Start sector position of the swap partition should be a multiple of 4096 (your physical sector size). If you don’t get it done with first try - don’t worry you can check it afterwards with
sudo fdisk -l
sudo fdisk -l
First sector: 1446689126
Last sector: 1465144064
Total sector: 18454939
edit: so how do I move this to get this aligned correctly?
Start sector 1446689128 would be fine.
When I am in GParted, and moving the arrows, what exactly am I looking for?
Reducing the linux-swap partition size I am guessing? It then creates an unallocated partition space?
I think GParted won’t allow you to move only by 2 sectors but setting 1 MiB free unallocated space before the partition should be fine. Keep “MiB” in the field “Alignment to”. Then the partition is aligned perfectly after you execute the change in GParted.
Thanks @Wollie.
In GParted, I:
Set free space preceding to 1Mb
New size 9010
Free space following 2Mb
Align to MiB.
returns:
Disk /dev/sda: 698.64 GiB, 750156374016 bytes, 1465149168 sectors
Disk model: ST750LM022 HN-M7
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 07ED1A8A-3900-904A-9379-412EC64306B1
Device Start End Sectors Size Type
/dev/sda1 4096 618495 614400 300M EFI System
/dev/sda2 618496 1446689125 1446070630 689.5G Linux filesystem
/dev/sda3 1446692864 1465145343 18452480 8.8G Linux swap
I’ll do a reboot now and see if any changes.
I edited the # out of the /etc/fstab file, saved and rebooted.
Not showing signs of increased boot time.
I tried:
And just went for a restart. No changes. Still 1:00 to login, and then at around 2:30 I’m in Firefox again.
I knew this machine was on it’s last legs, but thought I could at least get a good run out of KDE haha.
Any other options? I haven’t tried the live ISO boot you mentioned earlier in step 2.
Edit a few hours later: I’m going to attempt to do a clean instal of XFCE. From what I understand it will run general tasks better which is what I am after (Libreoffice, and most things just run and open too slow for me now). I will update this thread after if there’s any changes.
I assume the speed of your hdd is currently your limiting factor, but trying another DE could give you evidence. I would have checked some other things, first. For example you could post:
cat etc/default/grub
I’m in a live boot now via USB running XFCE iso.
returns:
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us
tz=Asia/Seoul utc=yes driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1 misobasedir=manjaro misolabel=MANJARO_XFCE_2012 quiet
systemd.show_status=1 apparmor=1 security=apparmor
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N56VZ v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N56VZ v: 1.0 serial: <filter>
UEFI: American Megatrends v: N56VZ.215 date: 11/02/2012
ID-1: BAT0 charge: 21.5 Wh condition: 22.5/57.7 Wh (39%) volts: 11.1/11.1
model: ASUSTeK N56--52 type: Li-ion serial: N/A status: Unknown
cycles: 577
Topology: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38328
Speed: 1197 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1196 2: 1197
3: 1197 4: 1197 5: 1198 6: 1197 7: 1197 8: 1197
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK N56VZ
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: NVIDIA GK107M [GeForce GT 650M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:0fd1
Device-3: Sunplus Innovation Asus Webcam type: USB driver: uvcvideo
bus ID: 3-1.3:4 chip ID: 1bcf:2883
Display: x11 server: X.Org 1.20.9 driver: intel display ID: :0.0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK N56VZ driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0e1b
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
port: f040 bus ID: 03:00.0 chip ID: 8086:0887
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ
driver: alx v: kernel port: d000 bus ID: 04:00.0 chip ID: 1969:1091
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 755.92 GiB used: 338.9 MiB (0.0%)
ID-1: /dev/sda vendor: Seagate model: ST750LM022 HN-M750MBB
size: 698.64 GiB block size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb type: USB vendor: SanDisk model: Ultra size: 57.28 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
scheme: MBR
ID-1: / raw size: N/A size: 5.75 GiB used: 338.9 MiB (5.8%) fs: overlay
source: ERR-102
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Processes: 235 Uptime: 5m Memory: 7.66 GiB used: 1.30 GiB (17.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1141 lib: 313
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
and
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-418xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-430xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-435xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-440xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-340xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-418xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-435xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-440xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/catalyst/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2020.10.04 false PCI
Today I’ve also tried mint and lubuntu distros. All distros including manjaro seem to run fine off the Usb, until I install them on my laptop and then they have the very slow boot times.
Manjaro xfce shows an improvement in boot time and opening programs. Mint was okay but had wifi problems, and lubuntu had graphic problems in libreoffice. Both mint and lubuntu kept having some error message on startup before login about PCE or something rather. I’m actually going to reinstall Manjaro xfce now because that’s the one I’d like to make work best if possible.
I’m back on Manjaro XFCE installed on my laptop. I’ve run most of the commands from this thread again already.
Boot times slightly better than KDE, with programs like Firefox and Libreoffice starting sightly quicker too.
