Hi team and everybody,
First of all, thanks for the amazing job on Manjaro that I use since a few months.
But here I have a problem and I’m a bit in “panic mode” : I did yesterday the update 20220123 on my GNOME Manjaro flavor and since I’m stuck at boot on these messages :
[FAILED] Failed to start Samba NMB Daemon
[FAILED] Failed to start Samba SMB Daemon
I guess that’s not really the problem as the upgrade included a new Kernel and new NVidia drivers.
Can anyone help me or at least tell me how to access a command line ?
Thanks a lot in advance !
PS: I am a total beginner under Arch, I come from Debian initially
Add systemd.unit=multi-user.target to the kernel parameter. That works on any system, which boots with systemd.
My main issue is that I don’t have for now any command line
Ctrl-Alt + F1 or F2 or F3 (during 7’’) ?
How would you add a kernel parameter on debian temporary? Just edit the grub boot menu and add it there.
Normally that should work… but if not, see above.
OK ok, I use instead a Live Boot and I try a
manjaro-chroot -a
Then I try an upgrade (no changes at reboot for both)
sudo pacman -Syyu
sudo pacman -Syyuu
Then I try to look at
sudo journalctl | grep fail
And I have some strange things
Jan 26 15:03:51 MyDevice dbus-daemon[504]: [system] Activation via systemd failed for unit ‘dbus-org.freedesktop.home1.service’: Unit dbus-org.freedesktop.home1.service not found.
Jan 26 15:03:51 MyDevice /usr/lib/gdm-x-session[29914]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Jan 26 15:03:51 MyDevice gdm[547]: Gdm: GdmDisplay: Session never registered, failing
Jan 26 15:03:51 MyDevice systemd[1]: Tell Plymouth To Jump To initramfs was skipped because of a failed condition check (ConditionPathExists=/run/initramfs/bin/sh).
Jan 26 15:03:51 MyDevice dbus-daemon[504]: [system] Activation via systemd failed for unit ‘dbus-org.freedesktop.nm-dispatcher.service’: Refusing activation, D-Bus is shutting down.
Jan 26 16:04:21 MyDevice systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
Jan 26 16:04:21 MyDevice systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
Jan 26 16:04:21 MyDevice systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
Jan 26 16:04:21 MyDevice systemd[1]: Rebuild Hardware Database was skipped because all trigger condition checks failed.
Jan 26 16:04:21 MyDevice kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
Jan 26 16:04:21 MyDevice systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
Jan 26 16:04:21 MyDevice systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
A problem with systemd I guess ?
OK, I just another topic with seemingly the same anomaly.
I try
sudo manjaro-chroot -a
mhwd-kernel -li
mhwd -li
inxi -Fza
mkinitcpio -P
An I got :
[manjaro-gnome /]# sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
[manjaro-gnome /]# sudo mhwd -la
> All PCI configs:
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
network-r8168 2016.04.20 true PCI
network-broadcom-wl 2018.10.07 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-vesa 2017.03.12 true PCI
video-sisusb 2020.01.18 true PCI
video-s3 2020.01.18 true PCI
video-nvidia-470xx 2021.12.18 false PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-rendition 2020.01.18 true PCI
video-openchrome 2020.01.18 true PCI
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-virtualmachine 2021.07.26 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-voodoo 2017.03.12 true PCI
video-nvidia-390xx 2021.12.18 false PCI
Warning: No USB configs found!
