I’m using Manjaro KDE in an Oracle Virtual box installed on Windows 10. I had no problems with the installation for almost 16 months. Now after an update, my boot screen is stuck on.
I have opened a terminal using Ctrl + Alt + F2 and tried to remove the video-nvidia, video-linux, nonfree 0300 [1], cleaned the cache and then force upgraded using pacman command [2].
I have upgraded the virtual box to 6.1 and installed the extension pack. I have upgraded the manjaro kernel from 5.15 to 5.19.
Since I run on virtual box as mentioned before as opposed to a normal boot, the solutions did not work for me. So I do not know what to do further. Please help.
Normally, this just works™.
Review your (virtual) hardware choices in VirtualBox.
The defaults should be fine.
The video driver is for a virtual card, after all - not a real one.
Perhaps your iso you use for booting is corrupted
or perhaps you need to change the (virtual) video driver to something else.
There are a few choices the names of which I can’t remember right now.
… and, come to think of it:
seems wrong
as the (also virtual) disks in VirtualBox
have names like /dev/vda1 - (not sda1)
Maybe.
Remove it (temporarily, for the time being) and find out.
But, in my opinion, this is not it.
… the share would simply fail, perhaps - but not prevent the machine to boot
… and it does boot - from what you said
just not to a graphical login or Desktop Environment
Since my shared folders are also removed, I’m sure I only have virtual disk as shown in snapshot below. I did not do any explicit configuration except that I chose to put my virtual disks in D drive to conserve some space in C drive.
