Booting issues. Stuck on a black screen. Optimus laptop
Issue is present on all kernels, EXCEPT 5.4.
Either a reboot, either a cold boot will get stuck on a black screen forcing me to shut down my laptop by long-pressing the power button. On a third try I can usually reach the log in screen, but it sometimes takes 5-6 force shutdowns.
  Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=adaf167a-abd1-4825-ba96-b6aa3fcf63cc rw udev.log_priority=3
  Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: FX503VD v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: FX503VD v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX503VD.308 date: 04/29/2019
  ID-1: BAT1 charge: 49.2 Wh condition: 49.2/64.4 Wh (76%) volts: 5.0/15.2
  model: ASUS A32-K55 type: Li-ion serial: N/A status: Full
  Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
  L2 cache: 6 MiB
  bogomips: 20004
  Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800
  Type: l1tf
  Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:591b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
  driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1c8d
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus ID: 1-7:4 chip ID: 13d3:5666 serial: <filter>
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.3
  direct render: Yes
  Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
  Sound Server: ALSA v: k5.10.7-3-MANJARO
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 02:00.0
  chip ID: 10ec:8168
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
  bus ID: 04:00.0 chip ID: 8086:24fd
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 1.17 TiB used: 25.45 GiB (2.1%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 model: SE32G size: 29.72 GiB block size:
  physical: 512 B logical: 512 B serial: <filter>
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800NS38 size: 238.47 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 8BS
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LX015-1U7172
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: SDM1
  ID-1: / raw size: 237.97 GiB size: 233.24 GiB (98.01%)
  used: 22.77 GiB (9.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  Kernel: swappiness: 3 (default 60) cache pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  System Temperatures: cpu: 48.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 208 Uptime: 6m wakeups: 1 Memory: 15.52 GiB
  used: 2.13 GiB (13.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
  pacman: 970 lib: 260 flatpak: 0 Shell: Bash v: 5.1.0
  running in: gnome-terminal inxi: 3.2.02
sudo journalctl -p 3 -xb
[sudo] password for radu:
-- Journal begins at Thu 2021-01-21 15:35:36 EET, ends at Thu 2021-01-21 16:50:17 EET. --
Jan 21 16:43:01 manjaro kernel:
Jan 21 16:43:05 manjaro kernel: Bluetooth: hci0: Reading supported features failed (-16)
Jan 21 16:43:17 manjaro gdm-password][2059]: gkr-pam: unable to locate daemon control file
Jan 21 16:43:19 manjaro sudo[2335]: pam_unix(sudo:auth): conversation failed
Jan 21 16:43:19 manjaro sudo[2335]: pam_unix(sudo:auth): auth could not identify password for [radu]
I’ve tried everything I came across on the numerous threads on this topic on the old forum and on this one.
I’ve tried several variants of acpi_osi kernel parameters, as suggested in another thread, but nothing worked.
Anything else I can try?
Hi, you post the journal of the current successful boot log, nothing to see there.
Have you read the stable update workarounds and solutions for display issues?
To get some advice, post the log of the previous tries:
journalctl --priority=err --boot=-1 for the one before the current one
journalctl --priority=err --boot=-2 one more in the past.
If it is a long log use:
[details=“Summary”]
past your log here
[/details]
Remember to wrap the paste in tripple-backticks. (```)
Can you switch to a TTY by pressing Ctrl+Alt+F4? What happens if you run startx there? Can you get the Xorg log for when this happens?
-- Journal begins at Thu 2021-01-21 15:35:36 EET, ends at Thu 2021-01-21 20:28:19 EET. --
Jan 21 19:33:16 manjaro systemd[221]: haveged.service: Failed at step NAMESPACE spawning /usr/bin/havege>
Jan 21 19:33:16 manjaro kernel:
Jan 21 19:33:20 manjaro kernel: Bluetooth: hci0: Reading supported features failed (-16)
Jan 21 19:33:42 manjaro gdm-password][2499]: gkr-pam: unable to locate daemon control file
Jan 21 19:33:45 manjaro sudo[2789]: pam_unix(sudo:auth): conversation failed
Jan 21 19:33:45 manjaro sudo[2789]: pam_unix(sudo:auth): auth could not identify password for [radu]
Jan 21 19:37:03 manjaro gdm[375]: Gdm: Failed to contact accountsservice: Error calling StartServiceByNa>
lines 1-9/9 (END)
 journalctl --priority=err --boot=-3
Jan 21 19:31:40 manjaro kernel:
Jan 21 19:31:44 manjaro kernel: Bluetooth: hci0: Reading supported features failed (-16)
journalctl --priority=err --boot=-4
Jan 21 16:58:09 manjaro gdm[367]: Gdm: Failed to contact accountsservice: Error calling StartServiceByNa>
Jan 21 16:58:09 manjaro pulseaudio[22563]: GetManagedObjects() failed: org.freedesktop.systemd1.Shutting>
lines 1-9/9 (END)
I can switch to tty4 but when I run startx I just get the cursor but sill a black screen, no login screen.
