Boots into black screen
Hi manjaro-community :slight_smile:
I hope someone can help me: I just recently installed manjaro-xfce on my notebook. The installation went smoothly and also a first boot into the newly installed system worked.
I then worked a little with the notebook and shut it down again afterwards.
When I start it now, I only get a black screen.
I suspect the problem is with the X server.
Data of the notebook:
TUXEDO Polaris 15
AMD Ryzen 7 4800H
NVIDIA GeForce RTX 2060
Full-HD IPS matte 144Hz
> [    11.237]
XOrg X Server 1.20.10
[    11.237] Build Operating System: Linux Manjaro Linux
[    11.237] Current Operating System: Linux finqin 5.10.26-1-MANJARO #1 SMP PREEMPT Thu Mar 25 16:56:17 UTC 2021 x86_64
[    11.237] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a874112e-4958-46ec-816a-eb23381a7cc3 rw quiet cryptdevice=UUID=10a5f69e-96b6-4721-9312-5a1da09f07cf:luks-10a5f69e-96b6-4721-9312-5a1da09f07cf root=/dev/mapper/luks-10a5f69e-96b6-4721-9312-5a1da09f07cf apparmor=1 security=apparmor resume=/dev/mapper/luks-06034c2b-3fbc-47d9-8c92-d7924a0c2400 udev.log_priority=3
[    11.237] Build Date: 16 December 2020  10:33:32PM
[    11.237]
[    11.237] Current version of pixman: 0.40.0
[    11.237] 	Before reporting problems, check http//wikixorg
[    11.237] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.237] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 10 20:51:22 2021
[    11.238] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.238] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.238] (==) No Layout section.  Using the first Screen section.
[    11.238] (==) No screen section available. Using defaults.
[    11.238] (**) |-->Screen "Default Screen Section" (0)
[    11.238] (**) |   |-->Monitor "<default monitor>"
[    11.238] (==) No monitor specified for screen "Default Screen Section".
[    11.238] (==) Automatically adding devices
[    11.238] (==) Automatically enabling devices
[    11.238] (==) Automatically adding GPU devices
[    11.238] (==) Automatically binding GPU devices
[    11.238] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.238] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    11.238] 	Entry deleted from font path.
[    11.238] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    11.238] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    11.238] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    11.238] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    11.238] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.238] (II) The server relies on udev to provide the list of input devices.
[    11.238] (II) Module ABI versions:
[    11.238] 	XOrg ANSI C Emulation: 0.4
[    11.238] 	XOrg Video Driver: 24.1
[    11.238] 	XOrg XInput driver : 24.1
[    11.238] 	XOrg Server Extension : 10.0
[    11.239] (++) using VT number 7
[    11.239] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.240] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.243] (--) PCI: (1@0:0:0) 10de:1f15:1d05:1100 rev 161, Mem @ 0xfb000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[    11.243] (--) PCI:*(6@0:0:0) 1002:1636:1d05:1100 rev 198, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[    11.243] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    11.243] (II) LoadModule: "glx"
[    11.244] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.245] (II) Module glx: vendor="XOrg Foundation"
[    11.245] 	compiled for 1.20.10, module version = 1.0.0
[    11.245] 	ABI class: XOrg Server Extension, version 10.0
[    11.245] (==) Matched nouveau as autoconfigured driver 0
[    11.245] (==) Matched nv as autoconfigured driver 1
[    11.245] (==) Matched ati as autoconfigured driver 2
[    11.245] (==) Matched modesetting as autoconfigured driver 3
[    11.245] (==) Matched fbdev as autoconfigured driver 4
[    11.245] (==) Matched vesa as autoconfigured driver 5
[    11.245] (==) Assigned the driver to the xf86ConfigLayout
[    11.245] (II) LoadModule: "nouveau"
[    11.245] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    11.245] (II) Module nouveau: vendor="XOrg Foundation"
[    11.245] 	compiled for 1.20.10, module version = 1.0.17
[    11.245] 	Module class: XOrg Video Driver
[    11.245] 	ABI class: XOrg Video Driver, version 24.1
[    11.245] (II) LoadModule: "nv"
[    11.245] (WW) Warning, couldn't open module nv
[    11.245] (EE) Failed to load module "nv" (module does not exist, 0)
[    11.245] (II) LoadModule: "ati"
[    11.246] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    11.246] (II) Module ati: vendor="XOrg Foundation"
[    11.246] 	compiled for 1.20.8, module version = 19.1.0
[    11.246] 	Module class: XOrg Video Driver
[    11.246] 	ABI class: XOrg Video Driver, version 24.1
[    11.246] (II) LoadModule: "radeon"
[    11.246] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[    11.247] (II) Module radeon: vendor="XOrg Foundation"
