Bootloader error persists
I’m encountering a persistent bootloader problem despite trying the fixes recommended in various threads on this problem. I’ve disabled secure boot in the bios and I’ve reformatted to GPT in gparted. And I’ve tried what I can understand (which isn’t much!) from the wiki on this topic.
But I still get the dreaded bootloader error when trying to install onto an Acer laptop. Messages like “grub install returned non-zero exit status 1”, “Could not prepare Boot variable: interrupted system call grub-install”, “efi bootmgr failed to register the boot entry.”
Surely it shouldn’t be this problematic to install Manjaro from the official image? What am I missing?
Any help gratefully received, otherwise I’ll never get this laptop off the live usb.
Are you sure your firmware is supporting UEFI?
In case you tried installing in UEFI mode, have you disabled Legacy boot (CSM)?
Can you boot a Manjaro live ISO and post
inxi -Fazy
sudo parted -l
sudo efibootmgr -v
Next time you try to install using Calamares start it in debug mode by:
sudo calamares -d
Thank you. Results of the above:
> manjaro@manjaro ~]$ inxi -Fazy
> System:
>   Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
>   parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
>   misobasedir=manjaro misolabel=MANJARO_XFCE_2021 quiet systemd.show_status=1
>   apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
>   radeon.modeset=1
>   Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
>   dm: LightDM 1.30.0 Distro: Manjaro Linux
> Machine:
>   Type: Convertible System: Acer product: Spin SP111-31 v: V1.02
>   serial: <filter>
>   Mobo: APL model: Ironhide_AP v: V1.02 serial: <filter> UEFI: Insyde v: 1.02
>   date: 01/04/2017
> Battery:
>   ID-1: BAT0 charge: 48.0 Wh condition: 48.0/48.9 Wh (98%) volts: 17.0/15.2
>   model: LGC AC14B8K type: Li-ion serial: <filter> status: Not charging
> CPU:
>   Info: Dual Core model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont
>   family: 6 model-id: 5C (92) stepping: 9 microcode: 40 L2 cache: 1024 KiB
>   flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4378
>   Speed: 961 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 961 2: 953
>   Vulnerabilities: Type: itlb_multihit status: Not affected
>   Type: l1tf status: Not affected
>   Type: mds status: Not affected
>   Type: meltdown status: Not affected
>   Type: spec_store_bypass status: Not affected
>   Type: spectre_v1
>   mitigation: usercopy/swapgs barriers and __user pointer sanitization
>   Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
>   IBRS_FW, STIBP: disabled, RSB filling
>   Type: srbds status: Not affected
>   Type: tsx_async_abort status: Not affected
> Graphics:
>   Device-1: Intel HD Graphics 500 vendor: Acer Incorporated ALI driver: i915
>   v: kernel bus ID: 00:02.0 chip ID: 8086:5a85
>   Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 1-7:6
>   chip ID: 04f2:b573
>   Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
>   alternate: fbdev,vesa display ID: :0.0 screens: 1
>   Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
>   s-diag: 414mm (16.3")
>   Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 133 size: 260x140mm (10.2x5.5")
>   diag: 295mm (11.6")
>   OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 20.3.1
>   direct render: Yes
> Audio:
>   Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
>   vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
>   alternate: snd_soc_skl,snd_sof_pci bus ID: 00:0e.0 chip ID: 8086:5a98
>   Sound Server: ALSA v: k5.9.16-1-MANJARO
> Network:
>   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
>   vendor: Lite-On driver: ath10k_pci v: kernel port: 1040 bus ID: 01:00.0
>   chip ID: 168c:0042
>   IF: wlp1s0 state: up mac: <filter>
>   Device-2: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
>   bus ID: 1-5:4 chip ID: 04ca:3015
> Drives:
>   Local Storage: total: 32.87 GiB used: 6.47 GiB (19.7%)
>   ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SK Hynix model: HBG4a2
>   size: 29.12 GiB block size: physical: 512 B logical: 512 B serial: <filter>
>   rev: 0x8
>   SMART Message: Unknown smartctl error. Unable to generate data.
>   ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer
>   size: 3.75 GiB block size: physical: 512 B logical: 512 B serial: <filter>
>   rev: 6.01
>   SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
> Partition:
>   ID-1: / raw size: N/A size: 2.75 GiB used: 123.1 MiB (4.4%) fs: overlay
>   source: ERR-102
> Swap:
>   Alert: No Swap data was found.
> Sensors:
>   System Temperatures: cpu: 36.0 C mobo: N/A
>   Fan Speeds (RPM): N/A
> Info:
>   Processes: 197 Uptime: 1h 24m wakeups: 2 Memory: 3.67 GiB
>   used: 1.66 GiB (45.2%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
>   pacman: 1203 lib: 370 flatpak: 0 Shell: Bash v: 5.1.0
>   running in: xfce4-terminal inxi: 3.2.01
> [manjaro@manjaro ~]$ sudo parted -l
> Model: SanDisk Cruzer (scsi)
> Disk /dev/sda: 4023MB
> Sector size (logical/physical): 512B/512B
> Partition Table: msdos
> Disk Flags:
> Number  Start   End     Size    Type     File system  Flags
>  2      2932MB  2937MB  4194kB  primary               esp
> Model: MMC HBG4a2 (sd/mmc)
> Disk /dev/mmcblk0: 31.3GB
> Partition Table: gpt
> Disk Flags:
> Number  Start   End     Size    File system     Name  Flags
>  1      2097kB  317MB   315MB   fat32                 boot, esp
>  2      317MB   28.2GB  27.9GB  ext4
>  3      28.2GB  31.3GB  3095MB  linux-swap(v1)        swap
> Error: /dev/mmcblk0boot0: unrecognised disk label
> Model: Generic SD/MMC Storage Card (sd/mmc)
> Disk /dev/mmcblk0boot0: 4194kB
> Partition Table: unknown
> Disk Flags:
> Error: /dev/mmcblk0boot1: unrecognised disk label
> Disk /dev/mmcblk0boot1: 4194kB
> Disk Flags:
> [manjaro@manjaro ~]$ sudo efibootmgr -v
> Skipping unreadable variable "Boot0000": Interrupted system call
> Skipping unreadable variable "Boot0001": Interrupted system call
> Skipping unreadable variable "Boot0002": Interrupted system call
> Skipping unreadable variable "Boot0003": Interrupted system call
> Skipping unreadable variable "Boot0004": Interrupted system call
> Skipping unreadable variable "Boot2001": Interrupted system call
> Skipping unreadable variable "Boot2002": Interrupted system call
> Skipping unreadable variable "Boot2003": Interrupted system call
> show_order(): Interrupted system call
I tried the Calamares -d but after the ‘set keyboard’ stage I couldn’t get further because the ‘Next’ button was greyed out.
Can you please edit this using ``` before the output and after the output?
Just makes it easier to read. Thanks!
Sorry - my unfamiliarity is showing. When I go to edit the post the ``` marks are already there, above and below. Hope it’s OK now.
I think the only options you have is either to use Manjaro Architect or a manual installation or to think about using Arch as I don’t think Calamares can install on mmc. :man_shrugging:
Thanks. Is Calamares a new installer for Manjaro? This laptop has successfully run Manjaro as its only OS for about four years, but had become very cluttered up with redundant software etc and I decided the best way to clean it up was to clear the entire memory and start afresh with a new install.
I now remember that when I installed Manjaro the first time I came across this bootload snag, and with help from the forum managed to solve it - if only I could remember how!
You can look at the old forum and see if you can find your topic
https://archived.forum.manjaro.org/
Had a good search there but couldn’t find such topic from me - maybe the solution last time came from elsewhere, I really can’t remember. What does strike me, though, is how often installs fail because of bootloader probs, and how many different solutions are suggested.
Meanwhile I can’t get any of the various suggestions to fix the prob on my machine, and I’m stuck with the laptop only working from the live usb stick.
I’ve tried the often suggested grub-install (from chroot), and get the message:
“Could not prepare Boot variable: Interrupted system call
grub-install: error: efibootmgr failed to register the boot entry: Input/output error.”
Does this indicate the cause of the problem … any suggestions?
I think you are mixing efi and bios - and this is often caused by the firmware’s setting named compatibility mode.
The error message itself indicates you are trying to install an EFI system when the system has been loaded as BIOS.
This causes endless confusion - and one method to around it is to - ensure you know the mode used to load the system and then select the appropriate installation method in Calamares.
Following some earlier advice I’m pretty sure I established that the system is EFI. How can I check this again?
