Recently I observed the booting process seems a bit slower. So I checked with systemd-analyze time
and the output is below:
Startup finished in 3.917s (firmware) + 10.083s (loader) + 17.043s (kernel) + 28.494s (userspace) = 59.538s
graphical.target reached after 27.918s in userspace
~1m boot time seems a bit long considering my boot drive is a Samsung 980 EVO NVME SSD. systemd-analyze blame
shows that ntpdate.service
is taking whooping 16+ seconds to load. Is this normal? Any tips for reducing the boot time?
16.048s ntpdate.service
6.352s NetworkManager-wait-online.service
5.041s nmb.service
3.811s systemd-cryptsetup@Data_Drive.service
2.476s systemd-cryptsetup@Web_Drive.service
2.014s systemd-modules-load.service
1.077s var-lib-snapd-snap-spotify-45.mount
979ms dev-mapper-CryptVolumeGroup\x2dRoot.device
958ms var-lib-snapd-snap-core18-2066.mount
910ms var-lib-snapd-snap-spotify-46.mount
906ms fwupd.service
888ms var-lib-snapd-snap-pycharm\x2dcommunity-238.mount
855ms var-lib-snapd-snap-core-11081.mount
849ms var-lib-snapd-snap-snap\x2dstore-518.mount
844ms var-lib-snapd-snap-core18-1997.mount
842ms var-lib-snapd-snap-gnome\x2d3\x2d34\x2d1804-66.mount
842ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
841ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1515.mount
841ms var-lib-snapd-snap-pycharm\x2dcommunity-236.mount
837ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
635ms docker.service
561ms var-lib-snapd-snap-core-10958.mount
553ms tlp.service
525ms ldconfig.service
504ms systemd-backlight@leds:system76::kbd_backlight.service
484ms lvm2-monitor.service
302ms dev-loop6.device
287ms dev-loop3.device
286ms dev-loop2.device
286ms dev-loop4.device
286ms dev-loop0.device
256ms systemd-rfkill.service
230ms snapd.service
205ms systemd-random-seed.service
162ms bolt.service
120ms system76-power.service
119ms udisks2.service
115ms upower.service
114ms user@1000.service
110ms systemd-vconsole-setup.service
109ms avahi-daemon.service
107ms bluetooth.service
105ms NetworkManager.service
94ms systemd-udev-trigger.service
93ms polkit.service
93ms systemd-journal-flush.service
92ms systemd-sysusers.service
88ms ModemManager.service
87ms apparmor.service
87ms smb.service
85ms lvm2-pvscan@254:0.service
81ms home.mount
79ms lm_sensors.service
73ms systemd-logind.service
71ms systemd-remount-fs.service
63ms systemd-machined.service
62ms systemd-journald.service
59ms unbound.service
51ms dev-loop8.device
43ms home-drive_container-data_drive.mount
40ms systemd-udevd.service
40ms gvtvgpu.service
39ms maia-console@tty1.service
39ms dev-disk-by\x2duuid-97897af4\x2da7ea\x2d47b6\x2d8db1\x2d4745590b229e.swap
35ms snapd.apparmor.service
34ms dev-loop5.device
34ms systemd-timesyncd.service
32ms dev-hugepages.mount
31ms boot.mount
31ms dev-mqueue.mount
29ms sys-kernel-debug.mount
27ms sys-kernel-tracing.mount
25ms systemd-binfmt.service
24ms dev-loop1.device
23ms kmod-static-nodes.service
23ms modprobe@fuse.service
22ms plymouth-quit-wait.service
22ms systemd-tmpfiles-clean.service
22ms plymouth-quit.service
19ms modprobe@configfs.service
18ms modprobe@drm.service
17ms dev-loop7.device
17ms user-runtime-dir@1000.service
16ms plymouth-start.service
14ms systemd-tmpfiles-setup.service
12ms systemd-journal-catalog-update.service
11ms plymouth-read-write.service
10ms home-drive_container-web_drive.mount
7ms systemd-backlight@backlight:intel_backlight.service
7ms systemd-tmpfiles-setup-dev.service
6ms dev-loop12.device
6ms wpa_supplicant.service
6ms rtkit-daemon.service
5ms systemd-update-utmp.service
4ms dev-loop11.device
4ms systemd-user-sessions.service
4ms tmp.mount
4ms dev-loop9.device
3ms boot-efi.mount
3ms systemd-sysctl.service
3ms systemd-update-done.service
2ms proc-sys-fs-binfmt_misc.mount
2ms sys-kernel-config.mount
2ms sys-fs-fuse-connections.mount
1ms dev-loop10.device
1ms docker.socket
807us snapd.socket