[    11.247] 	compiled for 1.20.8, module version = 19.1.0
[    11.247] 	Module class: XOrg Video Driver
[    11.247] 	ABI class: XOrg Video Driver, version 24.1
[    11.247] (II) LoadModule: "modesetting"
[    11.247] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.247] (II) Module modesetting: vendor="XOrg Foundation"
[    11.247] 	compiled for 1.20.10, module version = 1.20.10
[    11.247] (II) LoadModule: "fbdev"
[    11.247] (WW) Warning, couldn't open module fbdev
[    11.247] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    11.247] (II) LoadModule: "vesa"
[    11.248] (WW) Warning, couldn't open module vesa
[    11.248] (EE) Failed to load module "vesa" (module does not exist, 0)
[    11.248] (II) NOUVEAU driver
[    11.248] (II) NOUVEAU driver for NVIDIA chipset families :
[    11.248] 	RIVA TNT            (NV04)
[    11.248] 	RIVA TNT2           (NV05)
[    11.248] 	GeForce 256         (NV10)
[    11.248] 	GeForce 2           (NV11, NV15)
[    11.248] 	GeForce 4MX         (NV17, NV18)
[    11.248] 	GeForce 3           (NV20)
[    11.248] 	GeForce 4Ti         (NV25, NV28)
[    11.248] 	GeForce FX          (NV3x)
[    11.248] 	GeForce 6           (NV4x)
[    11.248] 	GeForce 7           (G7x)
[    11.248] 	GeForce 8           (G8x)
[    11.248] 	GeForce 9           (G9x)
[    11.248] 	GeForce GTX 2xx/3xx (GT2xx)
[    11.248] 	GeForce GTX 4xx/5xx (GFxxx)
[    11.248] 	GeForce GTX 6xx/7xx (GKxxx)
[    11.248] 	GeForce GTX 9xx     (GMxxx)
[    11.248] 	GeForce GTX 10xx    (GPxxx)
[    11.248] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[    11.251] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.251] (WW) Falling back to old probe method for modesetting
[    11.251] (II) modeset(1): using default device
[    11.251] (II) [drm] nouveau interface version: 1.3.1
[    11.251] (EE) Unknown chipset: NV166
[    11.252] (II) modeset(G0): using drv /dev/dri/card0
[    11.252] (EE) Screen 0 deleted because of no matching config section.
[    11.252] (II) UnloadModule: "modesetting"
[    11.252] (EE)
Fatal server error:
[    11.252] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[    11.252] (EE)
[    11.252] (EE)
Please consult the The XOrg Foundation support
	 at http//wikixorg
 for help.
[    11.252] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    11.252] (EE)
[    11.281] (EE) Server terminated with error (1). Closing log file.
Hello and welcome to the forum,
Can you try to switch the TTY to tty2 ?
Ctrl+Alt+F2
This should show you CLI then can you try to run startx and see if it runs ?
This have helped me with AMD Radeon issue.
Try this and let us know in this thread.
Hi and thanks for your answer.
The “startx” really brought up the GUI. I could work then. After rebooting the machine, same problem. I rebooted the machine several times and sometimes it would come up with GUI and sometimes not.
I think i have a “good” log now. See here:
[    11.307]
[    11.308] Build Operating System: Linux Manjaro Linux
[    11.308] Current Operating System: Linux finqin 5.10.26-1-MANJARO #1 SMP PREEMPT Thu Mar 25 16:56:17 UTC 2021 x86_64
[    11.308] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a874112e-4958-46ec-816a-eb23381a7cc3 rw quiet cryptdevice=UUID=10a5f69e-96b6-4721-9312-5a1da09f07cf:luks-10a5f69e-96b6-4721-9312-5a1da09f07cf root=/dev/mapper/luks-10a5f69e-96b6-4721-9312-5a1da09f07cf apparmor=1 security=apparmor resume=/dev/mapper/luks-06034c2b-3fbc-47d9-8c92-d7924a0c2400 udev.log_priority=3
[    11.308] Build Date: 16 December 2020  10:33:32PM
[    11.308]
[    11.308] Current version of pixman: 0.40.0
[    11.308] 	Before reporting problems, check http//wikixorg
[    11.308] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.308] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 10 20:51:22 2021
[    11.308] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.308] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.309] (==) No Layout section.  Using the first Screen section.
[    11.309] (==) No screen section available. Using defaults.
[    11.309] (**) |-->Screen "Default Screen Section" (0)
[    11.310] (**) |   |-->Monitor "<default monitor>"
[    11.312] (==) No monitor specified for screen "Default Screen Section".
[    11.312] (==) Automatically adding devices
[    11.312] (==) Automatically enabling devices
[    11.312] (==) Automatically adding GPU devices
[    11.312] (==) Automatically binding GPU devices
[    11.312] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.312] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    11.312] 	Entry deleted from font path.
[    11.312] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    11.312] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    11.312] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    11.313] (==) FontPath set to:
[    11.313] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.313] (II) The server relies on udev to provide the list of input devices.
