I’m trying to install Manjaro (gnome image) on my htpc but it keeps failing on the bootloader. I saw some replies on other posts recommending a larger size partition in case the efi couldn’t fit so I tried upping it from the default 300mb to 600, and then 800. I also tried using sudo calamares -d but had the same result
I was using the “Erase Disk” initially but started doing manual participation to experiment. I’m using GPT for the drive, /boot/efi mountpoint for the partition, with boot flag and fat32.
Other partitions are swap and root.
I have the log from my most recent attempt
at the end when it exits it says “unknown filesystem” I’m not sure why that would be since its fat32
=== START CALAMARES 3.2.61-10
2023-04-06 - 00:02:54 [6]: void CalamaresApplication::init()
Calamares version: 3.2.61-10
2023-04-06 - 00:02:54 [6]: .. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, oc, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
2023-04-06 - 00:02:54 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
2023-04-06 - 00:02:54 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2023-04-06 - 00:02:54 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
2023-04-06 - 00:02:54 [6]: .. No translation for "tz_" "C" using default (en)
2023-04-06 - 00:02:54 [6]: .. No translation for "calamares_" "C" using default (en)
2023-04-06 - 00:02:54 [6]: .. STARTUP: initSettings, initQmlPath, initBranding done
2023-04-06 - 00:02:54 [6]: .. STARTUP: initModuleManager: module init started
2023-04-06 - 00:02:54 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2023-04-06 - 00:02:54 [2]: WARNING: .. Module descriptor contains extra keys:
"requires"
2023-04-06 - 00:02:54 [6]: void Calamares::ModuleManager::doInit()
Found 57 modules
2023-04-06 - 00:02:54 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
2023-04-06 - 00:02:54 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
2023-04-06 - 00:02:54 [6]: .. Proposed window size: 1024 560
2023-04-06 - 00:02:54 [6]: QString CalamaresUtils::searchQmlFile(QmlSearch, const QString&)
Looking for QML for "calamares-sidebar"
2023-04-06 - 00:02:54 [6]: .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
STARTUP: CalamaresWindow created; loadModules started
2023-04-06 - 00:02:54 [6]: void Config::initLanguages()
Trying to match locale "C"
Trying to match locale QLocale(C, Default, Default)
2023-04-06 - 00:02:54 [6]: .. Trying to match approximate locale QLocale::C
2023-04-06 - 00:02:54 [6]: .. Trying to match English (US)
2023-04-06 - 00:02:54 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
2023-04-06 - 00:02:54 [6]: .. Loaded QRC translation "tz_" "en"
2023-04-06 - 00:02:54 [6]: .. Loaded QRC translation "calamares_" "en"
2023-04-06 - 00:02:55 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
2023-04-06 - 00:02:55 [6]: QStringList loadLocales(const QString&)
Loading locales from "/usr/share/i18n/SUPPORTED"
2023-04-06 - 00:02:55 [6]: .. Read 492 lines
2023-04-06 - 00:02:55 [6]: .. After filtering 317 lines
ViewModule "locale@locale" loading complete.
2023-04-06 - 00:02:55 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 189 keyboard models
2023-04-06 - 00:02:55 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now total= 0 selected= -1
2023-04-06 - 00:02:55 [6]: .. Loaded QRC translation "kb_" "en"
2023-04-06 - 00:02:55 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)\"")
ViewModule "keyboard@keyboard" loading complete.
2023-04-06 - 00:02:55 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
2023-04-06 - 00:02:55 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
2023-04-06 - 00:02:55 [6]: .. Backend @0x55a6f384f6d0 "pmsfdiskbackendplugin" "1"
2023-04-06 - 00:02:55 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
2023-04-06 - 00:02:55 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
WARNING: Legacy *users* key "userShell" overrides hostname-settings.
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
2023-04-06 - 00:02:55 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
2023-04-06 - 00:02:55 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
QML load on startup, API 2.
2023-04-06 - 00:02:55 [2]: QThread::setPriority: Cannot set priority, thread is not running
2023-04-06 - 00:02:55 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2023-04-06 - 00:02:55 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
CppJobModule "umount@umount" loading complete.
2023-04-06 - 00:02:55 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
2023-04-06 - 00:02:55 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "US"
2023-04-06 - 00:02:55 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code "US"
2023-04-06 - 00:02:55 [6]: .. Obtained from "https://ipapi.co/json" ( 1 "country" )
2023-04-06 - 00:02:55 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
2023-04-06 - 00:02:55 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
2023-04-06 - 00:02:55 [6]: .. 8 view steps loaded.
2023-04-06 - 00:02:55 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
QML component complete, API 2
2023-04-06 - 00:02:55 [6]: getting temp failed for "/dev/nvme0n1" : Success
2023-04-06 - 00:02:55 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
2023-04-06 - 00:02:55 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
2023-04-06 - 00:02:55 [6]: getting temp failed for "/dev/nvme1n1" : Success
2023-04-06 - 00:02:55 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
2023-04-06 - 00:02:55 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
2023-04-06 - 00:02:55 [6]: smartctl initialization failed for "/dev/sda" : No such file or directory
2023-04-06 - 00:02:55 [6]: error during smart output parsing for "/dev/sda" : Success
2023-04-06 - 00:02:56 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
Removing unsuitable devices: 3 candidates.
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme0n1")
2023-04-06 - 00:02:56 [6]: .. Finished. Exit code: 0 output:
/dev/nvme0n1: PTUUID="a4435648-acfb-4c81-b490-61fa7b741328" PTTYPE="gpt"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme0n1p1")
/dev/nvme0n1p1: UUID="4ae373a4-d0de-4f11-aad8-7a2f5d101e97" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="b982ed18-a56e-4918-ade1-c10310692484"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme1n1")
/dev/nvme1n1: PTUUID="a90c4637-34a7-46d9-a3fe-944d037f1033" PTTYPE="gpt"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme1n1p1")
/dev/nvme1n1p1: UUID="BB5A-9361" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="132fe2fb-1fd8-4fde-82ee-64dc831a6185"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme1n1p2")
/dev/nvme1n1p2: LABEL="swap" UUID="67e3a647-eba7-4045-9420-1b13973910a4" TYPE="swap" PARTLABEL="swap" PARTUUID="6c7f025e-59d0-4c10-88b5-b228668791e4"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/nvme1n1p3")
/dev/nvme1n1p3: LABEL="root" UUID="4fcef172-a173-4c4b-9db6-00502eda7d5c" BLOCK_SIZE="4096" TYPE="f2fs" PARTLABEL="root" PARTUUID="5c3c6448-2507-4620-b283-876f0d7f9c2c"
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "")
2023-04-06 - 00:02:56 [6]: .. Target cmd: ("blkid", "") Exit code: 2 (no output)
2023-04-06 - 00:02:56 [6]: .. Running ("blkid", "/dev/sda")
/dev/sda: BLOCK_SIZE="2048" UUID="2023-03-16-12-35-17-00" LABEL="MANJARO_GNOME_2205" TYPE="iso9660" PTTYPE="dos"
2023-04-06 - 00:02:56 [6]: .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sda"
2023-04-06 - 00:02:56 [6]: .. there are 2 devices left.
2023-04-06 - 00:02:56 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
2023-04-06 - 00:02:56 [6]: .. node capacity name prettyName
2023-04-06 - 00:02:56 [6]: .. "/dev/nvme0n1" 512105932800 DevName$1cbe20dd DevNamePretty$95fa8d17
2023-04-06 - 00:02:56 [6]: .. "/dev/nvme1n1" 250056737280 DevName$a80af24f DevNamePretty$c49ca618
2023-04-06 - 00:02:56 [6]: .. 2 devices detected.
2023-04-06 - 00:02:56 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
2023-04-06 - 00:02:56 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
2023-04-06 - 00:02:56 [6]: .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2023-04-06 - 00:02:56 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
2023-04-06 - 00:02:56 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
2023-04-06 - 00:02:58 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-04-06 - 00:02:58 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
os-prober gave no output.
2023-04-06 - 00:02:58 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
WARNING: system is EFI but no EFI system partitions found.
