Not sure if there’s a problem or if I’m just going insane or something. I had the Manjaro installer do full disk encryption when I first installed. It seems to not accept my password very often though. Almost never the first time and usually I have to type it in 4-5 times before I can boot. Which is annoying as each failure to grub rescue, reboot and new password attempt is about 30-45 seconds. I have my actual user login happen automatically so when I enter the encryption unlock password it’ll just boot to my desktop. The user password is the same as the boot unlock password and I almost always put that in correctly when I’m unlocking from sleep or whatnot. Even typing it in quite quickly is almost always fine.
Since the boot unlock screen shows nothing when I’m typing the password in, I can’t be 100% sure that I’m typing it in correctly each time but I’m sure I almost always am. I sometimes type it in very slowly out of frustration and sometimes that doesn’t even work. My keyboard doesn’t seem to be faulty either from just general use.
Is there some trick to putting in an unlock password that I don’t know? Are you supposed to type it in slowly? Are you supposed to wait 5 seconds after typing in before hitting Enter? I feel like I must be doing something wrong ![]()
Here is my system info
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1e4e6974-ae74-44f1-81ee-8b6cccc058cb ro quiet
cryptdevice=UUID=d7f6a6f7-9c65-4615-a1ed-13385163bf21:luks-d7f6a6f7-9c65-4615-a1ed-13385163bf21
root=/dev/mapper/luks-d7f6a6f7-9c65-4615-a1ed-13385163bf21 apparmor=1
security=apparmor
resume=/dev/mapper/luks-f16f6def-3431-4bcb-b3ea-4105285fa18e
udev.log_priority=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TOSHIBA product: PORTEGE Z20t-B v: PT15BA-00J00Y
serial: <filter> Chassis: type: 10 v: Version 1.0 serial: <filter>
Mobo: TOSHIBA model: PORTEGE Z20t-B v: Version A0 serial: <filter>
UEFI: TOSHIBA v: Version 1.90 date: 04/06/2015
ID-1: BAT1 charge: 24.6 Wh (86.6%) condition: 28.4/36.0 Wh (78.7%)
volts: 11.4 min: 11.4 model: G71C000JQ110 type: Li-ion serial: N/A
status: Discharging
ID-2: BAT2 charge: 0 Wh (0.0%) condition: 24.8/36.0 Wh (68.7%) volts: 11.4
min: 11.4 model: G71C000JQ110 type: Li-ion serial: N/A status: Discharging
RAM: total: 7.66 GiB used: 3.02 GiB (39.4%)
Info: Dual Core model: Intel Core M-5Y71 bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
L2: 4 MiB bogomips: 11179
Speed: 2097 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 2097 2: 2122
3: 2116 4: 2031
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx
avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 5300 vendor: Toshiba driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:161e class-ID: 0300
Device-2: Chicony TOSHIBA Web Camera - FHD type: USB driver: uvcvideo
bus-ID: 1-1:2 chip-ID: 04f2:b470 class-ID: 0e02 serial: <filter>
Device-3: Chicony TOSHIBA Web Camera - 5M type: USB driver: uvcvideo
bus-ID: 2-1:2 chip-ID: 04f2:b50b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 174 size: 280x160mm (11.0x6.3")
diag: 322mm (12.7")
OpenGL: renderer: Mesa Intel HD Graphics 5300 (BDW GT2) v: 4.6 Mesa 21.1.4
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Toshiba
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Intel Ethernet I218-LM vendor: Toshiba driver: e1000e v: kernel
port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3060
bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
IF-ID-1: wwp0s20u4c2i12 state: down mac: <filter>
bus-ID: 1-8:8 chip-ID: 8087:0a2a class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 238.47 GiB used: 114.58 GiB (48.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ256GVNU
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0101 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.77 GiB (97.99%)
used: 114.58 GiB (51.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d7f6a6f7-9c65-4615-a1ed-13385163bf21 label: N/A
uuid: 1e4e6974-ae74-44f1-81ee-8b6cccc058cb
used: 480 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3144-A2CD
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-f16f6def-3431-4bcb-b3ea-4105285fa18e label: N/A
uuid: 678be66e-4a1d-458e-9115-93352a12be3f
ID-1: /dev/sda2 maj-min: 8:2 size: 229.37 GiB fs: <superuser required>
label: N/A uuid: d7f6a6f7-9c65-4615-a1ed-13385163bf21
ID-2: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: <superuser required>
label: N/A uuid: f16f6def-3431-4bcb-b3ea-4105285fa18e
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
Device-1: 1-1:2 info: Chicony TOSHIBA Web Camera - FHD type: Video
Hub-2: 1-3:3 info: Microchip (formerly SMSC) Hub ports: 2 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2134 class-ID: 0900
Device-1: 1-4:4 info: Sierra Wireless EM7305 type: Communication,CDC-Data
driver: cdc_mbim interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 1199:9063 class-ID: 0a00
Device-2: 1-5:5 info: STMicro Sensor Hub type: HID
driver: hid-sensor-hub,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0483:91d1 class-ID: 0300 serial: <filter>
Device-3: 1-6:6 info: Atmel type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 03eb:8a55 class-ID: 0300
Device-4: 1-7:7 info: Wacom TPC12C type: Mouse driver: usbhid,wacom
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 056a:012c class-ID: 0301
Device-5: 1-8:8 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-1:2 info: Chicony TOSHIBA Web Camera - 5M type: Video
driver: uvcvideo interfaces: 2 rev: 3.0 speed: 5 Gb/s power: 800mA
Hub-4: 2-3:3 info: Microchip (formerly SMSC) Hub ports: 2 rev: 3.0
speed: 5 Gb/s chip-ID: 0424:5534 class-ID: 0900
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 218 Uptime: 31m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1371 pacman: 1364 lib: 424
flatpak: 7 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
Thanks for reading
