Boot problem (UEFI) after update, kernel problem, installation problem
New computer (UEFI boot). First update at Feb. 23 2021 successfull.
Today after updating Manjaro didn’t boot. I had to restore from rsync backup.
Kernel is 5.9.16-1-MANJARO
After restore I added kernel 5.4 and kernel 5.10 by manjaro-settings-manager. Both grub menu entries were not able to boot!
Does Manjaro handle UEFI boot correctly? (At first installation I made partitioning manually according to Hard disk Partitioning During Manjaro setup | Atanas Rusev, after boot there were no boot entries in UEFI BIOS. I had to reinstall and choose the automatic partitioning, which led to successful boot. But I had to repartition with gdisk and resize rootfs and add extra partitions manually)
CPU: Quad Core Intel Core i3-8100 (-MCP-) speed/min/max: 800/800/3600 MHz Kernel: 5.9.16-1-MANJARO x86_64 Up: 21m
Mem: 1479.7/7827.3 MiB (18.9%) Storage: 1.13 TiB (19.5% used) Procs: 166 Shell: Bash inxi: 3.3.01
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME H310M-A R2.0 v: Rev X.0x serial: 200467755703699 UEFI: American Megatrends
v: 1004 date: 09/06/2019
Graphics: Device-1: Intel 8th Gen Core Processor Gaussian Mixture Model driver: i915 v: kernel
Display: server: X.org 1.20.10 driver: loaded: intel unloaded: modesetting tty: 156x51
Message: Advanced graphics data unavailable in console for root.
I’m aware that Secure Boot for UEFI must be turned off. Have you tried this?
Secure Boot is off.
Kernel 5.9 is bootable.
Why is initramfs-5.10 smaller than initramfs-5.9. Are there things missing, e.g. modules?
$ ls -alt /boot/{5.9,5.10}
-rw-r–r-- 1 root root 22728600 2. Mär 21:40 /boot/initramfs-5.10-x86_64-fallback.img
-rw-r–r-- 1 root root 1634617 2. Mär 21:40 /boot/initramfs-5.10-x86_64.img
-rw-r–r-- 1 root root 8307840 2. Mär 21:40 /boot/vmlinuz-5.10-x86_64
-rw------- 1 root root 29143846 21. Feb 08:15 /boot/initramfs-5.9-x86_64-fallback.img
-rw------- 1 root root 7451824 21. Feb 08:15 /boot/initramfs-5.9-x86_64.img
-rw-r–r-- 1 root root 8141120 3. Jan 09:54 /boot/vmlinuz-5.9-x86_64
can you boot with USB iso manjaro ( live )
open a terminal and a browser on this topic
inxi -Fza
sudo manjaro-chroot -a
mhwd-kernel -li
ls /etc/mkinitcpio.d/*.preset
pacman-mirrors -c all
pacman -Sy
mhwd-kernel -i linux54
mhwd-kernel -i linux511
mhwd-kernel -r linux59
pacman -Syyu
exit ( end chroot )
then reboot and press ESC to see Grub appears
choose linux511 or 5.4
I made it. But I couldn’t boot with any of the menu entries. So had to restore the system again.
