Hi! Cfinnberg
I have the same problem described previously and to solve it, I run the 2 commands you post. This is the result (image). So, what comes next?
I appreciate your advice!
The specification of my system:
Host: manjaro Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.1.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_X570ZD
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <filter>
UEFI: American Megatrends v: X570ZD.310 date: 07/04/2019
ID-1: BAT0 charge: 42.9 Wh condition: 42.9/48.1 Wh (89%) volts: 11.7/11.7
model: ASUSTeK ASUS Battery type: Li-ion serial: <filter>
status: Not charging cycles: 36
RAM: total: 6.80 GiB used: 1.62 GiB (23.8%)
RAM Report:
Topology: Quad Core model: AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen L2 cache: 2048 KiB
bogomips: 35148
Speed: 1392 MHz min/max: 1600/2200 MHz boost: enabled Core speeds (MHz):
1: 1532 2: 1445 3: 1371 4: 1341 5: 1369 6: 1369 7: 1371 8: 1369
Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1c8d
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 04:00.0
chip ID: 1002:15dd
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.36.0 5.6.15-1-MANJARO LLVM 10.0.0)
v: 4.6 Mesa 20.0.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 04:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.6.15-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: AzureWave driver: rtw_pci v: N/A port: e000 bus ID: 02:00.0
chip ID: 10ec:b822
IF: wlp2s0 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 945.92 GiB used: 137.6 MiB (0.0%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0J scheme: GPT
ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
size: 14.41 GiB serial: <filter> scheme: MBR
ID-1: / size: 5.10 GiB used: 137.6 MiB (2.6%) fs: overlay source: ERR-102
System Temperatures: cpu: 48.1 C mobo: N/A
Fan Speeds (RPM): cpu: 2800
GPU: device: amdgpu temp: 48 C device: nouveau temp: 48 C
Processes: 243 Uptime: 16m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.17 running in: xfce4-terminal inxi: 3.0.37
The result after running hte 2 commands:
[manjaro@manjaro ~]$ sudo journalctl -b | curl -T - https://aptget.xyz/journal.txt
<!DOCTYPE html>
<!--[if IE 8]> <html lang="en" class="ie8 no-js"> <![endif]-->
<!--[if IE 9]> <html lang="en" class="ie9 no-js"> <![endif]-->
<!--[if !IE]><!-->
<html lang="en">
<!--<![endif]-->
<!-- BEGIN HEAD -->
<head>
<meta charset="utf-8" />
<title>SAI MAILING</title>
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta content="width=device-width, initial-scale=1" name="viewport" />
<meta content="IR Team" name="author" />
<!-- BEGIN GLOBAL FONTS STYLES -->
<script src="https://ajax.googleapis.com/ajax/libs/webfont/1.6.16/webfont.js"></script>
<script>
WebFont.load({
google: {"families":["Poppins:300,400,500,600,700","Roboto:300,400,500,600,700"]},
active: function() {
sessionStorage.fonts = true;
</script>
<!-- END GLOBAL FONTS STYLES -->
<!-- BEGIN PAGE GLOBAL STYLES -->
<link href="https://aptget.xyz/plugins/font-awesome/css/font-awesome.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/fontawesome5/css/all.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/simple-line-icons/simple-line-icons.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/bootstrap/css/bootstrap.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/bootstrap-sweetalert/sweetalert.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/bootstrap-toastr/toastr.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/bootstrap-switch/css/bootstrap-switch.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/bootstrap-select/css/bootstrap-select.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/plugins/widearea/widearea.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/styles/components.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/styles/plugins.min.css" rel="stylesheet" type="text/css" />
