Every time I restart or turn on the laptop, it takes a long time to log in, and this only happens if I’m using X11, on the other hand when using Wayland it turns out that there are no significant problems, loading is so fast to enter without having to wait anymore.
I’ve tried to find a way but it’s still like this, what have I done?
I tried to enter tty mode and tried to disable gdm service, then I tried to enter Xfce by typing in tty “startxfce4” and booted without problems. Then I took the initiative to disable gdm then enable lightdm enable, reboot. What happened? it turned out to be the same as before, it took a long time to enter the dm.
I have tried various kernels from LTS to the newest. Still doesn’t solve the problem.
Specs Laptop
MSI GP62MVR
Processor: i7-7700HQ
Graphics: Intel HD630 + Nvidia 1060
Storage: 128GB SATA SSD
Wifi: Intel Dual Band WirelessAC 3168
journalctl -elf -p err -b
Feb 05 08:19:22 drm-workstation kernel: x86/cpu: SGX disabled by BIOS.
Feb 05 08:19:23 drm-workstation kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Feb 05 08:19:24 drm-workstation kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
Feb 05 08:19:34 drm-workstation kernel:
Feb 05 08:19:39 drm-workstation gnome-session-binary[942]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Feb 05 08:19:41 drm-workstation kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
Feb 05 08:19:44 drm-workstation gdm-password][1235]: gkr-pam: unable to locate daemon control file
Feb 05 08:20:49 drm-workstation systemd[1245]: Failed to start Application launched by gnome-session-binary.
Feb 05 08:20:53 drm-workstation gdm-launch-environment][901]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Feb 05 08:27:05 drm-workstation systemd-coredump[7240]: [🡕] Process 7092 (gnome-documents) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 1c27de4fba5d2610b4cd3d44e154018f7e38a18e
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id be99503e12b86d78d6ede2f0d1ffb66408a37576
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libuuid.so.1 with build-id 1366ec3008cfdbe45a226330754baeea46a2d7e6
Module libsoup-2.4.so.1 with build-id 678dafa54638a6d0ab73f810643f9a23d988db00
Module libtracker-data.so with build-id d63759d15e716837194266d7310f09100d2fd82f
Module libtracker-sparql-2.0.so.0 with build-id 7b38a315ff6db81d1ed5b7109646e0920d04e184
Module libsynctex.so.2 with build-id 15d595e1f7ef62199c8bc7fd7a525b597d2bf365
Module libevdocument3.so.4 with build-id 74e8c8fad8ab9cdd8b83014520a1bc443889802c
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
Module libltdl.so.7 with build-id 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
Module libtdb.so.1 with build-id bec061530310665480ee91395b4eb0a937750a03
Module libvorbisfile.so.3 with build-id 0010b21da05e318b42e718d90738febf58028141
Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
Module libcanberra-gtk3.so.0 with build-id 133409dc3e744fe0edc6a4d078714dce82dacf98
Module libcanberra-gtk-module.so with build-id 72bd14fd5ba4fb0eda082b3daeccc80b796a5586
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libgthread-2.0.so.0 with build-id 4ead02c0964eb41003c65bc25f2baf92965f6d8b
Module libxfconf-0.so.3 with build-id 05a5980d778faaf25bba2d27249e359b41a796eb
Module libxfconfgsettingsbackend.so with build-id 8ce01e731b1120543da65b897c044ac6073f4b2b
Module libappmenu-gtk3-parser.so.0 with build-id a45a3eca7d54886dc06b688b1fcaf67f1cad771f
Module libappmenu-gtk-module.so with build-id d61298ef7d4a79ac023fb311ee58d9fb2affa620
