To follow up on the message posted on the Brave forum, here is a bug that I encounter when downloading a file with brave.
When I type the new file name, the focus swith to the search file
Here the video
Summary
Thanks
Here the video
Thanks
This has nothing to do neither with Brave, nor with Manjaro. It has to do with xdg-desktop-portal
and/or depending what you installed from xdg-desktop-portal-gnome
or you installed the xdg-desktop-portal-gtk
… but my guess is that you have the former and might not act properly outside gnome shell. I might be wrong, but that is what you should investigate and try to use xdg-desktop-portal-gtk
and check the service for it to be enabled if you replace it.
Thanks
unfortunately I didn’t understand what I have to do or check.
I have manjaro cinnamon
hostnamectl
Kernel: Linux 5.17.15-1-MANJARO
Architecture: x86-64
But your right, i have the same error with vivaldi
Here a solution from cneeper
It’s works for me… by uninstalling xdg-desktop-portal and flatpack.
Why this package are useful by default ?
