Hi everyone,
while trying to burn a file to a cdrom using an external dvd writer I encountered the following error:
“Error while burning. You do not have the required permission to use this drive”
Log:
Checking session consistency (brasero_burn_check_session_consistency brasero-burn.c:1739)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroLocalTrack called brasero_job_set_output_size_for_current_track
BraseroLocalTrack stopping
BraseroLocalTrack called brasero_job_get_session_output_size
BraseroLocalTrack called brasero_job_get_current_track
BraseroLocalTrack no remote URIs
BraseroChecksumFiles called brasero_job_get_output_type
BraseroChecksumFiles called brasero_job_get_current_track
BraseroChecksumFiles called brasero_job_get_action
BraseroChecksumFiles called brasero_job_set_output_size_for_current_track
BraseroChecksumFiles stopping
BraseroChecksumFiles called brasero_job_get_session_output_size
BraseroChecksumFiles called brasero_job_set_current_action
BraseroChecksumFiles called brasero_job_get_flags
BraseroChecksumFiles Adding graft for checksum file /.checksum.md5 file:///tmp/brasero_tmp_4MPQQ0.md5
BraseroChecksumFiles called brasero_job_add_track
BraseroChecksumFiles Finished track successfully
BraseroChecksumImage called brasero_job_get_current_track
BraseroChecksumImage called brasero_job_get_action
BraseroChecksumImage called brasero_job_get_flags
BraseroCDRecord called brasero_job_get_action
BraseroCDRecord creating input
BraseroCDRecord getting varg
BraseroCDRecord got varg:
BraseroCDRecord deactivating
BraseroChecksumImage creating input
BraseroChecksumImage called brasero_job_get_fd_in
BraseroChecksumImage deactivating
BraseroMkisofs called brasero_job_get_action
BraseroMkisofs getting varg
BraseroMkisofs called brasero_job_get_current_track
BraseroMkisofs called brasero_job_get_tmp_dir
BraseroMkisofs called brasero_job_get_data_label
BraseroMkisofs called brasero_job_get_flags
BraseroMkisofs called brasero_job_set_current_action
BraseroMkisofs got varg:
/usr/bin/mkisofs
-input-charset
utf8
-r
-J
-graft-points
-path-list
/tmp/brasero_tmp_25OSQ0
-exclude-list
/tmp/brasero_tmp_YYTSQ0
-V
Data disc (04 Sep 20)
-A
Brasero-3.12.2
-sysid
LINUX
-quiet
-print-size
BraseroMkisofs Launching command
BraseroMkisofs called brasero_job_get_fd_out
BraseroMkisofs called brasero_job_get_fd_in
BraseroMkisofs stdout: 5302
BraseroMkisofs called brasero_job_set_output_size_for_current_track
BraseroMkisofs stderr: HUP
BraseroMkisofs stdout: HUP
BraseroMkisofs process finished with status 0
BraseroMkisofs Finished track successfully
BraseroMkisofs called brasero_job_get_done_tracks
BraseroMkisofs stopping
BraseroCDRecord called brasero_job_get_bus_target_lun
BraseroCDRecord called brasero_job_get_flags
BraseroCDRecord called brasero_job_get_speed
BraseroCDRecord called brasero_job_get_input_type
BraseroCDRecord called brasero_job_get_fd_in
BraseroCDRecord called brasero_job_get_session_output_size
BraseroCDRecord called brasero_job_set_current_action
cdrecord
-v
dev=/dev/sr0
gracetime=0
speed=24
driveropts=burnfree
fs=4m
tsize=5302s
-data
-nopad
BraseroCDRecord Launching command
BraseroCDRecord called brasero_job_get_fd_out
BraseroChecksumImage linked to BraseroCDRecord
BraseroMkisofs linked to BraseroChecksumImage
BraseroChecksumImage called brasero_job_get_input_type
BraseroChecksumImage called brasero_job_set_current_actionBraseroMkisofs called brasero_job_get_fd_out
BraseroChecksumImage called brasero_job_get_fd_inBraseroMkisofs called brasero_job_set_current_action
BraseroChecksumImage Starting checksum generation live (size = 0)
BraseroMkisofs got varg:BraseroChecksumImage called brasero_job_set_nonblocking
/usr/bin/mkisofsBraseroChecksumImage called brasero_job_get_fd_in
-input-charset
BraseroChecksumImage called brasero_job_get_fd_out utf8
BraseroChecksumImage called brasero_job_get_fd_in -r
BraseroChecksumImage called brasero_job_get_fd_out -J
-graft-points
-path-list
/tmp/brasero_tmp_WOUGQ0
-exclude-list
/tmp/brasero_tmp_HRUGQ0
-V
-A
Brasero-3.12.2
-sysid
LINUX
BraseroCDRecord stderr: cdrecord: No write mode specified.
BraseroCDRecord stderr: cdrecord: Assuming -sao mode.
BraseroCDRecord stderr: cdrecord: If your drive does not accept -sao, try -tao.
BraseroCDRecord stderr: cdrecord: Future versions of cdrecord may have different drive dependent defaults.
BraseroCDRecord stderr: cdrecord: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.
BraseroCDRecord stderr: cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2).