inxi output:
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de tz=Europe/Berlin misobasedir=manjaro
misolabel=MANJARO_KDE_2021 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME H310M-A R2.0 v: Rev X.0x serial: UEFI: American Megatrends
CPU: Info: Quad Core model: Intel Core i3-8100 bits: 64 type: MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: B (11) microcode: DE L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 28808
Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 8th Gen Core Processor Gaussian Mixture Model vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e91
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.3x10.6") s-diag: 433mm (17")
Monitor-1: DP1 res: 1280x1024 hz: 60 dpi: 86 size: 380x300mm (15.0x11.8") diag: 484mm (19.1")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
Drives: Local Storage: total: 1.59 TiB used: 110.7 MiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: rev: J4.3
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: rev: CC43
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer size: 7.49 GiB block size: physical: 512 B
logical: 512 B serial: rev: 7.01
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital model: WD5000BEVT-35A0RT0 size: 465.76 GiB
block size: physical: 512 B logical: 512 B serial: rev: 1.75
Partition: ID-1: / raw size: N/A size: 5.73 GiB used: 110.7 MiB (1.9%) fs: overlay source: ERR-102
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 194 Uptime: 1m wakeups: 0 Memory: 7.64 GiB used: 1.2 GiB (15.7%) Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1264 lib: 375 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
action.log (forgot to tee the output of “mhwd-kernel -i linux511”, but all the kernels and initramfs were installed again during “pacman -Syyu”, which ran without any error messages):
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
→ mount: [/mnt]
→ mount: [/mnt/boot/efi]
→ mount: [/mnt/home]
→ mount: [/mnt/reserve1]
e[32mCurrently running:e[0m 5.9.16-1-MANJARO (linux59)
::e[1;31mERRORe[1;m ftp error: error_perm(‘550 Failed to change directory.’) ‘ftp://mirrors.opensource.is/manjaro/
… Indonesia : Index of /manjaro/
e[1;32m1.164e[1;m
e[1;32m1.050e[1;m
… Italy : Index of /manjaro/
e[1;32m0.577e[1;m
… Italy : https://ba.mirror.garr.it/mirrors/manjaro/
e[1;32m0.698e[1;m
… Italy : https://ct.mirror.garr.it/mirrors/manjaro/
e[1;32m0.750e[1;m
… Japan : Index of /Linux/manjaro
… Netherlands : Index of /manjaro/
e[1;32m0.352e[1;m
e[1;32m0.258e[1;m
… Netherlands : https://manjaro.mirrors.lavatech.top/
::e[1;31mERRORe[1;m _ssl.c:1106: The handshake operation timed out ‘https://manjaro.mirrors.lavatech.top/
… Netherlands : http://manjaro.mirrors.lavatech.top/
::e[1;31mERRORe[1;m TIMEOUT ‘http://manjaro.mirrors.lavatech.top/
… Netherlands : FTP archive directory
e[1;32m0.406e[1;m
… Netherlands : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
e[1;32m0.620e[1;m
e[1;32m0.347e[1;m
… New_Zealand : http://manjaro.mirrors.theom.nz/
e[1;32m1.945e[1;m
… Norway : Index of /linux/manjaro/
e[1;32m0.385e[1;m
… Philippines : Rise Mirror
e[1;32m1.227e[1;m
… Philippines : ftp://mirror.rise.ph/manjaro/
… Poland : Index of /manjaro
e[1;32m0.689e[1;m
… Russia : Index of /manjaro/
e[1;32m0.937e[1;m
e[1;32m0.675e[1;m
… Singapore : Index of /mirror/manjaro/
e[1;32m1.725e[1;m
… South_Africa : Index of /mirrors/manjaro.org
e[1;32m1.146e[1;m
… South_Africa : http://manjaro.mirror.ac.za/
e[1;32m1.532e[1;m
… South_Korea : Index of /manjaro
e[1;32m2.232e[1;m
… Sweden : Index of /pub/manjaro/
e[1;32m0.423e[1;m
… Sweden : ftp://ftp.lysator.liu.se/pub/manjaro/
e[1;32m0.611e[1;m
… Sweden : Index of /manjaro/
e[1;32m0.499e[1;m
