When I open the /etc/default/grub file in the notepad and try to save, it says permission denied.
I found this did the trick:
sudo xdg-open /etc/default/grub
Rebooting now.
No real change. Boot time to log in was still about 50 seconds.
Rebooting now.
Howdy!
Could you please provide me the output of udevadm info --attribute-walk -n /dev/sda1 | grep 'DRIVERS=="[^"]'
, please?
Thank you!
" DRIVERS==āsdā
DRIVERS==āahciā "
Sweet!
Now its time to sudo nano /etc/mkinitcpio.conf
Then find the line starting by MODULES="
, and remove everything between the quotation marks and add ahci sd_mod ext4
in between of the quotation mark.
Then find the line starting with BINARIES="
and clear everything (or add fsck fsck.ext4
if you want to check the disk quickly at startup)
Now find the line starting with HOOKS="
and remove everything except base
After that go completely to the bottom, and add COMPRESSION="cat"
If some of the lines are missing, you may add them.
Ctrl+S to save, Ctrl+X to leave.
You may then execute sudo mkinitcpio -P
, sudo update-grub
and reboot!
It should be 10 to 40% faster (results may vary)!
Awesome thanks!
I have done those things, Iāll reboot now and see.
Ok Iād say thereās about a 5-10 sec saving in time at the moment. After logging in the login screen seems to hang for a couple extra longer seconds than before, but otherwise the boot is faster for me to get back into a browser window. The shut down seems faster than before, Iād say about 2-3secs faster.
I have this added and noticed it did take some time (maybe 20secs or so). Iāll clear that line from BINARIES=" and re-execute:
I will update in a few minutes.
Edit: alright so time-wise thereās no difference whether I keep the fsck fsck.ext4
or not.
Is there a benefit to keeping this line/versus not keeping it?
If thereās minor corruption, this may fix it!
Ok Iāve added this back, reboot time is the same regardless. Pretty happy with how it runs once it is booted and logged in.
Is this probably going to be as good as I can get with this machine?
Maybe I can start looking into other things and using Manjaro haha.