If you are certain it is an efi system - maybe cleaning up your efi boot entries will help.
run efibootmgr from a terminal to list the registered entries - then delete entries not needed using efibootmgr (as root) from the the terminal.
efibootmgr -b bootid -B
efibootmgr shows the following:
BootCurrent: 0001
Timeout: 0 seconds
BootOrder: 2001,2002,2003
Boot0000* Unknown Device: HBG4a2
Boot0001* USB HDD: SanDisk Cruzer
Boot0002* Unknown Device: HBG4a2
Boot0004* Unknown Device:
Boot2001* EFI USB Device
Boot2002* EFI DVD/CDROM
Boot2003* EFI Network
Which of these should I delete? I guess the last two - any others?
I’ve tried installing other linux distros (I’d much prefer Manjaro if poss because my other two computers run on Manjaro and I’m used to it, but I’m getting desperate!). They all fail at the same point: the grub-install stage. A typical message was “Executing ‘grub-install /dev/mmcblk0’ failed.”
I’ve trawled through so many posts on this issue, have checked everything I can understand to check and carried out the various suggestions in the threads, all to no avail. I can’t help thinking this is a relatively simple breakdown of communication in the installation process - the boot requirement not pointing to the right grub file or something.
Any ideas or pointers for a non-techie?
Another observation: In the initial boot menu there’s an option “Detect EFI bootloaders” and if click that I get “(hd1,gpt1)/efi/Manjaro/grubx64.efi”
Does that tell us anything useful?
Doing Calamares in debug mode produced a very long terminal stream, but here it is in case useful:
> [manjaro@manjaro ~]$ sudo calamares -d
> QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
> 10:49:10 [6]: Calamares::Settings::Settings(const QString&, bool)
>     Using Calamares settings file at "/etc/calamares/settings.conf"
> 10:49:10 [6]: void Logger::setupLogfile()
>     Using log file: "/root/.cache/calamares/session.log"
> 10:49:10 [6]: void CalamaresApplication::init()
>     Calamares version: 3.2.34-4
>     ..          languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, es_PR, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
> 10:49:10 [6]: bool CalamaresUtils::initQmlModulesDir()
>     Using Calamares QML directory "/usr/share/calamares/qml"
> 10:49:10 [6]: Calamares::Branding::Branding(const QString&, QObject*)
>     Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
> 10:49:10 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&, Calamares::Branding::PanelSide&)
>     WARNING: Branding setting for sidebar is missing, using "widget" "left"
>     WARNING: Branding setting for navigation is missing, using "widget" "bottom"
> 10:49:10 [2]: Calamares::Branding::Branding(const QString&, QObject*)
>     WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
>     Loaded branding component "manjaro"
>     ..  Loaded QRC translation "tz_" "en_US"
>     ..  Loaded QRC translation "calamares_" "en_US"
>     ..  STARTUP: initSettings, initQmlPath, initBranding done
>     ..  STARTUP: initModuleManager: module init started
> 10:49:10 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&)
>     WARNING: Module descriptor contains extra keys:
>      "requires"
> 10:49:10 [6]: void Calamares::ModuleManager::doInit()
>     Found 45 modules
> 10:49:10 [6]: void CalamaresApplication::initView()
>     STARTUP: initModuleManager: all modules init done
>     STARTUP: initJobQueue done
> 10:49:10 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
>     Available desktop QSize(1366, 731) minimum size QSize(1024, 520)
>     ..  Proposed window size: 1024 560
> 10:49:11 [2]: QString Calamares::_stylesheet(const QDir&)
>     WARNING: The branding component "/usr/share/calamares/branding/manjaro" does not ship stylesheet.qss.
> 10:49:11 [6]: void CalamaresApplication::initView()
>     STARTUP: CalamaresWindow created; loadModules started
> 10:49:11 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
>     Loaded module configuration "/etc/calamares/modules/welcome.conf"
> 10:49:11 [6]: void Config::initLanguages()
>     Matching locale QLocale(English, Latin, United States)
>     ..  Matched with index 13 "en_US"
> 10:49:11 [6]: void Config::setLocaleIndex(int)
>     Index 13 Selected locale QLocale(English, Latin, United States)
> 10:49:11 [0]:   OpenType support missing for "Mukti Narrow", script 12
> 10:49:11 [0]:   OpenType support missing for "Droid Sans", script 11
> 10:49:12 [6]: virtual void Calamares::ViewModule::loadSelf()
>     ViewModule "welcome@welcome" loading complete.
> 10:49:12 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
>     Loaded module configuration "/etc/calamares/modules/locale.conf"
>     ViewModule "locale@locale" loading complete.
>     Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
> 10:49:12 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
>     Loaded 190 keyboard models
> 10:49:12 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
>     Variants now 0 -1
> 10:49:12 [6]: void Config::detectCurrentKeyboardLayout()
>     ("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
> 10:49:13 [6]: virtual void Calamares::ViewModule::loadSelf()
>     ViewModule "keyboard@keyboard" loading complete.
> 10:49:13 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
>     Loaded module configuration "/usr/share/calamares/modules/partition.conf"
> 10:49:13 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
>     KPMCore backend starting ..
> 10:49:13 [8]: Loaded backend plugin:  "pmsfdiskbackendplugin"
>     ..  Backend @0x561236539270 "pmsfdiskbackendplugin" "1"
> 10:49:13 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
>     KPMManager 1 created.
> 10:49:13 [6]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
>     Setting firmwareType to "efi"
> 10:49:13 [6]: QString PartUtils::findFS(QString, FileSystem::Type*)
>     Found filesystem "ext4"
>     Partition-module setting *defaultFileSystemType* "ext4"
> 10:49:13 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
>     WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
>     ViewModule "partition@partition" loading complete.
>     Loaded module configuration "/etc/calamares/modules/users.conf"
>     ViewModule "users@users" loading complete.
>     Loaded module configuration "/usr/share/calamares/modules/packagechooser.conf"
> 10:49:13 [6]: void PackageChooserViewStep::fillModel(const QVariantList&)
>     Loading PackageChooser model items from config
>     ViewModule "packagechooser@packagechooser" loading complete.
>     ViewModule "summary@summary" loading complete.
> 10:49:13 [6]: void Calamares::ModuleManager::loadModules()
>     Module "partition@partition" already loaded.
> 10:49:13 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
>     QML import paths:
>      "/usr/bin"
>      "qrc:/qt-project.org/imports"
>      "/usr/lib/qt/qml"
>     Loaded module configuration "/usr/share/calamares/modules/mount.conf"
>     Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
>     Loaded module configuration "/etc/calamares/modules/machineid.conf"
> 10:49:13 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
>     WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
> 10:49:13 [6]: virtual void Calamares::CppJobModule::loadSelf()
>     CppJobModule "machineid@machineid" loading complete.
>     Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
>     Module "locale@locale" already loaded.
>     Module "keyboard@keyboard" already loaded.
>     Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
>     CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
>     No config file for "initcpiocfg" found anywhere at
>      "/home/manjaro/src/modules/initcpiocfg/initcpiocfg.conf"
>      "/etc/calamares/modules/initcpiocfg.conf"
>      "/usr/share/calamares/modules/initcpiocfg.conf"
>     Loaded module configuration "/etc/calamares/modules/initcpio.conf"
>     CppJobModule "initcpio@initcpio" loading complete.
>     Module "users@users" already loaded.
>     Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
>     Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
>     Loaded module configuration "/etc/calamares/modules/services.conf"
>     Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
>     Loaded module configuration "/etc/calamares/modules/bootloader.conf"
>     Loaded module configuration "/etc/calamares/modules/postcfg.conf"
>     Loaded module configuration "/usr/share/calamares/modules/umount.conf"
>     Loaded module configuration "/etc/calamares/modules/finished.conf"
> 10:49:13 [2]: virtual void FinishedViewStep::setConfigurationMap(const QVariantMap&)
>     WARNING: Configuring the finished module with deprecated restartNowEnabled settings
>     ViewModule "finished@finished" loading complete.
> 10:49:13 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
>     xkbmap selection changed to:  "us" - ""
> 10:49:13 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
>     GeoIP result for welcome= "GB"
> 10:49:13 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
>     Unusable country code "GB"
>     ..  Obtained from "https://ipapi.co/json"  ( 1 "country" )
> 10:49:13 [6]: void CalamaresApplication::initViewSteps()
>     STARTUP: loadModules for all modules done
> 10:49:13 [6]: void Calamares::ModuleManager::checkRequirements()
>     Checking module requirements ..
> 10:49:14 [6]: void CalamaresApplication::initViewSteps()
>     STARTUP: Window now visible and ProgressTreeView populated
>     ..  9 view steps loaded.
