Hello!
I’ve been trying to solve an issue with brightness for my laptop. I’m able to control the brightness using brightness-controller-git via AUR, but other native solutions, such as through the function keys and from the brightness option in the system tray don’t seem to do anything. The reported brightness % for those will adjust when I interact in when them, but the brightness stays the same.
I’ve tried many of the steps mentioned on arch wiki (Backlight - ArchWiki) but no luck so far. The laptop has intel and nvidia video and that’s maybe part of the issue? I also have the nvidia proprietary drivers loaded which could be part of it but wanted to check on forums for advice before trying to remove those and seeing if that helps out.
My main goal is to try to get proper brightness control through function keys and the system tray. This way I won’t have to use a separate application like brightness-controller, so I can in turn better battery life (just stays at 100% now) and try other background tools like clight.
Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: root=UUID=ccee3d16-0810-4142-afc7-a57634bcd5d4 rw quiet
cryptdevice=UUID=ad4f54fd-68ec-48ab-aa93-4ef78a7713f7:luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7
root=/dev/mapper/luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 splash
udev.log_priority=3 initrd=\initramfs-6.11-x86_64.img
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GU605MY_GU605MY
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GU605MY v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GU605MY.323
date: 08/14/2024
ID-1: BAT1 charge: 72.6 Wh (86.1%) condition: 84.3/89.8 Wh (93.9%)
volts: 16.2 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: discharging
System RAM: total: 32 GiB available: 30.76 GiB used: 5.16 GiB (16.8%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3KL9L90CM-MGCT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x1C
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: 24 MiB note: check
Speed (MHz): avg: 1914 min/max: 400/4800:5100:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1914 2: 1914 3: 1914
4: 1914 5: 1914 6: 1914 7: 1914 8: 1914 9: 1914 10: 1914 11: 1914 12: 1914
13: 1914 14: 1914 15: 1914 16: 1914 17: 1914 18: 1914 19: 1914 20: 1914
21: 1914 22: 1914 bogomips: 135212
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Device-2: NVIDIA GN21-X11 [GeForce RTX 4090 Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2757 class-ID: 0300
Device-3: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 3277:0051
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: Samsung ATNA60DL01-0 built: 2023 res: 2560x1600
hz: 240 dpi: 191 gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235
y: 0.725 blue: x: 0.137 y: 0.047 white: x: 0.314 y: 0.329
size: 340x220mm (13.39x8.66") diag: 405mm (15.9") modes: 2560x1600
EDID-Warnings: 1: parse_edid: unknown tag 112
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 15.02 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4090 Laptop GPU driver: nvidia v: 550.135 device-ID: 10de:2757
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Arc
Graphics (MTL) driver: mesa intel v: 24.2.7-arch1.1 device-ID: 8086:7d55
surfaces: xcb,xlib
Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:22bb class-ID: 0403
API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
class-ID: e001
Device-1: luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 maj-min: 254:0
type: LUKS dm: dm-0 size: 3.64 TiB
Components:
p-1: nvme1n1p3 maj-min: 259:8 size: 3.64 TiB
Local Storage: total: 7.28 TiB used: 663.19 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 37.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT4000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 51.9 C
scheme: GPT
ID-1: / raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 662.96 GiB (18.1%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 label: N/A
uuid: ccee3d16-0810-4142-afc7-a57634bcd5d4
ID-2: /boot raw-size: 1000 MiB size: 965.9 MiB (96.59%)
used: 227.8 MiB (23.6%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
label: N/A uuid: 10d6d172-d3ca-4830-81d0-84b61d4edd25
ID-3: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
used: 12.7 MiB (2.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
uuid: 8666-C110
ID-1: swap-1 type: file size: 32 GiB used: 707.5 MiB (2.2%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 3.64 TiB
fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 500 MiB fs: vfat label: N/A
uuid: 4622-C39B
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 791 MiB fs: ntfs label: N/A
uuid: B49476299475EDEC
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: ASUSTek ITE Device(8910) type: keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 3-7:3 info: Shinetech USB2.0 FHD UVC WebCam type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0051 class-ID: fe01
serial: <filter>
Device-3: 3-8:4 info: ASUSTek ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:193b class-ID: 0301
Device-4: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1900
Packages: pm: pacman pkgs: 1372 libs: 384 tools: pamac,yay pm: flatpak
pkgs: 0
1: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
3: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
4: http://manjaro.grena.ge/stable/$repo/$arch
5: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
6: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
7: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
8: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
9: https://mirror.funami.tech/manjaro/stable/$repo/$arch
10: https://mirrors.manjaro.org/repo/stable/$repo/$arch
11: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
12: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
14: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
15: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
16: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
17: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
18: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
19: http://mirror.fcix.net/manjaro/stable/$repo/$arch
20: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
22: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
23: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
24: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
25: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
27: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
28: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
29: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
30: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
31: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
32: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
33: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
34: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
35: https://mirror.zetup.net/manjaro/stable/$repo/$arch
36: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
37: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
40: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
41: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
43: https://mirror.23m.com/manjaro/stable/$repo/$arch
44: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
45: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
46: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://mirror.easyname.at/manjaro/stable/$repo/$arch
48: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
49: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
50: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
51: https://mirror.init7.net/manjaro/stable/$repo/$arch
52: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
53: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
54: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
55: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
56: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
57: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
58: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
59: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
60: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
61: https://mirror.koddos.net/manjaro/stable/$repo/$arch
62: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
63: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
65: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
67: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
68: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
69: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
70: https://manjaro.ynh.ovh/stable/$repo/$arch
71: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
73: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
74: https://manjaro.kurdy.org/stable/$repo/$arch
75: https://mirrors2.manjaro.org/stable/$repo/$arch
76: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
77: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
78: https://muug.ca/mirror/manjaro/stable/$repo/$arch
79: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
81: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
82: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
83: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
84: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
85: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
86: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
87: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 440
1: cpu: 23.7% command: baloo_file_extractor pid: 2445
mem: 288.2 MiB (0.9%)
2: cpu: 21.1% command: firefox pid: 1610 mem: 558.5 MiB (1.7%)
3: cpu: 7.9% command: firefox pid: 2483 mem: 300.9 MiB (0.9%)
4: cpu: 7.3% command: firefox pid: 3765 mem: 283.7 MiB (0.9%)
5: cpu: 5.9% command: kwin_x11 pid: 1241 mem: 196.6 MiB (0.6%)
Memory top: 5 of 440
1: mem: 558.5 MiB (1.7%) command: firefox pid: 1610 cpu: 21.1%
2: mem: 352.1 MiB (1.1%) command: plasmashell pid: 1268 cpu: 1.5%
3: mem: 347.7 MiB (1.1%) command: Discord pid: 2913 cpu: 3.5%
4: mem: 325.4 MiB (1.0%) command: spotify pid: 1657 cpu: 0.7%
5: mem: 300.9 MiB (0.9%) command: firefox pid: 2483 cpu: 7.9%
Processes: 440 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.27 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
