A few days ago i installed linux 5.19 but my system still booted into 5.18 and it remained the only option in the bootloader. After deleting it ( foolish, i know ) the bootloader detects no kernel and i have to manually tell grub to use the current one by rewriting 5.18 into 5.19 every time i boot my system
I already tried grub-update before and after deleting the old kernel to no effect
@zbe i install and delete kernels via settings manager in kde
i meant to write update grub, not grub update
warning: linux519-5.19.1-2 is up to date -- reinstalling
resolving dependencies...
Packages (3) pahole-1.23-1 linux519-5.19.1-2 linux519-headers-5.19.1-2
Total Download Size: 33.21 MiB
Total Installed Size: 277.66 MiB
Net Upgrade Size: 141.75 MiB
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
Error: Kernel not installed.
Currently running: 5.19.1-3-MANJARO (linux519)
* linux519
* linux519-rt
