Bootloader is partially broken
While running an update in the Add/Remove software application, I also went into the Manjaro Settings Manager and removed (6.13) / installed (6.14) while this was running. This seemed to have resulted in the kernels not updating in grub. I tried running
sudo grub-install --recheck --no-rs-codes
which in hindsight was not the best idea as I wasn’t fully sure what that did/does. (really need to stop trying to fix things just before going to bed)
This has resulted in grub to no longer have the theme or allowing any boot of manjaro (any kernels). I then booted into a live environment and tried following the GRUB/Restore the GRUB Bootloader - Manjaro. However, this doesn’t seem to have fully worked. When restarting I am still stuck with the no theme/no launching grub, but if I go into the EFI bootloaders option on the startup of the live disk and select the correct one I get back to the themed/launching grub (I am writing this from my installed partition now).
So it is sort of fixed, but I would like to not have to go into the live disk first. What am I missing here? (side note I ran into issues with the system recovery tool. It doesn’t seem to actually do anything when I tried running it from the live environment)
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH           PTTYPE PARTTYPE                             FSTYPE PARTTYPENAME
/dev/nvme1n1   gpt
/dev/nvme1n1p1 gpt    c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat   EFI System
/dev/nvme1n1p2 gpt    0fc63daf-8483-4772-8e79-3d69d8477de4 ext4   Linux filesystem
/dev/nvme0n1   gpt
/dev/nvme0n1p1 gpt    de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs   Windows recovery environment
/dev/nvme0n1p2 gpt    c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat   EFI System
/dev/nvme0n1p3 gpt    e3c9e316-0b5c-4db8-817d-f92df00215ae        Microsoft reserved
/dev/nvme0n1p4 gpt    ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs   Microsoft basic data
grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.14-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.14-x86_64.img
Found initrd fallback image: /boot/initramfs-6.14-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
Found Windows Boot Manager on /dev/nvme0n1p2@/efi/Microsoft/Boot/bootmgfw.efi
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Those who might wish to help will probably benefit from:
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Should have known to put that in the question as well. My bad. When I select the detect bootloaders in the live environment, I do have to select the second option and it seems that there are three showing up for Manjaro?
inxi -zv8         ✔
  Kernel: 6.14.0-rc1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=3e6e4c0f-26d2-4b14-af4a-9bee693e02f7 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: H.H0 date: 05/19/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 7.83 GiB (25.0%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C14-8GVK serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3526 min/max: 550/5321 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3526 2: 3526 3: 3526
    4: 3526 5: 3526 6: 3526 7: 3526 8: 3526 9: 3526 10: 3526 11: 3526 12: 3526
    13: 3526 14: 3526 15: 3526 16: 3526 bogomips: 127255
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 6400x2160 display-ID: 0
  Monitor-1: DP-1 pos: right model: LG (GoldStar) Ultra HD serial: <filter>
    built: 2017 res: mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440
    dpi: 163 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.306
    y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x480, 640x480
  Monitor-2: DP-2 pos: primary,left model: LG (GoldStar) HDR QHD
    serial: <filter> built: 2019 res: mode: 2560x1440 hz: 144 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.671 y: 0.310 green: x: 0.255 y: 0.682
    blue: x: 0.149 y: 0.075 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 19.1.7 DRM 3.59 6.14.0-rc1-2-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
    surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: lact,radeontop wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Micro-Star MSI X570-A PRO driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: Samson Q2U handheld mic with XLR
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-3:3 chip-ID: 17a0:0304 class-ID: 0300
  API: ALSA v: k6.14.0-rc1-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 1.82 TiB used: 686.56 GiB (36.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 22.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 3B2QEXM7 temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 686.56 GiB (75.0%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
    label: N/A uuid: 3e6e4c0f-26d2-4b14-af4a-9bee693e02f7
    used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
    uuid: 9586-5453
  ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 529 MiB fs: ntfs label: Recovery
    uuid: 5892F20392F1E582
  ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
    uuid: 1AF2-DD4A
  ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 930.88 GiB fs: ntfs label: N/A
    uuid: CCA6F440A6F42C98
  Device-1: 1-5:2 info: Holtek USB-HID Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0161 class-ID: 0300
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
    serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:3 info: Samson Q2U handheld mic with XLR type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-2: 5-4:4 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
    serial: <filter>
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 25.0 C mobo: 27.0 C gpu: amdgpu temp: 36.0 C
    mem: 44.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 574 fan-3: 0 fan-4: 518 fan-5: 948
    fan-6: 681 fan-7: 0 gpu: amdgpu fan: 0
  Packages: 1630 pm: dpkg pkgs: 0 pm: pacman pkgs: 1607 libs: 457
    tools: pamac,yay pm: flatpak pkgs: 23
    1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    6: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://manjaro.kurdy.org/stable/$repo/$arch
    9: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    13: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    16: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    17: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    18: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    19: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    20: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    25: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    26: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    27: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    28: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    30: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    32: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    33: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    34: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    35: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    36: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    37: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    38: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    39: https://mirror.init7.net/manjaro/stable/$repo/$arch