2023-04-06 - 00:02:58 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 1 requirement results from "partition"
2023-04-06 - 00:02:58 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
2023-04-06 - 00:02:58 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/nvme0n1" with 0 entries.
2023-04-06 - 00:02:58 [6]: .. Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2023-04-06 - 00:02:58 [6]: .. contains resizable "/dev/nvme0n1p1"
2023-04-06 - 00:02:58 [6]: .. Checking if "/dev/nvme0n1p1" can be replaced.
2023-04-06 - 00:02:58 [6]: .. Partition "/dev/nvme0n1p1" authorized for replace install.
2023-04-06 - 00:02:58 [6]: .. contains replaceable "/dev/nvme0n1p1"
2023-04-06 - 00:02:58 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 0 osprober entries
2023-04-06 - 00:02:58 [2]: void ChoicePage::setupActions()
WARNING: System is EFI but there's no EFI system partition, DISABLING alongside and replace features.
2023-04-06 - 00:02:58 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device -1 new device 0
2023-04-06 - 00:02:58 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Erase "erase"
2023-04-06 - 00:02:58 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2023-04-06 - 00:02:58 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
2023-04-06 - 00:02:58 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
2023-04-06 - 00:02:58 [6]: .. requirement 0 "storage" satisfied? true mandatory? true
2023-04-06 - 00:02:58 [6]: .. requirement 1 "ram" satisfied? true mandatory? true
2023-04-06 - 00:02:58 [6]: .. requirement 2 "power" satisfied? true mandatory? false
2023-04-06 - 00:02:58 [6]: .. requirement 3 "internet" satisfied? true mandatory? false
2023-04-06 - 00:02:58 [6]: .. requirement 4 "root" satisfied? true mandatory? true
2023-04-06 - 00:02:58 [6]: .. requirement 5 "partitions" satisfied? true mandatory? true
2023-04-06 - 00:02:58 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
system is EFI and new EFI system partition has been found.
2023-04-06 - 00:02:58 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-04-06 - 00:02:58 [6]: .. ## Device: "/dev/nvme0n1"
2023-04-06 - 00:02:58 [6]: .. - CreatePartitionTableJob
2023-04-06 - 00:02:58 [6]: .. - CreatePartitionJob
2023-04-06 - 00:02:58 [6]: .. - SetPartFlagsJob
2023-04-06 - 00:02:58 [6]: .. ## Device: "/dev/nvme1n1"
2023-04-06 - 00:02:58 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
Updating partitioning preview widgets.
2023-04-06 - 00:03:00 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
Mapping "en" in "US" to locale.
2023-04-06 - 00:03:00 [6]: .. Got best match for "en" as "en_ZW.UTF-8"
2023-04-06 - 00:03:00 [6]: .. Got best match for "en_US" as "en_US.UTF-8"
2023-04-05 - 20:03:00 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2023-04-05 - 20:03:01 [6]: .. Got best match for "en" as "en_ZW.UTF-8"
2023-04-05 - 20:03:01 [6]: .. Got best match for "en_US" as "en_US.UTF-8"
2023-04-05 - 20:03:01 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2023-04-05 - 20:03:01 [6]: void Config::guessLocaleKeyboardLayout()
Got locale language "en_US.UTF-8"
2023-04-05 - 20:03:01 [6]: .. looking for locale part "US"
2023-04-05 - 20:03:01 [6]: .. matched "us"
2023-04-05 - 20:03:01 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
Next level: "en"
2023-04-05 - 20:03:12 [6]: getting temp failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:12 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:12 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:12 [6]: getting temp failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:12 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:12 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:13 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2023-04-05 - 20:03:13 [6]: void ChoicePage::updateDeviceStatePreview()
2023-04-05 - 20:03:13 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/nvme1n1" with 0 entries.
2023-04-05 - 20:03:13 [6]: .. Can not resize "/dev/nvme1n1p1" , filesystem "fat32" does not support resize.
2023-04-05 - 20:03:13 [6]: .. Checking if "/dev/nvme1n1p1" can be replaced.
2023-04-05 - 20:03:13 [6]: .. NO, insufficient storage
Required storage B: 9019431321 "(7.9GiB)"
Available storage B: 838860800 "(0GiB)"
Required storage B: 11166914969 "(10.4GiB)"
Available storage B: 9447669760 "(8GiB)" for "/dev/nvme1n1p2" length: 18452480 sectorsUsed: 0 fsType: "linuxswap"
2023-04-05 - 20:03:13 [6]: .. Checking if "/dev/nvme1n1p2" can be replaced.
2023-04-05 - 20:03:13 [6]: .. Partition "/dev/nvme1n1p2" authorized for replace install.
2023-04-05 - 20:03:13 [6]: .. contains replaceable "/dev/nvme1n1p2"
2023-04-05 - 20:03:13 [6]: .. Can not resize "/dev/nvme1n1p3" , filesystem "f2fs" does not support resize.
2023-04-05 - 20:03:13 [6]: .. Checking if "/dev/nvme1n1p3" can be replaced.
2023-04-05 - 20:03:13 [6]: .. Partition "/dev/nvme1n1p3" authorized for replace install.
2023-04-05 - 20:03:13 [6]: .. contains replaceable "/dev/nvme1n1p3"
2023-04-05 - 20:03:13 [6]: .. Can not resize "/dev/nvme1n1" , filesystem "unknown" does not support resize.
2023-04-05 - 20:03:13 [6]: .. Checking if "/dev/nvme1n1" can be replaced.
Available storage B: 1220096 "(0GiB)"
2023-04-05 - 20:03:13 [6]: ChoicePage::setupActions()::<lambda()>
No partitions available for resize-action.
2023-04-05 - 20:03:13 [2]: void ChoicePage::setupActions()
2023-04-05 - 20:03:13 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device 0 new device 1
2023-04-05 - 20:03:13 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2023-04-05 - 20:03:13 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme1n1"
2023-04-05 - 20:03:13 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2023-04-05 - 20:03:13 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-04-05 - 20:03:13 [6]: .. ## Device: "/dev/nvme0n1"
2023-04-05 - 20:03:13 [6]: .. ## Device: "/dev/nvme1n1"
2023-04-05 - 20:03:13 [6]: .. - CreatePartitionTableJob
2023-04-05 - 20:03:13 [6]: .. - CreatePartitionJob
2023-04-05 - 20:03:13 [6]: .. - SetPartFlagsJob
2023-04-05 - 20:03:13 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-04-05 - 20:03:30 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Manual "manual"
2023-04-05 - 20:03:30 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-04-05 - 20:03:36 [6]: virtual void PartitionViewStep::next()
Choice applied: Config::Manual
2023-04-05 - 20:03:36 [6]: getting temp failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:36 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:36 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
2023-04-05 - 20:03:36 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
No path to restore, choosing default
2023-04-05 - 20:03:36 [6]: getting temp failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:36 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:36 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
2023-04-05 - 20:03:36 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2023-04-05 - 20:03:36 [2]: QBasicTimer::start: Timers cannot be started from another thread
2023-04-05 - 20:04:08 [6]: void EditExistingPartitionDialog::applyChanges(PartitionCoreModule*)
