Riding the struggle bus here fam. Assistance would be appreciated getting the secondary monitors working. <3
Hardware:
Manjaro (latest)
2 Graphics Cards
Main: GeForce 2080ti
Primary Monitor BENQ (working great)
Secondary: GeForce 1080
Secondary Monitor HP VH240A
No used off brand monitor for teleprompter
lspci | grep VGA
03:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1080] (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1)
lsmod | grep "kms\|drm"
nvidia_drm 69632 12
nvidia_modeset 1200128 16 nvidia_drm
drm_kms_helper 270336 1 nvidia_drm
cec 69632 1 drm_kms_helper
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
drm 569344 16 drm_kms_helper,nvidia,nvidia_drm
agpgart 53248 1 drm
find /dev -group video
/dev/dri/card1
/dev/dri/card0
/dev/fb0
cat /proc/cmdline
BBOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=01f054dd-31bf-4824-8eb2-a9293df1b0e4 rw quiet cryptdevice=UUID=e87d06c2-e480-46f9-8e3c-112c14de88c2:luks-e87d06c2-e480-46f9-8e3c-112c14de88c2 root=/dev/mapper/luks-e87d06c2-e480-46f9-8e3c-112c14de88c2 apparmor=1 security=apparmor udev.log_priority=3
find /etc/modprobe.d/
/etc/modprobe.d/
/etc/modprobe.d/mhwd-gpu.conf
cat /etc/modprobe.d/*kms*
cat: '/etc/modprobe.d/*kms*': No such file or directory
ls -la /etc/X11/xorg.conf.d
total 16
drwxr-xr-x 2 root root 4096 Jul 23 17:15 .
drwxr-xr-x 5 root root 4096 Jul 23 15:04 ..
-rw-r--r-- 1 root root 232 Jul 21 14:30 00-keyboard.conf
-rw-r--r-- 1 root root 131 Jun 14 10:04 30-touchpad.conf
lrwxrwxrwx 1 root root 27 Jul 23 17:15 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
glxinfo | grep -i "vendor\|rendering"
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
grep LoadModule /var/log/Xorg.0.log
[ 250.586] (II) LoadModule: "glx"
[ 250.587] (II) LoadModule: "nvidia"
[ 250.587] (II) LoadModule: "fb"
[ 250.588] (II) LoadModule: "wfb"
[ 250.588] (II) LoadModule: "ramdac"
[ 250.588] (II) LoadModule: "glxserver_nvidia"
[ 251.102] (II) LoadModule: "dri2"
[ 251.125] (II) LoadModule: "dri2"
[ 251.161] (II) LoadModule: "libinput"
xrandr -q
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
1920x1080 60.00*+ 144.00 119.98 99.93 59.94 50.00
1440x900 119.85
1280x1024 75.02
1280x960 99.78
1280x720 60.00 59.94 50.00
1024x768 119.99 75.03 60.00
800x600 119.97 99.66 75.00 60.32
720x576 50.00
720x480 59.94
640x480 119.52 99.77 75.00 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
DVI-D-1-0 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
HDMI-1-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 60.00 59.94 50.00 23.98 60.00 50.04
1680x1050 59.95
1360x768 60.02
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 connected (normal left inverted right x axis y axis)
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 connected (normal left inverted right x axis y axis)
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
1920x1080 (0x1be) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1c2) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c3) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1280x720 (0x1c7) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c8) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1c9) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x1cc) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d0) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1d1) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d2) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d6) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d7) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
inxi -Fazy
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-GamingG1 v: N/A
serial: <filter>
Mobo: Gigabyte model: Z170X-GamingG1 v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F21 date: 03/06/2017
Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 8 MiB
bogomips: 64026
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:1b80 class-ID: 0300
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 04:00.0
chip-ID: 10de:1e07 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: NVIDIA TU102 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 04:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-4: SteelSeries ApS Arctis Pro Wireless type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.1.1.3:15
chip-ID: 1038:1294 class-ID: 0300
Device-5: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB
driver: snd-usb-audio bus-ID: 1-5.1.3:12 chip-ID: 1235:8202 class-ID: 0102
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
<redacted>
<redacted>
<redacted>
<redacted>
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 258 Uptime: 12m wakeups: 1 Memory: 62.77 GiB
used: 1.98 GiB (3.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1299 lib: 339 flatpak: 0 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x377 cap: 0x2, Sink Output crtcs: 4 outputs: 7 associated providers: 1 name:NVIDIA-G0
nvidia-smi
Fri Jul 23 17:32:03 2021
| NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:03:00.0 Off | N/A |
| 0% 41C P8 8W / 180W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce ... Off | 00000000:04:00.0 On | N/A |
| 41% 39C P8 19W / 260W | 300MiB / 11018MiB | 7% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 3029 G /usr/lib/Xorg 4MiB |
| 1 N/A N/A 3029 G /usr/lib/Xorg 138MiB |
| 1 N/A N/A 3144 G /usr/bin/kwin_x11 81MiB |
| 1 N/A N/A 3186 G /usr/bin/plasmashell 45MiB |
| 1 N/A N/A 4128 G /usr/bin/kcmshell5 3MiB |
| 1 N/A N/A 4244 G ...AAAAAAAAA= --shared-files 25MiB |
What I’ve done so far on this attempt
- Fresh manjaro install with free drivers. All monitors working.
- sudo pacman -Syyu - rebooted
- Did the auto install proprietary driver – rebooted
- Benq monitor (primary) on the 2080 card comes up. Others do not.
- Tried activating other monitors through Display Configuration utility, nothing happens when I apply changes and when I reopen it changes were not saved.
- Tried activating other monitors through nvidia-settings utility ran under sudo. Saved X configuration to file in my home directory and copy-paste replaced the contents of /etc/X11/xorg.conf.d/0-mhwd.conf with it… I noticed that file was symlinked to /etc/X11/mhwd.d/nvidia.conf so I was hoping that would do the trick. No dice.
Contents of that file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 470.57.02
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
Screen 2 "Screen2" RightOf "Screen1"
Screen 3 "Screen3" RightOf "Screen2"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "BenQ XL2720Z"
HorizSync 30.0 - 160.0
VertRefresh 56.0 - 144.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "HPN HP VH240a"
HorizSync 30.0 - 80.0
VertRefresh 50.0 - 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor3"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 2080 Ti"
BusID "PCI:4:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "NVIDIA GeForce GTX 1080"
BusID "PCI:3:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device2"
Driver "nvidia"
BusID "PCI:3:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device3"
Driver "nvidia"
BusID "PCI:3:0:0"
Screen 2
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-1-0: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-1-1: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Device3"
Monitor "Monitor3"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-1-3: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Thank you in advanced for any assistance you can provide. <3