Module libxkbfile.so.1 with build-id de5e415879c20263a8dd42f8cf2dd88107c2bfb2
Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
Module libgnomekbd.so.8 with build-id 794a46e6fb5c4ca09e07a74b1199fb1d480d0843
Module libgnomekbdui.so.8 with build-id 0f2fd1658447a0f5bf23a5eff2ec69bc9c306142
Module libxapp.so.1 with build-id 2d6867c3b087052ef8acd12a1a6c82b3c62b8f36
Module libxapp-gtk3-module.so with build-id 12b94957cbe0eb705d8e900c9006d5333846d4db
Module libseccomp.so.2 with build-id 54179323d84e1b713b7547ba0b3f8310e65eec93
Module libudev.so.1 with build-id e7bd18780bd5753c14f8561be78e4e78ae0266ee
Module libxkbregistry.so.0 with build-id fd1a0bf7d7dd5625c98422781d2b0240c9677d90
Module libgnome-desktop-3.so.19 with build-id 1e1070e9acfb96ee171cb8de0996b4eba36bbb72
Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libsystemd.so.0 with build-id 69dfd360ef432adc8911dd446411765f1922fb48
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e0578
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libxml2.so.2 with build-id b710b880b0d4e9c93554fa632129db44c20632cd
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libsqlite3.so.0 with build-id 5f711261aabe285f02a673ded77a37b413afbfa2
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libxkbcommon.so.0 with build-id 1f1bc7527e57c886c3df5803068122e1971d4724
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libpangoft2-1.0.so.0 with build-id ef74c3ce7ee52a746fb5f2840d80a84e314edb92
Module libpango-1.0.so.0 with build-id 730a8183a36afae82dd6a5564c0e490fed239a40
Module libpangocairo-1.0.so.0 with build-id 10d2af38056eee9a6b3458d8aac24095c4dfab72
Module libgdk-3.so.0 with build-id 6f77a9486fc38cb4e374d862662cb5e39ca3988a
Module libgtk-3.so.0 with build-id e17042e459bfe2a5cd401828a90435a81a82b70d
Module libgvfscommon.so with build-id 90d1858292300e4e1ee3fbe84ab06079af840ec6
Module libgvfsdbus.so with build-id dcb9d652f2e5c65154517fe6934215ec6bd1c29c
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b4cd7fe
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libexpat.so.1 with build-id 64e977cfebfe7539f428dec3b388f5d0498b3108
Module libblkid.so.1 with build-id 057b6bc8eebd42d1f5cafe4f4ac72646aae1f2c5
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libfontconfig.so.1 with build-id 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libncursesw.so.6 with build-id 859adb8b03a5655151b4da104bc4b326a0d4bc8c
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
Module libmount.so.1 with build-id 39e178b712b6635a8681182f7a9fbb64e6074aee
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libreadline.so.8 with build-id 50c2746af3cf9fa7373e6ba6d9b2bc0a2ef7735a
Module libmozjs-78.so with build-id 7da073ebd338f147b7dc72848141c85001fcea2f
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libgirepository-1.0.so.1 with build-id f851c06abfa29780d13693655d4ef65bc23eeb04
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
Module libgio-2.0.so.0 with build-id bce5a3881708e1e885fa1c9c32e2769a6447c411
Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a812331b20a2
Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c0387eefa4
Module libgjs.so.0 with build-id 7abe93923dfb2ebba735e723e70ed9feb73cdeb4
Module gjs-console with build-id e53056a863b787a2eaf80a2e09d9f31e8f151165
Stack trace of thread 7092:
#0 0x00007fd068d26c2e n/a (libtracker-sparql-2.0.so.0 + 0x14c2e)
#1 0x00007fd068d276a0 tracker_sparql_connection_get (libtracker-sparql-2.0.so.0 + 0x156a0)
