I sudo nano-ed the /etc/default/grub
and remove “quiet” from GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3" , saved it and updated the grub.
upon rebooting, I encountered the same line during the boot up.
[numbers] Bluetooth : hci0 : BCM : firmware Patch file not found , tried :
[numbers] Bluetooth : hci0 : BCM : ‘brcm/BCMHK20782A1-0a5c-21e3.hcd’
[numbers] Bluetooth : hci0 : BCM : ‘brcm/BCM-0a5c-21e3.hcd’
grabs all xorg logs and print it on the screen, the second one print nothing, but pipe it to curl and it uploads it to 0x0.st, then a link will be displayed.
sorry forgot to mention. You can switch to another tty CTRL+ALT+F3, login and type it there, or start a live session with a install disk, open a terminal, type manjaro-chroot -a and type it there.
[ 17.059] (II) LoadModule: "vesa"
[ 17.059] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 17.059] (II) Module vesa: vendor="X.Org Foundation"
[ 17.059] compiled for 1.20.9, module version = 2.5.0
[ 17.059] Module class: X.Org Video Driver
[ 17.059] ABI class: X.Org Video Driver, version 24.1
[ 17.059] (II) VESA: driver for VESA chipsets: vesa
This is the problem… please keep sure only video-linux is installed:
(if your on a live session, keep sure you are at a chroot)