    40: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    41: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    42: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    44: https://manjaro.ynh.ovh/stable/$repo/$arch
    45: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    46: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    47: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    48: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    49: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    50: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    51: https://mirror.23m.com/manjaro/stable/$repo/$arch
    52: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    53: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    54: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    55: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    56: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    57: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    58: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    59: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    60: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    61: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    62: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    63: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    64: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    65: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    66: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    67: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    68: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    69: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    70: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    71: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    72: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    73: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    74: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    75: http://manjaro.grena.ge/stable/$repo/$arch
    76: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    77: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    78: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    79: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    80: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    81: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    82: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    83: https://mirrors2.manjaro.org/stable/$repo/$arch
    84: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    85: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    86: https://linorg.usp.br/manjaro/stable/$repo/$arch
    87: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    88: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    89: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    90: http://manjaro.mirror.ac.za/stable/$repo/$arch
    91: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    92: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    93: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    94: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    95: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    96: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    97: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    98: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    99: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    100: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    101: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    102: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    103: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    104: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    105: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    106: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    107: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    108: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    109: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    110: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    111: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    112: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    113: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    114: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    115: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    116: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    117: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 389
  1: cpu: 35.7% command: clion pid: 1898 mem: 2621.7 MiB (8.1%)
  2: cpu: 11.4% command: Rider.Backend pid: 2341 mem: 1042.9 MiB (3.2%)
  3: cpu: 8.4% command: steamwebhelper pid: 3067 mem: 197.6 MiB (0.6%)
  4: cpu: 8.2% command: steamwebhelper pid: 3265 mem: 481.6 MiB (1.5%)
  5: cpu: 7.9% command: firefox pid: 2659 mem: 498.8 MiB (1.5%)
  Memory top: 5 of 389
  1: mem: 2621.7 MiB (8.1%) command: clion pid: 1898 cpu: 35.7%
  2: mem: 1042.9 MiB (3.2%) command: Rider.Backend pid: 2341 cpu: 11.4%
  3: mem: 498.8 MiB (1.5%) command: firefox pid: 2659 cpu: 7.9%
  4: mem: 481.6 MiB (1.5%) command: steamwebhelper pid: 3265 cpu: 8.2%
  5: mem: 481.4 MiB (1.5%) command: plasmashell pid: 1227 cpu: 1.5%
  Processes: 389 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
So I have found that I currently have two boot loaders, one that is broken and one that is fine.
The broken one is found at
/boot/efi/EFI/boot
and the working one is at
/boot/efi/EFI/Manjaro
My bootloader order has boot first
efibootmgr -v
BootOrder: 0004, 0001
Boot0001* manjaro
Boot0004* UEFI OS
So I changed the order with
efibootmgr -o 0001, 0004
I also ran
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --removable --recheck --no-rs-codes
To hopefully fix my backup bootloader? I didn’t test that it worked, but the 0001 is working as expected so I am making a copy of it on a different drive as a backup.
@vikinbread
It can happen in some cases when the fallback is damaged, or in a multi-boot scenario (on a single disk) when another OS is installed, that reinstalling Manjaro’s Grub will not replace the fallback boot file if it differs.
This is by design when using Manjaro’s install-grub, for example.
If not multi-booting, both the *.efi files should match, though the naming may be different they are the same file (but in different locations); that’s what makes it a “fallback”.
Assuming that grubx64.exi is also undamaged, copying that file to the fallback location as bootx64.efi can also resolve the issue.
sudo cp /boot/efi/EFI/Manjaro/grubx64.exi /boot/efi/EFI/BOOT/bootx64.efi
As both files are the same but with different names both files should have the same checksum, so, you could verify that by using your favourite tool to check.
Keep in mind that each time Grub is updated, the .efi boot files should also be updated, so keeping it backed up as a spare won’t likely be useful for all that long.