[    11.313] (II) Module ABI versions:
[    11.313] 	XOrg ANSI C Emulation: 0.4
[    11.313] 	XOrg Video Driver: 24.1
[    11.313] 	XOrg XInput driver : 24.1
[    11.313] 	XOrg Server Extension : 10.0
[    11.314] (++) using VT number 7
[    11.314] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.315] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.315] (II) xfree86: Adding drm device (/dev/dri/card1)
[    11.324] (--) PCI: (1@0:0:0) 10de:1f15:1d05:1100 rev 161, Mem @ 0xfb000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[    11.324] (--) PCI:*(6@0:0:0) 1002:1636:1d05:1100 rev 198, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[    11.324] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    11.324] (II) LoadModule: "glx"
[    11.325] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.326] (II) Module glx: vendor="XOrg Foundation"
[    11.326] 	compiled for 1.20.10, module version = 1.0.0
[    11.326] 	ABI class: XOrg Server Extension, version 10.0
[    11.326] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[    11.326] 	loading driver: amdgpu
[    11.326] (==) Matched amdgpu as autoconfigured driver 0
[    11.326] (==) Matched ati as autoconfigured driver 1
[    11.326] (==) Matched nouveau as autoconfigured driver 2
[    11.326] (==) Matched nv as autoconfigured driver 3
[    11.326] (==) Matched modesetting as autoconfigured driver 4
[    11.326] (==) Matched fbdev as autoconfigured driver 5
[    11.326] (==) Matched vesa as autoconfigured driver 6
[    11.326] (==) Assigned the driver to the xf86ConfigLayout
[    11.326] (II) LoadModule: "amdgpu"
[    11.326] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    11.328] (II) Module amdgpu: vendor="XOrg Foundation"
[    11.328] 	compiled for 1.20.8, module version = 19.1.0
[    11.328] 	Module class: XOrg Video Driver
[    11.328] 	ABI class: XOrg Video Driver, version 24.1
[    11.328] (II) LoadModule: "ati"
[    11.329] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    11.329] (II) Module ati: vendor="XOrg Foundation"
[    11.329] 	compiled for 1.20.8, module version = 19.1.0
[    11.329] 	Module class: XOrg Video Driver
[    11.329] 	ABI class: XOrg Video Driver, version 24.1
[    11.334] (II) LoadModule: "nouveau"
[    11.334] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    11.335] (II) Module nouveau: vendor="XOrg Foundation"
[    11.335] 	compiled for 1.20.10, module version = 1.0.17
[    11.335] 	Module class: XOrg Video Driver
[    11.335] 	ABI class: XOrg Video Driver, version 24.1
[    11.335] (II) LoadModule: "nv"
[    11.335] (WW) Warning, couldn't open module nv
[    11.335] (EE) Failed to load module "nv" (module does not exist, 0)
[    11.335] (II) LoadModule: "modesetting"
[    11.335] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.335] (II) Module modesetting: vendor="XOrg Foundation"
[    11.335] 	compiled for 1.20.10, module version = 1.20.10
[    11.335] (II) LoadModule: "fbdev"
[    11.335] (WW) Warning, couldn't open module fbdev
[    11.335] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    11.335] (II) LoadModule: "vesa"
[    11.335] (WW) Warning, couldn't open module vesa
[    11.335] (EE) Failed to load module "vesa" (module does not exist, 0)
[    11.335] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[    11.335] (II) NOUVEAU driver
[    11.335] (II) NOUVEAU driver for NVIDIA chipset families :
[    11.335] 	RIVA TNT            (NV04)
[    11.335] 	RIVA TNT2           (NV05)
[    11.335] 	GeForce 256         (NV10)
[    11.335] 	GeForce 2           (NV11, NV15)
[    11.335] 	GeForce 4MX         (NV17, NV18)
[    11.335] 	GeForce 3           (NV20)
[    11.335] 	GeForce 4Ti         (NV25, NV28)
[    11.335] 	GeForce FX          (NV3x)
[    11.335] 	GeForce 6           (NV4x)
[    11.335] 	GeForce 7           (G7x)
[    11.335] 	GeForce 8           (G8x)
[    11.335] 	GeForce 9           (G9x)
[    11.335] 	GeForce GTX 2xx/3xx (GT2xx)
[    11.335] 	GeForce GTX 4xx/5xx (GFxxx)
[    11.335] 	GeForce GTX 6xx/7xx (GKxxx)
[    11.335] 	GeForce GTX 9xx     (GMxxx)
[    11.335] 	GeForce GTX 10xx    (GPxxx)
[    11.335] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.335] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[    11.336] (WW) Falling back to old probe method for modesetting
[    11.337] (II) [drm] nouveau interface version: 1.3.1
[    11.337] (EE) Unknown chipset: NV166
[    11.337] (II) modeset(G0): using drv /dev/dri/card0
[    11.337] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    11.337] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[    11.337] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    11.337] (==) AMDGPU(0): Default visual is TrueColor
[    11.337] (==) AMDGPU(0): RGB weight 888
[    11.337] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[    11.337] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[    11.337] (II) Loading sub module "fb"
[    11.337] (II) LoadModule: "fb"
[    11.337] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.338] (II) Module fb: vendor="XOrg Foundation"
[    11.338] 	compiled for 1.20.10, module version = 1.0.0
