Hello,
I have my Manjaro on a Externel USB Drive installed and
i have a 200MB Bootpartition (installation was MBR) and after i updated to 5.10 i have zero free space on it.
I have removed my old Kernels in Manjaro Settings Manager but there are still old Kernel fallback boot Backups inside this Bootpartition.
Im worried, that i will get some corrupted boot data or something like that, if i dont make enough space befor the next Kernel update will happend.
Is there a easy way to get rid of the unused files?
Or should i ignore it, because there will be auto delete functions in Manjaro?
Thanks in advance
If you removed the old kernels through Manjaro Settings then you should have more space. Please post the output of df -h and pacman -Q | grep linux
can you return
sudo mhwd-kernel -li
sudo ls /etc/mkinitcpio.d/*.preset
@stephane
Currently running: 5.10.15-1-MANJARO (linux510)
/etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux58.preset
/etc/mkinitcpio.d/linux57.preset /etc/mkinitcpio.d/linux59.preset
I also found yesterday another Topic, that is maybe related to mine where you gave the solution to it:
https://forum.manjaro.org/t/how-to-remove-a-ghost-kernel/
This means i clean it and update grub:
- sudo rm /boot/initramfs-5.8-x86_64-fallback.img
- sudo rm /boot/initramfs-5.8-x86_64.img
- sudo rm /boot/vmlinuz-5.8-x86_64
- sudo rm /etc/mkinitcpio.d/linux58.preset
- sudo pacman -Qs linux58-
- sudo rm /boot/initramfs-5.7-x86_64-fallback.img
- sudo rm /boot/initramfs-5.7-x86_64.img
- sudo rm /boot/vmlinuz-5.7-x86_64
- sudo rm /etc/mkinitcpio.d/linux57.preset
- sudo pacman -Qs linux57-
- sudo mkinitcpio -P
- sudo update-grub
Is this the right way to solve my problem?
@mbb
df -h
df: /run/user/1000/doc: Operation not permitted
Filesystem Size Used Avail Use% Mounted on
dev 7.8G 0 7.8G 0% /dev
run 7.8G 1.9M 7.8G 1% /run
/dev/sdc1 87G 18G 65G 22% /
tmpfs 7.8G 0 7.8G 0% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 7.8G 50M 7.8G 1% /tmp
/dev/sda1 211G 32G 180G 16% /media/os
/dev/sdc3 190M 189M 0 100% /boot
/dev/sdc4 326G 3.8G 306G 2% /home
/dev/sdb2 586G 269G 318G 46% /media/games
tmpfs 1.6G 112K 1.6G 1% /run/user/1000
archlinux-appstream-data 20210125-1
archlinux-keyring 20210110-1
lib32-util-linux 2.36.1-1
linux-api-headers 5.10.13-1
linux-firmware 20210208.r1828.b79d239-1
linux510 5.10.15-1
linux510-nvidia 460.39-9
linux59 5.9.16-1
linux59-nvidia 460.39-1
util-linux 2.36.1-4
util-linux-libs 2.36.1-4
I did this already but the Bootpartition doesnt care, the only unused (but installed) Kernel is 5.9… that i still want to have as backup… till im sure 5.10 working flawless for me.
Optional Forum Question:
Summary
btw. i have forgot how to format and paste code stuff, how was the command? I can’t remember… i just pasted my stuff with quote but this feels not right.
yes you will have to suppress 5.8 version
sudo mkinitcpio -P
sudo mhwd-kernel -r linux59
sudo mhwd-kernel -i linux511
sudo update-grub
as you have only /boot and 200Mo do not add 3rd kernels ,
if possible remove one for add one
-r is remove linux5.9 Kernel… i don’t want this yet.
-i is install linux 5.11 Kernel, but i want to stay on 5.10
I better skip this 2 commands, i hope timeshift backup cover /boot Partition if something fails
I will do this, thanks.
I wish i had installed a bigger Boot Partition… well its my first time using Linux (specially rolling release Linux).
in /boot/efi , i have only cfg grub file
df -Th
/dev/sdf1 vfat 197M 275K 197M 1% /boot/efi
in /boot i have initram & faillback ( /boot is inside here / , not in a partition so all size )
@team-manjaro
bug calamares for size in case of /boot partition , 200Mo is too small
3 versions linux54 linux510&511
du -h /boot
145M /boot
