I’m trying to use a domotic application (Velbuslink).
When using Bottles, I’ve best results but still have problem to display it.
Here is the GIF capture…
Settings are:
Runner = soda-7.0-9 (won’t work with soda-9.0-1 or caffe-9.7 or others engines)
DXVK = dxvk-1.10.3
Virtual Desk seems a little bit better
Manjaro version is:
lsb_release -a
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 24.0.6
Codename: Wynsdey
Graphic hybrid card:
inxi -G ✔
Device-1: Intel CometLake-H GT2 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] driver: nvidia
v: 550.107.02
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1 driver: X:
loaded: modesetting,nvidia unloaded: nouveau dri: iris gpu: i915 resolution:
1: 2560x1080~60Hz 2: 1920x1080~144Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
renderer: Mesa Intel UHD Graphics (CML GT2)
API: Vulkan v: 1.3.279 drivers: nvidia,intel surfaces: xcb,xlib
Console error log:
002c:err:wineboot:process_run_key Error running cmd L"C:\\windows\\system32\\winemenubuilder.exe -r" (126).
00e8:err:system:NtUserChangeDisplaySettings Changing L"\\\\.\\DISPLAY2" display settings returned -2.
00e8:err:explorer:initialize_display_settings Failed to initialize registry display settings for L"\\\\.\\DISPLAY2".
00e0:err:msvcrt:_wassert (L"pellip->under == 0 && pellip->after == 0",L"dlls/user32/text.c",746)
Has someone already have the same problem with any application?