[    11.338] 	ABI class: XOrg ANSI C Emulation, version 0.4
[    11.338] (II) Loading sub module "dri2"
[    11.338] (II) LoadModule: "dri2"
[    11.338] (II) Module "dri2" already built-in
[    11.491] (II) Loading sub module "glamoregl"
[    11.491] (II) LoadModule: "glamoregl"
[    11.491] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.495] (II) Module glamoregl: vendor="XOrg Foundation"
[    11.495] 	compiled for 1.20.10, module version = 1.0.1
[    11.495] 	ABI class: XOrg ANSI C Emulation, version 0.4
[    11.512] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.40.0, 5.10.26-1-MANJARO, LLVM 11.1.0)
[    11.512] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[    11.512] (==) AMDGPU(0): TearFree property default: auto
[    11.512] (==) AMDGPU(0): VariableRefresh: disabled
[    11.512] (II) AMDGPU(0): KMS Pageflipping: enabled
[    11.513] (II) AMDGPU(0): Output eDP has no monitor section
[    11.515] (II) AMDGPU(0): EDID for output eDP
[    11.515] (II) AMDGPU(0): Manufacturer: BOE  Model: 84d  Serial#: 0
[    11.515] (II) AMDGPU(0): Year: 2018  Week: 1
[    11.515] (II) AMDGPU(0): EDID Version: 1.4
[    11.515] (II) AMDGPU(0): Digital Display Input
[    11.515] (II) AMDGPU(0): 8 bits per channel
[    11.515] (II) AMDGPU(0): Digital interface is DisplayPort
[    11.515] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    11.515] (II) AMDGPU(0): Gamma: 2.20
[    11.515] (II) AMDGPU(0): No DPMS capabilities specified
[    11.515] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[    11.515] (II) AMDGPU(0): First detailed timing is preferred mode
[    11.515] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[    11.515] (II) AMDGPU(0): redX: 0.640 redY: 0.329   greenX: 0.300 greenY: 0.600
[    11.515] (II) AMDGPU(0): blueX: 0.149 blueY: 0.060   whiteX: 0.312 whiteY: 0.328
[    11.515] (II) AMDGPU(0): Manufacturer's mask: 0
[    11.515] (II) AMDGPU(0): Supported detailed timing:
[    11.515] (II) AMDGPU(0): clock: 342.1 MHz   Image Size:  344 x 193 mm
[    11.515] (II) AMDGPU(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2080 h_border: 0
[    11.515] (II) AMDGPU(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1142 v_border: 0
[    11.515] (II) AMDGPU(0):  BOE HF
[    11.515] (II) AMDGPU(0):  NV156FHM-N4G
[    11.515] (II) AMDGPU(0): EDID (in hex):
[    11.515] (II) AMDGPU(0): 	00ffffffffffff0009e54d0800000000
[    11.515] (II) AMDGPU(0): 	011c0104a522137802de50a3544c9926
[    11.515] (II) AMDGPU(0): 	0f505400000001010101010101010101
[    11.515] (II) AMDGPU(0): 	0101010101019d8580a070383e406c30
[    11.515] (II) AMDGPU(0): 	aa0058c11000001a0000000000000000
[    11.515] (II) AMDGPU(0): 	00000000000000000000000000fe0042
[    11.515] (II) AMDGPU(0): 	4f452048460a202020202020000000fe
[    11.515] (II) AMDGPU(0): 	004e5631353646484d2d4e34470a0004
[    11.515] (II) AMDGPU(0): Printing probed modes for output eDP
[    11.515] (II) AMDGPU(0): Modeline "1920x1080"x144.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    11.515] (II) AMDGPU(0): Modeline "1680x1050"x144.0  342.05  1680 2028 2076 2080  1050 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "1280x1024"x144.0  342.05  1280 2028 2076 2080  1024 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "1440x900"x144.0  342.05  1440 2028 2076 2080  900 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "1280x800"x144.0  342.05  1280 2028 2076 2080  800 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "1280x720"x144.0  342.05  1280 2028 2076 2080  720 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "1024x768"x144.0  342.05  1024 2028 2076 2080  768 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "800x600"x144.0  342.05  800 2028 2076 2080  600 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Modeline "640x480"x144.0  342.05  640 2028 2076 2080  480 1090 1100 1142 +hsync -vsync (164.4 kHz e)
[    11.515] (II) AMDGPU(0): Output eDP connected
[    11.515] (II) AMDGPU(0): Using exact sizes for initial modes
[    11.515] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[    11.515] (II) AMDGPU(0): mem size init: gart size :bf69f000 vram size: s:1e2ed000 visible:1e2ed000
[    11.515] (==) AMDGPU(0): DPI set to (96, 96)
[    11.515] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[    11.515] (II) Loading sub module "ramdac"
[    11.515] (II) LoadModule: "ramdac"
[    11.515] (II) Module "ramdac" already built-in
[    11.516] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    11.516] (==) modeset(G0): RGB weight 888
[    11.516] (==) modeset(G0): Default visual is TrueColor
[    11.516] (II) Loading sub module "glamoregl"
[    11.516] (II) LoadModule: "glamoregl"
[    11.516] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.516] (II) Module glamoregl: vendor="XOrg Foundation"
[    11.516] 	compiled for 1.20.10, module version = 1.0.1
[    11.516] 	ABI class: XOrg ANSI C Emulation, version 0.4
[    11.788] (II) modeset(G0): glamor X acceleration enabled on NV166
[    11.788] (II) modeset(G0): glamor initialized
[    11.789] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    11.859] (II) modeset(G0): Output DP-1-1 has no monitor section
