Boot stuck after luks mounts /home ?!?
Hello there,
after closing the lid (Laptop User) last Night, i could not get manjaro to boot (BlackScreen in the moring, after pressing keys to get it out of suspend) properly. I tried to do some digging with journalctl:
-- Journal begins at Fri 2021-10-22 17:53:58 CEST, ends at Fri 2021-10-29 10:35:31 CEST. --
Okt 29 10:20:48 titanic kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Okt 29 10:20:48 titanic kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Okt 29 10:20:48 titanic kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Okt 29 10:20:48 titanic kernel: pci 0000:00:00.2: PCI INT A: not connected
Okt 29 10:20:48 titanic kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20210331/psargs-330)
Okt 29 10:20:48 titanic kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
Okt 29 10:20:48 titanic kernel: nvme nvme1: missing or invalid SUBNQN field.
Okt 29 10:20:48 titanic kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Okt 29 10:20:48 titanic kernel: vboxdrv: loading out-of-tree module taints kernel.
Okt 29 10:20:48 titanic kernel: VBoxNetAdp: Successfully started.
Okt 29 10:20:48 titanic kernel: VBoxNetFlt: Successfully started.
Okt 29 10:20:48 titanic systemd-udevd[345]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Okt 29 10:20:48 titanic systemd-udevd[359]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Okt 29 10:20:48 titanic kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Okt 29 10:20:48 titanic kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Okt 29 10:20:48 titanic kernel: nvidia: module license 'NVIDIA' taints kernel.
Okt 29 10:20:48 titanic kernel: Disabling lock debugging due to kernel taint
Okt 29 10:20:48 titanic kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.63.01  Tue Aug  3 20:44:16 UTC 2021
Okt 29 10:20:48 titanic systemd-udevd[348]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Okt 29 10:20:48 titanic systemd-udevd[341]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Okt 29 10:20:48 titanic systemd-udevd[393]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Okt 29 10:20:48 titanic kernel: mt7921e 0000:03:00.0: ASIC revision: 79610010
Okt 29 10:20:48 titanic kernel: mt7921e: probe of 0000:03:00.0 failed with error -110
Okt 29 10:20:48 titanic tlp[557]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:20:48 titanic tlp[557]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:20:48 titanic tlp[557]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:20:48 titanic tlp[557]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:20:49 titanic tlp[783]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:20:49 titanic tlp[783]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:20:49 titanic tlp[783]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:20:49 titanic tlp[783]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:20:49 titanic kernel: ATPX version 1, functions 0x00000001
Okt 29 10:20:49 titanic kernel: ATPX Hybrid Graphics
Okt 29 10:20:50 titanic systemd-backlight[879]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Okt 29 10:20:50 titanic systemd[1]: systemd-backlight@backlight:acpi_video0.service: Failed with result 'exit-code'.
Okt 29 10:20:50 titanic systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Okt 29 10:20:54 titanic kernel: kauditd_printk_skb: 16 callbacks suppressed
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.leaf
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.leaf
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.leaf
Okt 29 10:21:05 titanic acvpnagent[928]: Function: processOnLoadPreferencesComplete File: ../../vpn/Agent/MainThread.cpp Line: 7358 Invoked Function: CLoginUtilsMgr::SetAnyConnectLaunchAtLogin Return Code: -28180479 (0xFE520001) Description: LOGINUTILS_ERROR_NOT_IMPLEMENTED
Okt 29 10:21:05 titanic sddm[967]: Failed to read display number from pipe
Okt 29 10:21:05 titanic sddm[967]: Attempt 1 starting the Display server on vt 1 failed
Okt 29 10:21:05 titanic acvpnagent[928]: Function: getConfigurationFileContents File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 216 The configuration file for customizing debug logs doesn't exist or is not readable.