>     ..  Loaded QRC translation "kb_" "en_US"
> 10:49:14 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
>     Got 0 requirement results from "bootloader"
>     Got 0 requirement results from "displaymanager"
>     Got 0 requirement results from "finished"
>     Got 0 requirement results from "fstab"
>     Got 0 requirement results from "grubcfg"
>     Got 0 requirement results from "hwclock"
>     Got 0 requirement results from "initcpio"
>     Got 0 requirement results from "initcpiocfg"
>     Got 0 requirement results from "keyboard"
>     Got 0 requirement results from "locale"
>     Got 0 requirement results from "localecfg"
>     Got 0 requirement results from "luksbootkeyfile"
>     Got 0 requirement results from "luksopenswaphookcfg"
>     Got 0 requirement results from "machineid"
>     Got 0 requirement results from "mhwdcfg"
>     Got 0 requirement results from "mount"
>     Got 0 requirement results from "networkcfg"
>     Got 0 requirement results from "packagechooser"
> 10:49:14 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
>     HTTP error QNetworkReply::ServiceUnavailableError on request for QUrl("https://ipapi.co/json")
> 10:49:14 [8]: smartctl initialization failed for  "/dev/mmcblk0" :  No such file or directory
> 10:49:14 [8]: error during smart output parsing for  "/dev/mmcblk0" :  Success
> 10:49:14 [8]: smartctl initialization failed for  "/dev/sda" :  No such file or directory
> 10:49:14 [8]: error during smart output parsing for  "/dev/sda" :  Success
> 10:49:14 [6]: QList<Device*> PartUtils::getDevices(PartUtils::DeviceType)
>     Removing unsuitable devices: 2 candidates.
>     ..  Removing device with iso9660 filesystem (probably a CD) on it "/dev/sda"
> 10:49:15 [6]: void PartitionCoreModule::doInit()
>     LIST OF DETECTED DEVICES:
>     node	capacity	name	prettyName
>     "/dev/mmcblk0" 31264289280 "mmcblk0" "mmcblk0 – 29.12 GiB (/dev/mmcblk0)"
>     ..  1 devices detected.
> 10:49:15 [6]: void Calamares::RequirementsChecker::reportProgress()
>     Remaining modules: 8
>      "partition"
>      "postcfg"
>      "services"
>      "summary"
>      "umount"
>      "unpackfs"
>      "users"
>      "welcome"
> 10:49:16 [6]: void Calamares::RequirementsChecker::reportProgress()
>      "partition"
>      "postcfg"
>      "services"
>      "summary"
>      "umount"
>      "unpackfs"
>      "users"
>      "welcome"
> 10:49:17 [6]: void Calamares::RequirementsChecker::reportProgress()
>      "partition"
>      "postcfg"
>      "services"
>      "summary"
>      "umount"
>      "unpackfs"
>      "users"
>      "welcome"
> 10:49:18 [6]: void Calamares::RequirementsChecker::reportProgress()
>      "partition"
>      "postcfg"
>      "services"
>      "summary"
>      "umount"
>      "unpackfs"
>      "users"
>      "welcome"
> 10:49:19 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "env" ("blkid", "-s", "TYPE", "-o", "value", "/dev/mmcblk0p2")
>     ..  Finished. Exit code: 0
>     ..  Target cmd: ("blkid", "-s", "TYPE", "-o", "value", "/dev/mmcblk0p2") output:
>  ext4
> 10:49:19 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
>     Checking device "/dev/mmcblk0p2" for fstab (fs= "ext4" )
>     Running "env" ("mount", "-o", "ro,noload", "/dev/mmcblk0p2", "/tmp/calamares-YaMfUJ")
>     ..  Target cmd: ("mount", "-o", "ro,noload", "/dev/mmcblk0p2", "/tmp/calamares-YaMfUJ") output:
>     Running "env" ("udevadm", "settle")
>     ..  Target cmd: ("udevadm", "settle") output:
>     Running "env" ("sync")
>     ..  Target cmd: ("sync") output:
>     ..  reading "/tmp/calamares-YaMfUJ/etc/fstab"
>     ..  got 11 lines.
>     ..  got 11 fstab entries.
>     Running "env" ("umount", "-R", "/tmp/calamares-YaMfUJ")
>     ..  Target cmd: ("umount", "-R", "/tmp/calamares-YaMfUJ") output:
> 10:49:19 [6]: bool PartUtils::canBeResized(DeviceModel*, const QString&)
>     Checking if "/dev/mmcblk0p2" can be resized.
> 10:49:19 [6]: bool PartUtils::canBeResized(Partition*)
>     Partition "/dev/mmcblk0p2" authorized for resize + autopartition install.
> 10:49:19 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
>     os-prober lines after cleanup:
>      "/dev/mmcblk0p2:Manjaro Linux (20.2.1):ManjaroLinux:linux"
> 10:49:19 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
>     system is EFI and new EFI system partition has been found.
> 10:49:19 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
>     Got 0 requirement results from "postcfg"
>     Got 1 requirement results from "partition"
>     Got 0 requirement results from "services"
>     Got 0 requirement results from "umount"
>     Got 0 requirement results from "unpackfs"
>     Got 0 requirement results from "users"
> 10:49:19 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
>     Need at least storage bytes: 8482560409
>     Got 0 requirement results from "summary"
> 10:49:19 [6]: void ChoicePage::updateDeviceStatePreview()
>     Updating partitioning state widgets.
> 10:49:19 [6]: void ChoicePage::setupActions()
>     Setting up actions for "/dev/mmcblk0" with 1 entries.
> 10:49:20 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
>     Need at least ram bytes: 1073741824
> 10:49:20 [6]: bool GeneralRequirements::checkHasPower()
>     A battery exists, checking for mains power.
> 10:49:20 [6]: bool PartUtils::canBeResized(Partition*)
>     Checking if "/dev/mmcblk0" can be resized.
>     ..  NO, filesystem "unknown" does not support resize.
> 10:49:20 [6]: bool PartUtils::canBeReplaced(Partition*)
>     Checking if "/dev/mmcblk0" can be replaced.
>     ..  NO, insufficient storage
>      Required  storage B: 9019431321 "(7.9GiB)"
>      Available storage B: 1048576 "(0GiB)"
>     Checking if "/dev/mmcblk0p1" can be resized.
>     ..  NO, filesystem "fat32" does not support resize.
>     Checking if "/dev/mmcblk0p1" can be replaced.
>      Available storage B: 314572800 "(0GiB)"
>     ..  contains resizable "/dev/mmcblk0p2"
>     Checking if "/dev/mmcblk0p2" can be replaced.
>     Partition "/dev/mmcblk0p2" authorized for replace install.
>     ..  contains replaceable "/dev/mmcblk0p2"
>     Checking if "/dev/mmcblk0p3" can be resized.
>      Required  storage B: 11166914969 "(10.4GiB)"
>      Available storage B: 3094761984 "(2GiB)" for "/dev/mmcblk0p3" length: 6044457 sectorsUsed: 0 fsType: "linuxswap"
>     Checking if "/dev/mmcblk0p3" can be replaced.
>      Available storage B: 4230144 "(0GiB)"
> 10:49:20 [6]: ChoicePage::setupActions()::<lambda()>
>     Setting texts for 1 non-empty osprober entry
> 10:49:20 [6]: void ChoicePage::continueApplyDeviceChoice()
>     Previous device -1 new device 0
> 10:49:20 [6]: void ChoicePage::applyActionChoice(InstallChoice)
>     Prev -1 InstallChoice Config::NoChoice "none"
> 10:49:20 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
>     Updating partitioning preview widgets.
> 10:49:20 [6]: void Calamares::RequirementsChecker::reportProgress()
>     Remaining modules: 1
>      "welcome"
>     GeneralRequirements output:
>      enoughStorage :   true
>      enoughRam :   true
>      hasPower :   true
>      hasInternet :   true
>      isRoot :   true
> 10:49:20 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
>     Got 5 requirement results from "welcome"
> 10:49:20 [6]: void Calamares::RequirementsChecker::finished()
>     All requirements have been checked.
> 10:49:20 [6]: void Calamares::RequirementsModel::describe() const
>     Requirements model has 6 items
>     ..  requirement 0 "partitions" satisfied? true mandatory? true
>     ..  requirement 1 "storage" satisfied? true mandatory? true
>     ..  requirement 2 "ram" satisfied? true mandatory? true
>     ..  requirement 3 "power" satisfied? true mandatory? false
>     ..  requirement 4 "internet" satisfied? true mandatory? false
>     ..  requirement 5 "root" satisfied? true mandatory? true
> 10:49:24 [6]: void Config::setLocaleIndex(int)
>     Index 14 Selected locale QLocale(English, Latin, United Kingdom)
>     ..  Loaded QRC translation "tz_" "en_GB"
>     ..  Loaded QRC translation "calamares_" "en_GB"
> 10:49:24 [6]: ChoicePage::setupActions()::<lambda()>
>     ..  Loaded QRC translation "kb_" "en_GB"
> 10:49:41 [6]: void Config::onActivate()
>     Got locale language "en_GB.UTF-8"
>     ..  extracted country "United Kingdom" :: ("en", "GB")
>     ..  looking for locale part "GB"
>     ..  matched "gb"
> 10:49:42 [6]: void Config::guessLayout(const QStringList&)
>     Next level: "en"
> 10:49:42 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
>     xkbmap selection changed to:  "gb" - ""
> 10:50:09 [6]: void ChoicePage::applyActionChoice(InstallChoice)
>     Prev -1 InstallChoice Config::Erase "erase"
> 10:50:09 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
>     KPMManager 2 created.