… Switzerland : Index of /manjaro/
e[1;32m0.306e[1;m
e[1;32m0.261e[1;m
… Ukraine : Index of /manjaro/
e[1;32m0.369e[1;m
… Ukraine : ftp://mirrors.colocall.net/manjaro/
::e[1;31mERRORe[1;m ftp error: error_perm(‘550 Failed to change directory.’) ‘ftp://mirrors.colocall.net/manjaro/
… United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/re
e[1;32m0.367e[1;m
… United_Kingdom : http://manjaro.mirrors.uk2.net/
e[1;32m0.288e[1;m
… United_Kingdom : https://uk.mirrors.fossho.st/manjaro/
e[1;32m0.424e[1;m
… United_Kingdom : http://uk.mirrors.fossho.st/manjaro/
e[1;32m0.260e[1;m
… United_States : https://repo.ialab.dsu.edu/manjaro/
e[1;32m1.061e[1;m
… United_States : http://repo.ialab.dsu.edu/manjaro/
e[1;32m0.960e[1;m
… United_States : http://distro.ibiblio.org/manjaro/
e[1;32m0.870e[1;m
… United_States : https://mirrors.ocf.berkeley.edu/manjaro/
e[1;32m1.685e[1;m
… United_States : https://mirror.math.princeton.edu/pub/manjaro/
e[1;32m0.899e[1;m
… United_States : https://mirror.clarkson.edu/manjaro/
e[1;32m0.978e[1;m
… United_States : https://mirror.dacentec.com/manjaro/
e[1;32m3.160e[1;m
… United_States : https://mirrors.gigenet.com/manjaro/
e[1;32m1.064e[1;m
… United_States : http://mirrors.gigenet.com/manjaro/
e[1;32m0.652e[1;m
… United_States : https://us.mirrors.fossho.st/manjaro/
e[1;32m1.299e[1;m
… United_States : http://us.mirrors.fossho.st/manjaro/
e[1;32m1.056e[1;m
… Uruguay : https://manjaro.repo.cure.edu.uy/
e[1;32m3.519e[1;m
… Uruguay : http://manjaro.repo.cure.edu.uy/
e[1;32m1.948e[1;m
::e[1;37mINFOe[1;m Writing mirror list
::Germany : https://mirror.23media.com/manjaro/stablee[1;m
::Germany : https://manjaro.moson.eu/stablee[1;m
::Germany : https://manjaro.moson.org/stablee[1;m
::Australia : https://manjaro.lucassymons.net/stablee[1;m
::Belgium : https://mirror.futureweb.be/manjaro/stablee[1;m
::Netherlands : https://mirror.easylee.nl/manjaro/stablee[1;m
::United_Kingdom : https://uk.mirrors.fossho.st/manjaro/stablee[1;m
::Switzerland : https://mirror.init7.net/manjaro/stablee[1;m
::United_Kingdom : http://manjaro.mirrors.uk2.net/stablee[1;m
::Germany : https://mirror.atysleaks.org/manjaro/stablee[1;m
::Germany : https://mirror.netcologne.de/manjaro/stablee[1;m
::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/stablee[1;m
::Netherlands : https://mirror.koddos.net/manjaro/stablee[1;m
::United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stae[1;m
::Denmark : https://www.uex.dk/public/manjaro/stablee[1;m
::Denmark : https://mirrors.dotsrc.org/manjaro/stablee[1;m
::Norway : http://mirror.terrahost.no/linux/manjaro/stablee[1;m
::Bulgaria : http://manjaro.telecoms.bg/stablee[1;m
::France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stablee[1;m
::Sweden : https://mirror.zetup.net/manjaro/stablee[1;m
::Italy : https://manjaro.mirror.garr.it/manjaro/stablee[1;m
::Germany : https://manjaro.re/stablee[1;m
::Sweden : https://ftp.lysator.liu.se/pub/manjaro/stablee[1;m
::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stablee[1;m
::United_States : https://mirrors.gigenet.com/manjaro/stablee[1;m
::Russia : https://mirror.truenetwork.ru/manjaro/stablee[1;m
::Poland : https://mirror.tuchola-dc.pl/manjaro/stablee[1;m
::Italy : https://ba.mirror.garr.it/mirrors/manjaro/stablee[1;m
::Italy : https://ct.mirror.garr.it/mirrors/manjaro/stablee[1;m
::Bulgaria : https://manjaro.ipacct.com/manjaro/stablee[1;m
::United_States : http://distro.ibiblio.org/manjaro/stablee[1;m
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stablee[1;m
::United_States : https://repo.ialab.dsu.edu/manjaro/stablee[1;m
::United_States : https://mirror.clarkson.edu/manjaro/stablee[1;m
::Indonesia : https://mirror.deace.id/manjaro/stablee[1;m