#2 0x00007fd096322d4a n/a (libffi.so.8 + 0x6d4a)
#3 0x00007fd096322267 n/a (libffi.so.8 + 0x6267)
#4 0x00007fd096aebdc6 n/a (libgjs.so.0 + 0x3fdc6)
#5 0x00007fd096aec368 n/a (libgjs.so.0 + 0x40368)
#6 0x00007fd094c0cac6 n/a (libmozjs-78.so + 0x4eeac6)
#7 0x00007fd094beaaec n/a (libmozjs-78.so + 0x4ccaec)
#8 0x00007fd095027636 _Z15JS_CallFunctionP9JSContextN2JS6HandleIP8JSObjectEENS2_IP10JSFunctionEERKNS1_16HandleValueArrayENS1_13MutableHandleINS1_5ValueEEE (libmozjs-78.so + 0x909636)
#9 0x00007fd096ae9dc9 n/a (libgjs.so.0 + 0x3ddc9)
#10 0x00007fd096af01ac n/a (libgjs.so.0 + 0x441ac)
#11 0x00007fd096af12c1 n/a (libgjs.so.0 + 0x452c1)
#12 0x00007fd096322b62 n/a (libffi.so.8 + 0x6b62)
#13 0x00007fd096322ee0 n/a (libffi.so.8 + 0x6ee0)
#14 0x00007fd096945c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#15 0x00007fd096945e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#16 0x00007fd09681adb6 g_application_register (libgio-2.0.so.0 + 0xcfdb6)
#17 0x00007fd09681b540 n/a (libgio-2.0.so.0 + 0xd0540)
#18 0x00007fd09682667a g_application_run (libgio-2.0.so.0 + 0xdb67a)
#19 0x00007fd096322d4a n/a (libffi.so.8 + 0x6d4a)
#20 0x00007fd096322267 n/a (libffi.so.8 + 0x6267)
#21 0x00007fd096aebdc6 n/a (libgjs.so.0 + 0x3fdc6)
#22 0x00007fd096aec368 n/a (libgjs.so.0 + 0x40368)
#23 0x00007fd094c0cac6 n/a (libmozjs-78.so + 0x4eeac6)
#24 0x00007fd094e82767 n/a (libmozjs-78.so + 0x764767)
#25 0x00007fd094e885d1 n/a (libmozjs-78.so + 0x76a5d1)
#26 0x00007fd095079f16 n/a (libmozjs-78.so + 0x95bf16)
#27 0x00007fd09507a0a4 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95c0a4)
#28 0x00007fd096b25b0b n/a (libgjs.so.0 + 0x79b0b)
#29 0x00007fd096b280e7 gjs_context_eval (libgjs.so.0 + 0x7c0e7)
#30 0x00005583b477fb33 n/a (gjs-console + 0x2b33)
#31 0x00007fd096373b25 __libc_start_main (libc.so.6 + 0x27b25)
#32 0x00005583b477ff0e n/a (gjs-console + 0x2f0e)
Stack trace of thread 7120:
#0 0x00007fd0944428ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007fd09443c270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007fd094e9d240 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x77f240)
#3 0x00007fd094e9cd41 n/a (libmozjs-78.so + 0x77ed41)
#4 0x00007fd0950939cf n/a (libmozjs-78.so + 0x9759cf)
#5 0x00007fd094436259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007fd09644a5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 7122:
Stack trace of thread 7124:
Stack trace of thread 7117:
#0 0x00007fd09643fb2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007fd096a1afd6 n/a (libglib-2.0.so.0 + 0xaafd6)
#2 0x00007fd0969c2545 g_main_context_iteration (libglib-2.0.so.0 + 0x52545)
#3 0x00007fd0969c2592 n/a (libglib-2.0.so.0 + 0x52592)
#4 0x00007fd0969f4905 n/a (libglib-2.0.so.0 + 0x84905)
Stack trace of thread 7125:
Stack trace of thread 7221:
#0 0x00007fd09644518d syscall (libc.so.6 + 0xf918d)
#1 0x00007fd096a1510f g_cond_wait_until (libglib-2.0.so.0 + 0xa510f)
#2 0x00007fd096993993 n/a (libglib-2.0.so.0 + 0x23993)
#3 0x00007fd0969f7a2b n/a (libglib-2.0.so.0 + 0x87a2b)
Stack trace of thread 7127:
Stack trace of thread 7212:
#3 0x00007fd069e84ebe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 7126:
Stack trace of thread 7118:
#2 0x00007fd0969c4523 g_main_loop_run (libglib-2.0.so.0 + 0x54523)
#3 0x00007fd0968530fc n/a (libgio-2.0.so.0 + 0x1080fc)
Stack trace of thread 7121:
Stack trace of thread 7123:
Feb 05 08:44:24 drm-workstation systemd-coredump[18187]: [🡕] Process 18045 (gnome-documents) of user 1000 dumped core.