> 10:50:09 [6]: PartitionTable* CreatePartitionTableJob::createTable()
>     CreatePartitionTableJob::createTable trying to make table for device "/dev/mmcblk0"
> 10:50:09 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
>     WARNING: system is EFI but no EFI system partitions found.
>     KPMManager 3 created.
>     KPMManager 4 created.
> 10:50:09 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
>     KPMManager 5 created.
> 10:50:09 [6]: void PartitionCoreModule::dumpQueue() const
>     # Queue:
>     ## Device: "mmcblk0"
>     - "Create new gpt partition table on /dev/mmcblk0."
>     - "Create new 300MiB partition on /dev/mmcblk0 (mmcblk0) with file system fat32."
>     - "Set flags on 300MiB fat32 partition."
>     - "Create new 29513MiB partition on /dev/mmcblk0 (mmcblk0) with file system ext4."
> 10:50:09 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
> 10:50:14 [6]: void ChoicePage::applyActionChoice(InstallChoice)
> 10:50:14 [6]: CalamaresUtils::Partition::KPMManager::~KPMManager()
>     KPMManager 5 being destroyed.
>     KPMManager 4 being destroyed.
>     KPMManager 3 being destroyed.
>     KPMManager 2 being destroyed.
> 10:50:14 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
> 10:50:14 [8]: smartctl initialization failed for  "/dev/mmcblk0" :  No such file or directory
> 10:50:14 [8]: error during smart output parsing for  "/dev/mmcblk0" :  Success
> 10:50:14 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
> 10:50:14 [6]: PartitionTable* CreatePartitionTableJob::createTable()
> 10:50:14 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
> 10:50:14 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
> 10:50:14 [6]: qint64 PartitionActions::swapSuggestion(qint64, Config::SwapChoice)
>     Suggested swap size: 2.88222 GiB
>     KPMManager 6 created.
> 10:50:15 [6]: void PartitionCoreModule::dumpQueue() const
>     # Queue:
>     - "Create new 26562MiB partition on /dev/mmcblk0 (mmcblk0) with file system ext4."
>     - "Create new 2951MiB partition on /dev/mmcblk0 (mmcblk0) with file system linuxswap."
> 10:51:18 [6]: virtual void PackageChooserViewStep::onLeave()
>     PackageChooser "packagechooser_packagechooser" selected "libreoffice-still"
> 10:51:18 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
> 10:51:18 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
> 10:51:18 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
>     Building partition information map
>     ..  partitions on "/dev/mmcblk0"
>     ..  mapping for "" "unallocated"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "unknown"
>      fsName :   "unknown"
>      uuid :   ""
>      claimed :   "false"
>     ..  mapping for "" "New Partition"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   "/boot/efi"
>      fs: :   "fat32"
>      fsName :   "fat32"
>      uuid :   ""
>      claimed :   "true"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "9007388236709942"
>      mountPoint: :   "/"
>      fs: :   "ext4"
>      fsName :   "ext4"
>      uuid :   ""
>      claimed :   "true"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "linuxswap"
>      fsName :   "linuxswap"
>      uuid :   ""
>      claimed :   "true"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "unknown"
>      fsName :   "unknown"
>      uuid :   ""
>      claimed :   "false"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      fs: :   "fat32"
>      fsName :   "fat32"
>      uuid :   ""
>      claimed :   "true"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      mountPoint: :   "/"
>      fs: :   "ext4"
>      fsName :   "ext4"
>      uuid :   ""
>      claimed :   "true"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "linuxswap"
>      uuid :   ""
>      claimed :   "true"
> 10:51:18 [6]: void SummaryPage::onActivate()
>     Summary widget is larger than viewport, enlarge by 37 to QSize(844, 568)
> 10:51:53 [6]: void Calamares::JobThread::finalize()
>     There are 34 jobs, total weight 33
>     ..  Job 1 "Clear all temporary mounts." +wt 0.125 tot.wt 0.125
>     ..  Job 2 "Clear mounts for partitioning operations on /dev/mmcblk0" +wt 0.125 tot.wt 0.25
>     ..  Job 3 "Create new gpt partition table on /dev/mmcblk0." +wt 0.125 tot.wt 0.375
>     ..  Job 4 "Create new 300MiB partition on /dev/mmcblk0 (mmcblk0) with file system fat32." +wt 0.125 tot.wt 0.5
>     ..  Job 5 "Set flags on 300MiB fat32 partition." +wt 0.125 tot.wt 0.625
>     ..  Job 6 "Create new 26562MiB partition on /dev/mmcblk0 (mmcblk0) with file system ext4." +wt 0.125 tot.wt 0.75
>     ..  Job 7 "Create new 2951MiB partition on /dev/mmcblk0 (mmcblk0) with file system linuxswap." +wt 0.125 tot.wt 0.875
>     ..  Job 8 "Set partition information" +wt 0.125 tot.wt 1
>     ..  Job 9 "mount" +wt 1 tot.wt 2
>     ..  Job 10 "unpackfs" +wt 12 tot.wt 14
>     ..  Job 11 "networkcfg" +wt 1 tot.wt 15
>     ..  Job 12 "Generate machine-id." +wt 1 tot.wt 16
>     ..  Job 13 "fstab" +wt 1 tot.wt 17
>     ..  Job 14 "Set timezone to Europe/London" +wt 1 tot.wt 18
>     ..  Job 15 "Set keyboard model to , layout to gb-" +wt 1 tot.wt 19
>     ..  Job 16 "localecfg" +wt 1 tot.wt 20
>     ..  Job 17 "luksopenswaphookcfg" +wt 1 tot.wt 21
>     ..  Job 18 "Configuring LUKS key file." +wt 1 tot.wt 22
>     ..  Job 19 "initcpiocfg" +wt 1 tot.wt 23
>     ..  Job 20 "Creating initramfs with mkinitcpio." +wt 1 tot.wt 24
>     ..  Job 21 "Configure <pre>sudo</pre> users." +wt 0.166667 tot.wt 24.1667
>     ..  Job 22 "Preparing groups." +wt 0.166667 tot.wt 24.3333
>     ..  Job 23 "Create user ray" +wt 0.166667 tot.wt 24.5
>     ..  Job 24 "Set password for user ray" +wt 0.166667 tot.wt 24.6667
>     ..  Job 25 "Set password for user root" +wt 0.166667 tot.wt 24.8333
>     ..  Job 26 "Set hostname ray-spin1" +wt 0.166667 tot.wt 25
>     ..  Job 27 "displaymanager" +wt 1 tot.wt 26
>     ..  Job 28 "mhwdcfg" +wt 1 tot.wt 27
>     ..  Job 29 "hwclock" +wt 1 tot.wt 28
>     ..  Job 30 "services" +wt 1 tot.wt 29
>     ..  Job 31 "grubcfg" +wt 1 tot.wt 30
>     ..  Job 32 "bootloader" +wt 1 tot.wt 31
>     ..  Job 33 "postcfg" +wt 1 tot.wt 32
>     ..  Job 34 "umount" +wt 1 tot.wt 33
> 10:51:53 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Clear all temporary mounts." ( 1 / 34 )
> 10:51:53 [6]: virtual Calamares::JobResult ClearTempMountsJob::exec()
>     Opened mtab. Lines:
>     "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
>     "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
>     "dev /dev devtmpfs rw,nosuid,relatime,size=1898644k,nr_inodes=474661,mode=755,inode64 0 0"
>     "run /run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64 0 0"
>     "efivarfs /sys/firmware/efi/efivars efivarfs rw,nosuid,nodev,noexec,relatime 0 0"
>     "/dev/sda /run/miso/bootmnt iso9660 ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=default 0 0"
>     "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755,inode64 0 0"
>     "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=2887176k,mode=755,inode64 0 0"
>     "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
>     "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
>     "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
>     "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
>     "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off 0 0"
>     "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
>     "tmpfs /dev/shm tmpfs rw,nosuid,nodev,inode64 0 0"
>     "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
>     "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755,inode64 0 0"
>     "cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0"
>     "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
>     "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
>     "none /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0"
>     "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
>     "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
>     "cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0"
>     "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
>     "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
>     "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
>     "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
>     "cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0"
>     "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
>     "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
>     "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
>     "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12787 0 0"
>     "hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0"
>     "debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0"
>     "mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0"
>     "tracefs /sys/kernel/tracing tracefs rw,nosuid,nodev,noexec,relatime 0 0"
>     "tmpfs /tmp tmpfs rw,nosuid,nodev,size=1924784k,nr_inodes=409600,inode64 0 0"
>     "fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0"
>     "configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0"
>     "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755,inode64 0 0"
>     "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=384956k,nr_inodes=96239,mode=700,uid=1000,gid=1000,inode64 0 0"
>     "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