<!-- END PAGE GLOBAL STYLES -->
<!-- BEGIN PAGE LEVEL STYLES -->
<link href="https://aptget.xyz/styles/pages/errors.min.css" rel="stylesheet" type="text/css" />
<link href="https://aptget.xyz/styles/custom.min.css" rel="stylesheet" type="text/css" />
<!-- END PAGE LEVEL STYLES -->
<!-- BEGIN FAVICON -->
<link rel="shortcut icon" href="https://aptget.xyz/images/logos/favicon.ico?v=2" />
<!-- END FAVICON -->
</head>
<!-- END HEAD -->
<body class=" page-500-full-page" style="background-color: #444d58;">
<div class="row">
<div class="col-md-12 page-500" style="margin-top: 20% !important">
<div class=" number font-dark"> 404 </div>
<div class=" details">
<h3> Page Not Found! </h3>
<p>
</p>
<p><a href="https://aptget.xyz" class="btn grey-mint btn-outline"> Return home </a><br></p>
</div>
</div>
</div>
<!-- END COPYRIGHT -->
<!-- BEGIN JAVASCRIPTS -->
<!-- BEGIN CORE PLUGINS -->
<!--[if lt IE 9]>
<script src="http://aptget.xyz/plugins/respond.min.js"></script>
<script src="http://aptget.xyz/plugins/excanvas.min.js"></script>
<![endif]-->
<script src="https://aptget.xyz/plugins/jquery.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap/js/bootstrap.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/js.cookie.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/jquery-slimscroll/jquery.slimscroll.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/jquery.blockui.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-switch/js/bootstrap-switch.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-sweetalert/sweetalert.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-toastr/toastr.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-select/js/bootstrap-select.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-hover-dropdown/bootstrap-hover-dropdown.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/bootstrap-tabdrop/js/bootstrap-tabdrop.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/moment.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/jquery-inputmask/jquery.inputmask.bundle.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/plugins/widearea/widearea.js" type="text/javascript"></script>
<!-- END CORE PLUGINS -->
<!-- BEGIN PAGE LEVEL PLUGINS -->
<!-- END PAGE LEVEL PLUGINS -->
<script src="https://aptget.xyz/scripts/global/iresponse.min.js" type="text/javascript"></script>
<script src="https://aptget.xyz/scripts/global/datatable.min.js" type="text/javascript"></script>
<!-- BEGIN PAGE LEVEL SCRIPTS -->
<!-- END PAGE LEVEL SCRIPTS -->
<!-- END JAVASCRIPTS -->
<!-- BEGIN PRE-LOADER REMOVER -->
<script>
$(function(){
$("section.wrapper").fadeOut(500);
$(".page-content").css("min-height", ($(window).height() - 170) + "px");
</script>
<!-- END PRE-LOADER REMOVER -->
</body>
The problem is that aptget.xyz service is not available anymore. You can get something similar with:
sudo journalctl -b | curl -F 'file=@-' https://0x0.st
It should return just a URL you can copy here
That’s right. The URL is Https://0x0.st/i78E.txt
Could you please help me understand the meaning of what’s inside that URL?
It contains your computer’s logs from the last boot. I can only see that Xorg is core-dumping but I can’t see why. Your computer seems to have two graphic cards and probably it’s something related to that but unfortunately I have to say that graphic drivers are not in my expertise area, so I’m not going to be of much help. Let’s hope someone else steps in…
@LESS-MESS
This kernel:
LESS-MESS:
is deprecated. Use a STABLE one or a LTS one. https://www.kernel.org/
Installing:
If you use nvidia driver, keep sure you use at least version 450xx.
This coredump says that there is a problem with Xorg and the amdgpu driver. A Kernel upgrade could solve this (since amdgpu is built into the kernel):
nov 29 13:01:21 nawim-vivobookasuslaptopx570zdx570zd systemd-coredump[1425]: Process 1388 (Xorg) of user 0 dumped core.