Stack trace of thread 18045:
#0 0x00007f1c44640c2e n/a (libtracker-sparql-2.0.so.0 + 0x14c2e)
#1 0x00007f1c446416a0 tracker_sparql_connection_get (libtracker-sparql-2.0.so.0 + 0x156a0)
#2 0x00007f1c69c34d4a n/a (libffi.so.8 + 0x6d4a)
#3 0x00007f1c69c34267 n/a (libffi.so.8 + 0x6267)
#4 0x00007f1c6a3fddc6 n/a (libgjs.so.0 + 0x3fdc6)
#5 0x00007f1c6a3fe368 n/a (libgjs.so.0 + 0x40368)
#6 0x00007f1c6851eac6 n/a (libmozjs-78.so + 0x4eeac6)
#7 0x00007f1c684fcaec n/a (libmozjs-78.so + 0x4ccaec)
#8 0x00007f1c68939636 _Z15JS_CallFunctionP9JSContextN2JS6HandleIP8JSObjectEENS2_IP10JSFunctionEERKNS1_16HandleValueArrayENS1_13MutableHandleINS1_5ValueEEE (libmozjs-78.so + 0x909636)
#9 0x00007f1c6a3fbdc9 n/a (libgjs.so.0 + 0x3ddc9)
#10 0x00007f1c6a4021ac n/a (libgjs.so.0 + 0x441ac)
#11 0x00007f1c6a4032c1 n/a (libgjs.so.0 + 0x452c1)
#12 0x00007f1c69c34b62 n/a (libffi.so.8 + 0x6b62)
#13 0x00007f1c69c34ee0 n/a (libffi.so.8 + 0x6ee0)
#14 0x00007f1c6a257c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#15 0x00007f1c6a257e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#16 0x00007f1c6a12cdb6 g_application_register (libgio-2.0.so.0 + 0xcfdb6)
#17 0x00007f1c6a12d540 n/a (libgio-2.0.so.0 + 0xd0540)
#18 0x00007f1c6a13867a g_application_run (libgio-2.0.so.0 + 0xdb67a)
#19 0x00007f1c69c34d4a n/a (libffi.so.8 + 0x6d4a)
#20 0x00007f1c69c34267 n/a (libffi.so.8 + 0x6267)
#21 0x00007f1c6a3fddc6 n/a (libgjs.so.0 + 0x3fdc6)
#22 0x00007f1c6a3fe368 n/a (libgjs.so.0 + 0x40368)
#23 0x00007f1c6851eac6 n/a (libmozjs-78.so + 0x4eeac6)
#24 0x00007f1c68794767 n/a (libmozjs-78.so + 0x764767)
#25 0x00007f1c6879a5d1 n/a (libmozjs-78.so + 0x76a5d1)
#26 0x00007f1c6898bf16 n/a (libmozjs-78.so + 0x95bf16)
#27 0x00007f1c6898c0a4 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95c0a4)
#28 0x00007f1c6a437b0b n/a (libgjs.so.0 + 0x79b0b)
#29 0x00007f1c6a43a0e7 gjs_context_eval (libgjs.so.0 + 0x7c0e7)
#30 0x0000559069a75b33 n/a (gjs-console + 0x2b33)
#31 0x00007f1c69c85b25 __libc_start_main (libc.so.6 + 0x27b25)
#32 0x0000559069a75f0e n/a (gjs-console + 0x2f0e)
Stack trace of thread 18068:
#0 0x00007f1c69d51b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f1c6a32cfd6 n/a (libglib-2.0.so.0 + 0xaafd6)
#2 0x00007f1c6a2d4545 g_main_context_iteration (libglib-2.0.so.0 + 0x52545)
#3 0x00007f1c6a2d4592 n/a (libglib-2.0.so.0 + 0x52592)
#4 0x00007f1c6a306905 n/a (libglib-2.0.so.0 + 0x84905)
#5 0x00007f1c67d48259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f1c69d5c5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 18081:
#0 0x00007f1c67d548ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f1c67d4e270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f1c687af240 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x77f240)
