Hello community,
I have a problem to install bootloader on my HP probook 455 G7 12x21ae.
I have UEFI enabled, security boot disabled, fast boot disabled and USB installation media with GPT partitioning table.
At the end of the installation process I get this error:
The bootloader could not be installed. The installation command <pre>grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force</pre> returned error code 1.
Outputs:
sudo efibootmgr -v
BootCurrent: 0004
Timeout: 0 seconds
BootOrder: 0004,0000,0001,0007,0008,0006,0003,0002,0005
Boot0000* INTEL SSDPEKNW512G8H-BTNH04620TG4512A PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-00-00-00-00-00-00-00)4eac0881119f594d850ee21a522c59b21000000049535048
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 04 02 / 01 01 06 00 00 00 / 03 17 10 00 01 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 4e ac 08 81 11 9f 59 4d 85 0e e2 1a 52 2c 59 b2 10 00 00 00 49 53 50 48
Boot0001* Samsung SSD 860 EVO 1TB PciRoot(0x0)/Pci(0x8,0x2)/Pci(0x0,0x1)/Sata(0,65535,0)4eac0881119f594d850ee21a522c59b21000000049535048
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 08 / 01 01 06 00 01 00 / 03 12 0a 00 00 00 ff ff 00 00 / 7f ff 04 00
Boot0002* Samsung SSD 860 EVO 1TB BBS(HD,Samsung SSD 860 EVO 1TB ,0x400)/PciRoot(0x0)/Pci(0x8,0x2)/Pci(0x0,0x1)/Sata(0,65535,0)01001000000049535048
dp: 05 01 21 00 02 00 00 04 53 61 6d 73 75 6e 67 20 53 53 44 20 38 36 30 20 45 56 4f 20 31 54 42 20 00 / 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 08 / 01 01 06 00 01 00 / 03 12 0a 00 00 00 ff ff 00 00 / 7f ff 04 00
data: 01 00 10 00 00 00 49 53 50 48
Boot0003* INTEL SSDPEKNW512G8H-BTNH04620TG4512A BBS(HD,INTEL SSDPEKNW512G8H-BTNH04620TG4512A,0x400)/PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-00-00-00-00-00-00-00)02001000000049535048
dp: 05 01 2e 00 02 00 00 04 49 4e 54 45 4c 20 53 53 44 50 45 4b 4e 57 35 31 32 47 38 48 2d 42 54 4e 48 30 34 36 32 30 54 47 34 35 31 32 41 00 / 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 04 02 / 01 01 06 00 00 00 / 03 17 10 00 01 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 02 00 10 00 00 00 49 53 50 48
Boot0004* Kingston DataTraveler 70 1831BFB81BC8F690F9230134 PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x3)/USB(4,0)4eac0881119f594d850ee21a522c59b20918000049535048
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 01 08 / 01 01 06 00 03 00 / 03 05 06 00 04 00 / 7f ff 04 00
data: 4e ac 08 81 11 9f 59 4d 85 0e e2 1a 52 2c 59 b2 09 18 00 00 49 53 50 48
Boot0005* Intel Corporation: Realtek PXE B01 D00 BBS(Network,Intel Corporation: Realtek PXE B01 D00,0x0)/PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/IPv4(0.0.0.00.0.0.0,0,0)15001000000049535048
dp: 05 01 2f 00 06 00 00 00 49 6e 74 65 6c 20 43 6f 72 70 6f 72 61 74 69 6f 6e 3a 20 52 65 61 6c 74 65 6b 20 50 58 45 20 42 30 31 20 44 30 30 00 / 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 01 / 01 01 06 00 00 00 / 03 0c 1b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 15 00 10 00 00 00 49 53 50 48
Boot0006 USB: BBS(65535,,0x0)/PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x3)ffff0b18000049535048
dp: 05 01 09 00 ff ff 00 00 00 / 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 01 08 / 01 01 06 00 03 00 / 7f ff 04 00
data: ff ff 0b 18 00 00 49 53 50 48
Boot0007* IPV4 Network - Realtek PCIe GBE Family Controller PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/MAC(3024a99557b3,0)/IPv4(0.0.0.00.0.0.0,0,0)4eac0881119f594d850ee21a522c59b20000000049535048
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 01 / 01 01 06 00 00 00 / 03 0b 25 00 30 24 a9 95 57 b3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0c 1b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 4e ac 08 81 11 9f 59 4d 85 0e e2 1a 52 2c 59 b2 00 00 00 00 49 53 50 48
Boot0008* IPV6 Network - Realtek PCIe GBE Family Controller PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/MAC(3024a99557b3,0)/IPv6([::]:<->[::]:,0,0)4eac0881119f594d850ee21a522c59b20000000049535048
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 02 01 / 01 01 06 00 00 00 / 03 0b 25 00 30 24 a9 95 57 b3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0d 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
inxi -Fxza
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
lang=en_US keytable=us tz=Europe/Bratislava lang=en_US keytable=sk
tz=Europe/Bratislava lang=cs_CZ keytable=sk tz=Europe/Bratislava
misobasedir=manjaro misolabel=MANJARO_GNOME_2313 quiet
systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1 rdinit=/vtoy/vtoy
Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP ProBook 455 G7 v: N/A
Mobo: HP model: 8730 v: KBC Version 13.26.00 serial: <superuser required>
UEFI: HP v: S79 Ver. 01.08.20 date: 03/15/2022
ID-1: BAT0 charge: 34.7 Wh (99.4%) condition: 34.9/45.0 Wh (77.5%)
volts: 12.3 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 55
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1653 high: 2151 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2151 2: 1397
3: 1397 4: 1424 5: 1925 6: 1831 7: 1528 8: 1576 bogomips: 31958
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 45.0 C
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 05c8:03cb class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x062e built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1
renoir LLVM 16.0.6 DRM 3.54 6.6.10-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: no display-ID: :0.0
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 1.43 TiB used: 250.89 GiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 70
size: 57.62 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Processes: 333 Uptime: 3h 23m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.76 GiB used: 3.94 GiB (12.8%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1299 libs: 328 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.31
parted -l
Model: ATA Samsung SSD 860 (scsi)
Disk /dev/sda: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 1000GB 1000GB ext4
Model: Kingston DataTraveler 70 (scsi)
Disk /dev/sdb: 61.9GB
Disk Flags:
1 1049kB 61.8GB 61.8GB Ventoy msftdata
2 61.8GB 61.9GB 33.6MB fat16 VTOYEFI hidden, msftdata, no_automount
Model: ADATA USB Flash Drive (scsi)
Disk /dev/sdc: 15.8GB
Disk Flags:
1 1049kB 15.8GB 15.8GB Ventoy msftdata
2 15.8GB 15.8GB 33.6MB fat16 VTOYEFI hidden, msftdata, no_automount
Model: INTEL SSDPEKNW512G8H (nvme)
Disk /dev/nvme0n1: 512GB
Disk Flags:
1 1049kB 525MB 524MB fat32 boot, esp
2 525MB 9974MB 9449MB linux-swap(v1) swap
3 9974MB 512GB 502GB ext4
manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/nvme0n1p3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of `/boot/efi'.
I appreciate every advise to my problem. Thank you.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