old boundaries: 2048 1640447 1638400
2023-04-05 - 20:04:08 [6]: .. new boundaries: 2048 1640447
2023-04-05 - 20:04:08 [6]: .. dirty status: false
2023-04-05 - 20:04:08 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:04:08 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2023-04-05 - 20:04:08 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2023-04-05 - 20:04:44 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:04:51 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:05:22 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:05:41 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:06:29 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2023-04-05 - 20:07:04 [2]: QObject::setParent: Cannot set parent, new parent is in a different thread
2023-04-05 - 20:07:04 [6]: virtual QString PartitionViewStep::prettyStatus() const
Summary for Partition 1 Config::Manual
2023-04-05 - 20:07:04 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
Checking LVM use on 2 devices
2023-04-05 - 20:07:04 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
Building partition information map
2023-04-05 - 20:07:04 [6]: .. partitions on "/dev/nvme0n1"
2023-04-05 - 20:07:04 [6]: .. mapping for "/dev/nvme0n1p1" "/dev/nvme0n1p1"
partlabel : ""
partition-uuid (partuuid) : "PartUUID$8b63b7a2"
parttype : "0FC63DAF-8483-4772-8E79-3D69D8477DE4"
partattrs : "0"
mountPoint: : ""
fs: : "ext4"
fsName : "ext4"
filesystem-uuid (uuid) : "FSUUID$bcb54c58"
claimed : "false"
2023-04-05 - 20:07:04 [6]: .. partitions on "/dev/nvme1n1"
2023-04-05 - 20:07:04 [6]: .. mapping for "/dev/nvme1n1p1" "/dev/nvme1n1p1"
partlabel : ""
partition-uuid (partuuid) : "PartUUID$c7c401ca"
parttype : "EBD0A0A2-B9E5-4433-87C0-68B6B72699C7"
partattrs : "0"
mountPoint: : "/boot/efi"
fs: : "fat32"
fsName : "fat32"
filesystem-uuid (uuid) : "FSUUID$419ac5"
claimed : "false"
2023-04-05 - 20:07:04 [6]: .. mapping for "" "New Partition"
partlabel : ""
partition-uuid (partuuid) : "PartUUID$731f9aa4"
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
fsName : "linuxswap"
filesystem-uuid (uuid) : "FSUUID$bd429727"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "f2fs"
fsName : "f2fs"
claimed : "true"
2023-04-05 - 20:07:04 [6]: .. mapping for "" "unallocated"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "unknown"
fsName : "unknown"
claimed : "false"
partlabel : ""
partattrs : "0"
mountPoint: : ""
fs: : "ext4"
fsName : "ext4"
claimed : "false"
partlabel : ""
partattrs : "0"
fs: : "fat32"
fsName : "fat32"
claimed : "false"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "f2fs"
fsName : "f2fs"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "unknown"
fsName : "unknown"
claimed : "false"
2023-04-05 - 20:07:04 [2]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
partlabel : ""
partattrs : "0"
mountPoint: : ""
fs: : "ext4"
fsName : "ext4"
claimed : "false"
partlabel : ""
partattrs : "0"
fs: : "fat32"
fsName : "fat32"
claimed : "false"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "f2fs"
fsName : "f2fs"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "unknown"
fsName : "unknown"
claimed : "false"
partlabel : ""
partattrs : "0"
mountPoint: : ""
fs: : "ext4"
fsName : "ext4"
claimed : "false"
partlabel : ""
partattrs : "0"
fs: : "fat32"
fsName : "fat32"
claimed : "false"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "f2fs"
fsName : "f2fs"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "unknown"
fsName : "unknown"
claimed : "false"
2023-04-05 - 20:07:07 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
2023-04-05 - 20:07:07 [6]: void Calamares::JobThread::finalize()
There are 38 jobs, total weight 33
2023-04-05 - 20:07:07 [6]: .. Job 1 "Manage auto-mount settings" +wt 0.0833333 tot.wt 0.0833333
2023-04-05 - 20:07:07 [6]: .. Job 2 "Clear all temporary mounts." +wt 0.0833333 tot.wt 0.166667
2023-04-05 - 20:07:07 [6]: .. Job 3 "Clear mounts for partitioning operations on /dev/nvme1n1" +wt 0.0833333 tot.wt 0.25
2023-04-05 - 20:07:07 [6]: .. Job 4 "Set flags on partition /dev/nvme1n1p1." +wt 0.0833333 tot.wt 0.333333
2023-04-05 - 20:07:07 [6]: .. Job 5 "Delete partition /dev/nvme1n1p2." +wt 0.0833333 tot.wt 0.416667
2023-04-05 - 20:07:07 [6]: .. Job 6 "Delete partition /dev/nvme1n1p3." +wt 0.0833333 tot.wt 0.5
2023-04-05 - 20:07:07 [6]: .. Job 7 "Create new 9010MiB partition on /dev/nvme1n1 (Samsung SSD 960 EVO 250GB)." +wt 0.0833333 tot.wt 0.583333
2023-04-05 - 20:07:07 [6]: .. Job 8 "Set flags on 9010MiB linuxswap partition." +wt 0.0833333 tot.wt 0.666667
2023-04-05 - 20:07:07 [6]: .. Job 9 "Create new 228663MiB partition on /dev/nvme1n1 (Samsung SSD 960 EVO 250GB)." +wt 0.0833333 tot.wt 0.75
2023-04-05 - 20:07:07 [6]: .. Job 10 "Set flags on 228663MiB f2fs partition." +wt 0.0833333 tot.wt 0.833333
2023-04-05 - 20:07:07 [6]: .. Job 11 "Set partition information" +wt 0.0833333 tot.wt 0.916667
2023-04-05 - 20:07:07 [6]: .. Job 12 "Manage auto-mount settings" +wt 0.0833333 tot.wt 1
2023-04-05 - 20:07:07 [6]: .. Job 13 "mount" +wt 1 tot.wt 2
2023-04-05 - 20:07:07 [6]: .. Job 14 "unpackfs" +wt 12 tot.wt 14
2023-04-05 - 20:07:07 [6]: .. Job 15 "networkcfg" +wt 1 tot.wt 15
2023-04-05 - 20:07:07 [6]: .. Job 16 "Generate machine-id." +wt 1 tot.wt 16
2023-04-05 - 20:07:07 [6]: .. Job 17 "fstab" +wt 1 tot.wt 17
2023-04-05 - 20:07:07 [6]: .. Job 18 "Set timezone to America/New_York" +wt 1 tot.wt 18
2023-04-05 - 20:07:07 [6]: .. Job 19 "Set keyboard model to pc105, layout to us-" +wt 1 tot.wt 19
2023-04-05 - 20:07:07 [6]: .. Job 20 "localecfg" +wt 1 tot.wt 20
2023-04-05 - 20:07:07 [6]: .. Job 21 "Configuring encrypted swap." +wt 1 tot.wt 21
2023-04-05 - 20:07:07 [6]: .. Job 22 "Configuring LUKS key file." +wt 1 tot.wt 22
2023-04-05 - 20:07:07 [6]: .. Job 23 "initcpiocfg" +wt 1 tot.wt 23
2023-04-05 - 20:07:07 [6]: .. Job 24 "Creating initramfs with mkinitcpio." +wt 1 tot.wt 24
2023-04-05 - 20:07:07 [6]: .. Job 25 "Configure <pre>sudo</pre> users." +wt 0.166667 tot.wt 24.1667
2023-04-05 - 20:07:07 [6]: .. Job 26 "Preparing groups." +wt 0.166667 tot.wt 24.3333
2023-04-05 - 20:07:07 [6]: .. Job 27 "Create user vega" +wt 0.166667 tot.wt 24.5
2023-04-05 - 20:07:07 [6]: .. Job 28 "Set password for user vega" +wt 0.166667 tot.wt 24.6667
2023-04-05 - 20:07:07 [6]: .. Job 29 "Set password for user root" +wt 0.166667 tot.wt 24.8333
2023-04-05 - 20:07:07 [6]: .. Job 30 "Set hostname chuuni" +wt 0.166667 tot.wt 25
2023-04-05 - 20:07:07 [6]: .. Job 31 "displaymanager" +wt 1 tot.wt 26
2023-04-05 - 20:07:07 [6]: .. Job 32 "mhwdcfg" +wt 1 tot.wt 27
2023-04-05 - 20:07:07 [6]: .. Job 33 "hwclock" +wt 1 tot.wt 28
2023-04-05 - 20:07:07 [6]: .. Job 34 "services" +wt 1 tot.wt 29
2023-04-05 - 20:07:07 [6]: .. Job 35 "grubcfg" +wt 1 tot.wt 30
2023-04-05 - 20:07:07 [6]: .. Job 36 "bootloader" +wt 1 tot.wt 31
2023-04-05 - 20:07:07 [6]: .. Job 37 "postcfg" +wt 1 tot.wt 32
2023-04-05 - 20:07:07 [6]: .. Job 38 "Unmount file systems." +wt 1 tot.wt 33
2023-04-05 - 20:07:07 [6]: virtual void Calamares::JobThread::run()
Starting job "Manage auto-mount settings" ( 1 / 38 )
2023-04-05 - 20:07:07 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
Set automount to disable