[    11.929] (II) modeset(G0): Output DP-1-2 has no monitor section
[    11.930] (II) modeset(G0): EDID for output HDMI-1-1
[    12.002] (II) modeset(G0): EDID for output DP-1-1
[    12.072] (II) modeset(G0): EDID for output DP-1-2
[    12.072] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    12.072] (==) modeset(G0): DPI set to (96, 96)
[    12.072] (II) Loading sub module "fb"
[    12.072] (II) LoadModule: "fb"
[    12.072] (II) Loading /usr/lib/xorg/modules/libfb.so
[    12.072] (II) Module fb: vendor="XOrg Foundation"
[    12.072] 	compiled for 1.20.10, module version = 1.0.0
[    12.072] 	ABI class: XOrg ANSI C Emulation, version 0.4
[    12.072] (II) AMDGPU(0): [DRI2] Setup complete
[    12.073] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[    12.073] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[    12.121] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[    12.122] (II) AMDGPU(0): SYNC extension fences enabled
[    12.122] (II) AMDGPU(0): Present extension enabled
[    12.122] (==) AMDGPU(0): DRI3 enabled
[    12.122] (==) AMDGPU(0): Backing store enabled
[    12.122] (II) AMDGPU(0): Direct rendering enabled
[    12.134] (II) AMDGPU(0): Use GLAMOR acceleration.
[    12.134] (II) AMDGPU(0): Acceleration enabled
[    12.134] (==) AMDGPU(0): DPMS enabled
[    12.134] (==) AMDGPU(0): Silken mouse disabled
[    12.134] (II) AMDGPU(0): Set up textured video (glamor)
[    12.148] (==) modeset(G0): Backing store enabled
[    12.148] (==) modeset(G0): Silken mouse disabled
[    12.148] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    12.148] (==) modeset(G0): DPMS enabled
[    12.148] (II) modeset(G0): [DRI2] Setup complete
[    12.148] (II) modeset(G0): [DRI2]   DRI driver: nouveau
[    12.148] (II) modeset(G0): [DRI2]   VDPAU driver: nouveau
[    12.148] (II) Initializing extension Generic Event Extension
[    12.148] (II) Initializing extension SHAPE
[    12.148] (II) Initializing extension MIT-SHM
[    12.148] (II) Initializing extension XInputExtension
[    12.148] (II) Initializing extension XTEST
[    12.148] (II) Initializing extension BIG-REQUESTS
[    12.148] (II) Initializing extension SYNC
[    12.149] (II) Initializing extension XKEYBOARD
[    12.149] (II) Initializing extension XC-MISC
[    12.149] (II) Initializing extension SECURITY
[    12.149] (II) Initializing extension XFIXES
[    12.149] (II) Initializing extension RENDER
[    12.149] (II) Initializing extension RANDR
[    12.149] (II) Initializing extension COMPOSITE
[    12.149] (II) Initializing extension DAMAGE
[    12.149] (II) Initializing extension MIT-SCREEN-SAVER
[    12.149] (II) Initializing extension DOUBLE-BUFFER
[    12.149] (II) Initializing extension RECORD
[    12.149] (II) Initializing extension DPMS
[    12.149] (II) Initializing extension Present
[    12.149] (II) Initializing extension DRI3
[    12.149] (II) Initializing extension X-Resource
[    12.149] (II) Initializing extension XVideo
[    12.150] (II) Initializing extension XVideo-MotionCompensation
[    12.150] (II) Initializing extension GLX
[    12.152] (II) AIGLX: Loaded and initialized radeonsi
[    12.152] (II) GLX: Initialized DRI2 GL provider for screen 0
[    12.152] (II) Initializing extension XFree86-VidModeExtension
[    12.152] (II) Initializing extension XFree86-DGA
[    12.152] (II) Initializing extension XFree86-DRI
[    12.152] (II) Initializing extension DRI2
[    12.157] (II) modeset(G0): Damage tracking initialized
[    12.158] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[    12.262] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    12.262] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    12.262] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    12.262] (**) Power Button: Applying InputClass "system-keyboard"
[    12.262] (II) LoadModule: "libinput"
[    12.262] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    12.267] (II) Module libinput: vendor="XOrg Foundation"
[    12.267] 	compiled for 1.20.8, module version = 0.30.0
[    12.268] 	Module class: XOrg XInput Driver
[    12.268] 	ABI class: XOrg XInput driver, version 24.1
[    12.268] (II) Using input driver 'libinput' for 'Power Button'
[    12.268] (**) Power Button: always reports core events
[    12.268] (**) Option "Device" "/dev/input/event3"
[    12.268] (**) Option "_source" "server/udev"
[    12.276] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    12.276] (II) event3  - Power Button: device is a keyboard
[    12.276] (II) event3  - Power Button: device removed
[    12.299] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    12.299] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    12.299] (**) Option "xkb_layout" "de"
[    12.335] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    12.336] (II) event3  - Power Button: device is a keyboard
[    12.337] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    12.337] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    12.337] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    12.337] (**) Video Bus: Applying InputClass "system-keyboard"
[    12.337] (II) Using input driver 'libinput' for 'Video Bus'