#3 0x00007f1c687aed41 n/a (libmozjs-78.so + 0x77ed41)
#4 0x00007f1c689a59cf n/a (libmozjs-78.so + 0x9759cf)
Stack trace of thread 18078:
Stack trace of thread 18069:
#2 0x00007f1c6a2d6523 g_main_loop_run (libglib-2.0.so.0 + 0x54523)
#3 0x00007f1c6a1650fc n/a (libgio-2.0.so.0 + 0x1080fc)
Stack trace of thread 18176:
#0 0x00007f1c69d5718d syscall (libc.so.6 + 0xf918d)
#1 0x00007f1c6a32710f g_cond_wait_until (libglib-2.0.so.0 + 0xa510f)
#2 0x00007f1c6a2a5993 n/a (libglib-2.0.so.0 + 0x23993)
#3 0x00007f1c6a309a2b n/a (libglib-2.0.so.0 + 0x87a2b)
Stack trace of thread 18084:
Stack trace of thread 18079:
Stack trace of thread 18077:
Stack trace of thread 18082:
Stack trace of thread 18080:
Stack trace of thread 18083:
Stack trace of thread 18142:
#3 0x00007f1c4576bebe n/a (libdconfsettings.so + 0x5ebe)
Feb 05 08:45:52 drm-workstation systemd-coredump[19398]: [🡕] Process 19250 (gnome-documents) of user 1000 dumped core.
Stack trace of thread 19250:
#0 0x00007efff4284c2e n/a (libtracker-sparql-2.0.so.0 + 0x14c2e)
#1 0x00007efff42856a0 tracker_sparql_connection_get (libtracker-sparql-2.0.so.0 + 0x156a0)
#2 0x00007effff468d4a n/a (libffi.so.8 + 0x6d4a)
#3 0x00007effff468267 n/a (libffi.so.8 + 0x6267)
#4 0x00007effffc31dc6 n/a (libgjs.so.0 + 0x3fdc6)
#5 0x00007effffc32368 n/a (libgjs.so.0 + 0x40368)
#6 0x00007efffdd52ac6 n/a (libmozjs-78.so + 0x4eeac6)
#7 0x00007efffdd30aec n/a (libmozjs-78.so + 0x4ccaec)
#8 0x00007efffe16d636 _Z15JS_CallFunctionP9JSContextN2JS6HandleIP8JSObjectEENS2_IP10JSFunctionEERKNS1_16HandleValueArrayENS1_13MutableHandleINS1_5ValueEEE (libmozjs-78.so + 0x909636)
#9 0x00007effffc2fdc9 n/a (libgjs.so.0 + 0x3ddc9)
#10 0x00007effffc361ac n/a (libgjs.so.0 + 0x441ac)
#11 0x00007effffc372c1 n/a (libgjs.so.0 + 0x452c1)
#12 0x00007effff468b62 n/a (libffi.so.8 + 0x6b62)
#13 0x00007effff468ee0 n/a (libffi.so.8 + 0x6ee0)
#14 0x00007effffa8bc96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#15 0x00007effffa8be04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#16 0x00007effff960db6 g_application_register (libgio-2.0.so.0 + 0xcfdb6)
#17 0x00007effff961540 n/a (libgio-2.0.so.0 + 0xd0540)
#18 0x00007effff96c67a g_application_run (libgio-2.0.so.0 + 0xdb67a)
#19 0x00007effff468d4a n/a (libffi.so.8 + 0x6d4a)
#20 0x00007effff468267 n/a (libffi.so.8 + 0x6267)
#21 0x00007effffc31dc6 n/a (libgjs.so.0 + 0x3fdc6)
#22 0x00007effffc32368 n/a (libgjs.so.0 + 0x40368)
#23 0x00007efffdd52ac6 n/a (libmozjs-78.so + 0x4eeac6)
#24 0x00007efffdfc8767 n/a (libmozjs-78.so + 0x764767)
#25 0x00007efffdfce5d1 n/a (libmozjs-78.so + 0x76a5d1)
#26 0x00007efffe1bff16 n/a (libmozjs-78.so + 0x95bf16)
#27 0x00007efffe1c00a4 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95c0a4)
