Title pretty much explains the issue. I’m currently running Manjaro with i3wm on a Dell G15 Laptop, and when pressing fn+f6 / fn+f7, (the brightness down and up keys respectively,) the operating system doesn’t seem to receive the keydown/up signal in xinput test. I know for a fact that they work in windows, so it isn’t a hardware issue. I’ve been manually setting it with xrandr, but that’s tedious.
Sys info:
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=a4a28a95-b194-4d87-aa4f-0dec2500c0e4 rw quiet apparmor=1
security=apparmor resume=UUID=bd435fa8-9f6a-4f6c-a636-10bf41f23040
udev.log_priority=3
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: Dell G15 5510 v: N/A
Mobo: Dell model: 0J67YK v: A01 serial: <superuser required> UEFI: Dell
v: 1.20.0 date: 08/01/2023
ID-1: BAT0 charge: 8.1 Wh (19.6%) condition: 41.3/54.9 Wh (75.3%) volts: 10.7
min: 11.4 model: SMP DELL P8P1P95 type: Li-poly serial: <filter>
status: discharging
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 70421
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6720
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xed8f built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 15.04 GiB unified: yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.38 TiB used: 21.45 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Toshiba model: KBG40ZNS512G NVMe
KIOXIA 512GB size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 10410106
temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 30.9 C scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%) used: 13.48 GiB (9.4%)
fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2
ID-3: /home raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 7.97 GiB (8.3%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:4
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -3
dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 35.0 C pch: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 309 Uptime: 1d 17h 26m wakeups: 13 Memory: total: 16 GiB
note: est. available: 15.4 GiB used: 3.66 GiB (23.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1105 libs: 298 tools: pamac,yay Shell: Bash
v: 5.2.21 running-in: alacritty inxi: 3.3.31
Any help would be appreciated!
