alkl
October 1, 2022, 3:47pm
1
Greetings,
for quite some (1+ year) time I have been thinking about the Plasma Themes of Manjaro KDE.
If you look at the following screenshots, you will see what I mean by “Transparency different than original”.
Manjaro KDE Breeze-Dark - Live Session (same installed):
KDE Neon Breeze-Dark (and most/all of the other Distros) - Live Session:
Yes, I know that they aren’t technically the same KDE version, however this transparency/theming issue is preset for a very long time now
Changing settings in workspace effects doesn’t come anywhere close than the native breeze-dark theme.
This post is not meant to be pointing out an issue, it’s more like out of a cunfusion post, as finding similar posts with Google lead me to nowhere.
Is this an intended behavior?
Many Greetings
Hello,
alkl:
theming issue
Is not an issue, nor a feature … in order to get why it happens, check Settings > Workspace Behavior > Desktop Effects > Translucency and i bet you will see a difference, but that is as a choice by each distro team i guess …
On my end
But guess what? I disable it completely …
alkl
October 1, 2022, 4:09pm
3
Translucency seems to be disabled by both distros by default:
Manjaro KDE:
KDE Neon:
That setting doesn’t seem to have an effect on the transparency of the taskbar / kickoff applet.
Aham. I see. maybe related to Blur then !?!
alkl
October 1, 2022, 4:15pm
5
Nope.
Guess what I found:
Now Manjaro looks like this:
Case closed I guess xD
Edit: Maybe Manjaro could / should enable it by default, idk
Possible … mine is always disabled
Ben
October 2, 2022, 4:06am
7
bogdancovaciu:
Yes, I find it annoying that it bleeds all the yellow from the background across the settings window under the menu.
Leaving ‘contrast enhancement’ off gives a more subtle effect with the same problem, but more subtle and not annoying.
Having said that, I don’t use Breeze - I have ‘Utterly Round’ plasma style which has a nice amount of opacity (maybe 96% - not sure).
system
Closed
October 4, 2022, 6:07pm
8