[    12.337] (**) Video Bus: always reports core events
[    12.337] (**) Option "Device" "/dev/input/event5"
[    12.337] (**) Option "_source" "server/udev"
[    12.338] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[    12.338] (II) event5  - Video Bus: device is a keyboard
[    12.338] (II) event5  - Video Bus: device removed
[    12.386] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:00/input/input5/event5"
[    12.386] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    12.386] (**) Option "xkb_layout" "de"
[    12.387] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[    12.388] (II) event5  - Video Bus: device is a keyboard
[    12.388] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    12.388] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    12.388] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    12.388] (**) Power Button: Applying InputClass "system-keyboard"
[    12.388] (II) Using input driver 'libinput' for 'Power Button'
[    12.389] (**) Power Button: always reports core events
[    12.389] (**) Option "Device" "/dev/input/event0"
[    12.389] (**) Option "_source" "server/udev"
[    12.390] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    12.390] (II) event0  - Power Button: device is a keyboard
[    12.390] (II) event0  - Power Button: device removed
[    12.426] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[    12.426] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    12.426] (**) Option "xkb_layout" "de"
[    12.427] (II) event0  - Power Button: is tagged by udev as: Keyboard
[    12.427] (II) event0  - Power Button: device is a keyboard
[    12.428] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[    12.428] (II) No input driver specified, ignoring this device.
[    12.428] (II) This device may have been added with another device file.
[    12.429] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    12.429] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    12.429] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    12.429] (**) Sleep Button: Applying InputClass "system-keyboard"
[    12.429] (II) Using input driver 'libinput' for 'Sleep Button'
[    12.429] (**) Sleep Button: always reports core events
[    12.429] (**) Option "Device" "/dev/input/event1"
[    12.429] (**) Option "_source" "server/udev"
[    12.430] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    12.430] (II) event1  - Sleep Button: device is a keyboard
[    12.430] (II) event1  - Sleep Button: device removed
[    12.466] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    12.466] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    12.466] (**) Option "xkb_layout" "de"
[    12.467] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    12.467] (II) event1  - Sleep Button: device is a keyboard
[    12.468] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[    12.468] (II) No input driver specified, ignoring this device.
[    12.469] (II) This device may have been added with another device file.
[    12.469] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[    12.469] (II) No input driver specified, ignoring this device.
[    12.470] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[    12.470] (II) No input driver specified, ignoring this device.
[    12.470] (II) This device may have been added with another device file.
[    12.470] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[    12.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event13)
[    12.471] (II) No input driver specified, ignoring this device.
[    12.471] (II) This device may have been added with another device file.
[    12.471] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event14)
[    12.473] (II) config/udev: Adding input device HD Webcam: HD Webcam (/dev/input/event15)
[    12.473] (**) HD Webcam: HD Webcam: Applying InputClass "evdev keyboard catchall"
[    12.473] (**) HD Webcam: HD Webcam: Applying InputClass "libinput keyboard catchall"
[    12.473] (**) HD Webcam: HD Webcam: Applying InputClass "system-keyboard"
[    12.473] (II) Using input driver 'libinput' for 'HD Webcam: HD Webcam'
[    12.473] (**) HD Webcam: HD Webcam: always reports core events
[    12.473] (**) Option "Device" "/dev/input/event15"
[    12.473] (**) Option "_source" "server/udev"
[    12.474] (II) event15 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    12.474] (II) event15 - HD Webcam: HD Webcam: device is a keyboard
[    12.475] (II) event15 - HD Webcam: HD Webcam: device removed
[    12.546] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-4/3-4:1.0/input/input17/event15"
[    12.546] (II) XINPUT: Adding extended input device "HD Webcam: HD Webcam" (type: KEYBOARD, id 10)
[    12.546] (**) Option "xkb_layout" "de"
[    12.548] (II) event15 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    12.548] (II) event15 - HD Webcam: HD Webcam: device is a keyboard
[    12.549] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event16)
[    12.549] (II) No input driver specified, ignoring this device.
[    12.549] (II) This device may have been added with another device file.