Summary
[     8.353] (--) Log file renamed from "/var/log/Xorg.pid-1749.log" to "/var/log/Xorg.0.log"
[     8.353] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[     8.354]
X.Org X Server 1.20.10
[     8.354] Build Operating System: Linux Manjaro Linux
[     8.354] Current Operating System: Linux manjaro 5.10.7-3-MANJARO #1 SMP PREEMPT Fri Jan 15 21:11:34 UTC 2021 x86_64
[     8.354] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=adaf167a-abd1-4825-ba96-b6aa3fcf63cc rw udev.log_priority=3
[     8.354] Build Date: 16 December 2020  10:33:32PM
[     8.354]
[     8.354] Current version of pixman: 0.40.0
[     8.354] 	Before reporting problems, check http://wiki.x.org
[     8.354] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.354] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 21 20:38:28 2021
[     8.354] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.354] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.354] (==) ServerLayout "layout"
[     8.354] (==) No screen section available. Using defaults.
[     8.354] (**) |-->Screen "Default Screen Section" (0)
[     8.354] (**) |   |-->Monitor "<default monitor>"
[     8.355] (==) No monitor specified for screen "Default Screen Section".
[     8.355] (==) Automatically adding devices
[     8.355] (==) Automatically enabling devices
[     8.355] (==) Automatically adding GPU devices
[     8.355] (==) Automatically binding GPU devices
[     8.355] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.355] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     8.355] 	Entry deleted from font path.
[     8.355] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     8.355] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     8.355] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     8.355] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     8.355] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.355] (II) The server relies on udev to provide the list of input devices.
[     8.355] (II) Module ABI versions:
[     8.355] 	X.Org ANSI C Emulation: 0.4
[     8.355] 	X.Org Video Driver: 24.1
[     8.355] 	X.Org XInput driver : 24.1
[     8.355] 	X.Org Server Extension : 10.0
[     8.356] (++) using VT number 1
[     8.359] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[     8.359] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.360] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[     8.361] (II) xfree86: Adding drm device (/dev/dri/card1)
[     8.361] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[     8.363] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     8.363] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     9.751] (--) PCI:*(0@0:2:0) 8086:591b:1043:1b90 rev 4, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[     9.751] (--) PCI: (1@0:0:0) 10de:1c8d:1043:1b90 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[     9.752] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     9.752] (II) LoadModule: "glx"
[     9.752] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     9.756] (II) Module glx: vendor="X.Org Foundation"
[     9.756] 	compiled for 1.20.10, module version = 1.0.0
[     9.756] 	ABI class: X.Org Server Extension, version 10.0
[     9.756] (II) Applying OutputClass "intel" to /dev/dri/card1
[     9.756] 	loading driver: modesetting
[     9.756] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[     9.756] 	loading driver: nvidia
[     9.756] (==) Matched modesetting as autoconfigured driver 0
[     9.756] (==) Matched intel as autoconfigured driver 1
[     9.756] (==) Matched nvidia as autoconfigured driver 2
[     9.756] (==) Matched nouveau as autoconfigured driver 3
[     9.756] (==) Matched nv as autoconfigured driver 4
[     9.756] (==) Matched fbdev as autoconfigured driver 5
[     9.756] (==) Matched vesa as autoconfigured driver 6
[     9.756] (==) Assigned the driver to the xf86ConfigLayout
[     9.756] (II) LoadModule: "modesetting"
[     9.757] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     9.758] (II) Module modesetting: vendor="X.Org Foundation"
[     9.758] 	compiled for 1.20.10, module version = 1.20.10
[     9.758] 	Module class: X.Org Video Driver
[     9.758] 	ABI class: X.Org Video Driver, version 24.1
[     9.758] (II) LoadModule: "intel"
[     9.759] (WW) Warning, couldn't open module intel
[     9.759] (EE) Failed to load module "intel" (module does not exist, 0)
[     9.759] (II) LoadModule: "nvidia"
[     9.759] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     9.760] (II) Module nvidia: vendor="NVIDIA Corporation"
[     9.760] 	compiled for 1.6.99.901, module version = 1.0.0
[     9.760] 	Module class: X.Org Video Driver
[     9.760] (II) LoadModule: "nouveau"
[     9.761] (WW) Warning, couldn't open module nouveau
[     9.761] (EE) Failed to load module "nouveau" (module does not exist, 0)
[     9.761] (II) LoadModule: "nv"
[     9.762] (WW) Warning, couldn't open module nv
[     9.762] (EE) Failed to load module "nv" (module does not exist, 0)
[     9.763] (II) LoadModule: "fbdev"
[     9.764] (WW) Warning, couldn't open module fbdev
[     9.764] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     9.764] (II) LoadModule: "vesa"
[     9.765] (WW) Warning, couldn't open module vesa
[     9.765] (EE) Failed to load module "vesa" (module does not exist, 0)
[     9.765] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     9.765] (II) NVIDIA dlloader X Driver  460.32.03  Sun Dec 27 18:56:00 UTC 2020
[     9.765] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     9.765] (II) modeset(0): using drv /dev/dri/card1
[     9.765] (II) systemd-logind: releasing fd for 226:0
[     9.767] (II) Loading sub module "fb"
[     9.767] (II) LoadModule: "fb"
[     9.767] (II) Loading /usr/lib/xorg/modules/libfb.so
[     9.767] (II) Module fb: vendor="X.Org Foundation"
[     9.767] 	compiled for 1.20.10, module version = 1.0.0
[     9.768] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     9.768] (II) Loading sub module "wfb"
[     9.768] (II) LoadModule: "wfb"
[     9.768] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     9.768] (II) Module wfb: vendor="X.Org Foundation"
[     9.768] 	compiled for 1.20.10, module version = 1.0.0
[     9.768] (II) Loading sub module "ramdac"
[     9.768] (II) LoadModule: "ramdac"