2023-04-05 - 20:07:07 [6]: void CalamaresUtils::Partition::querySolidAutoMount(QDBusConnection&, AutoMountInfo&)
Solid not available: "Not connected to D-Bus server"
Starting job "Clear all temporary mounts." ( 2 / 38 )
Starting job "Clear mounts for partitioning operations on /dev/nvme1n1" ( 3 / 38 )
2023-04-05 - 20:07:07 [6]: QStringList getPartitionsForDevice(const QString&)
Reading from "/proc/partitions" looking for "nvme1n1"
2023-04-05 - 20:07:07 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
ClearMountsJob finished. Here's what was done:
2023-04-05 - 20:07:07 [6]: .. Running ("udevadm", "settle")
2023-04-05 - 20:07:07 [6]: .. Running ("sync")
2023-04-05 - 20:07:08 [6]: virtual void Calamares::JobThread::run()
Starting job "Set flags on partition /dev/nvme1n1p1." ( 4 / 38 )
2023-04-05 - 20:07:08 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
Setting flags on "/dev/nvme1n1" partition "/dev/nvme1n1p1"
"boot"
Starting job "Delete partition /dev/nvme1n1p2." ( 5 / 38 )
2023-04-05 - 20:07:09 [6]: virtual void Calamares::JobThread::run()
Starting job "Delete partition /dev/nvme1n1p3." ( 6 / 38 )
Starting job "Create new 9010MiB partition on /dev/nvme1n1 (Samsung SSD 960 EVO 250GB)." ( 7 / 38 )
2023-04-05 - 20:07:10 [6]: virtual void Calamares::JobThread::run()
Starting job "Set flags on partition /dev/nvme1n1p2." ( 8 / 38 )
2023-04-05 - 20:07:10 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
Setting flags on "/dev/nvme1n1" partition "/dev/nvme1n1p2"
"swap"
Starting job "Create new 228663MiB partition on /dev/nvme1n1 (Samsung SSD 960 EVO 250GB)." ( 9 / 38 )
2023-04-05 - 20:07:12 [6]: virtual void Calamares::JobThread::run()
Starting job "Set flags on partition /dev/nvme1n1p3." ( 10 / 38 )
2023-04-05 - 20:07:12 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
Setting flags on "/dev/nvme1n1" partition "/dev/nvme1n1p3"
"root"
Starting job "Set partition information" ( 11 / 38 )
2023-04-05 - 20:07:12 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
2023-04-05 - 20:07:12 [6]: .. partitions on "/dev/nvme0n1"
2023-04-05 - 20:07:12 [6]: .. mapping for "/dev/nvme0n1p1" "/dev/nvme0n1p1"
partlabel : ""
partattrs : "0"
mountPoint: : ""
fs: : "ext4"
fsName : "ext4"
claimed : "false"
2023-04-05 - 20:07:12 [6]: .. partitions on "/dev/nvme1n1"
2023-04-05 - 20:07:12 [6]: .. mapping for "/dev/nvme1n1p1" "/dev/nvme1n1p1"
partlabel : ""
partattrs : "0"
fs: : "fat32"
fsName : "fat32"
claimed : "false"
2023-04-05 - 20:07:12 [6]: .. mapping for "/dev/nvme1n1p2" "/dev/nvme1n1p2"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
filesystem-uuid (uuid) : "FSUUID$2e3e0844"
claimed : "true"
2023-04-05 - 20:07:12 [6]: .. mapping for "/dev/nvme1n1p3" "/dev/nvme1n1p3"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "f2fs"
fsName : "f2fs"
filesystem-uuid (uuid) : "FSUUID$384a9e69"
claimed : "true"
2023-04-05 - 20:07:12 [6]: .. mapping for "" "unallocated"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "unknown"
fsName : "unknown"
claimed : "false"
2023-04-05 - 20:07:12 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
Saving partition information map to GlobalStorage["partitions"]
FillGlobalStorageJob writing empty bootLoader value
Starting job "Manage auto-mount settings" ( 12 / 38 )
2023-04-05 - 20:07:12 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
Restore automount settings
Starting job "mount" ( 13 / 38 )
2023-04-05 - 20:07:12 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/mount/main.py"
2023-04-05 - 20:07:12 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:07:12 [6]: .. Job description from pretty_name "mount" = "Mounting partitions."
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "f2fs", "/dev/nvme1n1p3", "/tmp/calamares-root-c1jhkbd_/")
2023-04-05 - 20:07:12 [6]: .. Running ("udevadm", "settle")
2023-04-05 - 20:07:12 [6]: .. Running ("sync")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "vfat", "/dev/nvme1n1p1", "/tmp/calamares-root-c1jhkbd_/boot/efi")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-c1jhkbd_/dev")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "proc", "proc", "/tmp/calamares-root-c1jhkbd_/proc")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "tmpfs", "tmpfs", "/tmp/calamares-root-c1jhkbd_/run")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-c1jhkbd_/run/udev")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "sysfs", "sys", "/tmp/calamares-root-c1jhkbd_/sys")
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "efivarfs", "efivarfs", "/tmp/calamares-root-c1jhkbd_/sys/firmware/efi/efivars")
Starting job "unpackfs" ( 14 / 38 )
Job file "/usr/lib/calamares/modules/unpackfs/main.py"
2023-04-05 - 20:07:12 [6]: .. Job description from pretty_name "unpackfs" = "Filling up filesystems."
2023-04-05 - 20:07:12 [6]: .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmpdrcveb4_/rootfs")
2023-04-05 - 20:07:12 [6]: .. Finished. Exit code: 0 output:
mount: /tmp/tmpdrcveb4_/rootfs: WARNING: source write-protected, mounted read-only.
2023-04-05 - 20:07:12 [6]: .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs")
2023-04-05 - 20:07:13 [6]: .. Running ("rsync", "-aHAXr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--exclude", "/sys/firmware/efi/efivars/", "--progress", "/tmp/tmpdrcveb4_/rootfs/", "/tmp/calamares-root-c1jhkbd_")
2023-04-05 - 20:07:29 [6]: .. Running ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmpdrcveb4_/desktopfs")
2023-04-05 - 20:07:29 [6]: .. Finished. Exit code: 0 output:
mount: /tmp/tmpdrcveb4_/desktopfs: WARNING: source write-protected, mounted read-only.
2023-04-05 - 20:07:29 [6]: .. Running ("udevadm", "settle")
2023-04-05 - 20:07:29 [6]: .. Running ("sync")
2023-04-05 - 20:07:30 [6]: .. Running ("unsquashfs", "-l", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs")
2023-04-05 - 20:07:30 [6]: .. Running ("rsync", "-aHAXr", "--filter=-x trusted.overlay.*", "--exclude", "/proc/", "--exclude", "/sys/", "--exclude", "/dev/", "--exclude", "/run/", "--exclude", "/run/udev/", "--exclude", "/sys/firmware/efi/efivars/", "--progress", "/tmp/tmpdrcveb4_/desktopfs/", "/tmp/calamares-root-c1jhkbd_")
2023-04-05 - 20:08:28 [6]: virtual void Calamares::JobThread::run()
Starting job "networkcfg" ( 15 / 38 )
2023-04-05 - 20:08:28 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/networkcfg/main.py"
2023-04-05 - 20:08:28 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:08:28 [6]: .. Job description from pretty_name "networkcfg" = "Saving network configuration."
Starting job "Generate machine-id." ( 16 / 38 )
2023-04-05 - 20:08:28 [6]: .. Running ("systemd-machine-id-setup")
2023-04-05 - 20:08:28 [6]: .. Finished. Exit code: 0 output:
Initializing machine ID from random generator.
2023-04-05 - 20:08:28 [6]: .. Running ("ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id")
2023-04-05 - 20:08:29 [6]: virtual void Calamares::JobThread::run()
Starting job "fstab" ( 17 / 38 )
2023-04-05 - 20:08:29 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/fstab/main.py"
2023-04-05 - 20:08:29 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:08:29 [6]: .. Job description from pretty_name "fstab" = "Writing fstab."