#28 0x00007effffc6bb0b n/a (libgjs.so.0 + 0x79b0b)
#29 0x00007effffc6e0e7 gjs_context_eval (libgjs.so.0 + 0x7c0e7)
#30 0x000055f8b1334b33 n/a (gjs-console + 0x2b33)
#31 0x00007effff4b9b25 __libc_start_main (libc.so.6 + 0x27b25)
#32 0x000055f8b1334f0e n/a (gjs-console + 0x2f0e)
Stack trace of thread 19275:
#0 0x00007effff585b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007effffb60fd6 n/a (libglib-2.0.so.0 + 0xaafd6)
#2 0x00007effffb08545 g_main_context_iteration (libglib-2.0.so.0 + 0x52545)
#3 0x00007effffb08592 n/a (libglib-2.0.so.0 + 0x52592)
#4 0x00007effffb3a905 n/a (libglib-2.0.so.0 + 0x84905)
#5 0x00007efffd57c259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007effff5905e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 19277:
#0 0x00007efffd5888ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007efffd582270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007efffdfe3240 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x77f240)
#3 0x00007efffdfe2d41 n/a (libmozjs-78.so + 0x77ed41)
#4 0x00007efffe1d99cf n/a (libmozjs-78.so + 0x9759cf)
Stack trace of thread 19280:
Stack trace of thread 19281:
Stack trace of thread 19276:
#2 0x00007effffb0a523 g_main_loop_run (libglib-2.0.so.0 + 0x54523)
#3 0x00007effff9990fc n/a (libgio-2.0.so.0 + 0x1080fc)
Stack trace of thread 19284:
Stack trace of thread 19392:
#0 0x00007effff58b18d syscall (libc.so.6 + 0xf918d)
#1 0x00007effffb5b10f g_cond_wait_until (libglib-2.0.so.0 + 0xa510f)
#2 0x00007effffad9993 n/a (libglib-2.0.so.0 + 0x23993)
#3 0x00007effffb3da2b n/a (libglib-2.0.so.0 + 0x87a2b)
Stack trace of thread 19278:
Stack trace of thread 19283:
Stack trace of thread 19279:
Stack trace of thread 19282:
Stack trace of thread 19369:
#3 0x00007efff4be1ebe n/a (libdconfsettings.so + 0x5ebe)
Feb 05 08:55:32 drm-workstation systemd-coredump[26178]: [🡕] Process 26032 (gnome-documents) of user 1000 dumped core.
Stack trace of thread 26032:
#0 0x00007f1ce8673c2e n/a (libtracker-sparql-2.0.so.0 + 0x14c2e)
#1 0x00007f1ce86746a0 tracker_sparql_connection_get (libtracker-sparql-2.0.so.0 + 0x156a0)
#2 0x00007f1d0d476d4a n/a (libffi.so.8 + 0x6d4a)
#3 0x00007f1d0d476267 n/a (libffi.so.8 + 0x6267)
#4 0x00007f1d0dc3fdc6 n/a (libgjs.so.0 + 0x3fdc6)
#5 0x00007f1d0dc40368 n/a (libgjs.so.0 + 0x40368)
#6 0x00007f1d0bd60ac6 n/a (libmozjs-78.so + 0x4eeac6)
#7 0x00007f1d0bd3eaec n/a (libmozjs-78.so + 0x4ccaec)
#8 0x00007f1d0c17b636 _Z15JS_CallFunctionP9JSContextN2JS6HandleIP8JSObjectEENS2_IP10JSFunctionEERKNS1_16HandleValueArrayENS1_13MutableHandleINS1_5ValueEEE (libmozjs-78.so + 0x909636)
#9 0x00007f1d0dc3ddc9 n/a (libgjs.so.0 + 0x3ddc9)
#10 0x00007f1d0dc441ac n/a (libgjs.so.0 + 0x441ac)
#11 0x00007f1d0dc452c1 n/a (libgjs.so.0 + 0x452c1)