[     9.768] (II) Module "ramdac" already built-in
[     9.770] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     9.770] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[     9.770] (==) modeset(0): RGB weight 888
[     9.770] (==) modeset(0): Default visual is TrueColor
[     9.770] (II) Loading sub module "glamoregl"
[     9.770] (II) LoadModule: "glamoregl"
[     9.770] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     9.780] (II) Module glamoregl: vendor="X.Org Foundation"
[     9.780] 	compiled for 1.20.10, module version = 1.0.1
[     9.780] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    10.137] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 630 (KBL GT2)
[    10.137] (II) modeset(0): glamor initialized
[    10.138] (II) modeset(0): Output eDP-1 has no monitor section
[    10.142] (II) modeset(0): Output HDMI-1 has no monitor section
[    10.143] (II) modeset(0): EDID for output eDP-1
[    10.143] (II) modeset(0): Manufacturer: AUO  Model: 61ed  Serial#: 0
[    10.143] (II) modeset(0): Year: 2016  Week: 0
[    10.143] (II) modeset(0): EDID Version: 1.4
[    10.143] (II) modeset(0): Digital Display Input
[    10.143] (II) modeset(0): 8 bits per channel
[    10.143] (II) modeset(0): Digital interface is DisplayPort
[    10.143] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    10.143] (II) modeset(0): Gamma: 2.20
[    10.143] (II) modeset(0): No DPMS capabilities specified
[    10.143] (II) modeset(0): Supported color encodings: RGB 4:4:4
[    10.143] (II) modeset(0): First detailed timing is preferred mode
[    10.143] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[    10.143] (II) modeset(0): redX: 0.575 redY: 0.345   greenX: 0.350 greenY: 0.575
[    10.143] (II) modeset(0): blueX: 0.160 blueY: 0.150   whiteX: 0.313 whiteY: 0.329
[    10.143] (II) modeset(0): Manufacturer's mask: 0
[    10.143] (II) modeset(0): Supported detailed timing:
[    10.143] (II) modeset(0): clock: 142.0 MHz   Image Size:  344 x 193 mm
[    10.143] (II) modeset(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2100 h_border: 0
[    10.143] (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1126 v_border: 0
[    10.143] (II) modeset(0): Unknown vendor-specific block f
[    10.143] (II) modeset(0):  AUO
[    10.143] (II) modeset(0):  B156HAN06.1
[    10.143] (II) modeset(0): EDID (in hex):
[    10.143] (II) modeset(0): 	00ffffffffffff0006afed6100000000
[    10.143] (II) modeset(0): 	001a0104a52213780259259358599329
[    10.143] (II) modeset(0): 	26505400000001010101010101010101
[    10.143] (II) modeset(0): 	010101010101783780b470382e406c30
[    10.143] (II) modeset(0): 	aa0058c1100000180000000f00000000
[    10.144] (II) modeset(0): 	00000000000000000020000000fe0041
[    10.144] (II) modeset(0): 	554f0a202020202020202020000000fe
[    10.144] (II) modeset(0): 	004231353648414e30362e31200a00da
[    10.144] (II) modeset(0): Printing probed modes for output eDP-1
[    10.144] (II) modeset(0): Modeline "1920x1080"x60.1  142.00  1920 2028 2076 2100  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    10.144] (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    10.144] (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    10.144] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    10.144] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    10.144] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    10.144] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    10.144] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    10.144] (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    10.144] (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    10.144] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    10.144] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    10.144] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    10.144] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    10.144] (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    10.144] (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    10.144] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    10.144] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    10.144] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    10.145] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    10.145] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    10.145] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    10.145] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    10.145] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    10.145] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    10.145] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    10.145] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    10.145] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    10.145] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    10.145] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    10.145] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    10.145] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    10.145] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    10.145] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    10.145] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    10.145] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    10.145] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    10.145] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    10.145] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    10.145] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    10.145] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    10.145] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    10.145] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    10.145] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    10.145] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    10.145] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    10.145] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    10.145] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    10.145] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    10.145] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    10.145] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    10.145] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    