[    12.549] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event17)
[    12.550] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Touchpad (/dev/input/event8)
[    12.550] (**) UNIW0001:00 093A:0255 Touchpad: Applying InputClass "evdev touchpad catchall"
[    12.550] (**) UNIW0001:00 093A:0255 Touchpad: Applying InputClass "libinput touchpad catchall"
[    12.550] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:0255 Touchpad'
[    12.550] (**) UNIW0001:00 093A:0255 Touchpad: always reports core events
[    12.550] (**) Option "Device" "/dev/input/event8"
[    12.550] (**) Option "_source" "server/udev"
[    12.552] (II) event8  - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[    12.554] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[    12.554] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device removed
[    12.626] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-UNIW0001:00/0018:093A:0255.0001/input/input10/event8"
[    12.626] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:0255 Touchpad" (type: TOUCHPAD, id 11)
[    12.628] (**) Option "AccelerationScheme" "none"
[    12.628] (**) UNIW0001:00 093A:0255 Touchpad: (accel) selected scheme none/0
[    12.628] (**) UNIW0001:00 093A:0255 Touchpad: (accel) acceleration factor: 2.000
[    12.628] (**) UNIW0001:00 093A:0255 Touchpad: (accel) acceleration threshold: 4
[    12.630] (II) event8  - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[    12.632] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[    12.633] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Touchpad (/dev/input/mouse1)
[    12.633] (II) No input driver specified, ignoring this device.
[    12.633] (II) This device may have been added with another device file.
[    12.634] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Mouse (/dev/input/event7)
[    12.634] (**) UNIW0001:00 093A:0255 Mouse: Applying InputClass "evdev pointer catchall"
[    12.634] (**) UNIW0001:00 093A:0255 Mouse: Applying InputClass "libinput pointer catchall"
[    12.634] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:0255 Mouse'
[    12.634] (**) UNIW0001:00 093A:0255 Mouse: always reports core events
[    12.634] (**) Option "Device" "/dev/input/event7"
[    12.634] (**) Option "_source" "server/udev"
[    12.636] (II) event7  - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[    12.636] (II) event7  - UNIW0001:00 093A:0255 Mouse: device is a pointer
[    12.637] (II) event7  - UNIW0001:00 093A:0255 Mouse: device removed
[    12.692] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-UNIW0001:00/0018:093A:0255.0001/input/input9/event7"
[    12.692] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:0255 Mouse" (type: MOUSE, id 12)
[    12.693] (**) Option "AccelerationScheme" "none"
[    12.693] (**) UNIW0001:00 093A:0255 Mouse: (accel) selected scheme none/0
[    12.693] (**) UNIW0001:00 093A:0255 Mouse: (accel) acceleration factor: 2.000
[    12.693] (**) UNIW0001:00 093A:0255 Mouse: (accel) acceleration threshold: 4
[    12.694] (II) event7  - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[    12.695] (II) event7  - UNIW0001:00 093A:0255 Mouse: device is a pointer
[    12.697] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Mouse (/dev/input/mouse0)
[    12.697] (II) No input driver specified, ignoring this device.
[    12.697] (II) This device may have been added with another device file.
[    12.697] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    12.697] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    12.697] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    12.697] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    12.697] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    12.697] (**) AT Translated Set 2 keyboard: always reports core events
[    12.697] (**) Option "Device" "/dev/input/event4"
[    12.697] (**) Option "_source" "server/udev"
[    12.699] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    12.699] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    12.700] (II) event4  - AT Translated Set 2 keyboard: device removed
[    12.732] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    12.733] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[    12.733] (**) Option "xkb_layout" "de"
[    12.734] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    12.734] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    12.736] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    12.736] (II) No input driver specified, ignoring this device.
[    12.736] (II) This device may have been added with another device file.
[    12.745] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:08.1/0000:06:00.0/drm/card1 /dev/dri/card1
[    12.745] xf86: remove device 1 /sys/devices/pci0000:00/0000:00:08.1/0000:06:00.0/drm/card1
[    12.745] failed to find screen to remove
[    12.747] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event16)
[    12.747] (II) No input driver specified, ignoring this device.
[    12.747] (II) This device may have been added with another device file.
[    12.747] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event17)
[    21.122] (II) config/udev: Adding input device CHERRY  Wireless Mouse  Mouse (/dev/input/mouse2)
[    21.122] (II) No input driver specified, ignoring this device.
[    21.122] (II) This device may have been added with another device file.
[    21.248] (II) config/udev: Adding input device CHERRY  Wireless Mouse  (/dev/input/event19)
[    21.248] (II) No input driver specified, ignoring this device.
[    21.248] (II) This device may have been added with another device file.
