Hello,
after enthusiastically using Manjaro with Plasma Desktop for a couple of years on my entertainment laptop (thinkpad x230) now i have decided to take the next step and install it on my working machine (thinkpad x430). Everything works fine out of the box but i am a bit surprised to find the sparse grub-bootmenu (dualboot still).
I really like the fancy bootmenu that i have on the x230. Is there a possibility to get this?
Thank you very much for an answer. And greetings to all member of this forum
Heinrich
Thank you very much to both of you! Both ways worked just fine and with the pamac-option i even get a ton of new bootmenu-themes i didn’t know existed.
Great!!
For some reason it does not apply that with a fresh install from the ISO although the package is installed by default.
But yeah. Uninstalling and installing that package again will fix that indeed.