10.145] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    10.145] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    10.145] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    10.145] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    10.145] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    10.145] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    10.145] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    10.146] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    10.146] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    10.146] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    10.146] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    10.146] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    10.146] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    10.146] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    10.146] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    10.146] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    10.146] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    10.146] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    10.146] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    10.146] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    10.149] (II) modeset(0): EDID for output HDMI-1
[    10.149] (II) modeset(0): Output eDP-1 connected
[    10.149] (II) modeset(0): Output HDMI-1 disconnected
[    10.149] (II) modeset(0): Using exact sizes for initial modes
[    10.149] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[    10.149] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.149] (==) modeset(0): DPI set to (96, 96)
[    10.149] (II) Loading sub module "fb"
[    10.149] (II) LoadModule: "fb"
[    10.150] (II) Loading /usr/lib/xorg/modules/libfb.so
[    10.150] (II) Module fb: vendor="X.Org Foundation"
[    10.150] 	compiled for 1.20.10, module version = 1.0.0
[    10.150] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    10.150] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[    10.150] (==) NVIDIA(G0): RGB weight 888
[    10.150] (==) NVIDIA(G0): Default visual is TrueColor
[    10.150] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[    10.150] (**) Option "AllowNVIDIAGpuScreens"
[    10.150] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[    10.150] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[    10.150] (**) NVIDIA(G0): Enabling 2D acceleration
[    10.150] (II) Loading sub module "glxserver_nvidia"
[    10.150] (II) LoadModule: "glxserver_nvidia"
[    10.150] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[    10.201] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    10.201] 	compiled for 1.6.99.901, module version = 1.0.0
[    10.201] 	Module class: X.Org Server Extension
[    10.201] (II) NVIDIA GLX Module  460.32.03  Sun Dec 27 18:53:34 UTC 2020
[    10.203] (II) NVIDIA: The X server supports PRIME Render Offload.
[    12.261] (II) NVIDIA(G0): NVIDIA GPU GeForce GTX 1050 (GP107-A) at PCI:1:0:0 (GPU-0)
[    12.261] (--) NVIDIA(G0): Memory: 4194304 kBytes
[    12.261] (--) NVIDIA(G0): VideoBIOS: 86.07.40.00.2c
[    12.261] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[    12.261] (II) NVIDIA(G0): Validated MetaModes:
[    12.261] (II) NVIDIA(G0):     "NULL"
[    12.261] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[    12.261] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[    12.261] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[    12.304] (==) modeset(0): Backing store enabled
[    12.304] (==) modeset(0): Silken mouse disabled
[    12.384] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    12.384] (==) modeset(0): DPMS enabled
[    12.384] (II) modeset(0): [DRI2] Setup complete
[    12.385] (II) modeset(0): [DRI2]   DRI driver: iris
[    12.385] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    12.385] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    12.385] (II) NVIDIA:     access.
[    12.397] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    12.397] (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
[    12.397] (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
[    12.397] (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
[    12.397] (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
[    12.397] (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
[    12.397] (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    12.397] (II) NVIDIA(G0):     Config Options in the README.
[    12.439] (II) NVIDIA(G0): Setting mode "NULL"
[    12.442] (==) NVIDIA(G0): Disabling shared memory pixmaps
[    12.442] (==) NVIDIA(G0): Backing store enabled
[    12.442] (==) NVIDIA(G0): Silken mouse disabled
[    12.442] (==) NVIDIA(G0): DPMS enabled
[    12.443] (II) Loading sub module "dri2"
[    12.443] (II) LoadModule: "dri2"
[    12.443] (II) Module "dri2" already built-in
[    12.443] (II) NVIDIA(G0): [DRI2] Setup complete
[    12.443] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
[    12.443] (II) Initializing extension Generic Event Extension
[    12.443] (II) Initializing extension SHAPE
[    12.443] (II) Initializing extension MIT-SHM
[    12.443] (II) Initializing extension XInputExtension
[    12.443] (II) Initializing extension XTEST
[    12.443] (II) Initializing extension BIG-REQUESTS
[    12.443] (II) Initializing extension SYNC
[    12.443] (II) Initializing extension XKEYBOARD
[    12.443] (II) Initializing extension XC-MISC
[    12.443] (II) Initializing extension SECURITY
[    12.443] (II) Initializing extension XFIXES
[    12.443] (II) Initializing extension RENDER
[    12.443] (II) Initializing extension RANDR
[    12.443] (II) Initializing extension COMPOSITE
[    12.443] (II) Initializing extension DAMAGE
[    12.443] (II) Initializing extension MIT-SCREEN-SAVER
[    12.443] (II) Initializing extension DOUBLE-BUFFER
[    12.443] (II) Initializing extension RECORD
[    12.443] (II) Initializing extension DPMS
[    12.443] (II) Initializing extension Present
[    12.443] (II) Initializing extension DRI3
[    12.443] (II) Initializing extension X-Resource
[    12.443] (II) Initializing extension XVideo
[    12.443] (II) Initializing extension XVideo-MotionCompensation
[    12.443] (II) Initializing extension GLX
[    12.443] (II) Indirect GLX disabled.