>     ClearTempMountsJob finished. Here's what was done:
>     Starting job "Clear mounts for partitioning operations on /dev/mmcblk0" ( 2 / 34 )
> 10:51:53 [6]: QStringList getPartitionsForDevice(const QString&)
>     Reading from "/proc/partitions"
> 10:51:53 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
>     ClearMountsJob finished. Here's what was done:
> 10:51:53 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Starting job "Create new gpt partition table on /dev/mmcblk0." ( 3 / 34 )
> 10:51:53 [6]: virtual Calamares::JobResult CreatePartitionTableJob::exec()
>     Creating new partition table of type "gpt" , uncommitted yet:
>     "unallocated"
>     "New Partition"
>     "New Partition"
>     "New Partition"
>     lsblk:
>  "NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT\nloop0          7:0    0  85.1M  1 loop /run/miso/sfs/livefs\nloop1          7:1    0 619.2M  1 loop /run/miso/sfs/mhwdfs\nloop2          7:2    0   1.3G  1 loop /run/miso/sfs/desktopfs\nloop3          7:3    0 663.5M  1 loop /run/miso/sfs/rootfs\nsda            8:0    1   3.7G  0 disk /run/miso/bootmnt\n\xE2\x94\x9C\xE2\x94\x80sda1         8:1    1   2.7G  0 part \n\xE2\x94\x94\xE2\x94\x80sda2         8:2    1     4M  0 part \nmmcblk0      179:0    0  29.1G  0 disk \n\xE2\x94\x9C\xE2\x94\x80mmcblk0p1  179:1    0   300M  0 part \n\xE2\x94\x9C\xE2\x94\x80mmcblk0p2  179:2    0  25.9G  0 part \n\xE2\x94\x94\xE2\x94\x80mmcblk0p3  179:3    0   2.9G  0 part \nmmcblk0boot0 179:8    0     4M  1 disk \nmmcblk0boot1 179:16   0     4M  1 disk \n"
>     mount:
>  "proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)\nsys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)\ndev on /dev type devtmpfs (rw,nosuid,relatime,size=1898644k,nr_inodes=474661,mode=755,inode64)\nrun on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)\nefivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)\n/dev/sda on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=default)\ncowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)\noverlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=2887176k,mode=755,inode64)\n/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime)\n/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime)\n/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime)\n/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime)\noverlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off)\nsecurityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)\ntmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)\ndevpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)\ntmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755,inode64)\ncgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)\ncgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)\npstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)\nnone on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)\ncgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)\ncgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)\ncgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)\ncgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)\ncgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)\ncgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)\ncgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)\ncgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)\ncgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)\ncgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)\ncgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)\nsystemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12787)\nhugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)\ndebugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)\nmqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)\ntracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)\ntmpfs on /tmp type tmpfs (rw,nosuid,nodev,size=1924784k,nr_inodes=409600,inode64)\nfusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)\nconfigfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)\ntmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)\ntmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=384956k,nr_inodes=96239,mode=700,uid=1000,gid=1000,inode64)\ngvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)\n"
> 10:51:54 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Create new 300MiB partition on /dev/mmcblk0 (mmcblk0) with file system fat32." ( 4 / 34 )
> 10:51:57 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Set flags on partition /dev/mmcblk0p1." ( 5 / 34 )
> 10:51:57 [6]: virtual Calamares::JobResult SetPartFlagsJob::exec()
>     Setting flags on "/dev/mmcblk0" partition "/dev/mmcblk0p1" to QFlags(0x1)
> 10:51:58 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Create new 26562MiB partition on /dev/mmcblk0 (mmcblk0) with file system ext4." ( 6 / 34 )
> 10:52:05 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Create new 2951MiB partition on /dev/mmcblk0 (mmcblk0) with file system linuxswap." ( 7 / 34 )
> 10:52:08 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Set partition information" ( 8 / 34 )
> 10:52:08 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "unknown"
>      fsName :   "unknown"
>      uuid :   ""
>      claimed :   "false"
>     ..  mapping for "/dev/mmcblk0p1" "/dev/mmcblk0p1"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      fs: :   "fat32"
>      fsName :   "fat32"
>      uuid :   "14B8-4B7B"
>      claimed :   "true"
>     ..  mapping for "/dev/mmcblk0p2" "/dev/mmcblk0p2"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      mountPoint: :   "/"
>      fs: :   "ext4"
>      fsName :   "ext4"
>      uuid :   "5a9fd536-63e7-4ec0-845a-44097389891d"
>      claimed :   "true"
>     ..  mapping for "/dev/mmcblk0p3" "/dev/mmcblk0p3"
>      partlabel :   ""
>      partuuid :   ""
>      parttype :   ""
>      partattrs :   "0"
>      mountPoint: :   ""
>      fs: :   "linuxswap"
>      uuid :   "07153997-fa96-49ae-bd39-1f011673c099"
>      claimed :   "true"
> 10:52:08 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
>     Saving partition information map to GlobalStorage["partitions"]
>     FillGlobalStorageJob writing empty bootLoader value
>     Starting job "mount" ( 9 / 34 )
> 10:52:08 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/mount/main.py"
> 10:52:08 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Determining gettext path from ("/home/manjaro", "/usr/bin", "/usr/share/locale")
>     ..  Found "en_GB" in "/usr/share/locale/en_GB"
>     Job description from pretty_name "mount" = "Mounting partitions."
> chcon: failed to get security context of '/': Operation not supported
> 10:52:08 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "env" ("mount", "-t", "ext4", "/dev/mmcblk0p2", "/tmp/calamares-root-crgqsacr/")
>     ..  Target cmd: ("mount", "-t", "ext4", "/dev/mmcblk0p2", "/tmp/calamares-root-crgqsacr/") output:
> chcon: failed to get security context of '/boot/efi': Operation not supported
>     Running "env" ("mount", "-t", "vfat", "/dev/mmcblk0p1", "/tmp/calamares-root-crgqsacr/boot/efi")
>     ..  Target cmd: ("mount", "-t", "vfat", "/dev/mmcblk0p1", "/tmp/calamares-root-crgqsacr/boot/efi") output:
> chcon: failed to get security context of '/dev': Operation not supported
>     Running "env" ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-crgqsacr/dev")
>     ..  Target cmd: ("mount", "-o", "bind", "/dev", "/tmp/calamares-root-crgqsacr/dev") output:
> 10:52:09 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
> chcon: failed to get security context of '/proc': Operation not supported
>     Running "env" ("mount", "-t", "proc", "proc", "/tmp/calamares-root-crgqsacr/proc")
>     ..  Target cmd: ("mount", "-t", "proc", "proc", "/tmp/calamares-root-crgqsacr/proc") output:
> chcon: failed to get security context of '/run': Operation not supported
>     Running "env" ("mount", "-t", "tmpfs", "tmpfs", "/tmp/calamares-root-crgqsacr/run")
>     ..  Target cmd: ("mount", "-t", "tmpfs", "tmpfs", "/tmp/calamares-root-crgqsacr/run") output:
> chcon: failed to get security context of '/run/udev': Operation not supported
>     Running "env" ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-crgqsacr/run/udev")
>     ..  Target cmd: ("mount", "-o", "bind", "/run/udev", "/tmp/calamares-root-crgqsacr/run/udev") output:
> chcon: failed to get security context of '/sys': Operation not supported
>     Running "env" ("mount", "-t", "sysfs", "sys", "/tmp/calamares-root-crgqsacr/sys")
>     ..  Target cmd: ("mount", "-t", "sysfs", "sys", "/tmp/calamares-root-crgqsacr/sys") output:
> chcon: failed to get security context of '/sys/firmware/efi/efivars': Operation not supported
>     Running "env" ("mount", "-t", "efivarfs", "efivarfs", "/tmp/calamares-root-crgqsacr/sys/firmware/efi/efivars")
>     ..  Target cmd: ("mount", "-t", "efivarfs", "efivarfs", "/tmp/calamares-root-crgqsacr/sys/firmware/efi/efivars") output:
> 10:52:09 [6]: virtual void Calamares::JobThread::run()
>     Starting job "unpackfs" ( 10 / 34 )
> 10:52:09 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/unpackfs/main.py"
> 10:52:09 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Job description from pretty_name "unpackfs" = "Filling up filesystems."