Starting job "Set timezone to America/New_York" ( 18 / 38 )
2023-04-05 - 20:08:29 [6]: .. Running ("rm", "-f", "/etc/localtime")
2023-04-05 - 20:08:29 [6]: .. Running ("ln", "-s", "/usr/share/zoneinfo/America/New_York", "/etc/localtime")
Starting job "Set keyboard model to pc105, layout to us-" ( 19 / 38 )
2023-04-05 - 20:08:29 [6]: virtual Calamares::JobResult SetKeyboardLayoutJob::exec()
Executing SetKeyboardLayoutJob
2023-04-05 - 20:08:29 [6]: bool SetKeyboardLayoutJob::writeVConsoleData(const QString&, const QString&) const
Writing vconsole data to "/tmp/calamares-root-c1jhkbd_/etc/vconsole.conf"
2023-04-05 - 20:08:29 [6]: QString SetKeyboardLayoutJob::findConvertedKeymap(const QString&) const
Looking for converted keymap in "/tmp/calamares-root-c1jhkbd_/lib/kbd/keymaps/xkb"
2023-04-05 - 20:08:29 [6]: QString findLegacyKeymap(const QString&, const QString&, const QString&)
Looking for legacy keymap "us" "pc105" "" in QRC
2023-04-05 - 20:08:29 [6]: .. Found legacy keymap "us" with score 11
2023-04-05 - 20:08:29 [6]: .. Found legacy keymap "us-acentos" with score 11
2023-04-05 - 20:08:29 [6]: .. Found legacy keymap "dvorak" with score 11
2023-04-05 - 20:08:29 [6]: .. Written KEYMAP= "us" to vconsole.conf 0
2023-04-05 - 20:08:29 [6]: bool SetKeyboardLayoutJob::writeX11Data(const QString&) const
Writing X11 configuration to "/tmp/calamares-root-c1jhkbd_/etc/X11/xorg.conf.d/00-keyboard.conf"
2023-04-05 - 20:08:29 [6]: .. Written XkbLayout "us" ; XkbModel "pc105" ; XkbVariant "" to X.org file "/tmp/calamares-root-c1jhkbd_/etc/X11/xorg.conf.d/00-keyboard.conf" 0
2023-04-05 - 20:08:29 [6]: bool SetKeyboardLayoutJob::writeDefaultKeyboardData(const QString&) const
Writing default keyboard data to "/tmp/calamares-root-c1jhkbd_/etc/default/keyboard"
2023-04-05 - 20:08:29 [6]: .. Written XKBMODEL "pc105" ; XKBLAYOUT "us" ; XKBVARIANT "" to /etc/default/keyboard file "/tmp/calamares-root-c1jhkbd_/etc/default/keyboard" 0
Starting job "localecfg" ( 20 / 38 )
Job file "/usr/lib/calamares/modules/localecfg/main.py"
2023-04-05 - 20:08:29 [6]: .. Job description from pretty_name "localecfg" = "Configuring locales."
2023-04-05 - 20:08:29 [6]: .. Running ("locale-gen")
2023-04-05 - 20:08:30 [6]: .. Finished. Exit code: 0 output:
Generating locales...
en_US.UTF-8... done
Generation complete.
2023-04-05 - 20:08:30 [6]: [PYTHON JOB]: "/tmp/calamares-root-c1jhkbd_/etc/locale.gen done"
2023-04-05 - 20:08:30 [6]: [PYTHON JOB]: "/tmp/calamares-root-c1jhkbd_/etc/locale.conf done"
2023-04-05 - 20:08:30 [6]: [PYTHON JOB]: "/tmp/calamares-root-c1jhkbd_/etc/default done"
2023-04-05 - 20:08:30 [6]: virtual void Calamares::JobThread::run()
Starting job "Configuring encrypted swap." ( 21 / 38 )
2023-04-05 - 20:08:30 [6]: void write_openswap_conf(const QString&, QStringList&, const LOSHInfo&)
Will not write an invalid configuration to "/etc/openswap.conf"
Starting job "Configuring LUKS key file." ( 22 / 38 )
2023-04-05 - 20:08:30 [6]: virtual Calamares::JobResult LuksBootKeyFileJob::exec()
There are 0 LUKS partitions
2023-04-05 - 20:08:30 [6]: .. Nothing to do for LUKS.
Starting job "initcpiocfg" ( 23 / 38 )
2023-04-05 - 20:08:30 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/initcpiocfg/main.py"
2023-04-05 - 20:08:30 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:08:30 [6]: .. Job description from pretty_name "initcpiocfg" = "Configuring mkinitcpio."
2023-04-05 - 20:08:30 [6]: .. Running ("sh", "-c", "which plymouth")
/usr/bin/plymouth
Starting job "Creating initramfs with mkinitcpio." ( 24 / 38 )
2023-04-05 - 20:08:30 [6]: virtual Calamares::JobResult InitcpioJob::exec()
Updating initramfs with kernel "linux61"
2023-04-05 - 20:08:30 [6]: .. Running ("mkinitcpio", "-p", "linux61")
2023-04-05 - 20:08:45 [6]: .. Finished. Exit code: 0 output:
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.19-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
2023-04-05 - 20:08:45 [6]: virtual void Calamares::JobThread::run()
Starting job "Configure <pre>sudo</pre> users." ( 25 / 38 )
Starting job "Preparing groups." ( 26 / 38 )
2023-04-05 - 20:08:45 [6]: .. Running ("groupadd", "autologin")
Starting job "Create user vega" ( 27 / 38 )
2023-04-05 - 20:08:45 [6]: virtual Calamares::JobResult CreateUserJob::exec()
[CREATEUSER]: creating user
2023-04-05 - 20:08:45 [6]: .. Running ("useradd", "-m", "-U", "-s", "/bin/zsh", "-c", "Vega", "vega")
2023-04-05 - 20:08:45 [6]: .. Running "usermod" "-aG" "lp,network,power,wheel,users,storage,input,audio,autologin" "vega"
2023-04-05 - 20:08:45 [6]: .. Running ("chown", "-R", "vega:vega", "/home/vega")
Starting job "Set password for user vega" ( 28 / 38 )
2023-04-05 - 20:08:45 [6]: .. Running "usermod" "-p" <password> "vega"
Starting job "Set password for user root" ( 29 / 38 )
2023-04-05 - 20:08:45 [6]: .. Running "usermod" "-p" <password> "root"
Starting job "Set hostname chuuni" ( 30 / 38 )
Starting job "displaymanager" ( 31 / 38 )
2023-04-05 - 20:08:45 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/displaymanager/main.py"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:08:45 [6]: .. Job description from __doc__ "displaymanager" = "Configure display managers."
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "lightdm selected but not installed"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "mdm selected but not installed"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "sddm selected but not installed"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "lxdm selected but not installed"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "slim selected but not installed"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "Using rootMountPoint '/tmp/calamares-root-c1jhkbd_'"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: ".. selected DE gnome"
2023-04-05 - 20:08:45 [6]: [PYTHON JOB]: "Setting up autologin for user vega."
Starting job "mhwdcfg" ( 32 / 38 )
Job file "/usr/lib/calamares/modules/mhwdcfg/main.py"
2023-04-05 - 20:08:45 [6]: .. Job description from __doc__ "mhwdcfg" = "Configure the hardware"
2023-04-05 - 20:08:45 [6]: .. Running ("mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2023-04-05 - 20:08:46 [6]: .. Finished. Exit code: 0 output:
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mNo config found for device: 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
e[1me[31mWarning: e[mNo config found for device: 0000:07:00.0 (0200:8086:3165) Network controller Intel Corporation Wireless 3165
2023-04-05 - 20:08:46 [6]: .. Running ("mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
e[1me[31mWarning: e[mNo device of class 0280 found!