#12 0x00007f1d0d476b62 n/a (libffi.so.8 + 0x6b62)
#13 0x00007f1d0d476ee0 n/a (libffi.so.8 + 0x6ee0)
#14 0x00007f1d0da99c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
#15 0x00007f1d0da99e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
#16 0x00007f1d0d96edb6 g_application_register (libgio-2.0.so.0 + 0xcfdb6)
#17 0x00007f1d0d96f540 n/a (libgio-2.0.so.0 + 0xd0540)
#18 0x00007f1d0d97a67a g_application_run (libgio-2.0.so.0 + 0xdb67a)
#19 0x00007f1d0d476d4a n/a (libffi.so.8 + 0x6d4a)
#20 0x00007f1d0d476267 n/a (libffi.so.8 + 0x6267)
#21 0x00007f1d0dc3fdc6 n/a (libgjs.so.0 + 0x3fdc6)
#22 0x00007f1d0dc40368 n/a (libgjs.so.0 + 0x40368)
#23 0x00007f1d0bd60ac6 n/a (libmozjs-78.so + 0x4eeac6)
#24 0x00007f1d0bfd6767 n/a (libmozjs-78.so + 0x764767)
#25 0x00007f1d0bfdc5d1 n/a (libmozjs-78.so + 0x76a5d1)
#26 0x00007f1d0c1cdf16 n/a (libmozjs-78.so + 0x95bf16)
#27 0x00007f1d0c1ce0a4 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95c0a4)
#28 0x00007f1d0dc79b0b n/a (libgjs.so.0 + 0x79b0b)
#29 0x00007f1d0dc7c0e7 gjs_context_eval (libgjs.so.0 + 0x7c0e7)
#30 0x0000557e27b5bb33 n/a (gjs-console + 0x2b33)
#31 0x00007f1d0d4c7b25 __libc_start_main (libc.so.6 + 0x27b25)
#32 0x0000557e27b5bf0e n/a (gjs-console + 0x2f0e)
Stack trace of thread 26055:
#0 0x00007f1d0d593b2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f1d0db6efd6 n/a (libglib-2.0.so.0 + 0xaafd6)
#2 0x00007f1d0db18523 g_main_loop_run (libglib-2.0.so.0 + 0x54523)
#3 0x00007f1d0d9a70fc n/a (libgio-2.0.so.0 + 0x1080fc)
#4 0x00007f1d0db48905 n/a (libglib-2.0.so.0 + 0x84905)
#5 0x00007f1d0b58a259 start_thread (libpthread.so.0 + 0x9259)
#6 0x00007f1d0d59e5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 26053:
#2 0x00007f1d0db16545 g_main_context_iteration (libglib-2.0.so.0 + 0x52545)
#3 0x00007f1d0db16592 n/a (libglib-2.0.so.0 + 0x52592)
Stack trace of thread 26065:
#0 0x00007f1d0b5968ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f1d0b590270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
#2 0x00007f1d0bff1240 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x77f240)
#3 0x00007f1d0bff0d41 n/a (libmozjs-78.so + 0x77ed41)
#4 0x00007f1d0c1e79cf n/a (libmozjs-78.so + 0x9759cf)
Stack trace of thread 26148:
#0 0x00007f1d0d59918d syscall (libc.so.6 + 0xf918d)
#1 0x00007f1d0db6910f g_cond_wait_until (libglib-2.0.so.0 + 0xa510f)
#2 0x00007f1d0dae7993 n/a (libglib-2.0.so.0 + 0x23993)
#3 0x00007f1d0db4ba2b n/a (libglib-2.0.so.0 + 0x87a2b)
Stack trace of thread 26066:
Stack trace of thread 26067:
Stack trace of thread 26118:
#3 0x00007f1ce8fd0ebe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 26061:
Stack trace of thread 26062:
Stack trace of thread 26063:
Stack trace of thread 26064:
Stack trace of thread 26068:
