Hi I want to create a bridge so I can communicate with my gns3 install.
I have tried but it does not really work and I wonder If someone could help me and see what is wrong?
so I want to create a bridge with 4 interfaces.
tap0, tap1, br0 and enp0s31f6 (the physical ethernet device).
I can not get the tap devices to “up” so that I can use them to connect to gns3.
e.g.
nmcli connection up tap0 INT ✘ 59s
Error: Connection activation failed: IP configuration could not be reserved (no available address, timeout, etc.)
Hint: use ‘journalctl -xe NM_CONNECTION=29983195-4775-4cf5-b9b0-13151c5e5ab3 + NM_DEVICE=tap0’ to get more details.
Here is how I created them:
nmcli connection add type tun ifname tap0 con-name tap0 mode tap ipv4.method auto
nmcli connection add type tun ifname tap1 con-name tap1 mode tap ipv4.method auto
nmcli connection add type bridge ifname br0 con-name br0 ipv4.method auto
nmcli con add type bridge-slave ifname tap0 master br0
nmcli con add type bridge-slave ifname tap1 master br0
nmcli con add type bridge-slave ifname enp0s31f6 master br0
then to disable the previous configuration and use the bridge instead:
nmcli con del "Wired connection 1"; nmcli con reload "br0" &
here is some diagnostics I did, ask if you need more:
nmcli connection show ✔
NAME UUID TYPE DEVICE
tap0 29983195-4775-4cf5-b9b0-13151c5e5ab3 tun tap0
tap1 29a28d57-a27e-4531-baaf-81ead0f82d05 tun tap1
br0 2753365d-9b24-4d42-95ba-873e4f23d97a bridge br0
lo f59be18a-9796-41a1-a5df-87ecb958e7a8 loopback lo
bridge-slave-enp0s31f6 1a2425ad-4121-41d8-bc5b-bddb0f5fc8e0 ethernet enp0s31f6
bridge-slave-tap0 19ba8861-c641-420e-9014-93d89edd6ccb ethernet --
bridge-slave-tap1 7d0434c5-bd2d-4e2b-a928-6a4816f1e879 ethernet --
something is wrong with the tap connection:
nmcli connection up bridge-slave-tap1 ✔
Error: Connection activation failed: No suitable device found for this connection (device enp0s31f6 not available because profile is not compatible with device (mismatching interface name)).
I wonder why not the tap devices show in the list?
nmcli device show 4 ✘
GENERAL.DEVICE: br0
GENERAL.TYPE: bridge
GENERAL.HWADDR: B2:51:A9:CE:D2:72
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.CONNECTION: br0
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/2
IP4.ADDRESS[1]: 192.168.88.239/24
IP4.GATEWAY: 192.168.88.1
IP4.ROUTE[1]: dst = 192.168.88.0/24, nh = 0.0.0.0, mt = 425
IP4.ROUTE[2]: dst = 0.0.0.0/0, nh = 192.168.88.1, mt = 425
IP4.DNS[1]: 1.1.1.1
IP6.ADDRESS[1]: fe80::7780:2263:88cd:edfa/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 1024
GENERAL.DEVICE: lo
GENERAL.TYPE: loopback
GENERAL.HWADDR: 00:00:00:00:00:00
GENERAL.MTU: 65536
GENERAL.STATE: 100 (connected (externally))
GENERAL.CONNECTION: lo
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/1
IP4.ADDRESS[1]: 127.0.0.1/8
IP4.GATEWAY: --
IP6.ADDRESS[1]: ::1/128
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = ::1/128, nh = ::, mt = 256
GENERAL.DEVICE: enp0s31f6
GENERAL.TYPE: ethernet
GENERAL.HWADDR: 70:8B:CD:56:03:05
GENERAL.MTU: 1500
GENERAL.CONNECTION: bridge-slave-enp0s31f6
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/5
WIRED-PROPERTIES.CARRIER: on
IP4.GATEWAY: --
IP6.GATEWAY: --