>     Running "env" ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmpzdmenfjo/rootfs")
>     ..  Target cmd: ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs", "/tmp/tmpzdmenfjo/rootfs") output:
>  mount: /tmp/tmpzdmenfjo/rootfs: WARNING: source write-protected, mounted read-only.
> 10:53:11 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "env" ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmpzdmenfjo/desktopfs")
>     ..  Target cmd: ("mount", "-t", "squashfs", "-o", "loop", "/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs", "/tmp/tmpzdmenfjo/desktopfs") output:
>  mount: /tmp/tmpzdmenfjo/desktopfs: WARNING: source write-protected, mounted read-only.
> 10:55:48 [6]: virtual void Calamares::JobThread::run()
>     Starting job "networkcfg" ( 11 / 34 )
> 10:55:48 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/networkcfg/main.py"
> 10:55:48 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Job description from pretty_name "networkcfg" = "Saving network configuration."
>     Starting job "Generate machine-id." ( 12 / 34 )
> 10:55:48 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemd-machine-id-setup")
>     ..  Target cmd: ("systemd-machine-id-setup") output:
>  Initializing machine ID from random generator.
> 10:55:49 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id")
>     ..  Target cmd: ("ln", "-sf", "/etc/machine-id", "/var/lib/dbus/machine-id") output:
> 10:55:49 [6]: virtual void Calamares::JobThread::run()
>     Starting job "fstab" ( 13 / 34 )
> 10:55:49 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/fstab/main.py"
> 10:55:49 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Job description from pretty_name "fstab" = "Writing fstab."
>     Starting job "Set timezone to Europe/London" ( 14 / 34 )
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "rm", "-f", "/etc/localtime")
>     ..  Target cmd: ("rm", "-f", "/etc/localtime") output:
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "ln", "-s", "/usr/share/zoneinfo/Europe/London", "/etc/localtime")
>     ..  Target cmd: ("ln", "-s", "/usr/share/zoneinfo/Europe/London", "/etc/localtime") output:
>     Starting job "Set keyboard model to , layout to gb-" ( 15 / 34 )
> 10:55:49 [6]: virtual Calamares::JobResult SetKeyboardLayoutJob::exec()
>     Executing SetKeyboardLayoutJob
> 10:55:49 [6]: bool SetKeyboardLayoutJob::writeVConsoleData(const QString&, const QString&) const
>     Writing vconsole data to "/tmp/calamares-root-crgqsacr/etc/vconsole.conf"
> 10:55:49 [6]: QString SetKeyboardLayoutJob::findConvertedKeymap(const QString&) const
>     Looking for converted keymap in "/tmp/calamares-root-crgqsacr/lib/kbd/keymaps/xkb"
> 10:55:49 [6]: QString findLegacyKeymap(const QString&, const QString&, const QString&)
>     Looking for legacy keymap "gb" "" "" in QRC
>     ..  Found legacy keymap "uk" with score 12
>     ..  Written KEYMAP= "uk" to vconsole.conf 0
> 10:55:49 [6]: bool SetKeyboardLayoutJob::writeX11Data(const QString&) const
>     Writing X11 configuration to "/tmp/calamares-root-crgqsacr/etc/X11/xorg.conf.d/00-keyboard.conf"
>     ..  Written XkbLayout "gb" ; XkbModel "" ; XkbVariant "" to X.org file "/tmp/calamares-root-crgqsacr/etc/X11/xorg.conf.d/00-keyboard.conf" 0
> 10:55:49 [6]: bool SetKeyboardLayoutJob::writeDefaultKeyboardData(const QString&) const
>     Writing default keyboard data to "/tmp/calamares-root-crgqsacr/etc/default/keyboard"
>     ..  Written XKBMODEL "" ; XKBLAYOUT "gb" ; XKBVARIANT "" to /etc/default/keyboard file "/tmp/calamares-root-crgqsacr/etc/default/keyboard" 0
>     Starting job "localecfg" ( 16 / 34 )
>     Job file "/usr/lib/calamares/modules/localecfg/main.py"
>     Job description from pretty_name "localecfg" = "Configuring locales."
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "locale-gen")
>     ..  Target cmd: ("locale-gen") output:
>  Generating locales...
>   en_US.UTF-8... done
>   en_GB.UTF-8... done
> Generation complete.
> [PYTHON JOB]:  "/tmp/calamares-root-crgqsacr/etc/locale.gen done"
> [PYTHON JOB]:  "/tmp/calamares-root-crgqsacr/etc/locale.conf done"
> [PYTHON JOB]:  "/tmp/calamares-root-crgqsacr/etc/default done"
> 10:56:04 [6]: virtual void Calamares::JobThread::run()
>     Starting job "luksopenswaphookcfg" ( 17 / 34 )
> 10:56:04 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/luksopenswaphookcfg/main.py"
> 10:56:04 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Job description from pretty_name "luksopenswaphookcfg" = "Configuring encrypted swap."
>     Starting job "Configuring LUKS key file." ( 18 / 34 )
> 10:56:04 [6]: virtual Calamares::JobResult LuksBootKeyFileJob::exec()
>     There are 0 LUKS partitions
>     ..  Nothing to do for LUKS.
>     Starting job "initcpiocfg" ( 19 / 34 )
>     Job file "/usr/lib/calamares/modules/initcpiocfg/main.py"
>     Job description from pretty_name "initcpiocfg" = "Configuring mkinitcpio."
> 10:56:04 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "sh", "-c", "which plymouth")
>     ..  Finished. Exit code: 1
>     ..  Target cmd: ("sh", "-c", "which plymouth") output:
>  which: no plymouth in (/home/manjaro/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
> [PYTHON JOB]:  "which plymouth exit code: 1"
>     Starting job "Creating initramfs with mkinitcpio." ( 20 / 34 )
> 10:56:04 [6]: virtual Calamares::JobResult InitcpioJob::exec()
>     Updating initramfs with kernel "linux59"
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mkinitcpio", "-p", "linux59")
>     ..  Target cmd: ("mkinitcpio", "-p", "linux59") output:
>  ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
>   -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
> ==> Starting build: 5.9.16-1-MANJARO
>   -> Running build hook: [base]
>   -> Running build hook: [udev]
>   -> Running build hook: [autodetect]
>   -> Running build hook: [modconf]
>   -> Running build hook: [block]
>   -> Running build hook: [keyboard]
>   -> Running build hook: [keymap]
>   -> Running build hook: [resume]
>   -> Running build hook: [filesystems]
> ==> Generating module dependencies
> ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
> ==> Image generation successful
> ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
>   -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
> ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
> 10:56:29 [6]: virtual void Calamares::JobThread::run()
>     Starting job "Configure <pre>sudo</pre> users." ( 21 / 34 )
>     Starting job "Preparing groups." ( 22 / 34 )
> 10:56:29 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "groupadd", "autologin")
>     ..  Target cmd: ("groupadd", "autologin") output:
>     Starting job "Create user ray" ( 23 / 34 )
> 10:56:29 [6]: virtual Calamares::JobResult CreateUserJob::exec()
>     [CREATEUSER]: creating user
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "useradd", "-m", "-U", "-s", "/bin/bash", "-c", "Ray Chandler", "ray")
>     ..  Target cmd: ("useradd", "-m", "-U", "-s", "/bin/bash", "-c", "Ray Chandler", "ray") output:
>     Running "chroot" "/tmp/calamares-root-crgqsacr" "usermod" "-aG" "lp,network,power,sys,wheel,autologin" "ray"
>     ..  Target cmd: "usermod" "-aG" "lp,network,power,sys,wheel,autologin" "ray" output:
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "chown", "-R", "ray:ray", "/home/ray")
>     ..  Target cmd: ("chown", "-R", "ray:ray", "/home/ray") output:
>     Starting job "Set password for user ray" ( 24 / 34 )
>     Running "chroot" "/tmp/calamares-root-crgqsacr" "usermod" "-p" <password> "ray"
>     ..  Target cmd: "usermod" "-p" <password> "ray" output:
>     Starting job "Set password for user root" ( 25 / 34 )
>     Running "chroot" "/tmp/calamares-root-crgqsacr" "usermod" "-p" <password> "root"
>     ..  Target cmd: "usermod" "-p" <password> "root" output:
>     Starting job "Set hostname ray-spin1" ( 26 / 34 )
>     Starting job "displaymanager" ( 27 / 34 )
> 10:56:29 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/displaymanager/main.py"
> 10:56:30 [6]: boost::python::api::object CalamaresPython::gettext_path()
> 10:56:30 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job description from __doc__ "displaymanager" = "Configure display managers."