Stack trace of thread 1388:
#0 0x00007fa5c56b7615 raise (libc.so.6 + 0x3d615)
#1 0x00007fa5c56a0862 abort (libc.so.6 + 0x26862)
#2 0x000056288542735a OsAbort (Xorg + 0x14a35a)
#3 0x0000562885428e21 FatalError (Xorg + 0x14be21)
#4 0x000056288542ea79 n/a (Xorg + 0x151a79)
#5 0x00007fa5c56b76a0 __restore_rt (libc.so.6 + 0x3d6a0)
#6 0x00007fa5c56b7615 raise (libc.so.6 + 0x3d615)
#7 0x00007fa5c56a0862 abort (libc.so.6 + 0x26862)
#8 0x00007fa5c56a0747 __assert_fail_base.cold (libc.so.6 + 0x26747)
#9 0x00007fa5c56afbf6 __assert_fail (libc.so.6 + 0x35bf6)
#10 0x00007fa5c5ba1fd3 n/a (amdgpu_drv.so + 0x8fd3)
#11 0x00007fa5c5ba233a n/a (amdgpu_drv.so + 0x933a)
#12 0x00007fa5c5bae34d n/a (amdgpu_drv.so + 0x1534d)
#13 0x00007fa5c5bb046a n/a (amdgpu_drv.so + 0x1746a)
#14 0x00007fa5c5bb2127 n/a (amdgpu_drv.so + 0x19127)
#15 0x0000562885380871 MapWindow (Xorg + 0xa3871)
#16 0x0000562885316619 n/a (Xorg + 0x39619)
#17 0x00007fa5c56a2152 __libc_start_main (libc.so.6 + 0x28152)
#18 0x00005628853175de _start (Xorg + 0x3a5de)
Stack trace of thread 1418:
#0 0x00007fa5c556f6a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007fa5c07e9834 n/a (radeonsi_dri.so + 0x658834)
#2 0x00007fa5c07e5588 n/a (radeonsi_dri.so + 0x654588)
#3 0x00007fa5c55693e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007fa5c577a293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1419:
Stack trace of thread 1395:
#1 0x00007fa5c0663eac n/a (radeonsi_dri.so + 0x4d2eac)
#2 0x00007fa5c0663da8 n/a (radeonsi_dri.so + 0x4d2da8)
Stack trace of thread 1389:
Stack trace of thread 1410:
#1 0x00007fa5c07fe314 n/a (radeonsi_dri.so + 0x66d314)
#2 0x00007fa5c07e55b8 n/a (radeonsi_dri.so + 0x6545b8)
Stack trace of thread 1408:
Stack trace of thread 1414:
Stack trace of thread 1397:
Stack trace of thread 1411:
Stack trace of thread 1394:
Stack trace of thread 1396:
Stack trace of thread 1409:
Stack trace of thread 1402:
Stack trace of thread 1399:
Stack trace of thread 1392:
Stack trace of thread 1407:
Stack trace of thread 1420:
Stack trace of thread 1393:
Stack trace of thread 1401:
Stack trace of thread 1417:
Stack trace of thread 1406:
Stack trace of thread 1403:
Stack trace of thread 1400:
Stack trace of thread 1405:
Stack trace of thread 1416:
Stack trace of thread 1415:
Stack trace of thread 1390:
Stack trace of thread 1391:
Stack trace of thread 1398:
Stack trace of thread 1413:
Stack trace of thread 1412:
Stack trace of thread 1421:
Stack trace of thread 1404:
Stack trace of thread 1423:
Stack trace of thread 1422:
nov 29 13:01:21 nawim-vivobookasuslaptopx570zdx570zd systemd[1]: systemd-coredump@6-1424-0.service: Succeeded.
@megavolt
Thanks for your advise.
I’ve installed linux59 and linux54 kernels with no positive results (the problem with Xorg and amdgpu persist).
Even I run the following commands:
sudo pacman-mirrors -f && sudo pacman -Syyu
sudo mhwd-kernel -r linux59 && sudo mhwd-kernel -i linux59
sudo mhwd -f -i pci video-linux
…but It doesn’t seem to work. In fact, when execute startx command this is the result:
[manjaro /]# startx
xauth: error in locking authority file /home/manjaro/.Xauthority
_XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn't already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
And when run journalctl -p -err command, shows many errors related to lightdm and ADM:
[manjaro@manjaro ~]$ journalctl -p err
-- Logs begin at Tue 2020-12-01 18:13:32 UTC, end at Tue 2020-12-01 20:20:49 UTC. --
Dec 01 18:13:32 manjaro kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Dec 01 18:13:32 manjaro kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0x7d467000-0x7d467fff flags 0x200] vs 7d467000 4000
Dec 01 18:13:32 manjaro kernel: tpm_crb MSFT0101:00: can't request region for resource [mem 0x7d467000-0x7d467fff]
Dec 01 18:13:32 manjaro kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Dec 01 18:13:33 manjaro systemd-backlight[817]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Dec 01 18:13:33 manjaro systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Dec 01 18:13:35 manjaro systemd[1]: Failed to start Import ZFS pools by device scanning.
Dec 01 18:13:35 manjaro systemd[1]: Failed to start Mount ZFS filesystems.
Dec 01 18:13:46 manjaro kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 122124 [ IBUS ]
Dec 01 18:13:46 manjaro kernel: nouveau 0000:01:00.0: gr: intr 00000040
What can I do to troubleshoot this?
The last thing I made before system start failing was installed Blender.
Ok step by step…
Try to disable it with that kernel parameter: amd_iommu=off and check if the error is still there.
Try to disable TPM in your UEFI/BIOS under security and check if it is still there.
Did you install the amd pro driver, because of blender?
Could you please explain in a bit more detail how to do that? I’m still a newbie with Linux.
(Do I have to edit the grub config file at /etc/default/grub and add amd_iommu=off to GRUB_CMDLINE_LINUX=" ""? or how is the process?
I’m not aware of that. I just notice that I have dual-grapphics with an nvidia card using nouveau instead of proprietary nvidia. But don’t konow why.
@LESS-MESS sorry for the delay. I had some RL issues.
Yes, exactly.
Due the special system, could you also post:
inxi -Fazy
mhwd -l && mhwd -li
Thanks!
Of course:
[manjaro /]# inxi -Fazy
12System:
12Kernel 5.6.15-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 10.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_XFCE_2003 quiet systemd.show_status=1
apparmor=1 security=apparmor
12Desktop Xfce 12info xfce4-panel 12wm xfwm4 12dm N/A 12Distro Manjaro Linux
12Machine:
12Type Laptop 12System ASUSTeK 12product VivoBook_ASUSLaptop X570ZD_X570ZD 12v 1.0
12serial <filter>
12Mobo ASUSTeK 12model X570ZD 12v 1.0 12serial <filter> 12UEFI American Megatrends
12v X570ZD.310 12date 07/04/2019
12Battery:
12ID-1 BAT0 12charge 42.6 Wh 12condition 42.6/48.1 Wh (89%) 12volts 11.7/11.7
12model ASUSTeK ASUS Battery 12type Li-ion 12serial N/A 12status Not charging
12cycles 37
12CPU:
12Info Quad Core 12model AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx
12socket FP5 12bits 64 12type MT MCP 12arch Zen 12family 17 (23) 12model-id 11 (17)
12stepping N/A 12microcode 810100B 12L1 cache 384 KiB 12L2 cache 2048 KiB
12L3 cache 4000 KiB
12flags avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
12bogomips 35147
12Speed 1372 MHz 12min/max 1600/2200 MHz 12base/boost 2200/3800 12boost enabled
12volts 1.2 V 12ext-clock 100 MHz 12Core speeds (MHz) 121 1371 122 1379 123 1371 124 1449
125 1407 126 1517 127 1479 128 1387
12Vulnerabilities 12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1
12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GP107M [GeForce GTX 1050 Mobile] 12vendor ASUSTeK
12driver nouveau 12v kernel 12bus ID 01:00.0 12chip ID 10de:1c8d
12Device-2 AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
12vendor ASUSTeK 12driver amdgpu 12v kernel 12bus ID 04:00.0 12chip ID 1002:15dd
12Device-3 IMC Networks USB2.0 VGA UVC WebCam 12type USB 12driver uvcvideo
12bus ID 3-2.2:4 12chip ID 13d3:5a05 12serial <filter>
12Display 12server X.org 1.20.9 12driver amdgpu,ati,nouveau 12unloaded modesetting
12alternate fbdev,nv,vesa
12Message Advanced graphics data unavailable for root.