[    12.449] (II) AIGLX: Loaded and initialized iris
[    12.449] (II) GLX: Initialized DRI2 GL provider for screen 0
[    12.449] (II) Initializing extension XFree86-VidModeExtension
[    12.449] (II) Initializing extension XFree86-DGA
[    12.449] (II) Initializing extension XFree86-DRI
[    12.449] (II) Initializing extension DRI2
[    12.449] (II) Initializing extension NV-GLX
[    12.449] (II) Initializing extension NV-CONTROL
[    12.451] (II) modeset(0): Damage tracking initialized
[    12.451] (II) modeset(0): Setting screen physical size to 508 x 285
[    12.498] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    12.498] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    12.498] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    12.498] (**) Power Button: Applying InputClass "system-keyboard"
[    12.498] (II) LoadModule: "libinput"
[    12.498] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    12.499] (II) Module libinput: vendor="X.Org Foundation"
[    12.499] 	compiled for 1.20.8, module version = 0.30.0
[    12.499] 	Module class: X.Org XInput Driver
[    12.499] 	ABI class: X.Org XInput driver, version 24.1
[    12.499] (II) Using input driver 'libinput' for 'Power Button'
[    12.500] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 36 paused 0
[    12.500] (**) Power Button: always reports core events
[    12.500] (**) Option "Device" "/dev/input/event3"
[    12.500] (**) Option "_source" "server/udev"
[    12.506] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    12.506] (II) event3  - Power Button: device is a keyboard
[    12.506] (II) event3  - Power Button: device removed
[    12.506] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    12.506] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    12.506] (**) Option "xkb_layout" "ro"
[    12.520] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    12.520] (II) event3  - Power Button: device is a keyboard
[    12.521] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event5)
[    12.521] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[    12.521] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[    12.521] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[    12.521] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[    12.521] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 39 paused 0
[    12.522] (**) Asus Wireless Radio Control: always reports core events
[    12.522] (**) Option "Device" "/dev/input/event5"
[    12.522] (**) Option "_source" "server/udev"
[    12.522] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    12.522] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    12.523] (II) event5  - Asus Wireless Radio Control: device removed
[    12.523] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input7/event5"
[    12.523] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[    12.523] (**) Option "xkb_layout" "ro"
[    12.523] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    12.524] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    12.524] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[    12.524] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    12.524] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    12.524] (**) Video Bus: Applying InputClass "system-keyboard"
[    12.524] (II) Using input driver 'libinput' for 'Video Bus'
[    12.525] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 40 paused 0
[    12.525] (**) Video Bus: always reports core events
[    12.525] (**) Option "Device" "/dev/input/event11"
[    12.525] (**) Option "_source" "server/udev"
[    12.526] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    12.526] (II) event11 - Video Bus: device is a keyboard
[    12.526] (II) event11 - Video Bus: device removed
[    12.526] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input22/event11"
[    12.526] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    12.526] (**) Option "xkb_layout" "ro"
[    12.527] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    12.527] (II) event11 - Video Bus: device is a keyboard
[    12.528] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[    12.528] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    12.528] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    12.528] (**) Video Bus: Applying InputClass "system-keyboard"
[    12.528] (II) Using input driver 'libinput' for 'Video Bus'
[    12.528] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 41 paused 0
[    12.528] (**) Video Bus: always reports core events
[    12.528] (**) Option "Device" "/dev/input/event12"
[    12.528] (**) Option "_source" "server/udev"
[    12.529] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[    12.529] (II) event12 - Video Bus: device is a keyboard
[    12.529] (II) event12 - Video Bus: device removed
[    12.530] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input23/event12"
[    12.530] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
[    12.530] (**) Option "xkb_layout" "ro"
[    12.531] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[    12.531] (II) event12 - Video Bus: device is a keyboard
[    12.531] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    12.531] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    12.531] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    12.531] (**) Power Button: Applying InputClass "system-keyboard"
[    12.531] (II) Using input driver 'libinput' for 'Power Button'
[    12.532] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[    12.532] (**) Power Button: always reports core events
[    12.532] (**) Option "Device" "/dev/input/event1"
[    12.532] (**) Option "_source" "server/udev"
[    12.533] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    12.533] (II) event1  - Power Button: device is a keyboard
[    12.533] (II) event1  - Power Button: device removed
[    12.533] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    12.533] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 10)
[    12.533] (**) Option "xkb_layout" "ro"
[    12.534] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    12.534] (II) event1  - Power Button: device is a keyboard
[    12.534] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[    12.534] (II) No input driver specified, ignoring this device.
[    12.534] (II) This device may have been added with another device file.