2023-04-05 - 20:08:46 [6]: .. Running ("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2023-04-05 - 20:08:50 [6]: .. Finished. Exit code: 0 output:
e[1me[31m> e[mUsing config 'video-linux' for device: 0000:0b:00.0 (0300:1002:15dd) Display controller ATI Technologies Inc Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
e[1me[31m> e[mInstalling video-linux...
e[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'extra' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'community' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'multilib' does not exist (use '-Sy' to download)
e[me[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0380
e[me[0;32mProcessing classid: 0302
e[me[0;32m:: Synchronizing package databases...
e[me[0;32m mhwd downloading...
e[me[0;32mresolving dependencies...
e[me[0;32mlooking for conflicting packages...
e[me[0;32mwarning: dependency cycle detected:
e[me[0;32mwarning: lib32-keyutils will be installed before its lib32-krb5 dependency
e[me[0;32mwarning: lib32-mesa will be installed before its lib32-libglvnd dependency
e[me[0;32m
e[me[0;32mPackages (64) lib32-brotli-1.0.9-5 lib32-bzip2-1.0.8-3 lib32-curl-7.87.0-1 lib32-e2fsprogs-1.47.0-1 lib32-expat-2.5.0-2 lib32-gcc-libs-12.2.1-2 lib32-glibc-2.37-2 lib32-icu-72.1-2 lib32-keyutils-1.6.3-1 lib32-krb5-1.20.1-1 lib32-libcap-2.67-1 lib32-libdrm-2.4.114-1 lib32-libelf-0.188-1 lib32-libffi-3.4.4-1 lib32-libgcrypt-1.10.1-2 lib32-libglvnd-1.6.0-1 lib32-libgpg-error-1.46-1 lib32-libidn2-2.3.4-2 lib32-libldap-2.6.3-3 lib32-libpciaccess-0.17-1 lib32-libpsl-0.21.1-3 lib32-libssh2-1.e[me[0;32m10.0-2 lib32-libtirpc-1.3.3-2 lib32-libunistring-1.1-1 lib32-libunwind-1.6.2-2 lib32-libva-2.17.0-1 lib32-libvdpau-1.5-1 lib32-libx11-1.8.3-1.1 lib32-libxau-1.0.11-1 lib32-libxcb-1.15-2 lib32-libxcrypt-4.4.33-1 lib32-libxdamage-1.1.6-1 lib32-libxdmcp-1.1.4-1 lib32-libxext-1.3.5-1 lib32-libxfixes-6.0.0-2 lib32-libxml2-2.10.3-2 lib32-libxshmfence-1.3.2-1 lib32-libxxf86vm-1.1.5-1 lib32-llvm-libs-15.0.7-1 lib32-lm_sensors-1:3.6.0.r41.g31d1f125-2 lib32-mesa-22.3.5-1 lib32-ncurses-6.4-1 lib3e[me[0;32m2-openssl-1:3.0.8-0.1 lib32-pam-1.5.2-1 lib32-systemd-252.5-1 lib32-vulkan-icd-loader-1.3.240-1 lib32-wayland-1.21.0-1 lib32-xz-5.4.1-1 lib32-zlib-1.2.13-2 lib32-zstd-1.5.2-1 libxvmc-1.0.13-1 lib32-libva-vdpau-driver-0.7.4-7 lib32-mesa-vdpau-22.3.5-1 lib32-vulkan-intel-22.3.5-1 lib32-vulkan-radeon-22.3.5-1 libva-mesa-driver-22.3.5-1 libva-vdpau-driver-0.7.4-6 mesa-vdpau-22.3.5-1 vulkan-intel-22.3.5-1 vulkan-radeon-22.3.5-1 xf86-video-amdgpu-22.0.0-1 xf86-video-ati-1:19.1.0.r15.g7a6a34af-e[me[0;32m1 xf86-video-intel-1:2.99.917+923+gb74b67f0-1 xf86-video-nouveau-1.0.17-2
e[me[0;32m
e[me[0;32mTotal Download Size: 139.52 MiB
e[me[0;32mTotal Installed Size: 479.67 MiB
e[me[0;32m
e[me[0;32m:: Proceed with installation? [Y/n]
e[me[0;32m:: Retrieving packages...
e[me[0;32m lib32-llvm-libs-15.0.7-1-x86_64 downloading...
e[me[0;32m lib32-gcc-libs-12.2.1-2-x86_64 downloading...
e[me[0;32m lib32-mesa-22.3.5-1-x86_64 downloading...
e[me[0;32m lib32-icu-72.1-2-x86_64 downloading...
e[me[0;32m lib32-vulkan-intel-22.3.5-1-x86_64 downloading...
e[me[0;32m vulkan-intel-22.3.5-1-x86_64 downloading...
e[me[0;32m lib32-mesa-vdpau-22.3.5-1-x86_64 downloading...
e[me[0;32m libva-mesa-driver-22.3.5-1-x86_64 downloading...
e[me[0;32m mesa-vdpau-22.3.5-1-x86_64 downloading...
e[me[0;32m lib32-glibc-2.37-2-x86_64 downloading...
e[me[0;32m lib32-vulkan-radeon-22.3.5-1-x86_64 downloading...
e[me[0;32m vulkan-radeon-22.3.5-1-x86_64 downloading...
e[me[0;32m lib32-openssl-1:3.0.8-0.1-x86_64 downloading...
e[me[0;32m lib32-krb5-1.20.1-1-x86_64 downloading...
e[me[0;32m lib32-systemd-252.5-1-x86_64 downloading...
e[me[0;32m lib32-libx11-1.8.3-1.1-x86_64 downloading...
e[me[0;32m xf86-video-intel-1:2.99.917+923+gb74b67f0-1-x86_64 downloading...
e[me[0;32m lib32-libxml2-2.10.3-2-x86_64 downloading...
e[me[0;32m lib32-libelf-0.188-1-x86_64 downloading...
e[me[0;32m lib32-libunistring-1.1-1-x86_64 downloading...
e[me[0;32m lib32-libgcrypt-1.10.1-2-x86_64 downloading...
e[me[0;32m lib32-brotli-1.0.9-5-x86_64 downloading...
e[me[0;32m lib32-curl-7.87.0-1-x86_64 downloading...
e[me[0;32m lib32-zstd-1.5.2-1-x86_64 downloading...
e[me[0;32m lib32-e2fsprogs-1.47.0-1-x86_64 downloading...
e[me[0;32m lib32-ncurses-6.4-1-x86_64 downloading...
e[me[0;32m lib32-libglvnd-1.6.0-1-x86_64 downloading...
e[me[0;32m lib32-libxcb-1.15-2-x86_64 downloading...
e[me[0;32m lib32-libldap-2.6.3-3-x86_64 downloading...
e[me[0;32m lib32-pam-1.5.2-1-x86_64 downloading...
e[me[0;32m xf86-video-ati-1:19.1.0.r15.g7a6a34af-1-x86_64 downloading...
e[me[0;32m lib32-libdrm-2.4.114-1-x86_64 downloading...
e[me[0;32m lib32-vulkan-icd-loader-1.3.240-1-x86_64 downloading...
e[me[0;32m lib32-libssh2-1.10.0-2-x86_64 downloading...
e[me[0;32m lib32-xz-5.4.1-1-x86_64 downloading...
e[me[0;32m xf86-video-nouveau-1.0.17-2-x86_64 downloading...
e[me[0;32m lib32-libva-2.17.0-1-x86_64 downloading...
e[me[0;32m lib32-libtirpc-1.3.3-2-x86_64 downloading...
e[me[0;32m lib32-expat-2.5.0-2-x86_64 downloading...
e[me[0;32m lib32-libxcrypt-4.4.33-1-x86_64 downloading...
e[me[0;32m xf86-video-amdgpu-22.0.0-1-x86_64 downloading...
e[me[0;32m lib32-libgpg-error-1.46-1-x86_64 downloading...
e[me[0;32m lib32-libpsl-0.21.1-3-x86_64 downloading...
e[me[0;32m lib32-wayland-1.21.0-1-x86_64 downloading...
e[me[0;32m lib32-libidn2-2.3.4-2-x86_64 downloading...
e[me[0;32m lib32-libunwind-1.6.2-2-x86_64 downloading...
e[me[0;32m lib32-zlib-1.2.13-2-x86_64 downloading...
e[me[0;32m lib32-libva-vdpau-driver-0.7.4-7-x86_64 downloading...
