It happened after several update earlier. Have tried to reinstall breeze packages, clean .kwinrc, but no result.
Sorry, as a newby I can’t attach an image.
Hi @mjok,
You can put the link to the image between bacticks like this
Did you install from System Setting / Application Style / Window Decoration under the button Get new window decorations?
Regards,
https://imgur.com/a/nZgLGS3
Yes, I did. But it was after topics issue.
Hi @mjok,
Can you install another window decorations style, remove Breeze and reboot ?.
Then, try to install the breeze window decorations style again.
Hope it help