[    12.535] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    12.535] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    12.535] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    12.535] (**) Sleep Button: Applying InputClass "system-keyboard"
[    12.535] (II) Using input driver 'libinput' for 'Sleep Button'
[    12.536] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 43 paused 0
[    12.536] (**) Sleep Button: always reports core events
[    12.536] (**) Option "Device" "/dev/input/event0"
[    12.536] (**) Option "_source" "server/udev"
[    12.536] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    12.537] (II) event0  - Sleep Button: device is a keyboard
[    12.537] (II) event0  - Sleep Button: device removed
[    12.537] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[    12.537] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
[    12.537] (**) Option "xkb_layout" "ro"
[    12.538] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    12.538] (II) event0  - Sleep Button: device is a keyboard
[    12.539] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event13)
[    12.539] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "evdev keyboard catchall"
[    12.539] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "libinput keyboard catchall"
[    12.539] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "system-keyboard"
[    12.539] (II) Using input driver 'libinput' for 'USB2.0 HD UVC WebCam: USB2.0 HD'
[    12.539] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 44 paused 0
[    12.539] (**) USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events
[    12.539] (**) Option "Device" "/dev/input/event13"
[    12.539] (**) Option "_source" "server/udev"
[    12.541] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[    12.541] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[    12.541] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[    12.541] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input20/event13"
[    12.541] (II) XINPUT: Adding extended input device "USB2.0 HD UVC WebCam: USB2.0 HD" (type: KEYBOARD, id 12)
[    12.541] (**) Option "xkb_layout" "ro"
[    12.542] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[    12.542] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[    12.543] (II) config/udev: Adding input device Asus Keyboard (/dev/input/event10)
[    12.543] (**) Asus Keyboard: Applying InputClass "evdev keyboard catchall"
[    12.543] (**) Asus Keyboard: Applying InputClass "libinput keyboard catchall"
[    12.543] (**) Asus Keyboard: Applying InputClass "system-keyboard"
[    12.543] (II) Using input driver 'libinput' for 'Asus Keyboard'
[    12.544] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 45 paused 0
[    12.544] (**) Asus Keyboard: always reports core events
[    12.544] (**) Option "Device" "/dev/input/event10"
[    12.544] (**) Option "_source" "server/udev"
[    12.545] (II) event10 - Asus Keyboard: is tagged by udev as: Keyboard
[    12.545] (II) event10 - Asus Keyboard: device is a keyboard
[    12.545] (II) event10 - Asus Keyboard: device removed
[    12.545] (II) libinput: Asus Keyboard: needs a virtual subdevice
[    12.545] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0B05:1869.0002/input/input21/event10"
[    12.545] (II) XINPUT: Adding extended input device "Asus Keyboard" (type: MOUSE, id 13)
[    12.545] (**) Option "AccelerationScheme" "none"
[    12.545] (**) Asus Keyboard: (accel) selected scheme none/0
[    12.545] (**) Asus Keyboard: (accel) acceleration factor: 2.000
[    12.545] (**) Asus Keyboard: (accel) acceleration threshold: 4
[    12.547] (II) event10 - Asus Keyboard: is tagged by udev as: Keyboard
[    12.547] (II) event10 - Asus Keyboard: device is a keyboard
[    12.547] (II) config/udev: Adding input device ELAN1200:00 04F3:3090 Mouse (/dev/input/event8)
[    12.547] (**) ELAN1200:00 04F3:3090 Mouse: Applying InputClass "evdev pointer catchall"
[    12.547] (**) ELAN1200:00 04F3:3090 Mouse: Applying InputClass "libinput pointer catchall"
[    12.547] (II) Using input driver 'libinput' for 'ELAN1200:00 04F3:3090 Mouse'
[    12.548] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 46 paused 0
[    12.548] (**) ELAN1200:00 04F3:3090 Mouse: always reports core events
[    12.548] (**) Option "Device" "/dev/input/event8"
[    12.548] (**) Option "_source" "server/udev"
[    12.549] (II) event8  - ELAN1200:00 04F3:3090 Mouse: is tagged by udev as: Mouse Pointingstick
[    12.550] (II) event8  - ELAN1200:00 04F3:3090 Mouse: device is a pointer
[    12.550] (II) event8  - ELAN1200:00 04F3:3090 Mouse: device removed
[    12.551] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN1200:00/0018:04F3:3090.0001/input/input12/event8"
[    12.551] (II) XINPUT: Adding extended input device "ELAN1200:00 04F3:3090 Mouse" (type: MOUSE, id 14)
[    12.551] (**) Option "AccelerationScheme" "none"
[    12.551] (**) ELAN1200:00 04F3:3090 Mouse: (accel) selected scheme none/0
[    12.551] (**) ELAN1200:00 04F3:3090 Mouse: (accel) acceleration factor: 2.000
[    12.551] (**) ELAN1200:00 04F3:3090 Mouse: (accel) acceleration threshold: 4
[    12.552] (II) event8  - ELAN1200:00 04F3:3090 Mouse: is tagged by udev as: Mouse Pointingstick
[    12.552] (II) event8  - ELAN1200:00 04F3:3090 Mouse: device is a pointer
[    12.553] (II) config/udev: Adding input device ELAN1200:00 04F3:3090 Mouse (/dev/input/mouse0)
[    12.553] (II) No input driver specified, ignoring this device.