e[me[0;32m libva-vdpau-driver-0.7.4-6-x86_64 downloading...
e[me[0;32m lib32-bzip2-1.0.8-3-x86_64 downloading...
e[me[0;32m lib32-libcap-2.67-1-x86_64 downloading...
e[me[0;32m lib32-libxext-1.3.5-1-x86_64 downloading...
e[me[0;32m libxvmc-1.0.13-1-x86_64 downloading...
e[me[0;32m lib32-lm_sensors-1:3.6.0.r41.g31d1f125-2-x86_64 downloading...
e[me[0;32m lib32-libvdpau-1.5-1-x86_64 downloading...
e[me[0;32m lib32-libpciaccess-0.17-1-x86_64 downloading...
e[me[0;32m lib32-libffi-3.4.4-1-x86_64 downloading...
e[me[0;32m lib32-libxfixes-6.0.0-2-x86_64 downloading...
e[me[0;32m lib32-libxdmcp-1.1.4-1-x86_64 downloading...
e[me[0;32m lib32-libxxf86vm-1.1.5-1-x86_64 downloading...
e[me[0;32m lib32-keyutils-1.6.3-1-x86_64 downloading...
e[me[0;32m lib32-libxau-1.0.11-1-x86_64 downloading...
e[me[0;32m lib32-libxdamage-1.1.6-1-x86_64 downloading...
e[me[0;32m lib32-libxshmfence-1.3.2-1-x86_64 downloading...
e[me[0;32mchecking keyring...
e[me[0;32mchecking package integrity...
e[me[0;32mloading package files...
e[me[0;32mchecking for file conflicts...
e[me[0;32mchecking available disk space...
e[me[0;32m:: Processing package changes...
e[me[0;32minstalling lib32-glibc...
e[me[0;32minstalling lib32-vulkan-icd-loader...
e[me[0;32mOptional dependencies for lib32-vulkan-icd-loader
e[me[0;32m lib32-vulkan-driver: packaged vulkan driver [pending]
e[me[0;32minstalling xf86-video-ati...
e[me[0;32minstalling xf86-video-amdgpu...
e[me[0;32minstalling libxvmc...
e[me[0;32minstalling xf86-video-intel...
e[me[0;32m>>> This driver now uses DRI3 as the default Direct Rendering
e[me[0;32m Infrastructure. You can try falling back to DRI2 if you run
e[me[0;32m into trouble. To do so, save a file with the following
e[me[0;32m content as /etc/X11/xorg.conf.d/20-intel.conf :
e[me[0;32m Section "Device"
e[me[0;32m Identifier "Intel Graphics"
e[me[0;32m Driver "intel"
e[me[0;32m Option "DRI" "2" # DRI3 is now default
e[me[0;32m #Option "AccelMethod" "sna" # default
e[me[0;32m #Option "AccelMethod" "uxa" # fallback
e[me[0;32m EndSection
e[me[0;32mOptional dependencies for xf86-video-intel
e[me[0;32m libxrandr: for intel-virtual-output [installed]
e[me[0;32m libxinerama: for intel-virtual-output [installed]
e[me[0;32m libxcursor: for intel-virtual-output [installed]
e[me[0;32m libxtst: for intel-virtual-output [installed]
e[me[0;32m libxss: for intel-virtual-output [installed]
e[me[0;32minstalling xf86-video-nouveau...
e[me[0;32minstalling vulkan-intel...
e[me[0;32mOptional dependencies for vulkan-intel
e[me[0;32m vulkan-mesa-layers: additional vulkan layers
e[me[0;32minstalling vulkan-radeon...
e[me[0;32mOptional dependencies for vulkan-radeon
e[me[0;32minstalling libva-mesa-driver...
e[me[0;32minstalling libva-vdpau-driver...
e[me[0;32minstalling mesa-vdpau...
e[me[0;32minstalling lib32-libffi...
e[me[0;32minstalling lib32-expat...
e[me[0;32minstalling lib32-gcc-libs...
e[me[0;32minstalling lib32-icu...
e[me[0;32minstalling lib32-xz...
e[me[0;32minstalling lib32-zlib...
e[me[0;32minstalling lib32-libxml2...
e[me[0;32minstalling lib32-wayland...
e[me[0;32minstalling lib32-libxdmcp...
e[me[0;32minstalling lib32-libxau...
e[me[0;32minstalling lib32-libxcb...
e[me[0;32minstalling lib32-libx11...
e[me[0;32minstalling lib32-libxshmfence...
e[me[0;32minstalling lib32-libpciaccess...
e[me[0;32minstalling lib32-libdrm...
e[me[0;32minstalling lib32-zstd...
e[me[0;32minstalling lib32-e2fsprogs...
e[me[0;32minstalling lib32-openssl...
e[me[0;32mOptional dependencies for lib32-openssl
e[me[0;32m ca-certificates [installed]
e[me[0;32minstalling lib32-libxcrypt...
e[me[0;32minstalling lib32-libldap...
e[me[0;32minstalling lib32-keyutils...
e[me[0;32minstalling lib32-krb5...
e[me[0;32minstalling lib32-libtirpc...
e[me[0;32minstalling lib32-pam...
e[me[0;32minstalling lib32-libcap...
e[me[0;32minstalling lib32-libgpg-error...
e[me[0;32minstalling lib32-libgcrypt...
e[me[0;32minstalling lib32-systemd...
e[me[0;32minstalling lib32-vulkan-intel...
e[me[0;32mOptional dependencies for lib32-vulkan-intel
e[me[0;32m lib32-vulkan-mesa-layers: additional vulkan layers
e[me[0;32minstalling lib32-bzip2...
e[me[0;32minstalling lib32-brotli...
e[me[0;32minstalling lib32-libunistring...
e[me[0;32minstalling lib32-libidn2...
e[me[0;32minstalling lib32-libssh2...
e[me[0;32minstalling lib32-libpsl...
e[me[0;32minstalling lib32-curl...
e[me[0;32minstalling lib32-libelf...
e[me[0;32minstalling lib32-ncurses...
e[me[0;32minstalling lib32-llvm-libs...
e[me[0;32minstalling lib32-vulkan-radeon...
e[me[0;32mOptional dependencies for lib32-vulkan-radeon
e[me[0;32minstalling lib32-libxext...
e[me[0;32minstalling lib32-libxxf86vm...
e[me[0;32minstalling lib32-libxfixes...
e[me[0;32minstalling lib32-libxdamage...
e[me[0;32minstalling lib32-libunwind...
e[me[0;32minstalling lib32-lm_sensors...
e[me[0;32minstalling lib32-mesa...
e[me[0;32mOptional dependencies for lib32-mesa
e[me[0;32m opengl-man-pages: for the OpenGL API man pages
e[me[0;32m lib32-mesa-vdpau: for accelerated video playback [pending]
e[me[0;32m lib32-libva-mesa-driver: for accelerated video playback
e[me[0;32minstalling lib32-libglvnd...
e[me[0;32minstalling lib32-libva...
e[me[0;32mOptional dependencies for lib32-libva
e[me[0;32m lib32-libva-intel-driver: backend for Intel GPUs (<= Haswell)
e[me[0;32m lib32-libva-mesa-driver: backend for AMD and Nvidia GPUs
e[me[0;32minstalling lib32-libvdpau...
e[me[0;32minstalling lib32-libva-vdpau-driver...
e[me[0;32minstalling lib32-mesa-vdpau...
e[me[0;32m:: Running post-transaction hooks...
e[me[0;32m(1/1) Arming ConditionNeedsUpdate...
e[me[0;32mxf86-video-ati: install reason has been set to 'explicitly installed'
e[me[0;32mxf86-video-amdgpu: install reason has been set to 'explicitly installed'
e[me[0;32mxf86-video-intel: install reason has been set to 'explicitly installed'
e[me[0;32mxf86-video-nouveau: install reason has been set to 'explicitly installed'
e[me[0;32mvulkan-intel: install reason has been set to 'explicitly installed'
e[me[0;32mvulkan-radeon: install reason has been set to 'explicitly installed'
e[me[0;32mlibva-mesa-driver: install reason has been set to 'explicitly installed'
e[me[0;32mlibva-vdpau-driver: install reason has been set to 'explicitly installed'
e[me[0;32mmesa-vdpau: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-vulkan-intel: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-vulkan-radeon: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-libva-vdpau-driver: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-mesa-vdpau: install reason has been set to 'explicitly installed'
e[me[1me[31m> e[mSuccessfully installed video-linux
2023-04-05 - 20:08:50 [6]: .. Running ("mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2023-04-05 - 20:08:51 [6]: .. Finished. Exit code: 0 output:
e[1me[31mWarning: e[mNo device of class 0302 found!