[manjaro-gnome /]# mhwd-kernel -li
Currently running: 5.15.12-1-MANJARO (linux515)
* linux414
* linux513
[manjaro-gnome /]# mhwd -li
[manjaro-gnome /]# inxi -Fza
12System:
12Kernel 5.15.12-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 11.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=fr_FR keytable=fr tz=UTC misobasedir=manjaro
misolabel=MANJARO_GNOME_2121 quiet systemd.show_status=1 driver=nonfree nouveau.modeset=0
i915.modeset=1 radeon.modeset=1
12Console N/A 12wm gnome-shell 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Desktop 12System ASUS 12product All Series 12v N/A 12serial N/A
12Mobo ASUSTeK 12model H97-PRO GAMER 12v Rev X.0x 12serial <filter> 12BIOS American Megatrends 12v 2003
12date 06/18/2014
12CPU:
12Info 12model Intel Core i7-4790S 12socket BGA1155 (1150) 12note check 12bits 64 12type MT MCP 12arch Haswell
12family 6 12model-id 0x3C (60) 12stepping 3 12microcode 0x28
12Topology 12cpus 1x 12cores 4 12tpc 2 12threads 8 12smt enabled 12cache 12L1 256 KiB
12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 8 MiB 12desc 1x8 MiB
12Speed (MHz) 12avg 3193 12high 3197 12min/max 800/4000 12base/boost 3200/3900 12scaling
12driver intel_cpufreq 12governor schedutil 12volts 1.2 V 12ext-clock 100 MHz 12cores 121 3193 122 3193 123 3194
124 3193 125 3192 126 3194 127 3197 128 3193 12bogomips 51096
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
12Vulnerabilities
12Type itlb_multihit 12status KVM: VMX unsupported
12Type l1tf 12mitigation PTE Inversion
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2
12mitigation Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GP107 [GeForce GTX 1050 Ti] 12vendor ASUSTeK 12driver nvidia 12v 495.44 12bus-ID 01:00.0
12chip-ID 10de:1c82 12class-ID 0300
12Display 12server X.org 1.21.1.3 12compositor gnome-shell 12driver 12loaded nvidia
12note n/a (using device driver) 12resolution <missing: xdpyinfo>
12Message Unable to show advanced data. Required tool glxinfo missing.
12Audio:
12Device-1 Intel 9 Series Family HD Audio 12vendor ASUSTeK 12driver snd_hda_intel 12v kernel
12bus-ID 00:1b.0 12chip-ID 8086:8ca0 12class-ID 0403
12Device-2 NVIDIA GP107GL High Definition Audio 12vendor ASUSTeK 12driver snd_hda_intel 12v kernel
12bus-ID 01:00.1 12chip-ID 10de:0fb9 12class-ID 0403
12Device-3 GN Netcom Jabra Link 380 12type USB 12driver jabra,snd-usb-audio,usbhid
12bus-ID 3-10.2.2.1:19 12chip-ID 0b0e:24c8 12class-ID 0300 12serial <filter>
12Sound Server-1 ALSA 12v k5.15.12-1-MANJARO 12running yes
12Sound Server-2 JACK 12v 1.9.20 12running no
12Sound Server-3 PulseAudio 12v 15.0 12running yes
12Sound Server-4 PipeWire 12v 0.3.43 12running no
12Network:
12Device-1 Intel Ethernet I218-V 12vendor ASUSTeK 12driver e1000e 12v kernel 12port f040 12bus-ID 00:19.0
12chip-ID 8086:15a1 12class-ID 0200
12IF eno1 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Drives:
12Local Storage 12total 935.37 GiB 12used 766.81 GiB (82.0%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12maj-min 8:0 12vendor Crucial 12model CT1000BX500SSD1 12size 931.51 GiB 12block-size
12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12type SSD 12serial <filter> 12rev 030
12ID-2 /dev/sdb 12maj-min 8:16 12type USB 12vendor Kingston 12model DataTraveler 2.0 12size 3.86 GiB
12block-size 12physical 512 B 12logical 512 B 12type N/A 12serial <filter> 12rev 1.00
12Partition:
12ID-1 / 12raw-size 931.22 GiB 12size 915.53 GiB (98.32%) 12used 766.81 GiB (83.8%) 12fs ext4
12block-size 4096 B 12dev /dev/sda2 12maj-min 8:2
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 288 KiB (0.1%) 12fs vfat
12block-size 512 B 12dev /dev/sda1 12maj-min 8:1
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 29.8 C 12mobo 27.8 C
12Fan Speeds (RPM) N/A
12Info:
12Processes 273 12Uptime 23m 12wakeups 0 12Memory 15.57 GiB 12used 3.2 GiB (20.6%) 12Init systemd 12v 250
12tool systemctl 12Compilers 12gcc 11.1.0 12clang 13.0.0 12Packages 12pacman 1365 12lib 362 12flatpak 0
12Client Unknown Client: systemd 12inxi 3.3.12
[manjaro-gnome /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
==> Starting build: 4.14.262-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
-> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> Starting build: 5.13.19-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
I solve this by installing (thru pacman) :
linux515
linux515-headers
linux515-nvidia
And rebooting, all is OK now !