[    12.553] (II) This device may have been added with another device file.
[    12.554] (II) config/udev: Adding input device ELAN1200:00 04F3:3090 Touchpad (/dev/input/event9)
[    12.554] (**) ELAN1200:00 04F3:3090 Touchpad: Applying InputClass "evdev touchpad catchall"
[    12.554] (**) ELAN1200:00 04F3:3090 Touchpad: Applying InputClass "libinput touchpad catchall"
[    12.554] (II) Using input driver 'libinput' for 'ELAN1200:00 04F3:3090 Touchpad'
[    12.555] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 47 paused 0
[    12.555] (**) ELAN1200:00 04F3:3090 Touchpad: always reports core events
[    12.555] (**) Option "Device" "/dev/input/event9"
[    12.555] (**) Option "_source" "server/udev"
[    12.556] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: is tagged by udev as: Touchpad
[    12.557] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: device is a touchpad
[    12.557] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: device removed
[    12.558] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN1200:00/0018:04F3:3090.0001/input/input13/event9"
[    12.558] (II) XINPUT: Adding extended input device "ELAN1200:00 04F3:3090 Touchpad" (type: TOUCHPAD, id 15)
[    12.559] (**) Option "AccelerationScheme" "none"
[    12.559] (**) ELAN1200:00 04F3:3090 Touchpad: (accel) selected scheme none/0
[    12.559] (**) ELAN1200:00 04F3:3090 Touchpad: (accel) acceleration factor: 2.000
[    12.559] (**) ELAN1200:00 04F3:3090 Touchpad: (accel) acceleration threshold: 4
[    12.560] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: is tagged by udev as: Touchpad
[    12.562] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: device is a touchpad
[    12.562] (II) config/udev: Adding input device ELAN1200:00 04F3:3090 Touchpad (/dev/input/mouse1)
[    12.562] (II) No input driver specified, ignoring this device.
[    12.562] (II) This device may have been added with another device file.
[    12.563] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[    12.563] (II) No input driver specified, ignoring this device.
[    12.563] (II) This device may have been added with another device file.
[    12.563] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[    12.563] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[    12.564] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[    12.564] (II) No input driver specified, ignoring this device.
[    12.564] (II) This device may have been added with another device file.
[    12.564] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[    12.564] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[    12.565] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7)
[    12.565] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    12.565] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    12.565] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[    12.565] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[    12.565] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 48 paused 0
[    12.565] (**) Asus WMI hotkeys: always reports core events
[    12.565] (**) Option "Device" "/dev/input/event7"
[    12.565] (**) Option "_source" "server/udev"
[    12.566] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    12.566] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    12.566] (II) event7  - Asus WMI hotkeys: device removed
[    12.566] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input9/event7"
[    12.566] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 16)
[    12.566] (**) Option "xkb_layout" "ro"
[    12.567] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    12.567] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    12.568] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    12.568] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    12.568] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    12.568] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    12.568] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    12.569] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 49 paused 0
[    12.569] (**) AT Translated Set 2 keyboard: always reports core events
[    12.569] (**) Option "Device" "/dev/input/event4"
[    12.569] (**) Option "_source" "server/udev"
[    12.570] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    12.570] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    12.571] (II) event4  - AT Translated Set 2 keyboard: device removed
[    12.571] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    12.571] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[    12.571] (**) Option "xkb_layout" "ro"
[    12.572] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    12.572] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    12.573] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    12.573] (II) No input driver specified, ignoring this device.
[    12.573] (II) This device may have been added with another device file.
