Hello Everyone, I have a problem both on my desktop pc and in a VM machine at work, if the lan cable is not plugged in, Manjaro doesn’t boot, something is waiting for the network come’s up and it block the booting process, how can i fix this? how can i found this process?
Thanks
Hi @Kurtzisa and welcome to the Manjaro community.
Firstly, a little housekeeping:
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
After reading through the information in the above link you should now know how to provide and format information to enable others to help you more effectively…
Please provide the outputs of the following commands;
about your system;
inxi --admin --verbosity=8 --filter --no-host --width
and recent logs;
journalctl --boot=-1 --priority=3 --catalog --no-pager
With this information others can begin to understand your issue in greater detail, and possibly help you find a solution.
I hope this helps.
Cheers.
