutes
However, I would have assumed that would be after 5 minutes of inactivity? and once your active again the screen goes back to 100%, this will randomly change the brightness even if im currently using it again, and there is no way to set it back unless I manually set it back to 100%
Regardless, ill turn this off and see if that fixes it, thanks
Disable Dim and Enable Turn off
My Monitor also not go to 100% after Dimming
