I am unable to launch Brave Browser after clean install of Manjaro Gnome with Nvidia proprietary drivers.
How was it installed ?
If you launch from terminal … what is the output ?
Welcome to the forum! ![]()
First make sure you’re fully up to date. FYI, brave-browser 1.59.117-1 is now available in all branches.
As mentioned above, if you’re still having issues, please copy and paste the output running brave from the terminal using preformatted text.
Please also see:
Hello, I installed it with pamac. It is launching now after a reboot but still getting some errors:
brave ✔
[2228:2228:1016/155828.827975:ERROR:policy_logger.cc(154)] :components/enterprise/browser/controller/chrome_browser_cloud_management_controller.cc(163) Cloud management controller initialization aborted as CBCM is not enabled.
[2271:2271:1016/155828.962465:FATAL:gpu_init.cc(500)] Passthrough is not supported, GL is egl, ANGLE is
[2228:2228:1016/155832.832316:ERROR:gpu_process_host.cc(989)] GPU process exited unexpectedly: exit_code=133
[2488:2488:1016/155832.893471:FATAL:gpu_init.cc(500)] Passthrough is not supported, GL is egl, ANGLE is
[2228:2228:1016/155833.307743:ERROR:gpu_process_host.cc(989)] GPU process exited unexpectedly: exit_code=133
[2514:2514:1016/155833.358900:FATAL:gpu_init.cc(500)] Passthrough is not supported, GL is egl, ANGLE is
[2228:2228:1016/155833.762599:ERROR:gpu_process_host.cc(989)] GPU process exited unexpectedly: exit_code=133
[2523:2523:1016/155834.512625:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateContext: Requested GLES version (3.0) is greater than max supported (2, 0).
libva error: vaGetDriverNames() failed with unknown libva error
[2523:2523:1016/155834.592933:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateContext: Requested GLES version (3.0) is greater than max supported (2, 0).
This is version 1.58.137-1
