Hi,
I have used manjaro for a few months now, and I have liked the experience so far. It’s been a bit messy since I have a pretty old integrated/dedicated graphics card combo in my laptop (ASUS N56VB), but these days I’m on the 5.10 kernel using the latest Nvidia 460 drivers, completely bypassing the integrated graphics. This seems to work, and since I’ve had some glitches and trouble with it, I don’t know if it’s related to the following problem.
I have a laptop, but I use it as a desktop. This means I have a USB hub connected to it, to which everything is connected. Mouse, keyboard, usb ethernet, usb sound card, wireless headset dongle, usb webcam… Simply because the laptop doesn’t have enough outputs, but also so that if I need to take the laptop anywhere, I can unplug the one usb cable and be done.
However, since yesterday’s (20-1-2021) update, my boot time has become considerably longer. The boot seems normal, but right before I see the sign in screen, I see a black screen with a mouse pointer. After a while, the sign in screen pops up, but I can only use my laptop’s keyboard to log in. Then during that process and after the desktop has appeared, my USB devices slowly come alive.
If I simply disconnect the USB hub, I don’t have to wait at the black screen, and the sign in screen becomes available immediately, as it has before. Nor have I experienced the USB hub being this slow before.
This is systemd-analyze blame without the usb hub
4.341s optimus-manager.service
1.446s systemd-random-seed.service
691ms tlp.service
557ms var-lib-snapd-snap-snapd-10707.mount
554ms var-lib-snapd-snap-runescape-43.mount
551ms var-lib-snapd-snap-core18-1944.mount
513ms apparmor.service
489ms var-lib-snapd-snap-core-10583.mount
481ms var-lib-snapd-snap-core-10577.mount
479ms lvm2-monitor.service
472ms var-lib-snapd-snap-snapd-10492.mount
469ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
469ms var-lib-snapd-snap-spotify-43.mount
465ms var-lib-snapd-snap-runescape-42.mount
423ms var-lib-snapd-snap-core18-1932.mount
417ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
364ms snapd.service
316ms dev-sda2.device
243ms dev-loop2.device
238ms cups.service
227ms dev-loop0.device
214ms upower.service
164ms polkit.service
160ms dev-loop1.device
158ms user@1000.service
143ms systemd-udevd.service
142ms dev-loop3.device
132ms systemd-tmpfiles-clean.service
113ms avahi-daemon.service
110ms boot-efi.mount
etc...
This is systemd-analyze blame with the usb hub connected
58.629s upower.service
4.361s optimus-manager.service
1.603s systemd-random-seed.service
686ms tlp.service
557ms var-lib-snapd-snap-runescape-42.mount
544ms var-lib-snapd-snap-spotify-43.mount
486ms lvm2-monitor.service
485ms apparmor.service
483ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
479ms var-lib-snapd-snap-snapd-10492.mount
472ms var-lib-snapd-snap-snapd-10707.mount
413ms var-lib-snapd-snap-runescape-43.mount
411ms var-lib-snapd-snap-core-10577.mount
404ms var-lib-snapd-snap-core18-1944.mount
402ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
385ms var-lib-snapd-snap-core-10583.mount
383ms var-lib-snapd-snap-core18-1932.mount
380ms snapd.service
379ms dev-sda2.device
265ms ldconfig.service
236ms cups.service
168ms user@1000.service
164ms dev-loop1.device
163ms polkit.service
152ms dev-loop0.device
141ms dev-loop4.device
124ms systemd-udevd.service
121ms dev-loop3.device
119ms dev-loop2.device
111ms avahi-daemon.service
etc...
upon searching I’ve seen others request systemd-analyze critical chain to resolve problems with upower.service. However, mine doesn’t seem to show anything relevant:
$ systemd-analyze critical-chain upower.service
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
upower.service +58.384s
└─basic.target @1.907s
└─sockets.target @1.907s
└─snapd.socket @1.906s +647us
└─sysinit.target @1.903s
└─systemd-backlight@backlight:intel_backlight.service @1.817s +86ms
└─system-systemd\x2dbacklight.slice @1.286s
└─system.slice @411ms
└─-.slice @411ms
The problem obviously lies in the upower service, but I can’t figure out what it is, or why it has become an issue yesterday.
Also, I don’t know why optimus-manager is running, as I assume I just ran the graphics card directly.
I would appreciate any pointers or help. Thanks in advance.