This returns:
cat: etc/default/grub: No such file or directory
just before installing , check if USB iso manjaro boot is ok with no-free drivers
A) EFI bios boot
recheck all options in EFI bios
boot on USB iso manjaro with no-free drivers
check if all good EFI
inxi -Mxxa ( check for UEFI or bios , not UEFI[legacy] )
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l ( GPT is better case )
then redo installation ,
for EFI: GPT + /boot/efi ( partition /boot/efi type vfat ( FAT32 ) with flag boot & esp )
or
for Bios + GPT ( create partition 33Mo NOT FORMATTED with flag bios_grub )
B) for trouble on slow boot
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21 L2 cache: 6144 KiB
after install
add
sudo pacman -S powertop htop cpupower lm_sensors haveged
sudo systemctl enable --now haveged
sudo sensors-detect
sudo mhwd-kernel -i linux419 linux54
on next reboot press Esc to see Grub ,
and select older kernel ( 4.19 LTS or 5.4 LTS or 5.8 or 5.9 )
keep always 2 ore more kernels installed in case of trouble
also check
sudo systemd-analyze blame
sudo systemd-analyze critical-chain
sudo journalctl -b0 -p4
Sorry, misspelling it should have been
cat /etc/default/grub
Looking at your disk it is a superslow notebook hdd, 7 years old, even at release time one of not-so-fast models. So, in the end I fear with all the software tweaks, you won’t gain the time you invest. Replacing the disk with a ssd should give it a real boost.
The faster impression you got from windows might be the result of win using some sort of hibernation instead of full shutdown in most cases.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=f9620ed0-383b-482f-9df0-473fc0c365f5 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
Yeah I figured as much. On it’s last legs (or well past it) this HDD. I may begin looking at changing it for an SSD at some point.
To be honest I am quite happy with the performance of Manjara Xfce that I am getting at the moment. After about 2-3mins of getting past the booting in and logging in, it runs quite smooth. So I can only imagine with an SSD it would be flying.
@stephane Wow thanks for the post! Lot’s of details there for a beginner like me to go through. At least for today I’ll wait to go through another re-install after Manjara is feeling ok (excluding the boot time). I’ll see if I can clean some dust out. And yeah I’ll look at the SSD option too.
Would you recommend I run this now with my current install?
yes , it’s better to see now values , change and see after …
Done.
I followed this through with all the “YES” commands, this was the result:
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
* Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to generate /etc/conf.d/lm_sensors? (YES/no): YES
Created symlink /etc/systemd/system/multi-user.target.wants/lm_sensors.service → /usr/lib/systemd/system/lm_sensors.service.
Unloading i2c-dev... OK
Unloading cpuid... OK
I pressed Esc at reboot, and saw these options:
P2: DVDRAM
Atheros Boot Agent
Manjara
Enter Setup
I wasn’t sure, so I just went into setup and rebooted as normal back into Manjaro haha.
next
htop ( in one terminal see cpu idle , no other apps )
sudo powertop ( in another terminal and tab )
sudo cpupower frequency-info
sensors
Not sure what info to post but I’ll do my best here.
960G/7.66G, Tasks 74, 129 thr, 1 running.
PkG(HW)
C7(pc7) 92%
Core(HW)
C7(cc7) 98.9%
Core (HW)
C7 (cc7) 96.9%
The other “C”'s show from zero-1% (not sure what all this means?)
analyzing CPU 0:
driver: intel_cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 20.0 us
hardware limits: 1.20 GHz - 3.40 GHz
available cpufreq governors: performance schedutil
current policy: frequency should be within 1.20 GHz and 3.40 GHz.
The governor "schedutil" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 1.99 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
3200 MHz max turbo 4 active cores
3200 MHz max turbo 3 active cores
3300 MHz max turbo 2 active cores
3400 MHz max turbo 1 active cores
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +54.0°C (high = +87.0°C, crit = +105.0°C)
Core 0: +54.0°C (high = +87.0°C, crit = +105.0°C)
Core 1: +44.0°C (high = +87.0°C, crit = +105.0°C)
Core 2: +42.0°C (high = +87.0°C, crit = +105.0°C)
Core 3: +47.0°C (high = +87.0°C, crit = +105.0°C)
BAT0-acpi-0
Adapter: ACPI interface
in0: 11.10 V
acpitz-acpi-0
temp1: +52.0°C (crit = +108.0°C)
asus-isa-0000
cpu_fan: 1900 RPM
temp1: +52.0°C
Change this into
GRUB_TIMEOUT=2
and you save another 8 sec.
Afterwards
sudo update-grub
to make it effective at next boot.
Is it necessary to change the grub timeout?
I don’t think my grub appears? I Just see theAsus and intel logo for about half a second, and then it turns to black screen for about 45sec before the cursor and log in screen appears.
Try it.