Okt 29 10:21:05 titanic acvpnagent[928]: Function: loadConfigurationFromFile File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 284 Invoked Function: CAppLogCustomConfig::getConfigurationFileContents Return Code: -18939894 (0xFEDF000A) Description: APPLOGCUSTOMCONFIG_ERROR_CONFIG_FILE_NOT_READABLE
Okt 29 10:21:05 titanic acvpnagent[928]: Function: initConfigurationMap File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 76 Invoked Function: CAppLogCustomConfig::loadConfigurationFromFile Return Code: -18939894 (0xFEDF000A) Description: APPLOGCUSTOMCONFIG_ERROR_CONFIG_FILE_NOT_READABLE
Okt 29 10:21:05 titanic acvpnagent[928]: Function: getTargetPath File: ../../vpn/Common/Utility/DeviceID.cpp Line: 616 /dev/nvme0n1p5 is not a link
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.namcntrl
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.namcntrl
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.namcntrl
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.websecurity
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.websecurity
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.websecurity
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.fireamp_enabler
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.fireamp_enabler
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.fireamp_enabler
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.nvm
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.nvm
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.nvm
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.umbrella
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.umbrella
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.umbrella
Okt 29 10:21:05 titanic acvpnagent[928]: Function: instantiateInterfaces File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 962 Invoked Function: PluginLoader::loadModulesWithInterface Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.iseposture
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CreateInstance File: ../../vpn/Common/Utility/PluginLoader.cpp Line: 446 Invoked Function: PluginLoader::instantiateInterfaces Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.iseposture
Okt 29 10:21:05 titanic acvpnagent[928]: Function: QuickCreatePlugin File: ../../vpn/Common/Utility/PluginLoader.h Line: 206 Invoked Function: PluginLoader::CreateInstance Return Code: -29294570 (0xFE410016) Description: PLUGINLOADER_ERROR_NO_INTERFACE_NAME:No interface name. com.cisco.anyconnect.service.iseposture
Okt 29 10:21:05 titanic acvpnagent[928]: Function: getProfilePath File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 576 Invoked Function: getpwnam Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 400 Invoked Function: CNSSCertUtils::getProfilePath Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 76 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1887 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: OpenStores File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 451 Invoked Function: CCollectiveCertStore::addNSSStore Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: verify_callback File: ../../vpn/CommonCrypt/Certificates/FileCertificate.cpp Line: 417 Invoked Function: X509_verify_cert Return Code: 0 (0x00000000) Description: ok
Okt 29 10:21:05 titanic acvpnagent[928]: Function: startParser File: ../../vpn/Common/Xml/CVCSaxParser.cpp Line: 171 Invoked Function: xmlCreateFileParserCtxt Return Code: -33554427 (0xFE000005) Description: GLOBAL_ERROR_NULL_POINTER
Okt 29 10:21:05 titanic acvpnagent[928]: Function: LoadSettingsFromXmlFile File: ../../vpn/PhoneHome/PhoneHomeAgent.cpp Line: 627 Invoked Function: XmlParser::parseFile Return Code: -33554423 (0xFE000009) Description: GLOBAL_ERROR_UNEXPECTED
Okt 29 10:21:05 titanic acvpnagent[928]: Function: LoadFileToMap File: ../../vpn/PhoneHome/PhoneHomeAgent.cpp Line: 2259 Can't open file /opt/cisco/anyconnect/CustomerExperienceFeedback/config
Okt 29 10:21:07 titanic sddm[967]: Failed to read display number from pipe
Okt 29 10:21:07 titanic sddm[967]: Attempt 2 starting the Display server on vt 1 failed
Okt 29 10:21:09 titanic tlp[1191]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:21:09 titanic tlp[1191]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:21:09 titanic tlp[1191]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:21:09 titanic tlp[1191]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:21:09 titanic sddm[967]: Failed to read display number from pipe
Okt 29 10:21:09 titanic sddm[967]: Attempt 3 starting the Display server on vt 1 failed
Okt 29 10:21:09 titanic sddm[967]: Could not start Display server on vt 1
Okt 29 10:21:11 titanic kernel: kauditd_printk_skb: 28 callbacks suppressed
Okt 29 10:21:19 titanic systemd-xdg-autostart-generator[1240]: Configuration file /home/jonas/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Okt 29 10:21:35 titanic kernel: kauditd_printk_skb: 10 callbacks suppressed
Okt 29 10:21:50 titanic kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Okt 29 10:22:27 titanic tlp[1258]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:22:27 titanic tlp[1258]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:22:27 titanic tlp[1258]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:22:27 titanic tlp[1258]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:23:45 titanic tlp[1289]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:23:45 titanic tlp[1289]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:23:45 titanic tlp[1289]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:23:45 titanic tlp[1289]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:25:03 titanic tlp[1322]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:25:03 titanic tlp[1322]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Okt 29 10:25:03 titanic tlp[1322]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Okt 29 10:25:03 titanic tlp[1322]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Okt 29 10:26:06 titanic acvpnagent[928]: Function: GetSettings File: ../../vpn/Agent/ServicePluginMgr.cpp Line: 289 m_pIServicePlugin is NULL
Okt 29 10:26:22 titanic tlp[1357]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Okt 29 10:26:22 titanic tlp[1357]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
but i do not understand … a lot
this was the problem.
force reinstall of graphics drivers solved the boot problem
user $ sudo mhwd -f -a pci nonfree 0300