::United_States : https://us.mirrors.fossho.st/manjaro/stablee[1;m
::China : https://mirrors.aliyun.com/manjaro/stablee[1;m
::Canada : https://osmirror.org/manjaro/stablee[1;m
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stablee[1;m
::South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/stablee[1;m
::Bangladesh : http://mirror.xeonbd.com/manjaro/stablee[1;m
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stablee[1;m
::South_Africa : http://manjaro.mirror.ac.za/stablee[1;m
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stablee[1;m
::Austria : http://mirror.easyname.at/manjaro/stablee[1;m
::Singapore : https://download.nus.edu.sg/mirror/manjaro/stablee[1;m
::Chile : http://manjaro.dcc.uchile.cl/stablee[1;m
::New_Zealand : http://manjaro.mirrors.theom.nz/stablee[1;m
::Uruguay : https://manjaro.repo.cure.edu.uy/stablee[1;m
::Chile : https://mirror.ufro.cl/manjaro/stablee[1;m
::South_Korea : https://mirror.d-tl.com/manjaro/stablee[1;m
::Brazil : https://www.caco.ic.unicamp.br/manjaro/stablee[1;m
::Brazil : https://manjaro.c3sl.ufpr.br/stablee[1;m
::Philippines : http://mirror.rise.ph/manjaro/stablee[1;m
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stablee[1;m
::Chile : https://mirror1.cl.netactuate.com/manjaro/stablee[1;m
::United_States : https://mirror.dacentec.com/manjaro/stablee[1;m
::Hong_Kong : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stablee[1;m
::e[1;37mINFOe[1;m Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core is up to date
downloading extra.db…
downloading community.db…
multilib is up to date
downloading core.db…
downloading multilib.db…
The following packages are out of date, please update your system first: alsa-card-profiles aom appstream appstream-qt archlinux-appstream-data asciidoc attica baloo bluedevil bluez bluez-libs bluez-qt breeze breeze-gtk breeze-icons ca-certificates-mozilla cpupower dav1d device-mapper dosfstools e2fsprogs firefox firefox-i18n-de foomatic-db frameworkintegration fwupd gdbm glib2 glibc graphene gtk3 hdparm hwids iana-etc imagemagick intel-ucode jasper js78 kactivities kactivities-stats kactivitymanagerd karchive kauth kbd kbookmarks kcalendarcore kcmutils kcodecs kcompletion kconfig kconfigwidgets kcontacts kcoreaddons kcrash kdbusaddons kde-cli-tools kde-gtk-config kdeclarative kdecoration kded kdelibs4support kdeplasma-addons kdesu kdnssd kdoctools kemoticons kfilemetadata kgamma5 kglobalaccel kguiaddons kholidays khotkeys khtml ki18n kiconthemes kidletime kimageannotator kimageformats kinfocenter kinit kio kirigami2 kitemmodels kitemviews kjobwidgets kjs kmediaplayer kmenuedit knewstuff knotifications knotifyconfig kpackage kparts kpeople kpty kquickcharts krunner kscreen kscreenlocker kservice ksshaskpass ksysguard ktexteditor ktextwidgets kunitconversion kwallet kwallet-pam kwayland kwayland-integration kwayland-server kwidgetsaddons kwin kwindowsystem kwrited kxmlgui lib32-e2fsprogs lib32-glib2 lib32-glibc lib32-lcms2 lib32-libcap lib32-libelf lib32-libgcrypt lib32-libsndfile lib32-libva-mesa-driver lib32-llvm-libs lib32-lm_sensors lib32-mesa lib32-mesa-vdpau lib32-nss lib32-openssl lib32-pango lib32-util-linux lib32-vulkan-icd-loader lib32-vulkan-intel lib32-vulkan-radeon libakonadi libassuan libbytesize libcap libelf libgcrypt libgphoto2 libibus libinput libkscreen libksysguard libmm-glib libnm libqalculate libqmi libsamplerate libsndfile libupnp libva-mesa-driver linux-firmware llvm-libs lm_sensors lvm2 man-db mesa mesa-vdpau milou modemmanager modemmanager-qt mpd mujs nettle networkmanager networkmanager-qt npth nss openexr openssl oxygen oxygen-icons pamac-cli pamac-common pamac-flatpak-plugin