[    21.249] (II) config/udev: Adding input device CHERRY  Wireless Mouse  Mouse (/dev/input/event18)
[    21.249] (**) CHERRY  Wireless Mouse  Mouse: Applying InputClass "evdev pointer catchall"
[    21.249] (**) CHERRY  Wireless Mouse  Mouse: Applying InputClass "libinput pointer catchall"
[    21.249] (II) Using input driver 'libinput' for 'CHERRY  Wireless Mouse  Mouse'
[    21.249] (**) CHERRY  Wireless Mouse  Mouse: always reports core events
[    21.249] (**) Option "Device" "/dev/input/event18"
[    21.249] (**) Option "_source" "server/udev"
[    21.308] (II) event18 - CHERRY  Wireless Mouse  Mouse: is tagged by udev as: Mouse
[    21.308] (II) event18 - CHERRY  Wireless Mouse  Mouse: device is a pointer
[    21.308] (II) event18 - CHERRY  Wireless Mouse  Mouse: device removed
[    21.373] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-2/3-2.1/3-2.1:1.0/0003:046A:A087.0002/input/input20/event18"
[    21.373] (II) XINPUT: Adding extended input device "CHERRY  Wireless Mouse  Mouse" (type: MOUSE, id 14)
[    21.373] (**) Option "AccelerationScheme" "none"
[    21.373] (**) CHERRY  Wireless Mouse  Mouse: (accel) selected scheme none/0
[    21.373] (**) CHERRY  Wireless Mouse  Mouse: (accel) acceleration factor: 2.000
[    21.373] (**) CHERRY  Wireless Mouse  Mouse: (accel) acceleration threshold: 4
[    21.431] (II) event18 - CHERRY  Wireless Mouse  Mouse: is tagged by udev as: Mouse
[    21.432] (II) event18 - CHERRY  Wireless Mouse  Mouse: device is a pointer
[    32.719] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    32.720] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    32.720] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    32.720] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    33.608] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    33.608] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    33.608] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    38.640] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    38.640] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    38.640] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    38.641] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    38.641] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    38.641] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    53.597] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    53.597] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    53.597] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    78.601] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    78.601] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    78.601] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[    78.602] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[    78.602] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    78.602] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[ 16413.002] (II) event3  - Power Button: device removed
[ 16413.039] (II) event5  - Video Bus: device removed
[ 16413.106] (II) event0  - Power Button: device removed
[ 16413.132] (II) event1  - Sleep Button: device removed
[ 16413.159] (II) event15 - HD Webcam: HD Webcam: device removed
[ 16413.213] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device removed
[ 16413.266] (II) event7  - UNIW0001:00 093A:0255 Mouse: device removed
[ 16413.319] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 16413.346] (II) event18 - CHERRY  Wireless Mouse  Mouse: device removed
[ 16413.399] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 16438.732] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 16438.745] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[ 16438.745] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 16438.745] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[ 16439.183] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 16439.183] (II) event3  - Power Button: device is a keyboard
[ 16439.184] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 16439.184] (II) event5  - Video Bus: device is a keyboard
[ 16439.185] (II) event0  - Power Button: is tagged by udev as: Keyboard
[ 16439.185] (II) event0  - Power Button: device is a keyboard
[ 16439.186] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[ 16439.186] (II) event1  - Sleep Button: device is a keyboard
[ 16439.187] (II) event15 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[ 16439.187] (II) event15 - HD Webcam: HD Webcam: device is a keyboard
[ 16439.188] (II) event8  - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[ 16439.189] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[ 16439.190] (II) event7  - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[ 16439.190] (II) event7  - UNIW0001:00 093A:0255 Mouse: device is a pointer
[ 16439.191] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 16439.191] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 16439.249] (II) event18 - CHERRY  Wireless Mouse  Mouse: is tagged by udev as: Mouse
[ 16439.249] (II) event18 - CHERRY  Wireless Mouse  Mouse: device is a pointer
[ 17747.093] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[ 17747.093] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 17747.093] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[ 17748.963] (II) event3  - Power Button: device removed
[ 17748.985] (II) event5  - Video Bus: device removed
[ 17749.025] (II) event0  - Power Button: device removed
[ 17749.039] (II) event1  - Sleep Button: device removed
[ 17749.058] (II) event15 - HD Webcam: HD Webcam: device removed
[ 17749.118] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device removed
[ 17749.185] (II) event7  - UNIW0001:00 093A:0255 Mouse: device removed
[ 17749.265] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 17749.319] (II) event18 - CHERRY  Wireless Mouse  Mouse: device removed
[ 17749.365] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 17955.771] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 17955.785] (II) AMDGPU(0): EDID vendor "BOE", prod id 2125
[ 17955.785] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 17955.785] (II) AMDGPU(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[ 17955.794] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 17955.794] (II) event3  - Power Button: device is a keyboard
[ 17955.795] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 17955.795] (II) event5  - Video Bus: device is a keyboard
[ 17955.797] (II) event0  - Power Button: is tagged by udev as: Keyboard
[ 17955.797] (II) event0  - Power Button: device is a keyboard
[ 17955.798] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[ 17955.798] (II) event1  - Sleep Button: device is a keyboard
[ 17955.799] (II) event15 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[ 17955.799] (II) event15 - HD Webcam: HD Webcam: device is a keyboard
[ 17955.800] (II) event8  - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[ 17955.801] (II) event8  - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[ 17955.802] (II) event7  - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[ 17955.802] (II) event7  - UNIW0001:00 093A:0255 Mouse: device is a pointer
[ 17955.804] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 17955.804] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 17955.862] (II) event18 - CHERRY  Wireless Mouse  Mouse: is tagged by udev as: Mouse
[ 17955.862] (II) event18 - CHERRY  Wireless Mouse  Mouse: device is a pointer
I have not done anything else yet, but today I wanted to try the tips from the mentioned thread (above).
So I applied the latest updates and did a reboot. Now I have even less function than before :frowning:
Shortly after switching on, GRUB appears. There I enter the password for decrypting the partition. After that only the logo is displayed and nothing happens.
Attempting to decrypt master key…
Enter passphrase for hd0,gpt2 (…):
Slot 0 opened