> [PYTHON JOB]:  "gdm selected but not installed"
> [PYTHON JOB]:  "mdm selected but not installed"
> [PYTHON JOB]:  "sddm selected but not installed"
> [PYTHON JOB]:  "lxdm selected but not installed"
> [PYTHON JOB]:  "slim selected but not installed"
> [PYTHON JOB]:  "Using rootMountPoint '/tmp/calamares-root-crgqsacr'"
> [PYTHON JOB]:  ".. selected DE xfce"
> [PYTHON JOB]:  "Setting up autologin for user ray."
> [PYTHON JOB]:  "found greeter lightdm-gtk-greeter"
> [PYTHON JOB]:  "lightdm-gtk-greeter configured as greeter."
> 10:56:30 [6]: virtual void Calamares::JobThread::run()
>     Starting job "mhwdcfg" ( 28 / 34 )
>     Job file "/usr/lib/calamares/modules/mhwdcfg/main.py"
>     Job description from __doc__ "mhwdcfg" = "Configure the hardware"
> 10:56:30 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
>     ..  Target cmd: ("mhwd", "-a", "pci", "free", "0200", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") output:
>  Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-bumblebee/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-440xx-prime/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-340xx/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-440xx/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
> Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> Warning: No config found for device: 0000:01:00.0 (0200:168c:0042) Network controller Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
> 10:56:31 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
>     ..  Target cmd: ("mhwd", "-a", "pci", "free", "0280", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") output:
> Warning: No device of class 0280 found!
> 10:56:32 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
>     ..  Target cmd: ("mhwd", "-a", "pci", "free", "0300", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") output:
> > Using config 'video-linux' for device: 0000:00:02.0 (0300:8086:5a85) Display controller Intel Corporation HD Graphics 500
> > Installing video-linux...
> warning: database file for 'core' does not exist (use '-Sy' to download)
> warning: database file for 'extra' does not exist (use '-Sy' to download)
> warning: database file for 'community' does not exist (use '-Sy' to download)
> warning: database file for 'multilib' does not exist (use '-Sy' to download)
> Sourcing /etc/mhwd-x86_64.conf
> Has lib32 support: true
> Sourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
> Processing classid: 0300
> Sourcing /var/lib/mhwd/scripts/include/0300
> Processing classid: 0380
> Processing classid: 0302
> :: Synchronizing package databases...
> downloading mhwd.db...
> warning: libva-mesa-driver-20.3.1-1 is up to date -- skipping
> warning: libva-vdpau-driver-0.7.4-5 is up to date -- skipping
> warning: lib32-libva-vdpau-driver-0.7.4-6 is up to date -- skipping
> resolving dependencies...
> looking for conflicting packages...
> Packages (11) libxvmc-1.0.12-3  lib32-mesa-vdpau-20.3.1-1  lib32-vulkan-intel-20.3.1-1  lib32-vulkan-radeon-20.3.1-1  mesa-vdpau-20.3.1-1  vulkan-intel-20.3.1-1  vulkan-radeon-20.3.1-1  xf86-video-amdgpu-19.1.0-2  xf86-video-ati-1:19.1.0-2  xf86-video-intel-1:2.99.917+913+g9236c582-1  xf86-video-nouveau-1.0.16-2
> Total Download Size:   13.76 MiB
> Total Installed Size:  47.83 MiB
> :: Proceed with installation? [Y/n]
> :: Retrieving packages...
> downloading xf86-video-ati-1:19.1.0-2-x86_64.pkg.tar.zst...
> downloading xf86-video-amdgpu-19.1.0-2-x86_64.pkg.tar.zst...
> downloading libxvmc-1.0.12-3-x86_64.pkg.tar.zst...
> downloading xf86-video-intel-1:2.99.917+913+g9236c582-1-x86_64.pkg.tar.zst...
> downloading xf86-video-nouveau-1.0.16-2-x86_64.pkg.tar.zst...
> downloading vulkan-intel-20.3.1-1-x86_64.pkg.tar.zst...
> downloading vulkan-radeon-20.3.1-1-x86_64.pkg.tar.zst...
> downloading mesa-vdpau-20.3.1-1-x86_64.pkg.tar.zst...
> downloading lib32-vulkan-intel-20.3.1-1-x86_64.pkg.tar.zst...
> downloading lib32-vulkan-radeon-20.3.1-1-x86_64.pkg.tar.zst...
> downloading lib32-mesa-vdpau-20.3.1-1-x86_64.pkg.tar.zst...
> checking keyring...
> checking package integrity...
> loading package files...
> checking for file conflicts...
> checking available disk space...
> :: Processing package changes...
> installing xf86-video-ati...
> installing xf86-video-amdgpu...
> installing libxvmc...
> installing xf86-video-intel...
> >>> This driver now uses DRI3 as the default Direct Rendering
>     Infrastructure. You can try falling back to DRI2 if you run
>     into trouble. To do so, save a file with the following
>     content as /etc/X11/xorg.conf.d/20-intel.conf :
>       Section "Device"
>         Identifier  "Intel Graphics"
>         Driver      "intel"
>         Option      "DRI" "2"             # DRI3 is now default
>         #Option      "AccelMethod"  "sna" # default
>         #Option      "AccelMethod"  "uxa" # fallback
>       EndSection
> Optional dependencies for xf86-video-intel
>     libxrandr: for intel-virtual-output [installed]
>     libxinerama: for intel-virtual-output [installed]
>     libxcursor: for intel-virtual-output [installed]
>     libxtst: for intel-virtual-output [installed]
>     libxss: for intel-virtual-output [installed]
> installing xf86-video-nouveau...
> installing vulkan-intel...
> Optional dependencies for vulkan-intel
>     vulkan-mesa-layers: additional vulkan layers
> installing vulkan-radeon...
> Optional dependencies for vulkan-radeon
> installing mesa-vdpau...
> installing lib32-vulkan-intel...
> Optional dependencies for lib32-vulkan-intel
>     lib32-vulkan-mesa-layers: additional vulkan layers
> installing lib32-vulkan-radeon...
> Optional dependencies for lib32-vulkan-radeon
> installing lib32-mesa-vdpau...
> :: Running post-transaction hooks...
> (1/1) Arming ConditionNeedsUpdate...
> xf86-video-ati: install reason has been set to 'explicitly installed'
> xf86-video-amdgpu: install reason has been set to 'explicitly installed'
> xf86-video-intel: install reason has been set to 'explicitly installed'
> xf86-video-nouveau: install reason has been set to 'explicitly installed'
> vulkan-intel: install reason has been set to 'explicitly installed'
> vulkan-radeon: install reason has been set to 'explicitly installed'
> libva-mesa-driver: install reason has been set to 'explicitly installed'
> libva-vdpau-driver: install reason has been set to 'explicitly installed'
> mesa-vdpau: install reason has been set to 'explicitly installed'
> lib32-vulkan-intel: install reason has been set to 'explicitly installed'
> lib32-vulkan-radeon: install reason has been set to 'explicitly installed'
> lib32-libva-vdpau-driver: install reason has been set to 'explicitly installed'
> lib32-mesa-vdpau: install reason has been set to 'explicitly installed'
> > Successfully installed video-linux
> 10:56:36 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
>     ..  Target cmd: ("mhwd", "-a", "pci", "free", "0302", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") output:
> Warning: No device of class 0302 found!
> 10:56:37 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf")
>     ..  Target cmd: ("mhwd", "-a", "pci", "free", "0380", "--pmconfig", "/opt/mhwd/pacman-mhwd.conf") output:
> Warning: No device of class 0380 found!
> 10:56:38 [6]: virtual void Calamares::JobThread::run()
>     Starting job "hwclock" ( 29 / 34 )
> 10:56:38 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
>     Job file "/usr/lib/calamares/modules/hwclock/main.py"
> 10:56:38 [6]: boost::python::api::object CalamaresPython::gettext_path()
>     Job description from pretty_name "hwclock" = "Setting hardware clock."
> 10:56:38 [6]: static CalamaresUtils::ProcessResult CalamaresUtils::System::runCommand(CalamaresUtils::System::RunLocation, const QStringList&, const QString&, const QString&, std::chrono::seconds)
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "hwclock", "--systohc", "--utc")
>     ..  Target cmd: ("hwclock", "--systohc", "--utc") output:
> [PYTHON JOB]:  "Hwclock set using RTC method."
>     Starting job "services" ( 30 / 34 )
>     Job file "/usr/lib/calamares/modules/services/main.py"
>     Job description from pretty_name "services" = "Configure systemd services"
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "avahi-daemon.service")
>     ..  Target cmd: ("systemctl", "enable", "avahi-daemon.service") output:
>  Created symlink /etc/systemd/system/dbus-org.freedesktop.Avahi.service -> /usr/lib/systemd/system/avahi-daemon.service.
