Hello, it may have been one of the recent updates, but when I am fullscreen gaming and change volume (and tghe volume bar is displayed), the screen turns black for 1-2s, then comes back, then briefly flashes black once more. It’s a bit irritating during gaming and I didn’t have this happen in the past. How can I troubleshoot?
Here is some info on my system:
inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=0682666e-fffe-4b1a-b090-07fe3179db9b rw amdgpu.freesync_video=1
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: L2.71 date: 04/14/2023
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: available: 15.54 GiB used: 6.01 GiB (38.7%)
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3037 high: 4583 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2262 2: 2873
3: 2848 4: 2376 5: 2251 6: 2267 7: 3673 8: 3313 9: 2200 10: 2200 11: 3667
12: 4576 13: 2361 14: 2871 15: 3463 16: 2394 17: 2200 18: 2200 19: 3653
20: 3661 21: 3665 22: 3673 23: 3669 24: 4583 bogomips: 177329
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 07:00.0
chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung Q90A serial: <filter>
built: 2021 res: 3840x2160 dpi: 52 gamma: 1.2 size: 1872x1053mm (73.7x41.46")
diag: 2148mm (84.6") ratio: 16:9 modes: max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.29-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 21.83 TiB used: 18.4 TiB (84.3%)
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624311WD temp: 58.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MG09ACA18TE
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 4301 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 2T00
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHOS104 rev: WL0B dev-links: cdrom
Features: speed: 32 multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 3.1 TiB (86.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0682666e-fffe-4b1a-b090-07fe3179db9b
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1C65-29A7
ID-3: /run/media/defunct/Media raw-size: 16.37 TiB
size: 16.37 TiB (100.00%) used: 13.77 TiB (84.1%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: Media uuid: 7416879916875ACE
ID-4: /run/media/defunct/Stash raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.54 TiB (85.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Stash
uuid: 294b0bf6-cf44-4d8d-908d-3a79dedb0da7
ID-1: swap-1 type: file size: 17.67 GiB used: 510.2 MiB (2.8%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
Device-1: 1-2:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 045e:0745 class-ID: 0300
Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-7.4:5 info: Genesys Logic Logilink CR0012 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05e3:0745 class-ID: 0806
serial: <filter>
Device-2: 1-8:4 info: ASRock LED Controller type: N/A driver: N/A rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 26ce:01a2
class-ID: 0000 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-6: 3-2.2:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-2.2.2:4 info: Microsoft Wireless XBox Controller Dongle
type: <vendor specific> driver: xone-dongle interfaces: 1 rev: 2.0
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Device-2: 3-2.2.3:5 info: Logitech Logi Bolt Receiver
chip-ID: 046d:c548 class-ID: 0300
Device-3: 3-2.2.4:6 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-9: 4-2.2:3 info: Genesys Logic hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0616
System Temperatures: cpu: 77.6 C mobo: N/A gpu: amdgpu temp: 71.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 764
Processes: 439 Uptime: 8h 36m wakeups: 37 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1568 pm: pacman pkgs: 1488 libs: 439 tools: pamac pm: flatpak
pkgs: 80 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