pamac-gtk pamac-snap-plugin pango perl perl-http-message pipewire plasma-desktop plasma-framework plasma-integration plasma-nm plasma-pa plasma-workspace plasma-workspace-wallpapers polkit-kde-agent powerdevil prison procps-ng purpose python-cffi qpdf qqc2-desktop-style qt5-base qt5-tools sane sbc sddm-kcm snapd solid sonnet spectacle spirv-tools syntax-highlighting systemsettings taglib tar threadweaver thunderbird ttf-liberation util-linux util-linux-libs vte-common vte3 vulkan-icd-loader vulkan-intel vulkan-radeon webkit2gtk wine wine-mono wireless-regdb xdg-desktop-portal-kde xkeyboard-config youtube-dl
Do you want to continue anyway? [y/N] warning: linux54-5.4.100-1 is up to date – reinstalling
resolving dependencies…
Packages (1) linux54-5.4.100-1
Total Installed Size: 140.36 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] checking keyring…
checking package integrity…
loading package files…
checking for file conflicts…
checking available disk space…
:: Running pre-transaction hooks…
(1/1) Save Linux kernel modules
:: Processing package changes…
reinstalling linux54…
:: Running post-transaction hooks…
(1/5) Arming ConditionNeedsUpdate…
(2/5) Updating module dependencies…
(3/5) Updating linux initcpios…
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘default’
→ -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.100-1-MANJARO
→ Running build hook: [base]
→ Running build hook: [udev]
→ Running build hook: [autodetect]
→ Running build hook: [modconf]
→ Running build hook: [block]
→ Running build hook: [keyboard]
→ Running build hook: [keymap]
→ Running build hook: [resume]
→ Running build hook: [filesystems]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘fallback’
→ -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
(4/5) Updating Grub-Bootmenu
Generating grub configuration file …
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Adding boot menu entry for UEFI Firmware Settings …
done
(5/5) Restore Linux kernel modules
e[1;1me[1;32m==>e[1;0me[1;1m Warning:
→ Kernel has been updated. Modules of the current kernel
→ have been backed up so you can continue to use your
→ computer. However, the new kernel will only work
→ at next boot.
e[1;0m
e[1;0m
e[31mError:e[0m You can’t remove your current kernel.
Then I called “pacman -Syyu”, which ran without any error messages.
In fact I misinterpreted the UEFI BIOS entries and deleted the “keys” today, but it doesn’t change anything.
I tried mkinitcpio -P and even the booting entry failed.
Having made boot output visible there I saw this on the screen:
Failed to execute /init (error -2)
end Kernel panic - not syncing: no working init found. Try passing init= option to the kernel. See Linux Documentation …
mkinitcpio.d]# cat linux59.preset
mkinitcpio preset file for the ‘linux59’ package
ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-5.9-x86_64"
PRESETS=(‘default’ ‘fallback’)
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-5.9-x86_64.img"
#default_options=""
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-5.9-x86_64-fallback.img"
fallback_options="-S autodetect"
Please please wrap your all of your outputs with ``` before and after your output. Your outputs are all very hard to read atm.
Thanks! :smiley:
Sorry, sorry!
I have a new suspicion: An installation script for an external device (printer, card reader …), that was made for another linux distribution, destroyed some symbolic links in the /usr path and changed them to empty (or almost empty) directories. I will analyze it and inform you.
After I had restored the symlink “/usr/lib64 → lib” everything works. Update, new kernel and reboot ok.
THANK YOU FOR YOUR DEDICATION!