> Created symlink /etc/systemd/system/multi-user.target.wants/avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service.
> Created symlink /etc/systemd/system/sockets.target.wants/avahi-daemon.socket -> /usr/lib/systemd/system/avahi-daemon.socket.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "bluetooth.service")
>     ..  Target cmd: ("systemctl", "enable", "bluetooth.service") output:
>  Created symlink /etc/systemd/system/dbus-org.bluez.service -> /usr/lib/systemd/system/bluetooth.service.
> Created symlink /etc/systemd/system/bluetooth.target.wants/bluetooth.service -> /usr/lib/systemd/system/bluetooth.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "cronie.service")
>     ..  Target cmd: ("systemctl", "enable", "cronie.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/cronie.service -> /usr/lib/systemd/system/cronie.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "ModemManager.service")
>     ..  Target cmd: ("systemctl", "enable", "ModemManager.service") output:
>  Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service -> /usr/lib/systemd/system/ModemManager.service.
> Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service -> /usr/lib/systemd/system/ModemManager.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "NetworkManager.service")
>     ..  Target cmd: ("systemctl", "enable", "NetworkManager.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service.
> Created symlink /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service -> /usr/lib/systemd/system/NetworkManager-dispatcher.service.
> Created symlink /etc/systemd/system/network-online.target.wants/NetworkManager-wait-online.service -> /usr/lib/systemd/system/NetworkManager-wait-online.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "cups.service")
>     ..  Target cmd: ("systemctl", "enable", "cups.service") output:
>  Created symlink /etc/systemd/system/printer.target.wants/cups.service -> /usr/lib/systemd/system/cups.service.
> Created symlink /etc/systemd/system/sockets.target.wants/cups.socket -> /usr/lib/systemd/system/cups.socket.
> Created symlink /etc/systemd/system/multi-user.target.wants/cups.path -> /usr/lib/systemd/system/cups.path.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "tlp.service")
>     ..  Target cmd: ("systemctl", "enable", "tlp.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/tlp.service -> /usr/lib/systemd/system/tlp.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "haveged.service")
>     ..  Target cmd: ("systemctl", "enable", "haveged.service") output:
>  Created symlink /etc/systemd/system/sysinit.target.wants/haveged.service -> /usr/lib/systemd/system/haveged.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "ufw.service")
>     ..  Target cmd: ("systemctl", "enable", "ufw.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/ufw.service -> /usr/lib/systemd/system/ufw.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "apparmor.service")
>     ..  Target cmd: ("systemctl", "enable", "apparmor.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/apparmor.service -> /usr/lib/systemd/system/apparmor.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "snapd.apparmor.service")
>     ..  Target cmd: ("systemctl", "enable", "snapd.apparmor.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/snapd.apparmor.service -> /usr/lib/systemd/system/snapd.apparmor.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "snapd.service")
>     ..  Target cmd: ("systemctl", "enable", "snapd.service") output:
>  Created symlink /etc/systemd/system/multi-user.target.wants/snapd.service -> /usr/lib/systemd/system/snapd.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "fstrim.timer.service")
>     ..  Target cmd: ("systemctl", "enable", "fstrim.timer.service") output:
>  Failed to enable unit, unit fstrim.timer.service does not exist.
> 10:56:38 [2]: void CalamaresPython::warning(const string&)
>     WARNING: [PYTHON JOB]:  "Cannot enable systemd .service fstrim.timer"
>     WARNING: [PYTHON JOB]:  "systemctl enable call in chroot returned error code 1"
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "pkgfile-update.timer.service")
>     ..  Target cmd: ("systemctl", "enable", "pkgfile-update.timer.service") output:
>  Failed to enable unit, unit pkgfile-update.timer.service does not exist.
>     WARNING: [PYTHON JOB]:  "Cannot enable systemd .service pkgfile-update.timer"
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "lightdm.service")
>     ..  Target cmd: ("systemctl", "enable", "lightdm.service") output:
>  Created symlink /etc/systemd/system/display-manager.service -> /usr/lib/systemd/system/lightdm.service.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "enable", "graphical.target")
>     ..  Target cmd: ("systemctl", "enable", "graphical.target") output:
>  The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
> Alias= settings in the [Install] section, and DefaultInstance= for template
> units). This means they are not meant to be enabled using systemctl.
> Possible reasons for having this kind of units are:
> * A unit may be statically enabled by being symlinked from another unit's
>   .wants/ or .requires/ directory.
> * A unit's purpose may be to act as a helper for some other unit which has
>   a requirement dependency on it.
> * A unit may be started when needed via activation (socket, path, timer,
>   D-Bus, udev, scripted systemctl call, ...).
> * In case of template units, the unit is meant to be enabled with some
>   instance name specified.
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "systemctl", "disable", "pacman-init.service")
>     ..  Target cmd: ("systemctl", "disable", "pacman-init.service") output:
>     Starting job "grubcfg" ( 31 / 34 )
>     Job file "/usr/lib/calamares/modules/grubcfg/main.py"
>     Job description from pretty_name "grubcfg" = "Configure GRUB."
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "sh", "-c", "which dracut")
>     ..  Target cmd: ("sh", "-c", "which dracut") output:
>  which: no dracut in (/home/manjaro/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
>     Starting job "bootloader" ( 32 / 34 )
>     Job file "/usr/lib/calamares/modules/bootloader/main.py"
>     Job description from pretty_name "bootloader" = "Install bootloader."
> [PYTHON JOB]:  "Bootloader: grub (efi)"
>     Running "chroot" ("/tmp/calamares-root-crgqsacr", "grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force")
>     ..  Target cmd: ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force") output:
>  Installing for x86_64-efi platform.
> Could not prepare Boot variable: Interrupted system call
> grub-install: error: efibootmgr failed to register the boot entry: Input/output error.
> Python Error:
>  <class 'subprocess.CalledProcessError'>
>  File "/usr/lib/calamares/modules/bootloader/main.py", line 476, in run
>     prepare_bootloader(fw_type)
>   File "/usr/lib/calamares/modules/bootloader/main.py", line 448, in prepare_bootloader
>     install_grub(efi_directory, fw_type)
>   File "/usr/lib/calamares/modules/bootloader/main.py", line 310, in install_grub
>     check_target_env_call([libcalamares.job.configuration["grubInstall"],
>   File "<string>", line 6, in <module>
> 10:56:41 [6]: virtual void Calamares::JobThread::run()
>     Skipping non-emergency job "postcfg"
>     Skipping non-emergency job "umount"
> 10:56:41 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
>     ERROR: Installation failed:
> 10:56:41 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
>     - message: "Boost.Python error in job \"bootloader\"."
>     - details: "<div><strong>Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force' returned non-zero exit status 1.</strong></div><div>Installing for x86_64-efi platform.\nCould not prepare Boot variable: Interrupted system call\ngrub-install: error: efibootmgr failed to register the boot entry: Input/output error.</div><div><br/>Traceback:</div><div><pre>File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 476, in run\n    prepare_bootloader(fw_type)\n\n  File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 448, in prepare_bootloader\n    install_grub(efi_directory, fw_type)\n\n  File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 310, in install_grub\n    check_target_env_call([libcalamares.job.configuration[&quot;grubInstall&quot;],\n\n  File &quot;&lt;string&gt;&quot;, line 6, in &lt;module&gt;</pre></div>"
>     Calamares will quit when the dialog closes.
> 10:56:41 [6]: void FinishedPage::setUpRestart()
>     FinishedPage::setUpRestart(), Quit button setup= "never" command= "systemctl reboot"
> Shutting down Calamares...
>     ..  Finished shutdown.
As Wollie suggested, I’m now trying to install with Manjaro-Architect, and the process seemed to be going well until it froze with the error message “grub-probe: error: cannot find a GRUB drive for /dev/sda1.”
But sda1 is the USB installation stick - why does it need to find a GRUB drive there?
And more importantly, how can I progress the Architect installation past this sticking point?
Thanks for any help.
I’ve now tried various things from diverse posts - too many to keep track of! But things look different now. If I try booting without the live stick inserted, I now get:
“Failed to start Coldplug all udev devices”.
If I just wait for ages, I then get the following:
Timed out waiting for device /dev/mccblk0p1
Dependency failed for /boot/efi
Dependency failed for Local File Systems
I am told I am in emergency mode and I’m invited to press Ctrl-D to continue. I do that and up pops the Manjaro opening screen but the touch pad doesn’t work and a plugged-in usb mouse also doesn’t work.
What to do? Thanks
After trying everything suggested here and elsewhere, and finally suspecting that the laptop’s internal mmc had gone faulty, I’ve now installed Manjaro onto an inserted micro-SD card.
On booting, an initial error message pops up saying there is “no such device” followed by a very long number, but that quickly disappears and then the system boots up and appears to be working perfectly well.