2023-04-05 - 20:08:51 [6]: .. Running ("mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
2023-04-05 - 20:08:52 [6]: .. Finished. Exit code: 0 output:
e[1me[31mWarning: e[mNo device of class 0380 found!
2023-04-05 - 20:08:52 [6]: virtual void Calamares::JobThread::run()
Starting job "hwclock" ( 33 / 38 )
2023-04-05 - 20:08:52 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
Job file "/usr/lib/calamares/modules/hwclock/main.py"
2023-04-05 - 20:08:52 [6]: [PYTHON JOB]: Found gettext "en_US" in "/usr/share/locale/en_US"
2023-04-05 - 20:08:52 [6]: .. Job description from pretty_name "hwclock" = "Setting hardware clock."
2023-04-05 - 20:08:52 [6]: .. Running ("hwclock", "--systohc", "--utc")
2023-04-05 - 20:08:52 [6]: [PYTHON JOB]: "Hwclock set using RTC method."
Starting job "services" ( 34 / 38 )
Job file "/usr/lib/calamares/modules/services/main.py"
2023-04-05 - 20:08:52 [6]: .. Job description from pretty_name "services" = "Configure systemd services"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "apparmor.service")
Created symlink /etc/systemd/system/multi-user.target.wants/apparmor.service -> /usr/lib/systemd/system/apparmor.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "bluetooth.service")
Created symlink /etc/systemd/system/dbus-org.bluez.service -> /usr/lib/systemd/system/bluetooth.service.
Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service -> /usr/lib/systemd/system/bluetooth.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "btrfs-balance.timer.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "btrfs-balance.timer.service") Exit code: 1 output:
Failed to enable unit, unit btrfs-balance.timer.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service btrfs-balance.timer"
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "systemctl enable call in chroot returned error code 1"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "btrfs-scrub.timer.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "btrfs-scrub.timer.service") Exit code: 1 output:
Failed to enable unit, unit btrfs-scrub.timer.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service btrfs-scrub.timer"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "btrfs-trim.timer.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "btrfs-trim.timer.service") Exit code: 1 output:
Failed to enable unit, unit btrfs-trim.timer.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service btrfs-trim.timer"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "cups.service")
Created symlink /etc/systemd/system/printer.target.wants/cups.service -> /usr/lib/systemd/system/cups.service.
Created symlink /etc/systemd/system/multi-user.target.wants/cups.service -> /usr/lib/systemd/system/cups.service.
Created symlink /etc/systemd/system/sockets.target.wants/cups.socket -> /usr/lib/systemd/system/cups.socket.
Created symlink /etc/systemd/system/multi-user.target.wants/cups.path -> /usr/lib/systemd/system/cups.path.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "fstrim.timer.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "fstrim.timer.service") Exit code: 1 output:
Failed to enable unit, unit fstrim.timer.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service fstrim.timer"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "haveged.service")
Created symlink /etc/systemd/system/sysinit.target.wants/haveged.service -> /usr/lib/systemd/system/haveged.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "ModemManager.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service -> /usr/lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service -> /usr/lib/systemd/system/ModemManager.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "NetworkManager.service")
Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service.
Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service -> /usr/lib/systemd/system/NetworkManager-dispatcher.service.
Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service -> /usr/lib/systemd/system/NetworkManager-wait-online.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "pkgfile–update.timer.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "pkgfile–update.timer.service") Exit code: 1 output:
Invalid unit name "pkgfile–update.timer.service" escaped as "pkgfile\xe2\x80\x93update.timer.service" (maybe you should use systemd-escape?).
Failed to enable unit, unit pkgfile\xe2\x80\x93update.timer.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service pkgfile–update.timer"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "snapd.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "snapd.service") Exit code: 1 output:
Failed to enable unit, unit snapd.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service snapd"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "snapd.apparmor.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "snapd.apparmor.service") Exit code: 1 output:
Failed to enable unit, unit snapd.apparmor.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service snapd.apparmor"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "systemd-timesyncd.service")
Created symlink /etc/systemd/system/dbus-org.freedesktop.timesync1.service -> /usr/lib/systemd/system/systemd-timesyncd.service.
Created symlink /etc/systemd/system/sysinit.target.wants/systemd-timesyncd.service -> /usr/lib/systemd/system/systemd-timesyncd.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "touchegg.service.service")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("systemctl", "enable", "touchegg.service.service") Exit code: 1 output:
Failed to enable unit, unit touchegg.service.service does not exist.
2023-04-05 - 20:08:52 [2]: WARNING: [PYTHON JOB]: "Cannot enable systemd .service touchegg.service"
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "ufw.service")
Created symlink /etc/systemd/system/multi-user.target.wants/ufw.service -> /usr/lib/systemd/system/ufw.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "gdm.service")
Created symlink /etc/systemd/system/display-manager.service -> /usr/lib/systemd/system/gdm.service.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "enable", "graphical.target")
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
* A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
* A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
* A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
* In case of template units, the unit is meant to be enabled with some
instance name specified.
2023-04-05 - 20:08:52 [6]: .. Running ("systemctl", "disable", "pacman-init.service")
Starting job "grubcfg" ( 35 / 38 )
Job file "/usr/lib/calamares/modules/grubcfg/main.py"
2023-04-05 - 20:08:52 [6]: .. Job description from pretty_name "grubcfg" = "Configure GRUB."
2023-04-05 - 20:08:52 [6]: .. Running ("sh", "-c", "which dracut")
2023-04-05 - 20:08:52 [6]: .. Target cmd: ("sh", "-c", "which dracut") Exit code: 1 output:
which: no dracut in (/home/manjaro/.local/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
2023-04-05 - 20:08:52 [6]: .. Running ("sh", "-c", "which plymouth")
/usr/bin/plymouth
Starting job "bootloader" ( 36 / 38 )
Job file "/usr/lib/calamares/modules/bootloader/main.py"
2023-04-05 - 20:08:52 [6]: .. Job description from pretty_name "bootloader" = "Install bootloader."
2023-04-05 - 20:08:52 [6]: [PYTHON JOB]: "Bootloader: grub (efi)"
2023-04-05 - 20:08:52 [6]: .. Running ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force")
2023-04-05 - 20:08:53 [6]: .. Target cmd: ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force") Exit code: 1 output:
Installing for x86_64-efi platform.
grub-install: error: unknown filesystem.
2023-04-05 - 20:08:53 [2]: WARNING: [PYTHON JOB]: "Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force' returned non-zero exit status 1."
2023-04-05 - 20:08:53 [6]: [PYTHON JOB]: "stdout:Installing for x86_64-efi platform.\ngrub-install: error: unknown filesystem."
2023-04-05 - 20:08:53 [6]: [PYTHON JOB]: "stderr:None"
2023-04-05 - 20:08:53 [6]: virtual void Calamares::JobThread::run()
Skipping non-emergency job "postcfg"
2023-04-05 - 20:08:53 [6]: .. Skipping non-emergency job "Unmount file systems."
2023-04-05 - 20:08:53 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
ERROR: Installation failed: "Bootloader installation error"
2023-04-05 - 20:08:53 [6]: .. - message: "Bootloader installation error"
2023-04-05 - 20:08:53 [6]: .. - details: The bootloader could not be installed. The installation command <pre>grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force</pre> returned error code 1.
2023-04-05 - 20:08:53 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
Calamares will quit when the dialog closes.
2023-04-05 - 20:08:53 [6]: void Config::doNotify(bool, bool)
Notification not sent; completion: failed