12Audio:
12Device-1 AMD Raven/Raven2/Fenghuang HDMI/DP Audio 12driver snd_hda_intel
12v kernel 12bus ID 04:00.1 12chip ID 1002:15de
12Device-2 AMD Family 17h HD Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12bus ID 04:00.6 12chip ID 1022:15e3
12Sound Server ALSA 12v k5.6.15-1-MANJARO
12Network:
12Device-1 Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter 12vendor AzureWave
12driver rtw_pci 12v N/A 12port e000 12bus ID 02:00.0 12chip ID 10ec:b822
12IF wlp2s0 12state down 12mac <filter>
12Device-2 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
12vendor ASUSTeK 12driver r8169 12v kernel 12port d000 12bus ID 03:00.0
12chip ID 10ec:8168
12IF enp3s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Drives:
12Local Storage 12total 945.92 GiB 12used 149.60 GiB (15.8%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12vendor Toshiba 12model MQ04ABF100 12size 931.51 GiB 12block size
12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12serial <filter> 12rev 0J
12ID-2 /dev/sdb 12type USB 12vendor Kingston 12model DataTraveler 3.0 12size 14.41 GiB
12block size 12physical 512 B 12logical 512 B 12serial <filter>
12Partition:
12ID-1 / 12raw size 922.42 GiB 12size 906.94 GiB (98.32%) 12used 148.99 GiB (16.4%)
12fs ext4 12block size 4096 B 12dev /dev/sda2
12Swap:
12Alert No Swap data was found.
12Sensors:
12System Temperatures 12cpu 41.4 C 12mobo N/A
12Fan Speeds (RPM) 12cpu 2600
12GPU 12device nouveau 12temp 36.0 C 12device amdgpu 12temp 41.0 C
12Info:
12Processes 263 12Uptime 3h 10m 12Memory 6.80 GiB 12used 2.58 GiB (37.9%)
12Init systemd 12v 246 12Compilers 12gcc 10.2.0 12clang 11.0.0 12Packages 12pacman 1312
12lib 418 12flatpak 0 12Client Unknown Client: systemd 12inxi 3.1.08
It appears I have Kernel 5.6 but is just because I’m from a Live system *USB. On hard disk I have Kernel 5.9 and 5.4.
[manjaro@manjaro ~]$ mhwd -l && mhwd -li
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> 0000:01:00.0 (0302:10de:1c8d) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-440xx 2019.10.25 false PCI
video-nvidia-390xx 2019.10.25 false PCI
> 0000:04:00.0 (0300:1002:15dd) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
I try it from TTY3 and found that GRUB_CMDLINE_LINUX was already off (amd_iommu=off). I turn it on but nothing happen.
I’m also having this issue, on a recent HP Envy x360. Has anyone found a fix?
Here’s the output of journalctl from my last boot, in case it adds any more information:
https://pastebin.com/raw/JQe1ybR5
I have the same issue, with HP Probook 455 G7 – AMD Renior VGA.
Same issue on MSI Bravo 15 laptop. I’ve noticed that system boots fine when the laptop is connected to its power supply, but hangs when boot without it. Maybe the problem is related to energy management configuration.
xetra
15 March 2021 18:39
18
Same issue on Elitebook 845 G7. Laptop is unable to save brightness level properly as a result i think.
Kernel: 5.11.2-1-MANJARO
CPU: AMD Ryzen 7 PRO 4750U with Radeon Graphics (16) @ 1.700GHz
GPU: AMD ATI 03:00.0 Renoir