[    12.606] (**) Asus Keyboard: Applying InputClass "evdev keyboard catchall"
[    12.606] (**) Asus Keyboard: Applying InputClass "libinput keyboard catchall"
[    12.606] (**) Asus Keyboard: Applying InputClass "system-keyboard"
[    12.606] (II) Using input driver 'libinput' for 'Asus Keyboard'
[    12.606] (II) systemd-logind: returning pre-existing fd for /dev/input/event10 13:74
[    12.606] (**) Asus Keyboard: always reports core events
[    12.606] (**) Option "Device" "/dev/input/event10"
[    12.606] (**) Option "_source" "_driver/libinput"
[    12.606] (II) libinput: Asus Keyboard: is a virtual subdevice
[    12.606] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0B05:1869.0002/input/input21/event10"
[    12.606] (II) XINPUT: Adding extended input device "Asus Keyboard" (type: KEYBOARD, id 18)
[    12.606] (**) Option "xkb_layout" "ro"
[    12.989] (II) modeset(0): EDID vendor "AUO", prod id 25069
[    12.989] (II) modeset(0): Printing DDC gathered Modelines:
[    12.989] (II) modeset(0): Modeline "1920x1080"x0.0  142.00  1920 2028 2076 2100  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    19.593] (**) Option "fd" "36"
[    19.594] (II) event3  - Power Button: device removed
[    19.594] (**) Option "fd" "39"
[    19.595] (II) event5  - Asus Wireless Radio Control: device removed
[    19.595] (**) Option "fd" "40"
[    19.595] (II) event11 - Video Bus: device removed
[    19.596] (**) Option "fd" "41"
[    19.596] (II) event12 - Video Bus: device removed
[    19.596] (**) Option "fd" "42"
[    19.596] (II) event1  - Power Button: device removed
[    19.596] (**) Option "fd" "43"
[    19.596] (II) event0  - Sleep Button: device removed
[    19.597] (**) Option "fd" "44"
[    19.597] (II) event13 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[    19.597] (**) Option "fd" "45"
[    19.597] (**) Option "fd" "46"
[    19.597] (II) event8  - ELAN1200:00 04F3:3090 Mouse: device removed
[    19.597] (**) Option "fd" "47"
[    19.597] (II) event9  - ELAN1200:00 04F3:3090 Touchpad: device removed
[    19.597] (**) Option "fd" "48"
[    19.597] (II) event7  - Asus WMI hotkeys: device removed
[    19.597] (**) Option "fd" "49"
[    19.597] (II) event4  - AT Translated Set 2 keyboard: device removed
[    19.598] (**) Option "fd" "45"
[    19.598] (II) event10 - Asus Keyboard: device removed
[    19.598] (II) AIGLX: Suspending AIGLX clients for VT switch
[    19.609] (EE) modeset(0): failed to set mode: Permission denied
[    19.609] (II) systemd-logind: got pause for 13:74
[    19.609] (II) systemd-logind: got pause for 226:1
[    19.609] (II) systemd-logind: got pause for 13:72
[    19.609] (II) systemd-logind: got pause for 13:71
[    19.609] (II) systemd-logind: got pause for 13:75
[    19.609] (II) systemd-logind: got pause for 13:77
[    19.609] (II) systemd-logind: got pause for 13:67
[    19.609] (II) systemd-logind: got pause for 13:69
[    19.609] (II) systemd-logind: got pause for 13:73
[    19.609] (II) systemd-logind: got pause for 13:76
[    19.609] (II) systemd-logind: got pause for 13:68
[    19.609] (II) systemd-logind: got pause for 13:64
[    19.609] (II) systemd-logind: got pause for 13:65
[    22.705] (II) UnloadModule: "libinput"
[    22.705] (II) systemd-logind: not releasing fd for 13:74, still in use
[    22.705] (II) systemd-logind: releasing fd for 13:68
[    22.715] (II) UnloadModule: "libinput"
[    22.715] (II) systemd-logind: releasing fd for 13:71
[    22.731] (II) UnloadModule: "libinput"
[    22.731] (II) systemd-logind: releasing fd for 13:73
[    22.751] (II) UnloadModule: "libinput"
[    22.751] (II) systemd-logind: releasing fd for 13:72
[    22.758] (II) UnloadModule: "libinput"
[    22.758] (II) systemd-logind: releasing fd for 13:74
[    22.774] (II) UnloadModule: "libinput"
[    22.774] (II) systemd-logind: releasing fd for 13:77
[    22.790] (II) UnloadModule: "libinput"
[    22.790] (II) systemd-logind: releasing fd for 13:64
[    22.804] (II) UnloadModule: "libinput"
[    22.804] (II) systemd-logind: releasing fd for 13:65
[    22.817] (II) UnloadModule: "libinput"
[    22.817] (II) systemd-logind: releasing fd for 13:76
[    22.841] (II) UnloadModule: "libinput"
[    22.841] (II) systemd-logind: releasing fd for 13:75
[    22.864] (II) UnloadModule: "libinput"
[    22.864] (II) systemd-logind: releasing fd for 13:69
[    22.891] (II) UnloadModule: "libinput"
[    22.891] (II) systemd-logind: releasing fd for 13:67
[    22.941] (II) NVIDIA(GPU-0): Deleting GPU-0
[    22.944] (II) Server terminated successfully (0). Closing log file.
Have you tried what happens if you switch to (e.g.) tty4, and then back to tty1 after a couple seconds? I cannot see anything wrong in the Xorg log.
I have tried this, yes.
It’s the only way I can actually login.
But this is a best case scenario. Usually it’s a series of 3-6 force-shutdowns before I can even switch to a tty, other than tty, than back to tty1 so I can login.
hi,
i’m new to this forum and i write you from france (sorry if faults happen)
I’m using manjaro with a asus rog fx553vd (officially gl553vd, but i wonder if the same), and have similar black screen issue (but often i can have login screen after one or maximum two reboots)
i will try ctrl+alt+f4 trick when i encounter again and tell you
