Brave login session resetting after closing
I have noticed since the updates around 24.3.25 that the Brave Browser login Session is gone after closing Brave.
Even if “Delete browsing data / on exit” is not set.
I tested it with brave-browser-beta and on a fresh installed brave-browser
Also a thought brave-browser-beta should be ahead:
❯ sudo pacman -Sy ;yy brave-browser
 core is up to date
 extra is up to date
 multilib        146.5 KiB   360 KiB/s 00:00 [--------------------------------------------------------------------] 100%
2 extra/brave-browser-beta 1.78.69-1 [0 B 393.69 MiB] [Installed]
    Web browser that blocks ads and trackers by default (beta binary release).
1 extra/brave-browser 1.76.82-1 [0 B 388.38 MiB]
    Web browser that blocks ads and trackers by default (binary release)
:: Packages to install (eg: 1 2 3, 1-3):
And being confused that on the branch compare Page there are different versions as my mirror say’s:
branches
x64  ARM
Packages for query "brave" on x64 architecture.
2 results
Database last updated on: 2025-04-01 21:13:07 (UTC)
brave-browser
stable
:1.76.82-1
testing
:1.76.82-1
unstable
:1.76.82-1
brave-browser-beta
stable
:1.78.72-1
testing
:1.78.72-1
unstable
:1.78.72-1
There is a confirm fix on Version 1.78.72
Brave Forum
If the branch-compare page is different from your mirror - then your mirror may not be up-to-date. In such case you should rerun pacman-mirrors
sudo pacman-mirrors --continent
Using the mbn tool from manjaro-check-repos I get the same result as branch compare web.
07:26:20 ○ [fh@tiger] ~
 $ mbn info brave-browser-beta -q | grep -e 'Branch' -e 'Version'
Branch         : unstable
Version        : 1.78.72-1
Branch         : testing
Version        : 1.78.72-1
Branch         : stable
Version        : 1.78.72-1
07:28:53 ○ [fh@tiger] ~
 $ mbn info brave-browser -q | grep -e 'Branch' -e 'Version'
Branch         : unstable
Version        : 1.76.82-1
Branch         : testing
Version        : 1.76.82-1
Branch         : stable
Version        : 1.76.82-1
Thank you, I got the update today without.
So in future to get the updated mirror right away I need to run
instead of:
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
    sudo pacman-key --init
    sudo pacman -Syy
    sudo pacman-key --populate --populate archlinux manjaro
    sudo pacman-key -u --refresh-keys &&
        sudo pacman-mirrors -a -P https --fasttrack 22 &&
        sudo pacman -Syyu --disable-download-timeout
Also, I realize manjaro-check-repos is not on my System.
Problem solve on:
brave-browser-beta 1.78.72-1
i have the same problem. Just started with last update. I tried this version and i still have the issue. If i log into say youtube… close brave, then reopen it, it gives me an error that it could not log in. and i have to log in again. I tried the beta with same issue. Man i really dont want to abandon brave and go back to chrome.
edit:
moved to firefox with pwa plugin… I prefer brave, but until this is fixed, i cannot use it. it also happened in google chrome. with brand new profile and no extensions… so i am guessing a chromium bug at this point.
