Perhaps my CPU is too old (ADM Phenom II - no sse3, no avx, of course no avx2, too)
There may be another problem.
Downgrading to libotan-3.so.10, as well as to Thunderbird and KeepassXC, works again.
Without Downgrading KeepassXC too, KeepassXC says: error while loading shared libraries: libotan-3.so.11 cannot open shared object file: No such file or directory
My System:
Arch Manjaro, Last LTS Kernel, Xfce, X11, Nvidia 470 driver, ADM Phenom II x4 965
Please post at least the result of inxi -zv8 so we get more info about your system.
When posting the info, either put three backticks ( ` -sign) on an empty line before and after it, or paint over the text and then press “preformatted text” </> from the post toolbar. With long entries, you might also want to use “hide details” on it from behind the + -button on the toolbar to make the post more manageable.
I will add below a forum guide, and recommend you take the time to go through it.
Manjaro Forum guide
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a at their disposal – Instead, please help others to ask informed questions, based on information you provide.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