BraseroCDRecord stderr: cdrecord: WARNING: This causes a high risk for buffer underruns.
BraseroCDRecord stderr: cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler.
BraseroCDRecord stderr: cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
BraseroCDRecord stderr: cdrecord: Insufficient 'file read' privileges. You will not be able to open all needed devices.
BraseroCDRecord stderr: cdrecord: Insufficient 'file write' privileges. You will not be able to open all needed devices.
BraseroCDRecord stderr: cdrecord: Insufficient 'device' privileges. You may not be able to send all needed SCSI commands, this my cause various unexplainable problems.
BraseroCDRecord stderr: cdrecord: Insufficient 'memlock' privileges. You may get buffer underruns.
BraseroCDRecord stderr: cdrecord: Insufficient 'priocntl' privileges. You may get buffer underruns.
BraseroCDRecord stderr: cdrecord: Insufficient 'network' privileges. You will not be able to do remote SCSI.
BraseroCDRecord stderr: scsidev: '/dev/sr0'
BraseroCDRecord stderr: devname: '/dev/sr0'
BraseroCDRecord stderr: scsibus: -2 target: -2 lun: -2
BraseroCDRecord stderr: Warning: Open by 'devname' is unintentional and not supported.
BraseroCDRecord stderr: Linux sg driver version: 3.5.27
BraseroCDRecord stderr: SCSI buffer size: 64512
BraseroCDRecord stderr: cdrecord: Warning: Cannot read drive buffer.
BraseroCDRecord stderr: cdrecord: Warning: The DMA speed test has been skipped.
BraseroCDRecord stdout: Cdrecord-ProDVD-ProBD-Clone 3.02a09 (x86_64-unknown-linux-gnu) Copyright (C) 1995-2016 Joerg Schilling
BraseroCDRecord stdout: TOC Type: 1 = CD-ROM
BraseroCDRecord stdout: Using libscg version 'schily-0.9'.
BraseroCDRecord stdout: Driveropts: 'burnfree'
BraseroCDRecord stdout: atapi: 1
BraseroCDRecord stdout: Device type : Removable CD-ROM
BraseroCDRecord stdout: Version : 0
BraseroCDRecord stdout: Response Format: 2
BraseroCDRecord stdout: Capabilities :
BraseroCDRecord stdout: Vendor_info : 'TSSTcorp'
BraseroCDRecord stdout: Identifikation : 'CDDVDW SE-208DB '
BraseroCDRecord stdout: Revision : 'MF00'
BraseroCDRecord stdout: Device seems to be: Generic mmc2 DVD-R/DVD-RW/DVD-RAM.
BraseroCDRecord stdout: Current: CD-R
BraseroCDRecord stdout: Profile: DVD-R/DL sequential recording
BraseroCDRecord stdout: Profile: DVD-R/DL layer jump recording
BraseroCDRecord stdout: Profile: DVD+R/DL
BraseroCDRecord stdout: Profile: DVD+RW
BraseroCDRecord stdout: Profile: DVD-RW sequential recording
BraseroCDRecord stdout: Profile: DVD-RW restricted overwrite
BraseroCDRecord stdout: Profile: DVD-RAM
BraseroCDRecord stdout: Profile: DVD-R sequential recording
BraseroCDRecord stdout: Profile: DVD-ROM
BraseroCDRecord stdout: Profile: CD-RW
BraseroCDRecord stdout: Profile: CD-R (current)
BraseroCDRecord stdout: Profile: CD-ROM
BraseroCDRecord stdout: Profile: Removable Disk
BraseroCDRecord stdout: Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
BraseroCDRecord stdout: Driver flags : MMC-3 SWABAUDIO BURNFREE
BraseroCDRecord stdout: Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
BraseroCDRecord stdout: Drive buf size : 554400 = 541 KB
BraseroCDRecord stdout: FIFO size : 4194304 = 4096 KB
BraseroCDRecord stderr: cdrecord: Operation not permitted. rezero unit: scsi sendcmd: fatal error
BraseroCDRecord stderr: CDB: 01 00 00 00 00 00
BraseroCDRecord stdout: Track 01: data 10 MB
BraseroCDRecord stderr: cdrecord: Operation not permitted. Cannot send SCSI cmd via ioctl.
BraseroCDRecord called brasero_job_error
BraseroCDRecord finished with an error
BraseroCDRecord asked to stop because of an error
error = 4
message = "You do not have the required permissions to use this drive"
BraseroMkisofs got killed
BraseroMkisofs disconnecting BraseroMkisofs from BraseroChecksumImage
BraseroChecksumImage stopping
BraseroChecksumImage disconnecting BraseroChecksumImage from BraseroCDRecord
BraseroChecksumImage closing connection for BraseroChecksumImage
BraseroCDRecord stopping
BraseroCDRecord got killed
BraseroCDRecord stdout: Total size: 11 MB (01:10.69) = 5302 sectors
BraseroCDRecord stdout: Lout start: 12 MB (01:12/52) = 5302 sectors
BraseroCDRecord closing connection for BraseroCDRecord
Session error : You do not have the required permissions to use this drive (brasero_burn_record brasero-burn.c:2854)
If you need more information let me know.
Thanks for any help in advance!
